Contact Toyota's Customer Experience Center at 1-800-331-4331.
Has anyone had a similar 'clunk' noise and if so, did you find out what was causing it?
Thanks a bunch!
Dan
Dan
Question is what is causing the engine RPM to get picked up by the speakers? The engine not grounded properly? Perhaps the antenna, speaker, amplifier, power cables not properly connected/isolated/grounded? I am not an audio expert but there is definitely a high pitch noise that is exactly as the original poster describes.
A long history...I eventually took toyota to arbitration and lost because the arbitrator could not hear the noise....he was a 70 year old guy with bad hearing. this was after several trips to the dealer. What it is, i have narrowed it down to 2 things, there is a large mesh screen behind the butterfly throttle valve, it was dented. i straightened it out. Maybe it had a reed effect as the air passed over it?? The other thing i did is ran some silicone sealant around the intake manifold on the top of the engine - remove the plastic engine cover. i think it is air getting in to the engine through this manifold seam but toyota wont listen. the noise has greatly diminished and only happens around 1500 rpms. bottom line, the field engineer said it was "normal operation" and that was treated as gospel. even thouh i took it to othe dealers and they all said it was not normal, his decision trumped all. i gave up.
You can test it by doing a powerstand for a very short period, put emergency brake on, put in drive and keep push on brake pedal. bring rpms up to 2000 and you can hear it quickly. I made a dvd of it too.
good luck, feel free to email me directly and i'll give you my documentation. :mad:
My wife and I purchased a new 2008 5.7 2WD SR5 back in may. We have over 7,000 miles on it already and I think it's the best car I've ever owned.
We drove it, in October, 2600 miles through Oregon, Idaho, Washington State and Northern California.
The 5.7 engine with the 6 speed automatic never strained once throughout the trip. We averaged about 20 mpg, with a one of the tanks of fuel being wind aided that registered 24 mpg.
We are currently looking at a new Venza for my wife to replace her RAV 4.
It's a great vehicle, but for us there is no doubt the high feature V-8 and the 6 speed transmission is what sets it apart from the competition.
Thanks for this message board
my question is - does anyone know if that tire will fit the truck? How can i find out?
Thanks in advance.
I got my last two sets at the thrift store for about $5. Expect to pay around $40 for a new set. Or more.
Pros - fit and finish, drivetrain (transmission especially), true 4WD capability (driven in deep snow up steep grades) and carrying capacity - especially the space in the second row. Smooth as butter. Touch screen navigation is great if that's what you prefer (coming out of a BMW with iDrive it's heaven).
Cons - fuel economy. I knew it would be bad but accepted the tradeoff, and it's bad unless you spend your time on flat highways. For the first 3000 miles, average economy 14.4 mpg, high 18.8 mpg on a couple of highway tanks and low of 9.8 for mainly 4WD snow driving. Also the width of the car can be a con for some.
There is a plastic sounding "rattle" inside the passenger area, driver side, just behind the back corner of the moon-roof. When on a perfectly smooth road, you hear nothing...but even the slightest bump or expansion crack causes a very noticeable "rattle". It is loud enough to hear over conversation, but not loud enough to hear over the stereo at a moderate volume. It is a bit annoying, as it is right behind the driver seat.
If I reach back and apply very light pressure near about the area, it prevents the rattle. I haven't actually got back there yet to really isolate the area (haven't had a chance to get another driver in so I could sit back there).
Anyone else have this? Am I being too critical? I admit it is possible, but everything I read about the Sequoia indicated that the cabin noise level was well refined, and this definitely seems strange...would love some feedback on this one.
Thanks much...
I would like to hear more if someone manages to have this fixed - what is it and exactly how can it be fixed.
I am curious about how confident you are in your diagnosis? I still haven't had a chance to investigate yet. Also, do you have any experience at all with dealers taking care of these type of things? I have no idea how intrusive of a fix this is, or how willing dealers are to address items like this...anyone with any experience on these types of things? I wonder how easy it is to get into that space...
Thanks for the feedback, much appreciated...
Sometimes rattles and squeeks can be perplexing, but I'm confident that we've isolated our rattle. Just a little pressure on the duct stops the rattle and I can easily make the duct tap the steel roof.
Dealers will fix easy to isolate squeeks and rattles, but aren't too keen on tracking down and fixing the tougher cases. For example, I bought a 95 Avalon new - drove it 236,000 miles then gave it to my nephew - that had a wind noise problem the dealer was not able to fix. The dealer made two bona fide efforts (unfortunately, not without some firm encouragement) I just decided to accept this defect and appreciate the car as a whole.
I have a couple of blank spots on my dash where factory switches can be mounted. I have a loaded Platinum, so I assume these must be for options in Japan or something that is not offered in the US.
I need to mount a switch for a project I am working on and am looking for options. I would like to find something aftermarket that would mount into those panels. The toyota switches are all prelabeled and really would not do what I want. I want to put a simple toggle switch in but I would like for it to look as professional as possible. Anyone have a line on a good dealer for something like this?
Chris
Does anyone know what this blank is for?
My biggest fear is having the dealer address it, and them attempting to do so (with all good intention) and either making the problem worse or introducing other problems.
It turned out to be the front passenger shoulder strap buckle which was flipped upside down and gently banging (rattling) against the seat. It was left rubbing against the upper side of the seat and simply needed to be flipped down flat against the strap.
Problem solved...sound gone. May or may not be your issue however I thought it was worth sharing.
I honestly haven't gotten in the back seat with someone else is driving to really isolate it...but I can fairly confidently say it is coming from the ceiling, just behind the driver's seat...and I can also reach back and by applying a very small amount of pressure in the right spot on the ceiling actually eliminate/stop the noise. So I am pretty confident there is something loose up there...
We have only had the vehicle a short period, and just haven't had a chance to get back there while someone else is driving to really search it out yet.
I am definitely anxious to hear peoples experience getting this addressed...
Whatever the issue, I'm sure it would be easily diagnosed and corrected.
http://www.discountvantruck.com/centerconsoleseats/truckconsoleseats.htm
aanyone have any info. Was this because of a mechanical issue or a more of a sign of the financial times?
Posted: January 16, 2009 Toyota's two truck plants near Evansville will halt production temporarily this winter on the Sienna and Sequoia assembly lines.
The 4,600 workers will still report for duty and continue getting paid, or they can volunteer for unpaid leave, Toyota spokesman Mike Goss said.
Toyota is cutting output throughout North America to halve the inventory of unsold vehicles on dealer lots. At the Princeton, Ind., complex, production has been canceled for 17 days in March and early April in the Sequoia full-size sport-utility vehicle plant, and eight days in February and 13 days in March in the Sienna minivan plant.
During the Sequoia down time, the assembly plant will be readied to also produce mid-size Highlander SUVs, a model slated to enter production late this year. Sequoia output will continue on the same line. The Sequoia plant opened in 1997 for assembly of full-size Tundra pickup trucks. Toyota last year moved pickup production to the new Tundra plant at San Antonio, Texas.
However, I did read some where that the console in the Platinum could not be removed because it had the wiring and controls for the heated second row seats. Not sure about it though.
I was helping family to shop for a new car 15+ years ago. I forgot if that's a V6 Camry or Cressida (spelling?). To save cost, I asked if dealer can remove the power seat and replace with manual ones. The low life sales dude said sure no problem.
Wanna trade?
Mike
