The ICE is run at times only to keep the catalyst fired off when it isn't really needed otherwise. Obviously it can/may still be used "otherwise" at the same time but the ECU probably mades the decision to fire up the ICE based on the need to keep the catalyst up to or near the optimum temperature.
Otherwise the vehicle would never pass emissions, certainly not at the ultra-low level.
If you have a look at the engine in question you will see why this is not possible with the RX400h. The exhaust stack comes off the manifold at the front side of the engine next radiator so the only "easy" placement of a converter is somewhat downstream of the engine compartment.
I also suspect that close coupling only works with smaller engines as a larger engine might result in overheating the catalyst if it were close coupled.
Apparently the "cat" needs to be in the range of 700F for optimum operation, given that the engine, coolant, and radiator temperatures never exceed ~180F you would need a heat pump cycle to raise those temperatures to the 700F required.
either way, I understand there may be a lot of reasons why this isn't feasible such as the space, cost, etc.... something like I'm saying may require big $$ to redesign a combustion engine- assuming the theory is even valid. I can see the cost benefit of using off-the-shelf parts such as the current 3.3 v6 with minor modifications.
Compared to nonhybrid, that may not be the case.
On a hybrid, if it fires up to heat the cat, it also recharges the battery at the same time. Energy is not completely wasted.
On a nonhybrid, the engine is always running even if the cat is already hot, so there is wasted enregy when the vehicle is stationary.
I don't know, a bunch of Honda CR-Vs caught fire because the oil filter was directly over the emissions system. The problem was a bad gasket, but having the hot catalytic converter right next to the exhaust manifold was a contributing factor, in my opinion. Of course, they could have put the oil filter somewhere else as well...
Maybe the exhaust valve and its seat but there again the coolant is flowing through the head very nearby.
There will be times that the batteries are fully charged and thye vehicle is motionless werein the ICE will be fired up ONLY to lit the catalyst. But yes, certainly, if the battery needs to be charged and/or the vehicle is in motion then firing up the ICE will serve multiple functions.
The patent I linked appeared to monitor the catalyst temperature in order to determine when the ICE was to be fired up.
Several posters have asked why the RX400h's ICE runs so much/soon/often, seemingly needlessly, and the point I'm trying to make is to explain why that might be. Not contrasting anything with/about non-hybrids.
just because the engine and coolant are at "steady state" doesn't mean they are at the same temperature. you can pour hot 100F water over an ice cube and cube will still be 32F while the water is still 99 or whatever. the temp change is a function of flow (among other things). just think if your water pump broke- the water "touching" the block would just boil.
I don't mean to get side tracked like this. I think the patent was interesting (at least as interesting as a patent can get). It just seemed strange that you would need external heating (prior art) or a sensor to switch on the ICE (patented claim) when there appears to be a good heat source available.
maybe I should file a patent :P
Also, don't confuse operating temp with light-off temp. Lightoff temp is the point at which self sustaining reactions begin, and those reactions quickly heat the catalyst to its operating, which is hotter than the exhaust. Light-off is about 300-500F (depending on age), and operating temperature can be up to red hot, but depends on how much fuel is in the exhaust.
When the hybrid runs it's engine to heat up the catalyst, it does so with a retarded spark timing to get the exhaust temp as high as possible with no load, and it almost always charges the battery at the same time, since the battery is almost never full. However, I have been sitting in my car with the engine running but nothing on the energy display. I have to assume that is heating only.
I bet this is a devil of a problem for a hybrid trying to get a SULEV emmissions rating on a city cycle with the engine starting and stoping all the time, and the catalyst cooling down.
Pardon me while I step outside and check to see if the Prius' catalyst is "close coupled".
So, I'm back, but feeling a bit stupid.
Visually I learned that the intake side of the Prius engine is in front which would allow for close coupling. As I stood there trying to figure out how to actually get under the car and look it came to me that I had a complete set of Toyota shop manuals for the Prius.
The Prius seems to have three catalyst containers and a muffler in the exhaust stream. The first catalyst is DEFINITELY close coupled, bolted right to the engine exhaust manifold. One oxygen sensor right at the exhaust manifold and one after the close coupled catalyst.
What is interesting is that the Prius has a vacuum driven servomotor that operates a bypass valve just downstream of the first catalytic converter, after the second oxygen sensor. With a "cold" engine start the bypass valve closes (partially??) the exhaust outlet from the first converter until the "HC absorber's" temperature is raised to the proper operating level.
Apparently it also closes the bypass valve during decel or idle even if the catalyst temperature is already high enough "in order to scavenge the HC that remains in the absorber material".
Wonder what the service life of a bypass valve operating within the exhaust system might be?
They can't use the rollers since it is an AWD.
They can't just use the tail pipe sniffer since there is no way to directly control the ICE RPM, or for that matter even control when the ICE is running.
