SOA authorized my dealer to replace the timing belt. It's being done this Thursday. They're going to check the timing the old fashion way - using a timing light - just in case the computer is wrong. I'm not optimistic that this will fix the pinging, but I'll let everyone know what happens.
I have 23,000 miles on my 2000 legacy SC, and the dealer tells me I need to replace the brake pads on the front and back. Seems very low mileage for a brake change --- especially for the back. Could there be something else going on here?
Also, brake light stayed on. Dealer said it was due to a drop in the brake fluid level, which occurs when pads get worn down. Is this a good signal for the need to change brake pads? Thanks!
seems 23K is rather short, on my 3rd Legacy and IIRC front ones usually lasted 40-50K and back ones almost 70K+. obviously if you drive very aggressively your pad life goes way down. Subes have a wear indicator in the pad, it starts to make a nasty rattling noise when you wear down to it and you brake, then its really time to change or your rotors are history.
My dad and my uncle's 2nd gen legacy and outback generally go through brake pads in about 13-20K miles on both their cars. It's pretty well known that the pads wear extremely quickly on the 2nd gens. Not sure about the 3rd gens.
Serious is right - the professional drivers at the M-B PowerTrip event had to change tires every 50 miles. So it is possible to burn rubber rather quickly.
Joe: 23k seems short to me. I'm near 40k miles and my pads still have plenty of life left in them. Pads are cheap, though. I'd change them and bleed the brake lines before you damage the rotors.
I bet paisan is on to something - the 3rd gen Legacy brake pads have a higher metallic content, enough that people sometimes complain of their squeeking. Bet they'll last longer.
Grrrr! Another door ding. What the heck is wrong with people? They open their doors with full force with no regard to cars next to them?
Well this one is my third on my 2000 OB, an its a rather large, as far as door dings go. The other two are rather small, so I can live with them. The latest is on my front, driver-side door and is approx 2" in diameter. Every time I look at it, I cringe.
I am thinking of going to a local body shop to have it pushed and smoothed out as much as possible without any drilling, painting etc. They seem to have a system that works quite well. Has anyone heard of or tried such a system?
I've had that indicator come on a couple of times on my 96 due to wear in the pads. Usually you just pull the cap off, put it back on and it will go away.
Take a look at the brake pads yourself. You will be able to see how much is left.
I had a friend who had a door ding about the size of yours. It looks good, and cost about $100.00. Dents on the edge of the panel don't work well with Dentless repairs. Those in the center of the panel work OK. I tried to get a dent fixed around my wheel well and they wouldn't fix it because they couldn't get good results. $600.00 for the old fashioned repair.
Had it done on my wife's ci and it was great When she bought it it had a ton of door dings and rug rat dents on the hood. Dentpro took care of nearly all of them for less than $200 and you can tell where they were. Well worth it.
anyway, yes automatics generally do wear pads faster although the driver's braking style is still the #1 determiner of wear, and environment (hills, flat ground, gridlock, stop&go, open hwy) is #2.
it's not because of holding the car back at a stop though, that is minimal at best. it's because there is very little engine braking with an automatic.
I'm with Colin, driving style is the #1 reason for brake wear, if an automatic transmission is properly adjusted, the car really shouldn't creep at all when the car is stopped. As much as I don't enjoy driving them, modern auto trans. are better than that.
On another note, the rough idle that I posted about turned into a solid check engine light the day after I posted, It went into the dealer and turned out to be an O2 sensor which was covered under warranty. Lets hope the replacement lasts more than 15K miles.
so tough. You can make them to last longer but they are so noisey. If the noise is less, the pad has less metallic material and they wear sooner. It's a fine line.
I fail to understand the concern expressed here about Subaru brake pads. On my '94 Golf, the pads lasted 40,000 km (24k miles) at best (MT, gentle use, a lot of engine braking) the rotors not much longer, the wheels were constantly filthy and they were only fairly quiet. On my Forester the pads were judged to be 10-15% worn at 12,000 km (AT, little engine braking, mainly city driving) the wheels show virtually no dust, and I have yet to hear a sound from the brakes. The feel is slightly spongy, but the modulation is great.
I think my XT6 still has the original pads on it. I've had it for 30K and about 12-13 auto-xs plus numerous other spirited driving encounters w/o a problem. But my dad's '97 legacy goes through them like water, ever 13K-17K miles.
My 99 Forester is coming up to 60,000km and my 3 year / 60km warranty is about done. Should I get anything checked - there is no scheduled maintenance other than oil change. Someone suggested I get the car checked at a non Subaru dealer since the dealer may not want to find/do the warranty work because they don't get full payment or something?
