It's a driver, just keep it running.
If the light came on and you kept driving, your engine would be dead by now or making noises like the hammers of hell, so in a way you've sort of tested it yourself (at great risk).
I'd say it's just a bad sensor or loose sensor wire (the light lights when the sensor grounds out) but without the car in front of me I can't say more about it.
Next time you own a car and the red light comes on, stop the car immediately or come to idle speed open the hood and listen. If there is actually zero oil pressure, your engine will start to clatter, especially as you raise the idle speed or take off again.
Have the mechanic screw in a gauge. Check the oil and if the filter is old, change it.
And check what the DAWG says: Is this a pressure gauge or merely an oil level gauge?
Mike
I'd certainly read up carefully on how to do this and take all safety precaution concerning spring compression. This job can bite you if you are trying some jury-rig; otherwise, yes, pretty straightforward.
You'll probably need an alignment check afterwards.
And block the car up real good before you start work, since you'll have to tug and pull.
Mike
how the heck do I get the driveshaft back onto the tranny? (or differential, im not 100% sure) im new to this and im sure there is some trick.
last night i went to reattach the driveshaft and the last two bolts wouldnt go in because the first four put the shaft off kilter with its fitting.
it was kind of like opening a round tin of cookies or something. when you pull up on one side of the lid, it causes the other side to bind because its not in line with the tin itself.
JensAroo
Is this significantly better than any of the other more common name products?
Is this stuff sold at the local auto stores? I'll have to check out next time I'm there.
Thank you for your time.
I doubt if you did any damage to the rack and pinion itself.
Keep an eye on it for leaks for a while, just in case.
Thanks for your input.
One would have to review all of the wire connections that were done with the installation.
will a static timing work or should I strobe it with a tach?
If it were me, I would pull the radio and check everything. If I were someone else who was not mechanically or electrically inclined, I would take it back to where the install was done and tell them I assume they did something wrong and to please look into it.
An 009 can be a PITA with a VW---you have to drive aggressively and not let the revs drop, or you'll be lugging the engine---bad idea on an air cooled engine.
it has just started this ticking sound
i have a manule that says to clean all the HLA's so i did that but the sound got even worse
Can it be a bent rocker arm
anything can help
My son has a 1984 Ford Bronco and the brakes went out. Found out it was the Brake Power Booster went out so we changed it. We bleed the brake lines but now the passenger side rear nut will not screw back on to tighten the lines. I mean I have cleaned out any and all debris and tried to get that screw to go on every way I can think of but it just will not tighten up. It just turns and turns. Nothing looks striped but the nut just will not grab.
Does anyone have any idea of a way we can try to get the darm nut to tighten up?
My son is only 16 and does not have the cash to take the car to the shop for a nut.
Thanks a ton!!
If you took the bleeding screw out, then you'll just need to get it back in. If you can't and somehow it striped or broke, then you'll need to replace the wheel brake cylinder itself (I'm assuming your rears are drum brakes, as opposed to rotors). The bleeding screw is in the backside of the brake cylinder. If your rear brakes are rotors, then you'd need to replace the caliper.
Neither one of these would be terribly expensive if you are doing it yourself. The drums would be a little more technically difficult to change, only do one wheel at a time so you can see how the other side is put together. They would be mirror images.
Thanks a ton.
Sindy
Sometimes on older vehicles the bleeding screw is quite frozen stuck, and when you go to crack it open it actually breaks off. The screw end stays in the cylinder, the round top comes off in the socket. If that is what happened, then you need to replace the cylinder.
anything can help
edit: this guy rebuilt his head on a '91 626. and he says its got HLAs.
there is also smoke coming out by the exsate manafold.
it not as loud as it was befor.
is it burning oil
ticking sound
smoke from exhaust manifold
Then YOU have an exhaust gasket leak or a crack in the exhaust manifold or a leak in the connector pipe (down pipe) joint, where it connects to the exhaust header.
This is something I have never done, so is it complicated to replace the calipers on the rear?
You guys have been a great help. Thanks!!
Sindy
- You'll end up taking everything apart, so I would replace the rear brake shoes while you have everyting apart, if you can afford it.
- I would take a picture of how everyting is correctly positioned, before you take anything apart. Only work on one side at a time, so you can look at the other side (if need be). Don't mix the parts from right to left. You'll find them mirror images of each other.
- Get the rear jacked up, and block underneath the axle and/or frame on each side. You'll need both rear wheels off at the same time.
- Take the drums off, they would normally pull right off. You may find a small metal spring clip on one of the wheel lugs (helping to hold on the drum when you change tires). If you are not able to pull them off by wiggling back and forth, you may have to un-adjust the star wheel which is inside the drum. You can usually get to it with a screwdriver from the backside, via a slot on the bottom of the backside. You should do an internet search of get a service manual to see how drum brakes are typically put together. One side starwheel is right hand threads, the other left hand threads.
- When the drum is off, you will notice that one shoe typically has a longer pad than the other. Make sure you note which once is longer, so when you put the new ones on you get them on correctly.
- You'll notice typically two spring like devices holding each shoe on. You can get these off by putting a pair of vise grips on the end of it, push it in and turn it 90 degrees, then it will slide off the mounting pin.
- Make note of the starwheel, as to whether the starwheel is on the front side or the backside. The purpose of the starwheel, is to keep the brakeshoes in adjustment as they wear. As the shoes wear over the years, the movement of the shoes in and out via regular braking and usually going in reverse, will move a lever which adjusts the starwheel, pushing the bottom of the shoes further and futher apart.
- Notice any other pieces which are typical in drum brakes, which are used for auto-adjusting the brakes.
- The shoes, the starwheel, and any autoadjusting pieces should be off now.
- To take the hydralic wheel cylinder off now, you first disconnect the brake line from the wheel cylinder. Take care when disconnecting the brake line, as it may be frozen or slightly rusted. When you disconnect the brake line it will begin to drip brake fluid. I usually put it in the tip of a rubber glove and put a rubber band securely around it so keep it from dripping all over the place.
- Once the brake line is disconnected, you'll probably find two bolts in the back side of the cylinder. Remove these bolts and the wheel cylinder will come off. Make note of the position of the wheel cylinder. Sometimes they'll fit in rightside up or upside down. You need to make sure the bleed screw is on the top, so that when you bleed it the air will come out.
- Put together in reverse manner. Be careful not to get grease or brake fluid on the shoes. If you do get some surface dirt on the brake shoe, I use a little sandpaper to get it off.
- Inspect the drum, to make sure there aren't any grooves ground in it. You may have or want to take the drums to an autoparts store (PepBoys, AutoZone, etc), and they can true up the drum with a metal lathe.
- The new brake shoes will be thicker than the old, so you will need to adjust IN the starwheel. Otherwise, you won't be able to get the drum back on. I usually adjust the starwheel by hand, so that the drum is just able to get back on.
Shoes come in a set to do both sides, I personally would replace both wheel cylinders. The rubber boots go bad, the pistons leak over many years. You don't want to have to open these back up for years.
Once both sides are done, and drums are both back on, you'll need to bleed both brakes. When bleeding, use previous instructions.
These are generic instructions, since I don't have any manuals for your vehicle. You may find some slight differences with your specific vehicle. For instance, you may find the wheel cylinder held on with one bolt as opposed to two. You may have some extra autoadjustment gear.
Good Luck..