Are we exempt or what?
If you do some research here and there on the internet you will find that the emissions stations will be able to connect directly into your engine's control ECU via your standard diagnostic plug and determine if all of the smog control devices and sensors have previously and still are operating within the correct parameters.
Basically CARB has stuck a deal with the auto industry wherein your emissions content is being continuously monitored as you drive. Unplugging the battery prior to driving up to the emissions station will result in a "hell I don't know, I'm brain dead" message from the ECU and then you will be required to go through a fairly complex drive cycle ( low speed, stop and go, highway cruise, etc, etc.) before returning for the emissions check.
BUT, as with any new technology there are likely to be bugs. Last thing I want is to have spent the extra money on this (rather than 330), and then get into my car in the airport parking garage after returning from a trip and find that my cool new car won't start. Any perspectives on the reliability of these vehicles? Having owned one for a month or so are you still happy w/ your decision?
Welcome any thoughts!
While the RX330 has some sort of engine hesitation problem that Toyota, seemingly, refuses to address.
You bought a 2003 Prius and only have 17k miles ?????
I do 30k-35k miles a year... so it pays off faster.
More than ride comfort, I thought the issue is that sacrificing the traction would sacrifice safety, especially given the weight and torque in this vehicle. I wouldn't want to try that mod.
Other than that I agree with you.
Anyway ... I found a good site to do metric conversions
link title
so you can compare Canadian apples to American ones. It can get a bit confusing when you grew up with and still think in mpg (Imp.), much of the discussion on these forums is in mpg (US), and your car is calibrated to L/100 km.
Since the denominator is inverted in the L/100 km gauges, seeing the bars go up or across in the mileage meters is a bad thing. At a standstill, mpg is zero whereas L/100 km is infinite. I hope this is accounted for in the average consumption calculations!
I have noticed when the ICE initially fires up the consumption goes through the roof. Perhaps this improves once the engine is broken in. I've had her for a week or so and like eman5 above me, I notice the car seems to sometimes pull to the side. Is this a foible of electric steering? My consumption is also about the same but based on earlier discussions I am expecting it to improve.
Apart from that, I am loving this car!
What is probablby happening is that the factroy settings are broard enough to allow for a pretty wide range of "feel". At least in my opinon... most people probably would never notice.
The thing to do is have the dealer check the CASTOR angle and verify that it is at the HIGH end of the range. This will give the steering a heavier feel and it will tend to want to center better rather than following all the little grooves and slopes in the roadway.
The other thing that will affect this is the TOE IN value. If it is on the LOW end of the tolerance you will tend to wander more. All cars will have some toe in to make it more stable, but you will pay the price in fuel econnomy and tire wear if it is excessive. I like to keep my CASTOR - HIGH and the TOW IN - LOW to balance stability and road feel against tire wear and fuel consumption.
"CONDITION: STEERING FEELS UNSTABLE WHILE DRIVING
CAUSE: WHEEL ALIGNMENT OUT OF SPEC
CORRECTION: COMPLETED 4 WHEEL ALIGNMENT"
I am happy to report that my 400h now tracks like a luxury SUV oughta. Much much much better!
The BMW is rated 20 mpg US city and 27 mpg US hwy. I decided to run them both on a comparison test in what worked out to be an 18 mile (29 km) loop through the city and took accumulated mileage readings at various check-points along the way. I drove both vehicles normally (no jackrabbit or granny starts), staying within 10% of the posted speed limit. It was early evening, no wind, dry roads, temperature 68 F (20 C), A/C was on in both cars (but obviously not taxed), traffic was light, and both cars had not been driven for at least three hours.
Checkpoint 1 was almost a mile (1.4 km), then a freeway drive at speeds of approximately 70 mph to downtown to Checkpoint 2 at 7.5 miles (12 km). Checkpoint 3 was a cross town drive to a residential area at 10.5 mi (16.8 km). Checkpoint 4 was a nice drive by the river to 13 mi. (20.7 km). Checkpoint 5 was to home again through typical city streets (lots of traffic lights, heavier traffic) and some freeway.
The results are telling I think (results are in US mpg (L/100 km))
(mi) BMW // 400h
#1 (1) 16.2 (14.5) // 14.4 (16.3)
#2 (8) 26.0 (9.0) // 24.0 (9.7)
#3 (11) 24.5 (9.6) // 25.8 (9.1)
#4 (13) 24.8 (9.5) // 28.7 (8.2)
#5 (18) 23.2 (10.1)// 29.0 (8.1)
Evidently, it is the short cold engine trips that accumulate to make for a poor showing in mileage about which some owners are complaining. This is the same for any car but seems to be worse in a hybrid. However, the engine in my 400h has only 250 miles (400 km) on it. I intend to run the same test in a month or so after the engine is well broken in to see if it matches up better with the BMW on the first legs of the test.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
The numbers illustrate nicely why I think Canada has the right idea when it shows mileage as a volume over distance measurement instead of the distance over volume the US uses. Most of us have a given distance to drive and it gives a more accurate picture of the effect of the number on our wallets.
