Kia Sedona problems
(now we'll see if he can really take a joke)
The problem with these dispensers is you will get some of the octane from whatever the person before you ordered. Suppose you buy 92 octane gas...and if the person before you got 87 octane, the amount of fuel left from the valve inside the dispenser to the nozzle contains 87 octane! You start pumping gas into your car and you are getting 87 octane for the first gallon or so. You're paying for 87 octane at 92 octane prices!!! Can you say class-action lawsuit?
I've brought this issue up to my company management. They don't deem this a problem that is worthy of fixing until someone either sues them or the government makes it a law. The feeling is that there is about a gallon of gas in that pipe from the valve to the nozzle and this is not enough to offset most gas purchases (most people buy 8 gallons of gas so it won't lower your octane that much).
I only buy 87 octane so it really doesn't effect me. But if I bought 92 octane I might be a tad upset to know I may be getting some 87 octane and paying for it!
What really makes me mad about gas stations is when they raise the prices for no good reason. When the news reports crude oil prices going down, the stations hold prices steady. They claim the fuel they have in their tanks was bought at the old (higher) rates, so they must still pass this along to you. However, when the news reports that crude oil prices went up, gas stations jack up their prices $.07/gal the next morning. What happened to the gas in their tanks at the old price then?
I tend to follow jokes much better in person than in writing! As it turns out, the tab was $1,350 - the Honda dealer was not equipped to check/adjust the valve clearance and didn't feel it was necessary anyway (possibly because they couldn't do it), so that "saved" me 300 bucks for now. Hopefully it doesn't cost me $2k for a valve job if the valves go bad before I have the check/adjust done at an Isuzu dealer.
steve_HOST:
I don't think I've ever seen one of these old-style pumps you're describing? Sounds strange.
mikey mike:
Do really think it takes one of those single-hose pumps a gallon before it stops dispensing the octane used by previous customer? I don't know how those pumps work, but I'd think the changeover would be quicker.
uga91 (clay):
That one has bugged me too - for quite a while now. I do find some stations whose price increase typically lags other stations by a day or 2. So there's usually time to fill up at the lower price. These same stations also seem slower to drop their prices too. E.g. Speedway and Mobil are kitty corner about a mile from my house. Speedway is usually a nickel a gallon lower, but sometimes they will jump by 8-12 cents a gallon. Usually, Mobil doesn't catch up for 2-3 days. So for those 2-3 days the Mobil station is cheaper. The Speedway will usually drop quicker than the Mobil too.
Our 2002 Sedona EX (U.S. market) was built on 12/20/2001. We have not had the windshield cracking problem, although our windshield did pick up a small chip several months ago due to a rock striking it fairly low on the passenger side.
It sounds like you have had more problems with your Sedona than most of the folks on this board. Sorry about that.
Is your Sedona an LX or something? Our U.S. EX has a chrome grille and I don't believe it has any black primer/paint in that area or the rear license plate surround area.
Then there's the trick about filling up in the cool of dawn so the gas will expand during the heat of the day and go farther :-)
The chrome is under the Paint/primer that is peeling off, I should just let it go and see what the chrome looks like, it may be nicer.
When were the windshields replaced?
Did you buy your van in September 2001 or 2002?
Steve - I used to not only shut off the pump - I'd pull out the whole length of hose and hold the end closest to the pump up high so I'd get the siphon effect and drain the entire hose. Good for a pint or two I'd say.
I had the windsheilds replaced by the dealer rights after the failures both were performed by a window and glass company, not sure which one.
1-Check engine light comes on. According to owners manual and dealer, this can be caused by gas cap. However this has occured well after the tank has been filled, a couple times near half empty and a couple times near 1/4 tank. But no-one has touched the gas cap inbetween fillins.
2-THE RADIO SUCKS When I push the seek button to go to the next station, it just continues to skip stations that have very good reception. Also, when you push the seek button to go up, it sometimes goes down and vice versa. They replaced the radio under warranty, but it did not change. Does anyone else see this issue? (Live im Metro Detroit area where radio stations tend to have strong signals) DUE TO THIS, I'VE HAD TWO DEALERSHIP ISSUES. THE FIRST TIME WHEN THEY SWAPPED THE RADIO, THEY DIDN'T RECONNECT THE TWO SWITCHES ON THE RIGHT SIDE FOR THE RR HTR AND THE FRONT WIPER DEFROSTER. SO I HAD TO TAKE IT BACK. NEXT, THEY RECONNECTED THE SWITCHES, AND WHEN I LEFT I HAD NO CLUSTER/CONSOLE LIGHTS. SO I HAD TO GO BACK A THIRD TIME. SOMEHOW THEY BLEW THE FUSE, WHICH BY THE WAY IS NOT MENTIONED IN THE OWNERS MANUAL. WHEN YOU LOOK IN THEIR FOR FUSES ASSOCIATED WITH THE CLUSTER, THEY ARE IN THE KICK-PANEL. THE FUSE THAT CONTROLS THE CLUSTER LIGHTS IS IN THE ENGINE COMPARTMENT AND IS LABELED, I BELIEVE AS KEYHOLE ILLUMINATION. ABSOLUTELY NO MENTION OF CLUSTER. LESS THAN INFORMATIVE CALLOUT IN OWNERS MANUAL.
