The "mechanical" gauges have a metal tube running from the engine block to the gauge pack in the dash. No electrics.
Could it be you are running a 6 volt gauge on 12V or vice-versa? I'm running out of ideas.
I will call Walcks where I bought the gauge from. Maybe he sent me a 6v instead of a 12v gauge. Heck it is worth a try.
Thanks for you ideas.
I would be happy to sell this for $4000 but am uncertain if I am asking too much. If you read this, send a response to let me know if you think I am asking too much for the project. You can see more information at this web site I put together to show our work.
http://homepage.mac.com/salsafc/1954FordF100/Truck.html
Wmains
has any one done it ? I have heard that C4 with a 5 bolt bell housing will work ???
I have a 350 chevy engine (not sure the year, maybe 70 -73) with a 670 Holley carb and the secondaries will not open. they work fine if I manually pull on the linkage with hardly any resistance at all. I also looked at and tested all the vacuums and vacuum diaphragms and everything was fine. No tears in the diaphragm or anything. any ideas on why it wont automatically open through the vacuum?
The off set sockets and bulbs were usually double duty bulbs that provided tail and brake lights whereas the in line bulbs provided one function.
Sometimes if the installation were mixed up, you could get one function or the other.
Use steel wool in the sockets and if you discover two metal [non-permissible content removed], use a two [non-permissible content removed] bulb that is off set, one above the other on the other side of the bulb base.
I have to wonder if there is any connection to both reverse lights coming back to life. I have never touched those bulbs. The electrics of the car otherwise are very sound...I can let it sit for weeks and it will start up easily at the first turn of the key.
Possibly, depends on the angle of the contacts of the bulb to the socket.
Usually the backup lights have one purpose, one wire, one bulb [non-permissible content removed] and one socket contact. Perhaps the chuckholes you've encountered jostled the wires to be effective to the BU lights.
Trace the wiring from the lights to the fuse box. While at the FB, check out the fuses & their holders for any contamination buildup.
Maybe the Beirut-quality roads around here moved the bulb. The old car is much nicer on a rough road than my modern car though.
I think that part was used for many years, so I should be able to pick up another from a recycler for a few bucks and plug it in. If that doesn't do the trick...I'm just going to ignore it and call it a quirk. The car runs so well otherwise, and has been pretty good to me, I don't want to press my luck by going nuts over something small.
If you mean putting an engine from another make in there, well you can put just about anything into any car if you are willing to deal with all the modifications.
I think repairing your engine, or finding a used block and rebuilding that, would be far cheaper than fitting an engine and transmission from another type of car.
Now if your plan is to make a street rod out of it, then the sky's the limit. You can get a Chevy crate engine, TH400 transmission, fancy floor shifter and all the rest that goes with it, but you're talking some serious money to build a street rod out of a car that few people build street rods out of.
If the car is a 4D sedan, no harm in modifying it or installing another engine, but if it's a 2D HT or convertible, I wouldn't personally want to see anything but a Buick engine in there.
Didn't B-O-P engines at least use the same bolt pattern for the transmission? I'm pretty sure they did in later years, but maybe not in 1954.
Of course, even if another engine lines up to the transmission, you still have to deal with everything else that connects to the engine.
Back in the 1950's though, car bodies sat on top of the frame like a truck, rather than between the frame rails, so maybe there's more room underneath, to accommodate a wider variety of transmissions?
The color change might turn off the occasional purist but these people never buy anything anyway. :shades:
As an appraiser, I don't deduct value on a later T-Bird for a color change, as long as it is a bare metal respray. If you have a blue car with a red interior trunk lid and door jambs, well then, another story....
On a '57 Bird with an E code, yeah, I might deduct value, as these are far more rare and valuable cars.
And if you can add factory AC, all the better for value.
that means glass out, trim off, upholstery out, and maybe engine out--can't recall if that year's engine bay is black or color co-ordinated.
Might be worth doing if you found a really nice car with a ruined paint job or something that say got rear-ended and that you could buy dirt cheap.
A clean driver '66 Bird coupe with a decent "street level" paint job is worth about $10K.
Any '66 Bird needing work dives in value considerably because these are expensive cars to restore.
A $15K coupe would have to be pretty close to "great" in condition. Most of the ones I see have nice paint, pretty clean interiors, clean but less than spiffy engine bays and old unpainted/undetailed/unrebuilt undercarriages. That's a #3 car and not a $15,000 one.
They handle like an overloaded cruise ship. They are hard on suspension parts and tires, they wallow around corners and they have boatloads of electrical and vacuum leak problems.
If I were tempted to buy one (and I could be), I would pick one that is already done. I would never change the color of a car and, no, I'm not a "purist", I just don't like the results unless HUGE money is spent and 7500.00 plus is way to much for a T-Bird that will never be worth big bucks.
But, that's me.
The restorer is honor bound to be dictated by the I D tag, buck tag, & any other factory labels on the car. To do otherwise is similar to not getting an A+ on the test.
After factory "add ons" lead to missrepresentations, for example, today there are more 65 & 66 Mustang GT's than the factories built.
Be correct and be cautious when restoring anything.
As for originality, you'd be crazy for instance to keep the turboglide transmission in a '59 Impala or bias ply tires on an old T-Bird.
What you don't want to do is start chopping into a car or welding on it. These I would agree are no-nos unless you are going full-bore custom.
But in my book, anything "reversible" is fair game on an old car.
And let's face it---many old cars are not historical monuments, they are just old cars. Some history is not important enough to preserve with intense accuracy. That's what "survivors" are for.
Old plain cars are not included in my post as they are in yours so there is validity in what you say when it comes to the non classic clunker. With them, do anything you want.
The 57 Bel Air is more of a classic than the 59 Impala so I would go original on the BA. The 58 Impala is more of a rare classic than the 59 so keeping it stock would increase its value as well.
I question the value of adding an after market continental kit to anything.
Unless you really know what you are doing, I would proceed with great caution. These cars can be a nightmare and the 67-69's ae no better.
Yes you are correct, the 67-69 Birds will never be worth very much.
RE: Hagerty --- Hagerty will insure ANYTHING that is remotely old, so I think the criteria for whether you "modify or don't modify" an old car has to rest on something else---probably market value is the most sober approach.
Modify a $15,000 car? Sure, why not. After 45-50 years if it's only worth $15,000 nearly restored, you are not sitting on a gold mine there.
Modify a $50,000 car? Probably not a smart idea, but people do it all the time, and if the mods are tasteful and reversible, the marketplace doesn't seem to mind too much. Just don't mess with vin and data tags, don't cut the car, and don't throw away what you took off.
The idea of "purist" coupled with mass production American cars made in the 100s of thousands makes me chuckle a bit. There comes a point where a heated debate on the fender bolt markings and lengths on a Model A Ford becomes Theater of the Absurd.
I can see big changes in people's attitudes about restoration. It seems we went from the "careless restoration" period of the 60s and 70s, to the fanatical authenticity and pampering of the 90s to the "get it in and drive it" attitude of 2009.
A balanced middle ground if you will.
Saturday, July 18, Bellevue College, Bellevue, WA is when judged Mustangs undergo a very meticulus and exacting discernment of authenticity.
Your attending the judging process would be educational, informative, & inspiring.
Hose clamps, bumper bolts, & fender bolts are just a few items that can cost points. Striving for perfection is to be admired.
