Lincoln LS: Problems & Solutions
Maybe you had a problem with the accelerator linkage and now it's back to normal?
Here are links to good comparison charts. Note the number of miles driven by the survey respondents. The bigger the number the more accurate the results. Also, read the individual comments on the tire you're interested in as the same tire can be very different on different vehicles or in different sizes.
http://www.tirerack.com/tires/surveyresults/index.jsp
I checked the tirerack. Unfortunately, Pilot sport A/S does not have right tire for 215/60-16 size. I checked the survey, Bridgestone and Kunho have some tires on the top of the survey list.
Kumho ECSTA HP4, 716 HP4 and 716
Turanza LS with UNI-T AQII tires
Yokohama Avid S/T
BFGoodrich's Traction T/A family
Do your guys think I should go with Kumho or Yokohama? And I am confused why some performance tires have lower score in wet traction and lower price than Groundtouring tires? Does performance tire wear our faster than groundtouring one?
I have noticed quite frequently that there is a very stong burning smell coming from the front of the car. It almost smells like when something electrical shorts out and it overheats. I have taken the car to two seperate mechanics. The mechanics at the Lincoln dealer tell me that they could not find anything. I have taken it to another mechanic and the only thing that they can tell me is that they think it is the catalytic converter and the way that it is mixing the fuel. (???) I am an accountant, so I am not even going to pretend that I understand this. They have assured me that the car is very "tight" and is not leaking a drop of anything. I park the car in a garage and do not see any evidence of leakage. I just don't know if I buy the theory that it is the catalytic converter. Have any of you experienced this? HELP. Oh, and the car runs GREAT.
If you have even the least amount of mechanical aptitude I would suggest removing the Coil that sits on the spark plugs. I can email you a picture and some details on the removal process. It would be worth seeing if you have oil on them or your spark plugs.
Transient wafts of smoke have to be the hardest thing to extrapolate a diagnosis from. Good luck.
I am sure other members will gladly add to this thread.Good luck.
oil - common problem with the valve cover gaskets. This smell would be present most of the time and is easy to diagnose by visual inspection around the valve cover gaskets. Typically fills up the spark plug well with oil.
catalytic converter - I've had this smell since day one. It only occurs when the engine stays above 3000 rpms for more than a few seconds. WOT runs will do it as will leaving it in a lower gear with the SST and holding the rpms above 3000. It is very strong with the moonroof open but this smell goes away very quickly once the rpms drop - within a minute or so it's totally gone. Had 2 mechanics tell me it was normal. 3rd guy went through the entire engine and found no oil leaks at all, then went with me for a test drive. He thought it was the cat and said they had a similar issue with the explorers and mountaineers when they first came out. It's not supposed to be detrimental - mine's been doing that since Nov. 1999 with no ill effects.
I drove it for several miles and the shutter seemed to happen going up hills at lower RPM's. It also was very apparent in SST if you tried to start out in 3rd or give it extra throttle in 3rd.
They finally were able to have their mechanic fix it by changing each COP, one at a time until he found the culprit.
PS - The V6 LS running on 5 cylinders is not a fun experience!
I've had 3 COP's crap out on my V6 - thanks to the COP's getting moisture in them, after I power washed the engine. (I think the COP's are covered in the V8's.) It seems funny to me that Ford recommends washing the engine and does not show to cover the COP's, yet when put into contact with moisture - they fail.
I also have a brake lamp out. The manual tells how to change all lamps, but says that it has to go to the dealer for the brake lamp change. Sounds ridiculous to me. Please help.
The filter is located just in front of the windshield under the cowl grille on the passenger side of the vehicle.
Remove the cover by pressing in on the center of the plastic studs, then removing them. You'll see the filter after you remove the cover on that side of the cowl. Push the center pin of the plastic stud out si it sticks up, reinstall the cowl and push the stud into the hole, then push in the center pin to lock it.
Not sure about the brake lamp change - is it one of the taillights or the CHMSL?
I bought a set of new Kumho tires. After I inflate the tires to 35psi, they still look like under inflation comparing to my old continental set. Should I still follow LS manual and inflate the tires to 30 psi for these Kumho tires? My tire size is 215 60HR16. They are Kumho 714. What is your experience?
I've seen previous correspondence on this site about changing fluid. So is this good info??
BTW, they wanted to charge me $350 to change the fluid - prior to the phone call. Seems a bit high!!
Oh and by the way i just had to replace the water pump hose tonight, what a mess, woke up this morning and warmed up the car and came out to the wonderful odor of antifreeze and steam rolling out from the under the hood and underneath the car. I found on the internet that this is a common problem in the 01's. Cheap fix though, just went to autozone and got a radiator hose (not the exact, which is dealer only part) cost 16.00 with gallon of antifreeze! Hope someone can help me, don't care much for a moody expensive car!
THANKS A BUNCH!
Hebbie
The price sounds high. In addition, the dealership doesn't sould like they know what they are doing. You need a special machine to do a proper fluid change on these vehicles. The machine takes the old fluid out while replacing it with new fluid. It should change almost 100% of the fluid.
If you aren't having problems I'd wait. A dirty flush can actually introduce problems and would be worse than no flush.
As far as the water pump hose being bad, that's the first I've heard and I've been on this board and others for 5 years so I don't know where you got the idea that this is a common problem.
And the info on the water pump hose my husband found at Lincolnonline(i think it was that one) in the forum there, it was common because the hose isn't the best quality that they put on it and it cracks in the 90 degree curve, so that is where we got the info...
Don't go by one post that says it's a common problem unless others concur that they've also seen it a lot.
If it was really a common problem (like the rear window regulators or the seat heater failures) there would be numerous posts here and on both of those other sites with owners reporting that same problem.
Dealers say a lot of things that aren't necessarily true. Maybe their definition of 'common' is that they saw it one time before.
Its funny though. It honestly seemed to run a bit better. (Maybe I'm just optimistic.)
I had the first tranny flush at 30K.
You should have read up about 9 messages. I wrote about how my V6 ran bad after pressure washing the engine. The Coil-on-plug units that Ford used for the first couple of years can really crap out quick with moisture.
I think the V8's are safer since they have covers over them. The V6's are open to the air and moisture. The ones on the drive side are a since to replace and each one costs about $40 or so. The ones on the passenger side are a real bear. You'd have to tear off the intake manifold, etc.
Does the check engine light ever come on? If so, then you'd have a code that would tell you which particular cylinder was misfiring. Otherwise, you'd have to play a guessing game.
A neighbor with a V8 LS had a similar problem and their mechanic fixed by replacing one of the COP's and driving until he found the bad one.
Don't you think that a common problem like that would be reported by at least one other owner either on this forum or one of the other two? That's all I'm basing this on, and it's much more valid statistically than an offhand comment from one dealer.
Potential buyers reading this could be misled. I assure you it was not personal and I'm sorry if you were offended, but I do not think it's fair to label a problem as "common" without evidence to back it up.
