Ford 2001 Heavy Duty F-250
Wally world has oil filters for $10. I'm still getting them from International for $13.50. Plan on ordering fuel filters from DIS at $13.16(case of 5)ea. To order go to www.dieselpage.com or look though ford-diesel.com. Just got back from Klamath Falls and got 17.5 mpg(empty). Plan on going to eastern Washington in a few weeks so will find out how my PSD does over the pass.
Did you change shocks, and if so how do you like the new ones?
I Negotiated a f250 4x4 sc for invoice - half holdback (3%, not bluoval). Dealer's paperwork charge was 298. So dealer made about $828 dollars. Decent deal? or should they stick a fork in me?
Either way I already took delivery. The truck lights look B-Bad... f250 psd 4x4 sc lb silver
Dan
You can't pull that particular trailer with your truck because you'll exceed the GVWR..
Your not supposed to exceed any of the numbers. (GVWR, or GCVWR, or axle ratings)..
You can pull the 13k trailer, as long as it didn't put more than 1800 on the bed.. As you said, many 5th wheels will put 25% on the pin, but some might not..
As you see, with the F250, the payload is your limiting factor.. This is one reason many folks opt for the F350..(and sometimes F350 with DRW's).
In the Commercial vehicle brochure for the SuperDuty, the payload is not listed per 'engine' and tranny type, and we know the PSD is alot heavier than the 5.4L..
My truck (F250 SC 4x2 5.4L 5sp 4.10LS) is only weighing in around 5800lbs with me in it, and full of fuel.. So I'm much closer to the available 3k payload than you..
The dealer has another 'trailering guide' that has even more weights/dimensions listed..
This is a bit of a jungle, as I did have a 350 with its 1100 lbs more GVWR (and about that much more payload). Still had E rated tires, tho, which would be less suitable than with the 250.
For my truck, they only list the payload at 3200 or something like that (not 3500).. So they were pretty close for my particular truck.. There no way for the manufacture to be 'exactly' on as the weight of hitches, fuel, tire choice, accessories (if you have brush guards, winches, cab steps etc) also count against gvwr.
I didn't understand the comment about e-rated tires being less suitable on the F350 than the F250? The same e-rated tires are available on both vehicles (standard on F350, option on F250), each tire is rated at 3500lbs at 70psi, so that would put them within reach of of the 7k you mentioned earlier.
frankno:
I agree, pulling many 5th wheels will exceed the 8800 gvwr.. Its highly unlikely you'd have a 200lb topper when pulling a 5th wheel.
So in your case, you could pull a 5th wheel that has a pin weight of less than 1200 lbs.. (1894lbs - 5 passengers).
I never saw it advertised that an F250 would pull all 5th wheels.. I suspect this is one reason you see mostly F350's pulling the big 5th's..
The difference in price between the F250 and F350 is only 500 or 600 dollars, so there's really no excuse for not buying the truck that fits one's needs..
I did buy a truck that would fit my needs, I decided not to ever pull a fifth wheel as I wanted the storage space in the back of my truck more than the bed space of a fifth wheel. I wanted the ride of a 3/4 ton vs a 1 ton and with a Hensley hitch for the trailer, I have as much stability as one can get for the TT. I probably won't ever go over a 28' to 30' trailer so I won't ever exceed the GCWR or GVWR. My point is that between the truck manufacturers and the trailer factories one gets burned at least once in this trailer and truck buying experience. Maybe there should be more regulations on the publishing and more truth in advertising. Have a great day.
Sorry, I didn't mean to imply that you didn't buy the right truck for your needs.. I should have chosen better words..
jcmdie: in the truck brochure, Ford has the payload rating for truck chassis (F250, F350, F350DRW), each cab type (RC,SC,CC), each wheel base (SB,LB), and 4x4/4x2 combination..
The only significant thing they didn't take into account was engine choice, tranny choice and optional equipment. My guess is like you suggest that they use the 5.4L, 5sp, no options.. obviously the bigger kicker here is the PSD is quite a bit heavier than the 5.4L.
I'm not sure what documentation Chevy and Dodge produce, so I'm not sure if they're like Ford or not in their documentation and advertising claims.
This is just in the 2000 Ford sales brochure, I would suspect the trailering guide has even more info..
