Dodge Ram: Problems & Solutions
I have a 2004 Dodge Ram 1500 quad cab with a 4.7 engine in it. I recently put a 3 inch body lift on it and replaced the stock P245 tires with 315. Since I have done these changes my truck has loss power and shifts more then the usual. I was told my computer was programed for the original specs and this is what is creating my problems. Super-Chips does have a performance chip due out, towards the end of August and they claim it will correct these problems. I have also been told by upgrading my rear end gears to 410"s should also correct this problem but will cost more $$$. If I opt to change my stock gears to 410's will I also have to upgarde my rear axle ? Due you feel the Super chip will do the trick or in the long run changing my gearing will be the best fix ???? Would appreciate any input to help me get my turck running good.
But your's sounds different, and, no, there are no obvious causes that come to mind. It almost sounds like you lost PCI bus circuit, but I'm a little suspicious that your PCM might be bad. This is a good case for having a dealer (or AutoZone, etc.) pull the codes with a DRB3 scan tool.
Good luck,
Dusty
Even at that, nothing can make up for the loss of final drive ratio. A chip might provide you with some benefit. How much is just a guess, but I suspect it'll never make up completely for those tall tires.
A change of rear axle gear set will be the only complete way to compensate for the increased tire size. I'm not sure 410s will be enough, though.
Dusty
the engine cranks right up when you give it gas the it bogs down you can spray starter fuild in as it bog and it will speed up no pr0blems it does act like its backfiring a little it the intake
i done this so far
1 comper check 150 all good
2 replaced all inject
3 replaced the dist.
4 put the other flywheel sensor on
5 check time a100 time and no wire cross
6 fuel pressure test done
7 the exhaust was drop
you tell me please help this is a small thing i can not put my fingers on
jay
Replaced fuse, runs fine. Dealer searching for cause.
Any experience?
Steve
The oil pressure gague goes to 60 lbs. as soon as the key is turned on, before the engine is started, and stays there untill the engine is turned off. Noticed this about one month ago.
In the past few weeks the engine seens to be running out of fuel at about 2000 rpm. Changed the fuel filter for the first time and for about a week it was fine, now the trouble has come back. But it is interminttent. Some days it is fine, other days when first starting it will not go past 2000 rpm. After driving for 15 - 20 min. it seems fine, turn it off for an hour or so and when restarting it happens all over again. Took a 300 mile trip with no problems, the next day it happened again. Any ideas?
Bob
As far as the engine wanting to die, maybe the two problems are related if you have a oil pressure cut-off switch. I'm not very familiar with the diesel versions. Other than that, it might be a fuel pump issue. Check the fuel pump relay in the relay panel. I've heard of a couple of relay failures on RAMs.
Best regards,
Dusty
Dusty
Not to be confused with the Front Wheel and Rear Wheel Speed Sensors which are used to control the Automatic Braking System (ABS).
Dusty
I would first start with a good tune-up (spark plugs, distributor cap & rotor, and plug wires. There could be a ignition coil problem (reaching saturation), or a PCM failure, or a fuel pressure problem. On high mileage RAMs of that vintage I would suspect the catalytic converter.
Dusty
Any Ideas ?????????
Driving me nuts !! gas prices ya know
Dusty
Dusty
My 2001 started the same thing last weekend, plus no Power windows/locks/seat and the fasten seatbelt light stays on. I have been through every fuse I can find and nothing is bad? Just wondering if there was a fuse somewhere that I am missing before taking it to the Dealer...
Thanks.......................
John
dodgegirl
Robert
Other things to look at are the idle speed motor, vacuum leaks (rubber hoses and intake manifold gasket) and throttle position sensor, although the latter would be my last suspect. If it runs weak and it's high mileage it could be a slipped timing chain. After that, I'd check the fuel pressure and fuel injectors.
If it starts hard but runs fine, you can rule out the catalytic converter.
Best regards,
Dusty
1998 Ram 1500
3.9 liter V6
5 speed manual tranny
and
I replaced the rear speed sensor at the differential.
The dash brake lights went off, but the check engine light is still on.
Of course, the speedometer is not working.
I have looked and do not see a sender at the rear of the tranny.
What I thought might have been that sensor was the backup light switch.
Does anyone care to help?
carlsalt
:lemon: I bought a '99 1500 Quadcab 4x2 5.9L Sport off the lot in '99.
:lemon: At 18K miles, the transmission had to be replaced after it gave out on the freeway. This was covered under my 36K warranty.
:lemon: At 44K miles, I had to replace the engine bearings, which meant taking the engine out, and of course the car was now out of warranty. That set me back over $2500.
:lemon: As of 4 weeks ago (now at 55K miles), the engine started running rough, and my gas mileage has kept dropping down and now is at a sorry 6 MPG.
:lemon: About one week ago, my speedometer went out, and my Engine/ABS/Brake dash lights came on. I read on this site that replacing the rear differential sensor should fix this one.
So... can anyone advise me on whether and how I might get Dodge to make an exception of some sort and fix this truck before it, I don't know, spontaneously combusts next?
Your help is much appreciated,
LA Stetson
I had the same problem on my truck a month ago. Mine was the catalyc converter. I also replaced my o2 sensor. The smoke quit and I'm back to 14 to 15 mpg.
dpence2002
Is this a two or four-wheel drive?
Has this problem been with the vehicle since day-one?
Dusty
