Could be one (or several) of many things. First step is to remove the diff cover and make an inspection of both the components, and the oil that drains out.
Suspects in your problem will be worn bearings, worn gears, worn clutch plates (if you have an LSD/Trac Loc), low or contaminated oil.
You have had the axles serviced as required haven't you?
Terry
You've got that right; what a bunch of morons. I bet those imbeciles measure precipitation by weighing a pile of dirt before and after a rain shower...
I'll take a chance and assume that the a/c isn't a problem only in reverse.
It sounds like a vacuum problem, as they shouldn't have been anywhere near the HVAC unit to replace the camshaft. Could be a damaged vac hose, or one improperly replaced. (Vacuum actuators are used to control the airflow direction doors in the HVAC unit).
As for dying in reverse, it could be connected with the aforementioned leak, or it could be other things. It's possible that you'll have fault codes which will help with the diagnosis, and you can that checked out at Autozone for free.
Unless you can spot a loose vacuum hose under the hood, I'd let the dealer take care of it to preserve your warranty coverage. If he messes up it's Jeep's problem, if you mess up it's yours!
RUN, as fast as you can to another dealer.
That would require some thought. It's more likely they would just count the number of turkeys looking up with their mouths open.
Good point! LOL!!!
Let me know.
Mike
At any rate, I really appreciate you help and kind response!
Mike
Here's how the FSM describes the hydraulics:
"HYDRAULIC LINKAGE COMPONENTS
The hydraulic linkage consists of a clutch master
cylinder with integral reservoir, a clutch slave cylinder
and an interconnecting fluid line.
The clutch master cylinder push rod is connected
to the clutch pedal. The slave cylinder push rod is
connected to the clutch release fork. The master cylinder
is mounted on the driver side of the dash panel
adjacent to the brake master cylinder and booster
assembly. This positioning is similar for both left and
right hand drive models."
First check is to remove the master cylinder cap and see if you've lost fluid.
Anyway, exhaust leak is a very good guess.
Definitely check yours - mine sounded like what I think you are describing. We ended up ignoring it for probably a year, until it needed a smog check.
Im thinking of buying a used Wrangler from someone in the area. Its a '98 Sport, and I dont know a hell of a lot else about it or its history. Drove it a little bit, it handled as I expected. Upon inspecting underneath I noticed a LOT of rust and corrosion on the brakes and calipers. Is this normal for wranglers to have these parts deteriorate? I get the impression that this car doesnt get driven very often, and sits for weeks at a time which Im sure doesnt help. But I was surpised to see this kind of corrosion. Anyway, I was just wondering if anyone else has seen this. I really dont know much about Jeeps, never bothered researching them, always liked them, and Im looking for something different than a boring road car. Thanks!
If you or anybody else knows how much clutch replacements usually run let me know (maybe I can negotiate it this sounds too much).
Mike
It could have been used in an area that salts the roads in the winter, or maybe it's been used on the beach.
Wranglers definitely aren't boring though!
Actually that doesn't make a lot of sense. If the springs on the friction plate had come adrift it would be very noisy but it shouldn't affect the pedal feel. If there was a problem with the spring on the pressure plate then the pedal might go the the floor, but the clutch would slip badly and you wouldn't be able to drive it. As I remember it, your problem was that the pedal went slack and the clutch wouldn't disengage, so you started it in second gear and drove slowly home.
How was it diagnosed? The only real way to check the friction plate is to remove the transmission and strip the clutch assembly.
Labor costs vary so much based on location and type of shop that I couldn't price it for you, apart from saying that $1K seems high. A complete clutch kit (pressure plate, friction plate, and release bearing) costs around $150, and labor should be around 4-5 hours. Your best bet is to make a few phone calls and get several estimates for fitting a complete replacement Wrangler clutch.
:sick:
Here's the FSM instructions:
"HUB BEARING REMOVAL
(1) Raise and support the vehicle.
(2) Remove the wheel and tire assembly.
(3) Remove the brake caliper, rotor and ABS wheel
speed sensor, refer to Group 5 Brakes.
(4) Remove the cotter pin, nut retainer and axle
hub nut.
(5) Remove the hub bearing mounting bolts from
the back of the steering knuckle. Remove hub bearing
from the steering knuckle and off the axle shaft.
INSTALLATION
(1) Install the hub bearing and brake dust shield
to the knuckle.
(2) Install the hub bearing to knuckle bolts and
tighten to 102 N·m (75 ft. lbs.).
(3) Install the hub washer and nut. Tighten the
hub nut to 237 N·m (175 ft. lbs.). Install the nut
retainer and a new cotter pin.
(4) Install the brake rotor, caliper and ABS wheel
(5) Install the wheel and tire assembly.
(6) Remove support and lower the vehicle."
The hardest part is usually removing the three bearing carrier mounting bolts.
HELP!!!!
Thanks, Mike :confuse:
On multiple cylinders it could also be a fuel problem (pump, filter, regulator, etc.), coil, either CPS, and so on.
Reading and identifying the code is just the beginning of diagnosis.
Glad you got it fixed.
My '98 has some light surface corrosion on the underside but has lived most of its life on the West Coast so it's pretty minimal.
Mike
HOWEVER, lately...I've been having a problem with it. I'm going to explain what it is doing the BEST I can.
It doesn't do this ALL the time but...when I am in 3rd or 4th gear...it feels like it is about to lose power at times. It will start making this popcorn sound and sounds as if it's coming from under the drivers seat. If it does this while in 4th gear, it will stop if I change to a lower gear. But then again, after awhile...while in 3rd gear, it will start up again.
I've talked to soooooo many different people about this and nobody has a clue what I'm talking about. And of course, it ONLY happens when I'm driving it. A good friend of mine has driven it to hell & back trying to figure out what the deal is but it never happens when he is driving. Is there ANYbody here that has experienced anything like this with their Wrangler? Or anyone who can tell me what I need to check?
These kinds of issues are not easily diagnosed but ARE diagnosable. You need to find a technician who goes about it methodically, like Sherlock Holmes..."well, it's not this so we go on to that". It's called a "diagnostic tree".
Having someone esle guessing with YOUR checkbook is no fun.
I think your engine is "pinging" and that often means a timing issue, or overheating, or really rotten gasoline.
The water normally gets in under the windshield frame. There's a rubber gasket under the frame that compresses and rots with age. The frame itself will often rust too. The gasket is available and isn't expensive. The hardest part will be persuading the windshield hinges to allow the frame to fold forward. Lots of PB Blaster and patience usually do the trick.
The true solution, of course, is to buy a 91 Wrangler.
Seriously, if it's coming in under the dash, have you checked to see if the small grill between the windshield and hood is draining correctly? My YJ leaked like crazy until I realized that small box was clogged and draining through the floorboard vents since that feeds the HVAC.