I'd like to see the F250 SC that can haul the advertised 3575 lb payload, since this implies a truck that has a base curb weight (something the literature does not provide) of 5225 lbs. I'll bet the thing doesn't have a box on it, or at the very least no rear bumper, no spare, smallest fuel tank, etc. Maybe even no steering wheel. It would be one thing if the payload misleads you by a couple hundred pounds. In this case, it misleads by a factor of 100% comparing 1800 lbs to almost 3600 lbs. advertised. It is doubly misleading to advertise, on top, a 20,000 GCWR when the only way you could pull a gooseneck of 13,700 lbs (which, by the way, implies a truck weighing 6300 - wonder where that number came from??) would be to [non-permissible content removed]-load the thing to lighten up the hitch. Kind of ironic that GCWR goes up with horsepower, yet the vehicle's ability to haul the advertised trailer weight does DOWN with the increased horsepower. The PSD, for example, seems to add about 600 lbs. If the gooseneck multiplier (at 25% on the ball) penalizes towing capacity by a factor of 4 for every pound you add to the towing vehicle, the PSD should subtract 2400 lbs from the GCWR towing capacity just for its own weight. I guess they trust us all to load our trailers so the [non-permissible content removed]-end is just heavy enough.
Also, listed right here on edmunds, 01 F250 XLT SC 5.4L 5sp 4.10ls:
Maximum Payload: 2950 lbs. (not the 3500 you claimed that Ford said)
So I was not misled at all. I read the brochure that applied to the particular truck I was looking at.
I'm not sure what advertising your looking at. The 2000 Commercial vehicle brochure (which has my truck), the stated number is less than the 3500 you claim..
I would bet there are advertisements that claim that Ford F-Series can haul 3500 lbs, and tow 13k. And properply equipped from the factory, they can. Not EVERY truck will be capabable of this..
Saying that you can pull a goose neck of 13.5k does not imply the truck weighs 6.5k, they probably did try to account for some pin weight..
Again, you are exactly right that the on the F250, the payload limitation will affect the ability to handle the bigger trailers, and is impacted even more with the added weight of the diesel..
This is not unusual or even mis-leading. This trend is the same with every 3/4 ton truck on the market (f250, ram 2500, silverado 2500).
Your last statement is right on,
" I guess they trust us all to load our trailers so the [non-permissible content removed]-end is just heavy enough."
I like the fact that they provide their customers with enough documentation to be able to determine whether their trailer application will fit the truck your buying. Each towing situation is unique and needs to be left up to the customer.
If you do alot of hwy driving, 75 mph +,, and occational towing #5000 lbs or less, maybe you should consider the 3:73 rear end. We'll talk at you later.
I guess part of my gripe is too much information, and not enough explanation. A couple of examples (like the conversation we've been having) showing how these various ratings interact would not hurt anything. In fact, since most people seem to be po'd that the thing won't do what they want once they get it, a little more info would probably move more people UPmarket. Considering the price range we're in already, the couple of hundred to take you to the 350 is nothing. I'll admit I'm aggravated because I left a 5.4L 350 for a PSD 250 because I wanted the diesel economy, and based on the literature it looked like I was gaining significant trailering capacity; in fact there was little net gain unless I become a fanatic about trailer loading. I'm already contributing to the college education of the local farm scale operator's kids:-) Better informed purchasing would make for a LOT more happy customers, and would contribute to safer trailering overall since people won't be pushing their rigs, either knowingly or (more likely) unknowingly. The F250 axle rating at 6830 shown in the 1999 literature is a good example, given that the trucks are equipped with tires capable of handling only 6084. Since you sound like you might know someone at Ford, you might pass on (or maybe they will read it here anyway), the last thing Ford needs right now is more lawsuits alleging tire failures from overloads. A little more forthrightness and examples in the literature wouldn't hurt. The average dealer salesperson, or even dealer management person doesn't have the expertise to address these issues. Ford has to do it.
I guess it would be nice if Ford put a sticker on each truck saying how much it can haul, and tow. But I can see cases that even if they did this, the owner would still need to do basically the same homework to insure that the trailer is balanced right, and take into account hitch weights etc..
Figuring all of that out is a service, and I think the dealerships should provide it..
btw, my truck tires (stock from factory LT265) say max load of 3415 at 80psi. So reaching 6800 on the axle's isn't limited by the tires..
This topic has been a little slow anyway. It nice to see some civil exchange of opinions and ideas.
Thats my opinion.
I'm looking at old truck 1989 - 1992 but so for I have not found one with an extended cab for my kids.
What goes into the thought process of deciding F150 of F250?
I actually prefered the ride of the Superduty compared to the F150. It is a bit more firm when empty, but not jolting.. Take one for a testdrive.
You also get a bit more interior space in addition to the exterior hauling/towing capacity..
