I am leaving for work now and will not be able to assist in tracking until I return Saturday, but there is one somewhere in an earlier post here.
Do not "trial & error" it!
Dean.
GL
After dropping the pan, I used a multimeter to check the old and new solenoids. The new one measured about 15 ohms from the connector to the metal body. The old (bad) one measured open (no connection).
Thanks all!
Merry
Search back in this thread, there are many helpful posts, use the search feature to find exactly what you need.
If yours scanned 0750 you need an "A" solenoid.
It costs about $48 at the Ford parts counter. Don't let them BS you.
Follow the many here who have had the same issue.
One of these posts has the Ford part # for the solenoid as well.
Check posts #76 & #110 for more info.
GL
Dean
My dad was a master mechanic. I know how to change oil, spark plugs, brakes, just not transmissions. He is no longer with us. Can anyone help with suggestions. Called FORD and they said that I can't rely on what is on the web
any ideas?
The car is an 01 Focus ZX3. It has been laboring when getting into 3rd gear (~38-45mph?), but this USUALLY happens when going up a hill. Thankfully most of Delaware is FLAT, so it's not always an issue. However, I'm worried that it could become more serious, since I do a lot of long distance driving. Sometimes the car "chugs" or shakes and won't make it past 45 unless I step more on the accelerator or reach flat land. I've read about a solenoid "A" in the transmission being the culprit, but when I talked to a dealership about this they ask me to be more specific, as they do not know which solenoid I am referring to specifically.
Also, my check engine light is NOT on. But it was on at one point when I was having an extremely difficult time going up a mountain pass in PA (couldn't get about 30mph). Since then it has gone off, and Auto Zone states that they will not do a diagnostic hook-up to the computer if the check engine light is off. Can they still detect a problem if the light is off?? :confuse:
Thank you for any help..
My local A-Z will hook up even if there is no light, as I am a regular.
If you tell them the light was on when you left your house and just shut off, they may help you as well.
Keep us informed
Good Luck.
Dean
Haven't done anything to it yet because I just bought it.
Any ideas would be greatly appreciated?
spark plugs. Now, don't let them brake your spark plugs while removing them (they brake way too easy).
cheers mate.
The problem seems to be either my clutch of transmission, but I'm leaning toward the clutch at the moment. A month or so ago it made a brief but loud "crunch" when I put the car into reverse with the clutch completely engaged. A few days later, it acted slightly sloggish when I took off from 1st, but was otherwise fine. That happened occasionally, maybe one in ten or twelve times I drove, for a couple weeks, then the whole thing went south fairly quickly.
Now, it's nearly impossible to start on a hill; the engine will be turning 4500 rms, and the car moves by inches. The tach will flutter going up hills at higher speeds, and I realized by accident a couple of days ago that I can take my foot completely off the clutch while my car is in gear, and it doesn't even notice.
The car seems to go into all its gears correctly; that is when I'm sitting still and go through the pattern, I hear only the normal sounds it has always made, and it doesn't give me problems when I shift any more or less than any other time. The engine still purrs, but it's like I'm driving with the clutch pressed. Usually, after about ten or fifteen minutes, everything sort of mellows out, especially if I stop an pump the clutch.
I wanted to check the fluids, but can't find the transaxle resevoir my owner's manual says should be located just right of the middle, near the air filter. I did check the brake/clutch fluid, and when I got it serviced (around the same time the problem started), they seemed to have filled it to the brim. Still, taking the cap off and putting it back on seems to make it a lot better until I turn the car off and restart it.
Does anybody have any ideas? I'm competent to do minor repairs on my own, and I'm not afraid to get my hands dirty, but if I have to take it for repairs, I like to have an idea about what the problem is and how much is should cost. I have had unscrupulous mechanics try to rip me off a couple times and I know for a fact that doing the homework has saved me nearly a thousand dollars so far! I know the vast majority of mechanics are honest guys, but I'm in a new town and don't know the good guys from the bad guys yet!
MySedai
She called from college yesterday and she couldn't keep her car started...turns out a mouse or a squirrel chewed the wire from the battery to the starter...she just called earlier tonight and the blinkers stopped working and called a short time later and her car wouldn't start again...could be bad battery or more rodent damage.....
I am getting tired of this car!
How many mile on the car??
Original Clutch??
Personally, I would first check and see if there is any pedal adjustment available for your car. it sound as if you are slipping terribly (4500 rpm's only moving inches) This is very bad to do to any clutch and will 'smoke' it.
You fluid-level description seems a bit strange...
Suggestion....I would start by getting a Haynes or Chilton repair manual for your car. This is a source of much better detail for all basic service and repairs, with many pictures to assist. It sounds like you are competent at the basic stuff and would be a good investment of less than $20.
