:sick: the engine codes are p1698- no buss msg received from pcm
p1693 MLT FLT in companion module
p1694 no engine buss message received
HELP PLEASE THANK YOU
kcram - Pickups/Wagons Host
THANK YOU
Don't know much about programing or chipping, interested to hear what you find in that area but only to increase milage.
good luck,
If you're going through batteries that quickly, you need to check for a drain somewhere, or make sure you have sufficient amp ratings (never use less than 750 CCA).
Can be picked up at local auto parts store for around 10 bucks, 2 water clamps and one splice and your in shape.
01ram01
If anyone has some additional info that might direct me in a dif direction I certainly would appreciate it, I don't think that I want just jury rig a wire from the left light if I can correct the problem correctly.
kcram - Pickups/Wagons/Vans+Minivans Host
