people with the 4cyl had been complaining of hesitation, and the V6, a transmission shift flare.
it's possible your vehicle is affected by a long-standing problem going back years with DBW implementation on some lexus and toyota cars. search for hesitation here on edmunds and you'll find other forums marked read-only.
with the 2007 specifically, some people with the 4cyclinder experience delayed accelerator response when merging on the highway, changing lanes, slowing to make a left-hand turn.
i suggest you start collecting some evidence to support your assertion there is a problem with your vehicle.
one thing you could do, you could find a parking lot where it is empty using a video camera (with the time displayed) and you videotape the speedometer (so they can see your speed) wheel position (so someone knows you are making a turn) and tachometer (RPM indicator), while verbally explaining what you are doing and what you are experiencing.
bring it to the dealership and show it to them, and have them ride with you while you duplicate the problem. tell them it is unacceptable and you expect an immediate solution.
does the vehicle have stability control? it could be an issue. you could have a fuel pump problem or a loose hose or sensor. you could have a loose wire / ignition problem. whose to know. so it might not be DBW (drive by wire) or stability control.
but first things first, get some objective evidence and go into the dealership prepared. doing so will show them it is unacceptable and you've got it documented right out of the gate. from prior posters, expect to be told everything is operating properly.
if you feel your safety is compromised and you want out of a vehicle that hesitates because you are concerned about your safety, the safety of your passengers, other people on the road in your immediate vicinity, tell them.
there might have been a TSB issued to reflash the ECM/TCM to improve the situation somewhat.
you'd have to scan this forum and
2007 Toyota Camry Transmission Questions
to check on this.
good luck to you.
Thanks! The fix looks promising.
We may have to wait until next winter to find out how effective it is.
Gary
A sharp turn, a fast one or accelerating turn especially, would imply the possibility of understearing or even slight actual understearing in which case the VSC might activate. You may even have roll-over protection in the system firmware or if one of the front tires slipped even ever so slight then TC would activate and result in your symptoms.
In a tight, sharp turn the outside front wheel is already turning faster than the inside wheel and the firmware tolerance for wheelspin/slip may result in the ECU "thinking" that means the outside wheel is slipping and therefore activate TC.
VSC, or even TC, activation might result in so slight a brake application as to be un-noticeable but the simultaneous engine dethrottling, and the rsulting recovery delay, would be VERY noticeable.
Lose traction of/on the driven wheels of a RWD vehicle due to engine DRIVING torque and you still have the front wheels to maintain directional control with, On a FWD vehicle....
*** Traction Control firmware on a modern day RWD vehicle will apply moderate braking to the (DRIVEN) slipping wheel(s) but delay engine dethrottling to give the driver time to react.
On a FWD the firmware differs in that it will simultaneously dethrottle the engine and apply moderate braking to BOTH front wheels. TC sensitivity to wheelspin/slip and reaction time is much quicker and faster than the driver could possibly be in doing EXACTLY what needs to be done, THROTTLE LIFT!
Loss of traction, slight, or in some cases even impending, on/of the driven wheels on a FWD vehicle is so much more hazardous than on that of a RWD vehicle that the firmware design varies quite radically and in numerous ways/methods in order to most quickly return directional control to the driver.
I think if it's repeatible, they can try it over and over again with the camera making a history of the experiment and what is indicated.
I presume neither VSC nor TC will be completely "silent". There must be some tone or indication it is activating. If not, I would think that would be an issue.
1) has anyone plugged an Apple ipod into their Camry?
2) When you hit the mode button on the the stearing wheel does AUX show up as one of the functions?
3) Is there a chance the dealer updated my DVD Nav system without me knowing loosing the AUX function?
4) Should I reset the system to factory specs loosing all inputted info on the Navi system?
Please help if you know anything about this. I know that this is a small problem but I would like to fix this myself if I can rather than wasting time at the dealership. Thank you!
My original complaint stated that the ride height on the front left side of the car is half an inch higher than the right.Also,the car feels a little bouncy and unstable and seems to wobble and wander at times.
A week ago before I turned in the car I measured the ride height myself and so did a local mechanic.The measurements were taken from the ground to the fender.To make sure the results were accurate the tire pressures were set equal on all four sides.Also the car sittting on a flat even road with no load on it.Nothing was in the car and no one was sitting in it.
The mechanic and I also measured it from the center cap of the wheel to the fender and still there is a half an inch difference on the left side.
