Let me know.
the past few months it has been shifting funny and the RPM's
are climbing.Today from a stop light I counted the shifting between gears
and counted only 4 with the overdrive off.
Does anyone know why it won't hit that 5th gear?
F-fix
O-or
R-repair
D-daily
but I love my explorer and mustang....
Please note - I posted this same message in "starting and stalling" forum
Thanks for any help
Basically, can a 2002 Ford Explorer transmission be replaced with transmission from any other year?
Today I noticed the LOUD thump noise from the front end of the vehicle while in reverse, just taking off a few feet with A/C on. It is so loud it startles me and I think I may have hit something, ect...I called service dept at FORD who state we just replaced some of the A/C parts per TSB, so should not be that, so will have to take in again this Saturday to see if they hear it. Of course, If they can't duplicate it then they can't fix it. Could it be something else?
Now they want me to purchase an extended warranty, but I really don't feel it is fair to spend more $ knowing the issues that are evident to them.
HELP!!!! I am so sick of the "We can't duplicate it so nothing wrong attitude" or "It's the way you drive"...
Any suggestions are welcome, thanks...
I really wish a mechanic would actually get their hands dirty...
If I can't get this issue taken care of, I told her (mom) that I'm selling it! It has been nothing but trouble since she got it. The A/C compressor locked up last year and the dealer said it would cost anywhere from $1900 to $2300+ to replace it. I tracked down a new compressor from a Ford dealer who sells parts online and managed to haggle them down almost 20% for the compressor, evaporator (if I'm not mistaken....either that or a condenser), new lines and the A/C belt for $800 shipped. My dad's mechanic installed it for $300 including the refrigerant so it was repaired for $1100.
During an oil change, at least a year ago, the mechanic discovered a small leak in the radiator. He poured some product in with the coolant that works like "Fix-a-flat"' for radiators, as he put it. It has been more than a year and still holding, but it's past due for a coolant change and I've been putting it off with the intention of replacing the radiator at the same time. Ford's price for the radiator (just the part) is over $300. I've found several from other sources that are in the $160-$180 range and come with a 2yr/24k warranty. There are a few as cheap as $120, but I'm not familar with the vendors and they don't have a warranty....no thanks.
If you haven't already figured this out, for some reason I'm the one who has to take care of my mom's vehicle issues...my dad is too nice for his own good, I'm not! =/
The most frustrating thing is how reliable her previous Explorer was and continues to be. She had a 2003 XLT 4WD V6 and my sister bought it when mom got the EB in May 2008. The '03 recently hit 170k miles and still runs like a champ and has never needed more than regular maintenance.
Speaking of regular maintenance, the maintenance schedule in the owner's manual doesn't require a transmission fluid/filter change until 150k...I've never known of a vehicle that went more than 50k between fluid changes. 150k seems ike a lot of miles for the fluid to perform properly, but I could just be stuck in the 90s in that regard....has anyone changed theirs more frequently?
3500 for a new one.
When the going gets tough, it's still my first choice.
Mine too, obviously. Anxious to try out the new one, and see if it can still tow.
My 02 gave me a lot more trouble than my 03, which is still running with 130,000 on the clock. I've heard that 03 was a great year for Explorers as far as reliability was concerned. I have no idea why.
-John
I know there was some kind of transmission snafu in '04 or '05.
It drives well, sounds good and has a good sound system.
It's also my kids first choice for the above reasons.
I filled up my AWD Fusion about 3 weeks ago and have driven it about 60 miles since then.
Pretty much drive the Explorer every day.
Our weather has been pretty bad for the last month or more, so why use your second best tool for the job?
When I turn of the engine and starts it back again the OD light won't flash until I drive for a while.
I know this model has transmission problems but could this be fixed. My check engine light is on and the oil level is ok. What could be the problem.
Mine did that and I had the trans replaced.
The valve body has been replaced twice since the transmission was rebuilt a little over a month ago, and i am still haveing the same probelm. the repair shop has been great. They thought they might have been getting a bad batch of valve bodies, so they used a different supplier last time. Unfortunately, that does not seem to be the problem.
Any ideas on what the problem could be?
One may ask, why do I keep buying them? Because, they are engineered so well, are tough as nails, and generally are pretty bullet proof. The 07 I have now, is great.
so after changing the transmission, i took it for a test drive and it would engage in gear. so i warmed up the car and after a few minutes i took it for a another test drive and it was good. three days later i took it again to drive a it started slipping. it wouldn't even stay in drive. its like its having a hard time engaging.
anybody out there that can help me
thank you for your time.
mike
my email is
pabrosmc@sbcglobal.net