Having said that, when I ordered our 01' F250, PSD, SC, 4X4, 141.8, auto, etc. my dealer said it would weigh about 6500 lbs fuel full. I had to rely on their truthfulness and knowledge to know if I needed the 250 or 350. What else can one do? Regardless, we tow a 32' 5th wheel with a hitch weight of about 2000lbs, a dry weight of 9900, and a GVWR of 13,000. These weights are within the max payload rating (3135) and max loaded trailer weight (13,200) of the 250, barely, and unless the truck weighs more then the dealer said, or I put a lot of "stuff" in the truck and trailer, I should be OK. I am sure there is a fudge factor in all this of at least 10 percent and as long as the tires and axle ratings add up to much more then the 8800 lbs GVWR it should be OK. Like bess said, my "E" rated 265's are at 3415 @ 80 psi and the axles are rear-6084 @ 70 psi, and front 4400 @ 55 psi. Since it seems the single limiting factor is the spring rating of 8800, I am not worried. Happy towing to all.
I've had it now for about a month (got it in six weeks! The dealer said it would be eight) and could not be happier.
I'm inclinded to stick with the stock 5.4L V8, but I've read that the only difference between it and its larger V10 brother is maybe 1-2 MPG and that it's actually better to get the V10 simply because this is a whole lot of truck.
I'd sure appreciate any advice.
Cheers,
-Charlie
edmunds@linuxninja.org
Cheers,
-Charlie
edmunds @ linuxninja.org
PS: Thanks for the engine info
PS---If anyone can tell me where to find the new options/changes on the Ford Super Duty F250 for the year 2002 please email me if possible---thanks! Tom at TSSawyer@aol.com
Although the SuperDuty is 'alot of truck', in some configurations the SuperDuty weighs about as much as an Expedition SUV which runs just find with the 5.4L.
More opinions of mine:
5.4L:
- if your towing needs are light (by superduty standards)
- if your towing needs are infrequent
- works really well with the 5sp manual. (and I hear a 6sp tranny will be available in 2002).
(I'm not a fan of automatic trannys anyway. The 4r100 seems to take up more of the 5.4L power, causing it to shift more often than I prefered).
- 4.10 ratio is a preference of mine. mileage is excellent (better than an Expedition), power is excellent.. (Think of an F150 with the 4.6L).
- is not 'underpowered' as some folks might claim.
V10:
- need to tow heavy
- need to tow often
- works well with 5sp and auto tranny..
- 3.73 works for most folks, unless you really need extra towing capacity or you plan to install larger aftermarket tires)
- is an awsome engine with more power than the 5.4L (duh), but at a price of 2 mpg's city and 1mpg highway (best case)
Again, the above is just my opinion..
00 F250 xlt SC 4x2 5.4L 5sp 4.10LS overall mpg for life of the truck 15.5
What's the difference between the 4.10 and the 3.73 axle ratios? And what benefit, if any, does the limited slip axle provide?
Thanks again for all your help.
Cheers,
-Charlie
3.73= for every 3.73 revolutions of the driveshaft, the tires go 1.
so, when you go to a higher rear diff ratio (numerically) the engine will be at a higher RPM for a given speed, than a lower ratio..
Rpm at 65mph: (stock tires)
3.73 = 1900 rpms
4.10 = 2100 rpms
The higher ratios (numerically) give more of a 'punch' and increase towing capacity, but if you run too high of a ratio it can use more fuel and affect mpg..
The lower ratios can increase mpg's (if you do alot of highway driving), but if your towing or doing alot of city driving, the tranny may have to shift down a little more often if the rpm's drop too low.. (thus negating any mpg advantage in the city or while towing).
Limited slip: (this is an oversimplified description):
With a normal diff (open diff), basically only as much torque is applied to the ground as the wheel with the least resistance will support.. Ok, in english, only one rear wheel spins, the one thats on the slipperier surface).
With the limited slip diff, even the wheel that on the more solid surface gets some extra torque. It doesn't get as much as if the diff was fully locked up (like if it was a solid axle), but more than an open diff.
So, if one wheel is in mud, and the other on dry pavement: with the open-diff, your stuck.
With the limited slip diff, you might get out..
To summarize my rambling:
4x2 without LS = 1 wheel drive
4x2 with LS = 2 wheel drive (both rears)
4x4 without LS = 2 wheel drive (1 front, 1 rear)
4x4 with LS = 3 wheel drive (1 front, both rears)
I hope this helps
Cheers,
-Charlie
Here's a link for the changes to Superduties for 2002.
http://www.sunrisefordfleet.com/guides/