Can anyone tell me if what the dealer said is true? Is it normal for the ride height on the front left side of the car to be a little higher than the right side?
I also measured the ride height on two other camry's like mine and the dimensions were the same on both side.I also went to several auto specialists that deal with allighment and mechanical stuff and they all cofirmed the results on my car and said that its not normal.The ride height should be normal on both sides considering that the car is new and only has 700 miles.
Can anyone help please? I pretty sure if you guys measure the ride height like I did you will find that its equal on both sides in the front.Tommorow I have to go in and pick up the car.
I'm assuming the problems I'm having with my car have alot to do with that difference in ride height.I don't think one side being higher than the other is normal.
Also if it helps my car is a 2007 camry le-v6.I suppose the dimensions would be the same on a four cylinder.
On my other car; 2007 Toyota Camry Se V6 with navigation, this vehicle does not lean at all. It sits level, but this is not the exact vehicle that you own. This might be the same issue depending on model, accessories etc that causes the leaning. I hope this helps you. You can also call Toyota Corporate and see if they can explain this issue.
I don't have any optional accesories on my car so that doesn't explain for the difference in ride height.And I don't think this issue is normal.
I called toyota corporate a while back and they were not really helpful.The only thing I could do they said is to open an arbitration case.I will probably do that if the dealer insists its normal.I am also considering of reporting this issue to the better buisness burea.
Does anybody have any advice and suggestions?
In the past few days, I've been busy measuring ride heights of cars. What I want to say again is that wheel alignment or even body alignment (as may be needed after a collision) is NOT done by taking measurements from the wheels to the bodywork. So either those non-Toyota mechanics are blowing smoke or their eyes are seeing $$$ signs when you approach, because they know that the Toyota dealer is going to say it's normal.
Below are the differences in centimeters (1 in = 2.54 cm) measured between the left and right sides on different cars. All except my car were inside my employer's building on a level concrete surface. My car was in the parking lot, with just a slight uphill incline, in the same spot on two different days. I used the same tape measure, always measuring up from the floor/ground through the wheel center to the top of the wheel arch on the fender. I didn't inflate the employer's cars to the proper tire pressure -- just made sure there was no significant difference between left and right. (There wasn't, except for the Volvo, where the two left tires were 1 psi higher than the two right tires.)
A plus sign means the ride height was greater on the left (driver's) side. A minus sign means the ride height was greater on the right (passenger) side.
4/17:
My '04 Camry, 43,720 miles. Front: +0.7, rear: -0.6
2007 Volvo S80, 47 miles. Front: -0.6, rear: -0.9
2007 Saab 9-3 convert., 58 miles. Front: -0.4, rear: -0.4
2007 Subaru Legacy, 173 miles. Front: -0.9, rear: -0.5
4/18: (after I bounced the front and rear of both cars up and down)
My '04 Camry, 43,754 miles. Front: +0.1, rear: -1.3
2007 Saab, moved inside building. Front: -0.9, rear: -0.3
So as you can see, these measurements vary, were never exactly zero, and were sometimes 0.9 cm different (0.4 inches), or in the case of my car 1.3 cm different (0.5 in).
So...there's either nothing wrong with the car, or there may still be a defect in one of the tires. OTOH, Michelin is very good in making tires without defects, but no one is perfect. Still, you must drive another '07 Camry V6 again on the same route as yours to see if there really is a difference.
BTW, what happened to the engine noise?
Since the the mechanic found the ride height was not normal he assumed that the wheel allignment was perhaps out of place or one of the tires was defective.If ride height is adjusted or perhaps in my case if its not normal then the wheel allignment must be checked.That is what I meant in my earlier posts about the wheel allignment issue.
Also,I still disagree with you on the assumption that you think my car is normal.The ride height on a new car should be within proper specifications.So basically that half an inch difference should not be there.
I confirmed that theory by visiting the sevice center at another toyota dealer.The technician there said the half an inch difference on the 07' camry is unacceptable.Most likely there's a problem somewhere.I will probably take the car there to the other dealer this time.Perhaps tomorrow when I get my car back from my local dealer.
I'm also convinced that the ride height difference has alot to do with the problems I'm experiencing.They are consistent with that analysis.I'm feeling the left side of the car bounce often in situations when it should stay stable.
For example,I drove the car slowly on a smooth road and noticed that the left side of the car bounced several times while the right side of the car stayed stable.The car felt very unstable and wobbly.
