A leaking fuel injector(s) can cause a hard start situation, but it's because of flooding which you would smell easily.
Pumping the gas pedal achieves nothing with a fuel injected engine, it just flaps the throttle butterfly. In a carb'd engine it's different as a carb normally has an accelerator pump, and pumping the gas pedal squirts neat gas into the manifold.
Don't just check the battery, have the alternator output checked as well.
The resistors are used to control the lower three speeds and the pack is located in one of the HVAC ducts, accessible in the passenger footwell.
It's always good to hear when it works out.
P.S. The check is in the mail.
Check your distributor cap and make sure the contacts are clean as well. Have you checked the OBDII codes to see if anything is being thrown?
Sounds similar to problems I had before my throttle position sensor went out last year. But check the plugs, wires, distributor.
-Paul
This part is cheep but is only a symptom of a much worse problem.
There was a recall for a faulty heater, dash ground.
This caused the switches to burn out, wiring to overheat, motors to smoke and other electrical issues.
Check with Jeep and see if your Jeep is included in this recall.
The recall was for a limited number of vehicles.
The problem is wide spread. "DENIAL"
Have the blower motor and all heater/ac related electronics checked.
The best solution probably is to replace the heater/air conditioner console, (This is the fan switch, heat/ac selector switch, temp mixer) all damaged wiring.
Make sure the ground wire is firmly attached and undamaged.
The wiring harness for the heater/ac is not available so it will need to be repaired. (Go figger that one)
When you are done write a letter to Dodge and ask to join the frat.
This has been a problem on Dodge vans since 1973.
(Keeps the service bays full)
"Thank you Sir. May I have another?"
Maybe someday Jeep will again be come its own company.
i.e. AMF/HD Chrysler/Jeep
any suggestions / ideas greatly appreciated !
How do you fix such a problem?
The HVAC unit in your '97 uses rotary switch for blower fan speed, and slider controls for both temperature control and for a/c selection and direction.
You have a large combination of air treatment options. Cooled and de-humidified air can be drawn and treated from the outside or recirculated within the cab. The recirculated air can be directed to the face only, but treated outside air can be sent to the windshield, face, or face and feet. Untreated air is also available. To both treated and untreated air, heat can be added. For instance, if the weather is cold and damp you would use treated air, but combine it with heat to give a warm dry output.
This is just a basic idea of the HVAC options available to you. Maybe erickpl, who has a '97, can give some greater detail.
Anyhow, all that was to explain that there are no dedicated a/c vents or hot air vents. Hot, cold, treated or untreated can come from any, or sometimes combinations of vents.
It may well be that you don't actually have a problem, but are misunderstanding the functions of your HVAC system. Or, it could well be that I am just misunderstanding the problem (wouldn't be the first time ). Perhaps you could explain exactly what position the sliders are in, and where the air is coming from, when you think it's functioning incorrectly?
If there is a problem, it will likely be connected with the various actuators and diverter doors that control the air flow and temperature.
www.jeepsareus.com probably has em a bit cheaper than the dealer. OR you could possibly find the setup at a local salvage yard. I've bought quite a few parts for my 97 from the salvage yard - including my windshield frame that matched my paint perfectly.
-Paul
The 97's slide control is less sophisticated that he gives it credit for.
You have a choice of:
fresh air to face OR
fresh air to feet OR
fresh air to feet with defrost
The only recirc air you have is when A/C is involved.
After having taken apart my center console stack to do that switch mod, I looked at the HVAC and the slider switch for the temp portion. It is purely mechanical at the controls. If I were to take apart the unit and look at the upper selector, I'd expect to see something similar, but I'm not 100% sure on that.
-Paul
The BANG almost sounds like a locker in the diff gave.
But have you tried putting it in 4wd to see if you can get moving THAT way? If you STILL can't move, I'd just about say the chain or something in your t-case or your linkage to your t-case from the transmission went out.
-Paul
thanks jason
i bought 2 brute force u-joints today for $38,,,is there that muchlabor involved for the cardan universal?? :confuse: :confuse:
This might help.
http://www.stu-offroad.com/axle/driveshaft/driveshaft-1.htm
Trust me it is not as easy as it looks.
But what the heck it's already broke.
..might as well get out the big hammer and beat your drive shaft into shape.
It's the ball centering joint, labor and parts, that adds to the cost. Check out the link burntup gave you, and have a look at this one too.
next silly question...i am thinking of removing the DS and taking it to the shop. the jeep is the only wheels i have, so am wondering can i remove the driveshaft and still drive the jeep without any problems???
The stock Moab wheels on the Rubi have a 5" BS vs the 5.5" BS. if you are going with 33x10.5, you'd be fine. 33x12.5's may cause some problems.
Your height MAY be an issue - it WILL be an issue offroad.
I'd probably opt for a budget boost (spacer lift) to fit the 33's.
-Paul
-Paul
There are many known causes, but nothing concrete.
Check:
Tie rod ends for play and wear
ALL joints in your steering
Trackbar connections
Tire balance
Tire alignment
Pitman arm
Is your jeep lifted? If so, what steering components have been replaced?
-Paul
Used to have a similar problem back in the big tire days.
14x35's and bigger...balancing took pounds of lead not oz.
Just a little bump and the old Jeep would shake like a washing machine on speed.
Maybe you can borrow a set of tires and wheels to test out the tire out of balance theory.
Hey if you were out of country a while you deserve a new set of tires and wheels at the very least. Treat yourself and welcome home.
-Paul
Seriously, please turn off the caps. I don't like being yelled at this early in the morning. :shades:
If you follow your upper radiator hose to the metal area just behind the fan... remove that assembly (after draining the coolant). It is in there. I'll even shoot a pic of my 97 SE's engine to show you (but the engine needs a SERIOUS cleaning... you've been warned!
A Haynes manual would cover that basic one for ya, but a Factory Service Manual would be GREAT if you plan on more detailed repairs/maintenance down the road.
-Paul
..Joe..
Removing the hoses and sensors is step 2 (draining is step 1). Remove that front bolt. Remove assembly. The tstat gasket may be holding it on, so using a rubber mallet to strike it gently will break that t-stat housing loose.
You'll need a new t-stat gasket when you reattach everything, so you may as well put in a new t-stat at the same time.
Hope that helps.
-Paul
I have an 1998 wrangler and my gauges wouldn't work for about five minutes while driving, they do now but I dont want this probelm happening again, also, theres a rattle under the jeep and its annoying. so if you guys have any answers with the gauges and rattle please reply. thanks
zach
The repair kit from Dodge is about "a buck and a half" installed.
Cheaper it you you can cut and solder.
