Sound system its pretty good - can't see why you would change - unless you go high high end and are an audiophile.
Warning - this is a plow horse compared to the Morano - don't go hot into the corners as you would have .. you wont like the plow understeer - and the "on demand" all wheel drive can get very annoying with its momentary delay in tight snow covered corners. Other than those comments I also like mine - and it can tow 3500 lbs of trailer to boot.
But it is no Audi or Morano
IMHO
http://www.invisiblecarbras.com/
Oh and if you decide to install the invisible bra - heed the warning about no breezes while working tith the front especially - you REALLY need a closed garage
Flying stones are also produced by trucks and cars at high speed travelling in both directions to you. These stones can chip not only your car paint but also lacerate your wind screen. No car paint can sustain this punishment regardless of car make.
Protective film kits are also a good help (e.g. AUT07yxx01) and hood protector (e.g. MR936650), etc. You may need to change them every 3-4 years for new ones. However after this time you may be thinking in trade your car for a new one.
You may take your VW, BMW, Subaru, etc to Alaska and you will see that there is not paint strong enough to protect your car’s paint.
this vehicle has design problems, especially the bottom part of the door. i don't think it's the paint at all.you can repaint it with other paint types but if you don't protect it with a long mudflap, it will get stripped.
No excuse for the lousy support from Mitsubishi Canada i.m.o.
Mud flaps / mud guards - english term vs. N.A. term i believe - and they are available at Canadian Mitsu dealers you can find reference to them here:
http://www.mitsubishi-motors.ca/en/vehicles/outlander/2012/accessories/
As to buying another one? Probably not for me - they are simply to noisy on the highway compared to competitors vehicles. But mine has been trouble free. The only annoyance has been the suspension noises caused by the rubber bushings - and getting them to make the noises when at the dealer!!
Apparently a common problem on the east coast salty roads but as I own one of only 4 '07 Outlanders sold at the then new dealership - they do not have the volume of returns some eastern dealers record. And of course Mitsu Canada will once again not acknowledge this as a problem.
Perhaps you didn't read my post completely. 2 cars and 4 full winters later (the Mits didn't roll off the showroom floor until January), and no chips on either car. Same roads, same flying stones, gravel, sand, and magnesium chloride. 3 years more on one car, and 3 months more on the other. No sand blast effect, no chips. Windshields need to be replaced almost annually here in Colorado, but not paint. There is clearly a significant difference in the application and/or quality of the paint (also waterbased). Either there is more paint, more clear coat, or both are higher quality, or all of the above. The Mits would have had no paint remaining by now. There isn't a mud flap big enough. It would have had to cover the entire car. Pity is correct. As another poster said, use your common sense. Based on my direct experience that would be not buying a Mits. Sorry!
The Mitsubishi undoubtedly will have more paint spots if I do not take care at the very beginning to protect the paint of my car. For many owners the numbers of scars are synonymous of battles performed or gained against the aggressive terrain.
Not any comparable (BMW, Audi, etc) cars as far as the number of differentials (which are responsibly for your safety) equal the Outlander GT performance. So if I care about my safety a few more paint chips are worth having.
If you have relatives in Australia you may request front mudflaps: These mudflaps, as I said, help to protect your Outlander’s body work from paint chips caused from stones and other obstacles that are flung out from beneath the tires.
There's not a lot of difference between the cars, honestly. Performance is virtually identical, other than MPGs suffering right now. More than likely, that's due to the break-in period.
Things I like:
-Fog lights
-Auto headlights
-Color info center
-Auto-sensing wipers
-Navigation with traffic
-Soft feel application on doors and dash, although they should have done the whole dash
-Reverse camera
-More aggressive styling
Things I miss:
-The "secret" compartment in the middle of the dash.
-The 5 spoke 18" wheels. Much sportier than the 7 spoke
-The 110 volt outlet in the arm rest
Things I still dislike:
-The Goodyear tires. Same exact ones I got 28k miles out of the first time. I'll start saving up for the Michelins now.
Things that need work:
-The arm rest on the driver's door needs thicker material. At 4 years, the 2008 developed a hole from my elbow.
The current 2012 GT is perforamance oriented, the S-AWC is outstanding. (I drove all of the contenders out there but the Outlander GT AWD makes me smile when tossing it around) I also like the flip down tailgate, a nice place to stage and change my shoes for biking and hiking.
While the design is a few years old I liked that they upgraded the intrument panel with color LCD, such a simple thing upped the class.
I would think there won't be much discount getting the 2013 model (at least not that $1000 incentive going on now), plus you have to deal with potential first year issues.
The black looks great on the face lift. I think it's the best color for it.. but I chose a white one with beige because I'm sensitive to heat inside the cabin.
When I had a 95 Mitsubishi Eclipse, and the paint is thick on it, you can actually see the depth and luster of the clear coat. I almost don't notice any chips on the front bumper. Things are not the same now
Mazda also make pretty looking cars but their paint is just as thin and received similar complaints.
Search on some forums and you will find people with bug splatter easily chipped the paint job on the bumper.
I also own a 2011 Volvo, a slightly more expensive brand, received a couple of bird droppings on it for a few hours the clearcoat permanently blemished and etched after cleaning it off.
Solvent based paints didn't hold up to bird droppings any better than modern clear coats do, and for every complaint about someone's car paint you can find today, you can find similar ones going back to the early days of the net. Before the mid-90s research isn't as easy as clicking around with your mouse, but I don't know anyone who wants to go back to cans of Japan Black.