I drove my friends v6 camry on the same road at the same speed and saw that neither side of the car bounced.The ride felt a bit more firm.His car is same 07' camry like mine.
As far as the engine noise,I think that issue is normal on my car.I heard the same thing on the dealers v6 camry.Before I was listening for it on my friends v6 camry and didn't here it,but when I drove his car again at a different time I heard it.It simply the fuel injectors firing they explained.
but seriously - there could have been frame damage, or there could be a problem with the strut tower, strut or spring on that side of the vehicle, right?
in another forum we are discussing tires being "out of round". if the tire on that side is bouncing, it should be evidenced by "cupping". that would suggest suspension issues unless i'm mistaken.
about your ride height on your camry,it may be
possible that when your camry was tied down in transportation they may have damaged one of the front struts.this may cause the bouncing effect
you are complaining about.I worked at a Honda dealership and had the same problem with a
2000 Accord,just a thought
jimmyz1
NHTSA Campaign I D Number: 06V096000
Recall date: 04/03/2006
Source of info:
http://www.motortrend.com/cars/2007/toyota/camry/recalls/index.html
Also an owner of SE 5-sp AT 2007 Camry reported today on another website that the front and the knee airbags failed to deploy in a high speed head on collision and Toyota insisted the airbags not deploying was the owner's fault.
I wonder why Toyota did not inform the customers about the recall by mail and TV broadcast instead of waiting for the customers to find out the recall on the internet if they are "lucky" enough or find out the hard way when the air bags fail to deploy in a serious accident then refused to take responsibilty inspite of the recall.
Do you have confirmation from Toyota that all those 133 vehicles have been identified and that the owners have been notified directly by mail or phone? If not,why are you so sure about it?
If all owners of the 133 Camry affected have been notified as you believe, can you explain why customer JD on the other website has not been notified when his 2007 Camry also has problems with the airbags?
Of course I agree with you that a vast majority of of 2007 Camry are not affected but unless all those 133 vehicles have been identified and the owners notified directly,I don't think it is a big deal out of "nothing" no matter how small the probability is.
I can say as God as my witness that most of these problems being reported on this site are also problems I am experiencing with my 2007 camry. I agree with the earlier post that it's the worst built car I've ever owned.
I didn't complain about those problems because I cared more about safety issues such as acceleration hesitation which is reported by some to have been corrected Toyota.
I don't know how bad the airbag failure problem in the 2007 Camry is. I found out the airbag failure recall a few months ago after I had traded in the Camry and I thought the problem must have been taken care of by Toyota. Then I read the first report of airbag failure in 2007 Camry today on another website but was unable to post a message to the owner JD about the recall no matter how hard I tried.
A serious problem like airbag failure can be an even bigger worry to a car owner who knows about the recall which does not mention the VIN number because there is no way the car owner can know for sure if his or her car is affected unless informed by the manufacturer or until the airbags fail to deploy in a serious collision.
If Toyota has nothing to hide in this matter, why not give the 2007 Camry owners a report on this website to tell them details about the recall and what they have done, if any, to ensure that those Camrys affected have all been fixed?
It's easy to find on the NHTSA website the number of vehicles affected by a recall and also the build dates. Consumer Reports publishes the same information for significant recalls.
With regard to the alleged nondeployment in a collision, just because one person claims the airbag should have deployed does not make it so. Read your owner's manual about under what conditions the airbags should deploy; most (all?) manufacturers have a statement that the amount of vehicle damage is NOT a reliable indicator as to whether a particular airbag should or should not have deployed.
I haven't checked the link, but presumably the complainant is alive and kicking, so that's one indicator that the airbag maybe didn't need to deploy?
Phyllis of Heflin LA (04/04/07)
Was in an accident on Feb. 25, 2007. I was headed North and a car headed South turned in front of me on a rural highway. I hit her head on and then hit a deep ditch. I have a 2005 Toyota Camry and the damage totaled 10,000 but the insurance company decided to fix it. The airbags never deployed even though the front of my car looked like I hit a tree. We were traveling about 40 mph. I'm pregnant and had my other two children in the car with me. Just muscle strains and bruising. Has anyone ever been sucessful against Toyota??? I'm really scared of my car and what might happen next time.
First of all, it wasn't a "head on" collision in the usual sense of the word, but more like front of the Camry into the corner or side of the other car, which turned left from the opposing lane in front of her Camry. Then the Camry went into a ditch.