3-The liftgate swings up abruptly. If you don't watch out when opening the liftgate, it could knock you out. Many people have commented on this when they open the liftgate on our van. We have many minivans(villager, odyssey and sienna) in our family and they all open slowly. The dealer said this was normal!! Does anyone else notice this.
4-Sliding doors don't seem to shut. This occurs quite often, when you slide the door shut, it doesn't always latch. I've tried to close it with and without holding the handle and it occurs for both cases.
5-I cant lay the 3rd row seat down and not have it unlatch from the floor. When you stop suddenly it always comes unlatched and flips upward. I've seen this posted before, but wondered if anyone else has encountered this?
6-Windshield wiper solvent can't shoot up past halfway on the windshield and when driving on the freeway, it barely goes up past the wiper itself. Also, the wipers do suck in cold weather. Hopefully replacing with different aftermarket wipers will help.
7-Very disappointed with dealership quality and what the warranty didn't cover. The center cap has fallen off the aluminum wheels and I inquired to see if this was covered under the first year warranty for body fittings. They said that since the tires had been rotated and the dealership wasn't the ones who rotated the tires, it was not under warranty. In the owners manual it gives recommended mileage for tire rotation which I also believe is required for the tire warranty, and when you follow this they don't cover the damn cap. Come to find out, to replace the cap it costs $36.
We really like our sedona, and most of these are just minor nuisances to us and comparing items to our previous minivans. I'm in the auto industry as a supplier and attribute some of these to engineering, which is probably why this van is considerably cheaper than others.
Please let us know which dealer you have been visiting and consider trying another dealer for your service needs!
Now, to respond to your specific problems:
#1: Check Engine Light (CEL). Did the dealer scan the computer to see what trouble codes were stored? Sure, a vehicle's CEL can often be triggered by too-loose gas cap, and many Sedona owners have had this problem. Did the dealer investigate/diagnose your CEL(s) and conclude the gas cap was the cause, or did they take the easy way out and just say that was the likely problem without investigating? This is a problem that the dealer should be able to resolve fairly easily - after all, the computer stores the trouble codes, and these codes point the technicians in the right direction.
#2 Radio Seek button jumps past good stations. That should not happen, but I don't see it as a big deal. I don't think we've ever used the Seek button on our radio. If you are in your home area, don't you already know what the stations are? I frequently switch among different stations in the preset memory slots, but I hardly ever use the scan or seek function. To me, scan and seek are most useful when traveling. I'll have to try out our Seek button to see if we have similar behavior as you are reporting.
We are quite pleased with the sound quality, controls, and layout of the radio.
Your dealer sure did a poor job putting things back together after replacing your radio!
#3 Liftgate swings up abruptly. Yes, I have noticed this too. It concerns me. I may have the dealer look at it, because I don't remember our liftgate working like this until the last couple months. The struts don't provide resistance until the liftgate is halfway open or so, which allows the liftgate to gain too much speed. This one has been bugging me more and more lately.
#4 Sliding doors won't close. This is the first report of problematic Sedona doors that I remember on the Edmunds forums. Sounds like something definitely isn't right with your doors. Has a dealer looked into the problem yet?
#5 3rd row seat won't stay latched to floor when in folded-down position. Yours is the first report I remember hearing about this problem. Are you sure the seats are properly attached to the floor?
#6 Windshield wiper solvent doesn't shoot far enough up the windshield. This is a problem that annoys me on our van. It's not as bad on our van as you are describing, but I have noticed the spray pattern is too low. My workaround is to spray longer, to get more fluid on the windshield. This usually gets more, and enough, fluid on the upper portion of the windshield. I've been thinking about having the dealer look at this and see if the spray pattern or the jets can be adjusted. It seems possible, but it would probably take a fairly friendly dealer to be willing to fix this under warranty.
