Lexus RX 350 Driving Experiences and Problems
I have a 2008 RX350. Recently I noticed that when I start the engine while ;the steering column is still extending to its full position, I could feel a momentary knock on the steering wheel. I don't recall feeling this when the car was new. If I put the key in (but not starting the engine) and just let the steering column to extend to the final position, and then start the engine, there is NO knock.
I showed the Lexus dealer service person this the other day and he insisted that it was normal. But I really don't recall having this issue in the past and one of my coworker confirmed that his RX350 did not have the problem.
Can anyone let me know if your RX does the same? My warranty period is going to expire in a month and I want to make sure this is resolved if it indeed is abnormal.
Thanks in advance.
Thanks in advance.
I know a lot of people have already bought the new 2010 RX350 and wanted to start a new place to start discusing your driving experiences, new features and any issues that you might have.
Well, have at it! You can start by sharing your driving experiences, features and issues.
SUVs and Smart Shopper
Robalao
It's the tires. And the loose nut behind the wheel. :P
I have 168,000 miles on the 2001 RX 300. I went to CarMax and was offered $7500 so I think that is the value. I may give it to our daughter in law.
Hope that answers your question.
Robalao
Bill
Be for warned, I would have waited longer to buy this car had I not had trust in Lexus. Shame on me.
Good luck with yours.
Also I was finding the steering wheel quite stiff during the first 2-3k miles but the ride now has been getting smoother. I am loving it.
I found one inconvient for voice command is you can't do like 'go to xxx' which in your address book. I think they should add it in voice command list because it is so useful and so easy to add it.
Thank you,
voice command, call xxx is real amazing after contact transfer done.
Just following your instruction and I make it.
Thanks again!
Otherwise, no problems, except that the bumper is popping off on the front right corner when driving long distances at higher speed (very annoying). Not sure if this happened with a valet service or another defect. I'm going tohave the dealer look at it once I go for service.
Possible design problem?
That's the same exact bumper popping problem I have. I wasn't sure if it was just mine, but seeing how you are having the same issue, this might just be a design flaw. I plan on telling my dealer the next time I go back in for service.
Hope this helps.
Anyone have any ideas n how I can do it?
Wes
The answer is to change the setting referenced on page 316 in the Nav system manual. The General Setting # 3 (Auto Screen Change) has to be OFF.
Thanks to all who sent information,
Wes
I believe my RX 300 2005 had this feature, so I could hear the nav instructions even though I was listening to the radio.
Wes
My 2010 rx does not have Navigation however, when I change the radio from a fm station or I pod to XM I can barely hear it. I have to turn up the volume almost twice as high to hear the xm radio. Does anyone else have this problem or a solution?
I'd rather sell my new car if it has any problem whatsoever.