Hi Guys! I have a brand new Subbie Outback 2001. What I have noticed is a whistling noise from my exhaust ( noise is coming from cat. converter towards the end of the car). Maybe it is because the car is new but you can hear it inside driving a car. It sounds like a high whistle or something ( not much but still annoying!) Has anyone had the same problem?
patti3m- whistle depends on your engine rpm: on idle speed it is constant, when you accelerate it is going higher etc. Very strange and like I said: VERY ANNOYING! (the worst thing is that you can hear it INSIDE the car)
I've heard of radio interference causing a whistle, but if yours is on the outside it could be an exhaust leak. In that case I'd have it checked right away because it's polluting unnecessarily.
Nothing in particular wrong - I had a valve cover gasket go a few months ago that was fixed. (I want them to check that everything is fine now). And the standard clutch chatter on my first 1 or 2 shifts from a stop each morning.
If it gives you piece of mind, you could have an outside mechanic do a basic inspection and service. I know Pep Boys does has a package for $300 where they basically do everything you'd do at a 60k mile service, minus an alignment.
I'm not sure if they have them up in Canada, though.
Can anything be done about it? I own a 2000 RS 5sp. Has anyone else experienced this? I'm unable to determine any particular patterns with it. Any help would be great.
Well, I thought about asking the dealer to take a look, but since that is the only very minor problem I'm having, I'm not sure I want them messing around with it. It is the stock exhaust system and if I had to say, it most frequently happens when I'm shifting from 2nd to 3rd.
Normal, I'd wager. You'll hear much more of it if you fit an aftermarket muffler, even moreso if you replace the stock midpipe and resonator at the same time.
Like I said, bummer. I guess I'll have to live with it. It actually doesn't happen all the time and as the car ages, it seems to happen less often. I'm still really happy with the RS, usually I get bored with cars and start looking to buy after owning it for as long as I've owned my RS. I did drive the WRX (twice), but was not that crazy about how it felt, anyway gotta go - bye.
I bought my 01 Forester S+ a couple of months ago and my dealer just called me to offer an extended warranty from Subaru for $995. It's a bumper-to bumper, 6 year/60,000 mile warranty (they called it "Gold Plus"). Does anyone have any advice on whether you think its worth it or whether that's a decent price for such a warranty. Personally, it seems a bit steep to extend the BTB for another three years and the power train just one more year beyond the standard warranty.
Anything below $1000 seems to be a good deal. I've seen quotes as high as $1200.
Keep in mind the powertrain is already covered for 5/60. If you drive a lot of miles, you're getting a longer bumper to bumper warranty, but nothing extra on the powertrain.
I'm planning on buying a similar warranty for my Trooper. Although the trooper already has a 3/50K BTB and 10/120K PT warranty. I believe the Extended BTB 10/120 is around $1200-$1300.
Don't forget the dealer needs to prove that your particular aftermarket item directly caused the failure. Other than the springs the important stuff is un-modified. The only thing that may hurt me is the 275-70-16s I plan to get to replace the 245-70-16s.
To be on the safe side, I'd check with your regular dealer to make sure they won't turn their backs on you when the time comes.
Remember, you've got higher wattage bulbs that could affect the electrical system (or at least a dealer could claim that), plus push bars and rear bumpers - things that affect payload.
Fyi - I remember a few old i-club posts about modified RS's going to Flemington. IIRC, they liked the mods and the techs were talking to the guy about them. I think he had an STi or P1 suspension on his RS. Dennis edit: Found it! Man, I love the i-club's search engine! It's a P1 suspension and Flemington installed it. Check out mav1c's comments. http://www.i-club.com/forums/showthread.php?threadid=42716&referrerid=767
All the tires look new, no wear to speak of. I felt this was ok and I believe they are with the specs.
Russ
7800 miles should be no problem (unless you do some SERIOUS driving ).
Ken
-mike
-juice
Luck11
-juice
bit
bit
Also, it's more common to use engine braking with a manual on down hills (though autos can too).
-juice
bit
bit
-Colin
John
Patti
Cheers,
-wdb
Seriously, mine look as-new. Even after 11k miles.
-juice
Ross
But my dad's Outback does squeek a bit first thing in the AM. I've heard it, though it goes away pretty much once you're out of the driveway.
-juice
-mike
Unless you don't have any warranty issues, then I don't see any problem with taking it to a qualified mecahnic.
Ken
Have you noticed anything wrong?
-juice
Patti
-juice
Greg
-juice
Thanks - Jim
-juice
stock exhaust or aftermarket? when do you hear the pop?
-Colin
-juice
if it's stock though we might be able to help Jim out.
-Colin
Jim
-Colin
Jim
-juice
Greg
-mike
-juice
-mike
-juice
Dennis
