Thanks again!
Rebekah
For everyone's information, my research indicates 50% of the T6 models have had their transmissions fail.
My Volvo dealer replaced the transmission, without charge. There was no argument and no delay (and not a GM tranny). I had my car back witnin days.
Just joined the site and am a new owner of an '05 XC90.T^. I unfortunately found out out about the issue after buying one of these units even though I searched online a bit before buying and did not see the tranny issues until too late. I bought the vehicle out of Texas and imported it into Canada. What are my chances of getting work done in the US or Canada if need be?
The tranny is not giving me issues and although expect it is the same tranny that has all the problems, I am not sure. The tag from the tranny has a number of letters, numbers on it. I found this site and discussion based on the numbers following :
A135 400. Other alpha-numeric identifies are as follows:
T615TP P8689242 WKJKF TP.
Is this the problem tranny?
By now Volvo should no longer ignore this problem. I traded my Yukon with 125,000 mi with no problem with this Volvo. What a shame. I have a 1999 MBZ E430 with 165,000 mi with no problem.
Does anybody have an idea as to what concerted effort we can all make to make Volvo listen to our problems?
In fact i found out it had two transmissions previously. It appears the radiator can bleed into the transmission frying it.....so if you replace the transmission you need to replace the radiator for good measure. It is a GM transmission--that is---made in Japan--for a car that was owned by Ford, and now the Chinese.
Today i just replaced the ignition lock and switch....(around $650) and also needed the shifter cable and other parts to the gear shift replaced ($712)
The gear shift problem is probably related to the fact that it has had three transmissions....and the car has only has 94,000 on it.
Seems my tranny is acting up, or so I think. No lights coming on, but there are some clunking and cracking noises occurring, particularly in this cold spell (-20C, 0 F). It started with some light clunking, knocking, and seems to be getting louder. Thought it might be lose wheel nuts, ice build up on the rims, etc, but no such luck. What have your symptoms been with your trannies as they approached the end of their useful lives?
The previous item discusses a heavy duty clutch plate to resolve the issue. I spoke with a Volvo rep who stated that the engine T6 (high rpm) is mated to a low rpm tranny causing premature failure through shearing, etc. Perhaps this heavy duty plate will last (or cause something else to wear, worse??) Any thoughts? If I have to fix mine, I would like to try the heavy duty plate.
Cheers, happy trucking.....
Anyway, my bad news is Volvo decided not to grant me the "goodwill" because my mileage is over 100,000 and that strictly speaking the warranty is done after 4 years and 50,000 mi. Volvo is asking $5,600.95 for the repair and had the guts to tell me that they are doing it for cost, so in a way, I was given a "goodwill"
I hope there is a good lawyer that can compile these transmission problems and file a class action law suit against Volvo.
Let's get after them.
Good luck!
Let's see if the headcount increases. I'm wondering how many we need for a class action.
Good luck!
I thought that I had read somewhere that a class action suit had already begun. I found this link
Good luck everyone. I'll let you know when I actually get my car back. Hopefully next Friday.
I have a 2004 Volvo XC90 that I purchased new through the overseas delivery program. My family chose this car for it's supposed safety and reliability. Along with other problems that needed attention in the first 50,000 miles, my main issue has been the transmission(s) on this car. At approximately 52K miles, the XC90 1st generation transmission went bad and had to be replaced. Fortunately, the Carlsen Volvo (Palo Alto, CA) service rep agreed to cover the cost of the transmission replacement. I was very pleased with the service and went on my way. In early December 2010 at ~107,000K miles, the transmission started to hesitate & function erratically while driving. The danger was frightening, e.g., when trying to accelerate onto a highway, it would not accelerate immediately, and caused a real danger to me and my children. Within a few days, the car was parked at my home, and was unable to engage in forward or reverse. I again called Carlsen Volvo,and talked to my service rep, who stated that I should bring the car in and have it officially diagnosed; she also stated that she would talk to the local factory rep regarding compensation. Apparently, the 2nd generation transmissions on the XC90 are also faulty, and have been replaced in at least 50% of the cars. My car was towed to the dealer and it was confirmed that the transmission had an internal problem and needed to be replaced. The dealer rep called Volvo N.A. rep, Wyatt, who offered to pay for the parts (~$3,500) but I would have to pay for the labor(~$1,500). My husband countered that we would like the whole thing paid for since it was well-known factory defect. When Wyatt heard of our counter offer, he not only denied this, but simply stated that the deal was off the table, period. The next day, I reconsidered and asked the service rep to call Wyatt again with our acceptance of the initial deal. Wyatt refused to put the deal back on the table and said we should pay for the repairs ourselves. I then called Volvo Customer Care who documented the complete story, contacted Wyatt via email to again present my case, however, Wyatt again refused. Apparently, because I have chosen in the past to have a personal mechanic service my car, change the oil and tires, etc., I am considered to be a "Disloyal Volvo Customer" and this was a consideration in Wyatt's decision to pay for my transmission, even though it is a defective part. At this point, I had to have my car back, and told Carlsen to replace the transmission. Carlsen offered a 10% discount off the total price. A very kind gesture, however, I had to pay $4,600 out of pocket for another new transmission for this car. It is well documented that the 1st and 2nd generation transmissions for this model have been defective. It is unheard of that a car should have a failed transmission every 50,000 miles.
:mad:
My husband badly needs to upgrade his vehicle, and we had planned to do it as soon as he returns. However, I just found a good deal on a 2004 XC90 with what is listed as a 5-cylinder engine. Am I correct in saying that's not the same as the engine that we originally had? I'm heavily considering trading in my husband's vehicle for this one. Before I go to the dealership, I just want to be absolutely sure that I understand the transmission issues, and that this vehicle doesn't have the same engine as the problematic model. Can anyone offer me a bit of clarification? Also, any major problems with the 2004 5-cylinder that I should be aware of? Thanks in advance!