For example: 14.4 to 25.8 mpg with an improvement of 10.4 mpg saves 7.2 liters of gas over 100 km of driving.
going from 25.8 mpg to 29 mpg, another 4.2 mpg improvement saves only 1.6 liters.
even if you went from 25.8 to 36.2 you would drop liters/100 km from 9.1 to 6.5 so you would save 2.6 liters. The mpg improvement looks large, but we get diminishing returns in savings per distance driven when it looks like the mpg number is soaring up.
That also helps explain why seemingly small factors like the AC running make a big difference to the mpg reading on the more efficient cars. Relatively small changes in gas consumption make bigger changes in the mpg rating for high mpg cars.
I wonder why the BMW does so much better on the cold engine than the hybrid.
Well, not quite.
Since the pressure (~1000PSI??) is always there and readily available it is ALWAYS used to help keep the front wheels pointed in the direction you designate with the stearing wheel with a very high degree of resolution and POWER.
In the RX400h using the same level of ELECTRIC power to keep the front wheels "on center" would result in a complete discharge of the hybrid batteries in very short order.
So if you're coming from a car using the "old way", to an RX400h, you will feel as if the front wheels are more easily drifting from "on center" simply because they are!
If you drive conservatively, you should get close to the EPA stated 31 mpg in pure city driving without the AC on & perhaps 29 with it on. I would say that with the AC on, you should be getting about 24-25 on the highway.
Poor steering shouldn't be settled for. The 400H being delivered with a poor alignment seems to be a wide-spread problem (from this and other boards) perhaps because of confusion on what the correct settings are.
On triple digit days (>99 degrees F), I see highway mileage drop about 2 mpg from 27 mpg to 25 mpg. I see that pretty repeatably. Here's how much fuel I'm using for an hour of driving:
no AC 27 mpg 2.4 gal/hour
with AC 25 mpg 2.6 gal/hour
So cooling is costing me about 0.19 gal/hour (I'm pulling numbers off the spread sheet and not putting in all the digits which is why the number is .19 rather than .2)
City driving should require about the same amount of energy to cool the car per hour but the average speed of the car is much lower. The EPA city profile average speed is 20 mph. At 31 mpg, an hour of 20 mph average speed driving uses 0.65 gallons of gas. If AC still adds 0.19 to the gass consumption, an hour of 20 mph driving with AC on requires 0.84 gallons of gas. 20 miles/ 0.84 gallons = ~24 mpg.
The AC load that pushes highway mileage from 27 mpg to 25 mpg could push city mileage from 31 mpg to 24 mpg.
My city mileage is more suburban than city so it is a good bit higher speed so the mpg penalty I get isn't quite as bad as that. On the recent triple digit days we are having I'm seeing 25 mpg city and 25 mpg highway.
The current heavy AC load also really pushes up the short trip penalty too. Get in a hot car and the AC has to blast for the first 5 to 10 minutes.
Here is another thought. Two of the three RH owners reporting very low mileage 19-22 MPG, are in very hot 100 degree plus areas of TX and CA desert. Maybe the electric motor generators are more stressed at the higher temperatures. That was the reason for not using the RX400h offroad. It would overheat the rear drive electric motor. Heat is not good for any electrical/electronic device. Maybe Toyota has used air conditioning to cool the battery and other critical electronic modules. That would keep the AC running even more. I noticed on the GMC mild hybrid that when I am at a stop light the engine shuts down for the whole time. If it is very warm and the AC is high the engine starts up before I take my foot off the brake. Presumably to keep the batteries at a proper level.
In a HOT climate where A/C is used constantly it's also likely that the engine coolant pump motor is drawing a heavier load...
Haven't I read that there is a C-best option for the Prius wherein the A/C reheat/remix method is "short-circuited" in favor of just refrigerant cooling?
If that option is available for the RX400h the owners might consider having it enabled. That would likely result in less runtime for the engine and certainly less use of the engine coolant circulation pump.
Maybe its exhaust outlet could even be used to keep the catalyst "fired off".
When I first start out, the AC is running nearly continuously as one would expect with a very hot interior needing to be cooled. Even with that, the engine still shuts down the whole time when I am at a stop light or sign. The difference I notice is for the first few minutes of driving any application of the accelerator turns on the ICE - even just puttering through the parking lot. After the first few minutes when the car has gotten to a reasonable passenger compartment temperature, the AC settles down and the motor versus engine usage becomes similar to what happens in cooler weather.
I don't see any sign that the AC is being used beyond a normal amount. It is just hot weather and the AC takes some energy to run.