As I said in my prior post, the dollar amount of damage isn't indicative, and if you look at the photo of the damaged car here (the silver 2005 Camry in the upper right), you can see that it didn't take much of a frontal or side hit. Looked like it hit a tree? Yeah, maybe at the equivalent of 10 mph! Contrast with these photos of the IIHS frontal offset test 2002 Camry (structurally the same as the 2005 Camry) after a 40 mph hit into a deformable barrier.
Interesting too that the photo caption says the driver was "severely injured," when in her own words she said she sustained "just muscle strains and bruising."
This is how rumors and misinformation spread...
And no, I'm not a Toyota employee, but I do know something about car crashes, both in the lab and in the real world.
I didn't think that silver car stated it belonged Phyllis of Heflin LA
I owned a 2006 Camry XLE... (beautiful car!!) And a couple of weeks ago had a sports car hit me broadside going 35 mph into the passenger side where I was sitting and all I can say is thank God for those side airbags and crumple zones. I think the car only moved inches and we're all ok, jumped out and started to dance around to prove we weren't hurt. Totaled out the car but it's so much more worth being physically ok.
But it definitely would concern me if there was a recall and those owners were unaware of it. Safety is the MOST important.
I was referring to the Motortrend site about 2007 Camry:
Glad to see that the normal procedure is to contact the car owners affected by first class mail but has Toyota followed that normal procedure to inform the owners of the 133 Camrys and has all 133 owners been successfully contacted?
If Toyota affirms that it has successfully contacted all the owners of all 133 Camrys affected, I would agree with you that 2007 Camry owners should not have undue worry about that recall. If Toyota can not affirm that, then owners of Camrys in the early production should contact Toyota to see if they are affected.
I do agree with you that alleged nondeployment does not necessarily mean that the airbag must be defective. But any responsible car manufacturer should look into every case seriously to see if there is any room for improvement even if the airbags appeared to react as intended by the manufacturer.
Regarding the consumer affairs site, the silver Camry seems to match the one described by Phyllis (although not explicitly stated), and the car's either a 2005 or '06 based on the grille design.
This doesn't guarantee all owners are ultimately notified, and it is a good idea if you buy a used car to check with the manufacturer to be sure that your particular car has had all of its recall work completed.
Still, the bottom line is no one can be forced to bring their car in -- there's no penalty for the owner, although it's not too smart to ignore such recalls when serious safety issues are involved.
I'm having the same problem
Is there a TSB for shaky passenger seat?
or anyone succeed of getting this problem fixed
Please post
I just had my third oil and filter change which was done at 6,900 miles by the selling Toyota dealer. I paid for this service with the coupon from the "Toyota Prepaid Maintenance Program." Had I not had two oil and filter changes done earlier, this service would have occured at 5,000 miles.
For the period of time since the purchase of this vehcle, I have averaged an oil and filter change every 2,300 miles, which was well within my goal of every 2,500 miles.
IMPORTANT NOTE TO REMEMBER: -----Toyota engines have a track record of being "sludge producing units," if the oil and filters are not changed often. Only time will tell if this new V6 engine will have the same issue. Let's hope not! This is why I cut the recommended oil change interval of 5,000 miles in half, (2,500 miles).
FUEL:
I use 87 octane fuel in the Camry, (both name brand and off-brand gasoline). I find no difference in the performance of the vehicle between the different fuels. I try to purchase fuel from stations that pumps large quantities of fuel. I look for the cheapest fuel in the area, when it comes time to make a purchase. "Fuel quality" is a subject for another posting!
I do NOT have any of the problems that are listed on these boards for this vehicle, and I have been VERY observant with regards to the "operating characteristics of this vehicle"!
Best regards! ----- Dwayne :shades:
Both the 4-cylinder and V6 engines in the current Camry are new/different from what was used pre-'02 for the 4-cyl. and pre-'07 for the V6.
Sludge seemed to affect those who amassed low mileage over an extended interval AND stretched the oil change interval beyond the 7500 miles (for normal service) recommended at the time, at least based on the heated debates we had on Edmunds back then.
I had a '97 Camry with the potentially affected 4-cylinder engine -- no sludge problems in the 7 years and 111K miles I owned it, but I did change the oil at least every 5K miles (about 3+ times per year).
IMHO, you are wasting time and money changing your oil so often when you are racking up the miles so quickly.
Regarding gas, I generally avoid the no-name or "1-hit wonder" stations, but I trust the regional chains that pump a lot of the stuff, such as Sheetz in my area. But if the national brand is the same price, I'll go with that.