#7 Center cap fell off and wasn't under warranty. This is something that some dealers would probably cover, depending on how good the dealer's service is. I can understand the dealership's position that if someone other than they rotated the tires (and removed/reinstalled the center caps), they couldn't/wouldn't cover the lost center cap under warranty.
$36 must be the list price for the center cap. We had one replaced by a dealer a month or so ago. Had a flat fixed at a Kia dealer in Grand Rapids, Mich. No charge for flat repair - I was impressed. Drove a mile down road to Sam's Club, got out and realized center cap was gone. Went back to dealer. A salesperson saw the cap in the parking lot. Tabs on the backside were damaged. Had to call dealer back the following Monday and speak with service manager to arrange new cap shipped to us. Cap arrived a week or so ago. No charge.
These center caps are pretty tricky to install. I had quite a bit of trouble with a couple of them (recently removed all 4 of them to rotate the tires). Obviously the quick lube technician who fixed our flat tire did not re-install the cap properly. Beware!
Dealer Service
wfbjr23, what dealer have you been using for your service? Glassman Kia in Southfield is closest to our home, but I didn't get a good vibe there while Sedona shopping. We bought our Sedona from Dick Scott Kia in Canton. Pleasant buying experience, but it's 40 minutes from our house so we have not used them for service. Jeffrey Kia in Roseville is a few miles from my wife's office. We've been there twice so far and had decent service. Took 2 tries to resolve a left pull - first time they advised us to rotate the tires more often (we had them rotated on that visit - at 7700 miles), 2nd visit they did an alignment. Wanted airbag reprogram done 1st visit, but they didn't have their tools available so was done on 2nd visit. Had plastic cap on rear wiper arm replaced - must have fallen off in a car wash or something. On 2nd visit, wanted grounding plate procedure performed to resolve poor keyless entry performance. Dealer didn't have necessary parts even though I asked about this in advance of our appointment. We'll have this one taken care of at our next visit. Off the top of my head, I can't think of anything else that we've had corrected/adjusted.
I have pinpointed this to only when the weather is cold. And if you open the lift gate a few times during a short trip, like hitting a few different stores, the struts work correctly after the first time.
We will have our dealer check this also.
Everything else OK to date. 8 months and 7500 miles without any problems.
We will be travelling from St. Louis to San Antonio this summer for vacation. I can't wait to see how the Sedona does on this 2,000 mile plus trip.
I am not sure if the Sedona has this kind of a nozzle to spray as i dont own one but its been standard on all cars i have encountered.
2. Stress crack in windshield. Dealer had it replaced the day I brought it in -- did both item 1 and 2 on the same day between 9 and 5.
Dealer: Lia Kia in Schenectady NY -- very good service and the sale wasn't bad either.
2002 Kia Sedona EX with all options except spoiler and auto-wipers.
> 15,000 miles in less than 6 months of ownership. Happy campers here.
The temp bumped up over the last tank and I think on this one I'm going to hit close to 20 -- seems pretty good.
By the way -- my windshield cracked when I backed out of my attached garage at home (30 - 40 degrees or so) into the -10 degrees (worse I'm told with wind chill) on one very cold morning -- I heard a crack and low and behold there it was right in front of me. I did not have the defrost on.
Be glad the dealer gave you a loaner at all - it is not Kia policy to provide loaners, even for warranty work. That's pretty common for most non-luxury makes. This means the dealer was extending you some goodwill.
I wouldn't be so quick to say they've been great to you, though. These times when you took in the van and complained of excess oil or leaking oil and the dealer told you nothing was wrong - did they actually investigate or examine anything, or just pat you on the back and send you home?
I'm not extremely familiar with the lemon law, but generally I think you need to have had the vehicle in for the same problem at least 3 times, and the problem needs to be significant enough to affect the ability to use the vehicle. E.g. a squeaky seat would not qualify.
You definitely got a poorly or sloppily put-together Sedona. This probably doesn't make you feel any better, but most folks seem to have relatively few and/or minor problems so far with their Sedonas.
I hope you get things resolved to your satisfaction, either with a buyback or some proper repairs and then smooth sailing. At this point, I wouldn't blame you for not trying another Sedona, or even another Kia. Bad experiences like yours are how automakers lose customers. But I would encourage you to give Sedona another chance. Overall, it seems to be pretty well made.
Go Kia.
You probably didn't have a chance to notice whether the spare had any damage from sitting against those metal bars that hold it under the van, did you? I checked my spare after having our Sedona about 9 months, and there were several large indentations in the tire, along the edge of the tread near the sidewall. To me, this looks like a potential safety issue. I will have the dealer take a look on our next visit.
Doubtful that "dents" will have an impact on the tire life/service. After all, YOU have zebra stripes on your face when you sleep on top of the bedspread, right? No permanent damage there.
If rubber is broken, or evidence of broken tire belts is there, THEN worry. The rest is cosmetic. They cinched your spare up against the cage tightly to make sure it didn't rattle.
My wife likes to use tires as "curb feelers" on my truck. Despite some uglyness on the sidewalls, they seem to be OK...will end up changing out this spring at 50K on original equipment, despite sidewall scrapes.
These indentations caused by the spare tire carrier worry me mostly because they seem so big/deep. It's almost as if someone carved out a convex chunk of tire, leaving a fairly significant concave dent in the tire.
This would be a good question to pose over in Tires, tires, tires - a "pro" has posted some in there recently and may have some advice.
I began hearing a noise from the front end that sounded like a B-52 taking off. I suspected a tire problem, but after swapping out the spare, the noise was still there. Off to the dealer!
They were accommodating in that they would look at it the next day. I received a call the next day from the service manager telling me that there was a bad right front wheel bearing.
The bad news was that one had to be ordered. The good news is that they got the parts the following day. They replaced the bearing,seal and hub.
My Sedona has 16000 miles on it.
Next I found a spot of RUST on the tailgate, The dealer tells me that this was caused by a loose tailgate trim near the license plate. He is going to repaint the complete tailgate for me at no cost.
I now am experiencing the oil leak that I have just read about in some previous postings. I first noticed it about 2 weeks ago and since I was due an oil change I brought the van in and was told that the leak was a result of a loose filter and the problem was solved. It has returned today and when I called the dealer I was informed that this is an issue that they have heard of and that is has something to do with the rubber gasket on the filter being too hard and this causes the leaks.
The van goes in tomorrow to fix the oil leak and in 2 weeks to get painted and the radio replaced.
This seems to me to be an outrageous amount of problem, not just those mentioned here but in the other post as well. Does anyone think that this has a Lemon Law potential?? Any input would be greatly appreciated.
P.S. the dealer has been great and has fixed things without any questions but that can only go so far.
I can understand your frustration with license paint trim paint pealing and a loose piece of trim causing a rust spot. However, seems like dealer eager to please a customer and fixing it.
Cracked side windows are almost always an installer problem, if not impact related.
Two of your other problems aren't vehicle flaws, they are accessories or aftermarket...Radio is an easy fix already offered by the dealer and believe me, any piece of electronics subject to vibrations of road and heat/cold can develop a short. Right now I have a Nakamichi tape deck, a JVC receiver, and a television all awaiting repairs, and they weren't being driven down the highway at 100+KPH (61mph) hitting potholes.
The oil filter is an easy fix...switch brands. I suppose one can blame Kia if you are using an OEM filter, but chances are, it is an aftermarket (BD did you say Wix?) painted with Kia brand name.
IVO your dealer offering a loaner, and taking care of 100% of complaints (none left you stranded ?) seems like he is one you want to keep.
I don't have nearly as many miles on my 2003, but have bookmarked this for comparison of items in a year or two.
Hope you resolve the problems to your satisfaction...running back/forth to the dealer is no fun.
I'm not saying it's okay that you are having those problems with your Sedona, but at least your dealer is taking good care of you.
OIL FILTER
Yep, I think the oil filter has all the markings of something made by Wix. Most car-brand filters seem to be made by the actual filter makers - e.g. Ford doesn't make Motorcraft filters - Purolator makes them and badges them as Ford. For the consumer whose vehicle has a faulty Kia brand filter, the blame ultimately lies with Kia. It's up to them to make sure the filter company is producing the filters with acceptable specs and quality.
I used a Kia filter for one of our oil changes but since then it's been Purolator PureOne or Castrol MaxPro.
The one on the right seems to be out out alignment or something. The one on the lest doesn't want to come out.
When I took it to the dealer, after playing with it for 30 min. they finally got the right seat back in and then blamed it on the cold. We garage the van and it was one of the warmest days we've had in months.
This is a safety issue though. My son and I were driving around with a darn heavy seat that wasn't even secured and for the life of me, I couldn't secure the seat.
Has anyone else heard of this? The van is about a month old with less than 600 miles on it.
I've had our '02 EX's seats in and out several times, and occasionally it will take me a good 5 minutes to remove one of them. Slightly annoying. Hopefully your problem is similar or one of not being quite familiar enough yet with the seats, and NOT something physically wrong with the seats.