Keep us informed.
You say, "I'll turn on the car and accelerate and it seems like the car doesn't want to go into 1st gear. The rpm's will go up but the speedometer stays on 0."
Is the car moving and the speedo stays at 0??
Can you tell us, mileage of your car, with any recent work done.
Second, take your car to a place and get the codes scanned for free. You may need to call a few places and explain your situation. Have them scan it and look at the codes yourself as they do it, it is not a big secret thing. Details get lost/filtered in translation.
A decent parts store will give you a printout of the codes with recommended repairs/parts all for free.
A speed sensor can cause problems. Most speed sensors now are magnetic, and there is a maintainence item with some of them as they collect a mass of little bits of metal on the tip as the years pass, They can be removed, cleaned, and reused.
If you allow a shop to just replace things until they find the problem, you may be broke by the time they replace them all.
Always start with the codes.
Keep us informed.
Thank you so much for taking the time to answer my question. I genuinely appreciate it.
-Mysti
Thanks for your suggestions. I took it to a mechanic and 3 codes came up this time. One was for the speed sensor, another was something about the computer and the last was the transmission. The mechanic is going to take out the sensors and clean them and go from there. Hopefully its nothing too big. Thanks again
Of course the warranty was 5 years/100,000 miles and I've had the car for 6 years. They said I would get no help from Ford and after reading all these posts I understand. I am for the Class Action Lawsuit!
Any suggestions as to what I should do? Will I do more harm to it if I drive it to another service station? It bearly goes above 20 mph. I really don't have the $3,000+ to fix it. And by the way, they did ask me if I wanted to trade it in!
Can you give more info on your car and current problem? Any check engine light activity at all??
did it just start to act up?
Has it been seeming strange for a while??
Where was it setting when the battery died??
If there is a trouble code, it will reset. Do you have a bad battery??
There is not much more to hurt by driving it, aside from getting stranded if the trans is kaput.
Parked it for a few weeks and the battery died. Was original battery, guess it was it's time. I also saw a post on how the Focus eats tires. My Perrelli tires were shot at less than 15,000. miles.
Also to the person who keeps blowing out their rear tail light, mine it also out. All these stories are sadly similar.
I guess I'll have them put in a new battery and try to get it home. I haven't heard a word from them in about a week. Think they will charge me $100. to put it on the computer even though no codes showed up?
I have had numerous wierd problems over the past two years with this car. Mysterious dead battery; blown anti-theft fuse; alternator shot, new alternator gone bad before the car even left the repair shop; alternator just tested bad diodes, even though battery had just tested 104%; turn and brake lights gone out, although they came back when the engine codes were cleared. I had a new trans put in a year-and-a-half ago. Problems started before that.
The reapairman who drove it when the brake lights went out said he had someone else run codes and it showed the GEM was bad. I took the car to another shop for another opinon and they said they didn't think that was the problem. They found no code showing anything wrong with GEM (actually, two places have told me that). The tranny people say the car has an electrical problem. The auto electic guy I went to this summer says it needs to go back to the transmission shop.
I have a feeling I may try to find a new GEM and have that put in and see if it takes care of the problem. I heard they used to only be available through a dealer, but they may now be available aftermarket. I guess I could also find one in a junk yard. Anyone have an idea on the cost of a GEM?
Personally, I would call around and find a parts or repair shop that will hook up your car to an engine reader for free. They are out there, you will need to make calls. Be straight with them.
Outside of that, the 1st thing I would check the battery (non-running voltage should be 12.3 - 12.6 volts, and running 14 or so volts) and all of the grounds should be checked as well.
Blowing a taillight sounds like a shorting (positive contacting ground) issue somewhere. If the voltage regulator is going out, I would think it would effect all of the lights not just 1 of them.
I am not a Ford mechanic, just someone who shares your pain.
GL & Keep us informed.
Anybody know any good repair shops in the Allentown, PA area?
Keep me posted on your issues. I feel your pain!
Did run in to old service manager told him my story. Said he would make some phone calls and get back to me. I'm not holding my breath about it, but do appreciate his efforts.
By the way the exact mileage is 24,253 and it's a Focus ZTS with a 2.3L. It also needs front brake pads and rotors to pass inspection. I'll see who is having a special and have it done there and replace the brake light bulb myself.
I'll update you on any new developments. No news is good news!
For example there is a transmission diagnostic test that can be done -- it's kind of like a 'stress test' for the transmission. I had this done on my car. I was told they would run the transmission on a lift or place it on a device to watch how the automatic transmission shifts, speed etc. It's been a while but I think it had something to do with testing the TCM [Transmission Control Module] or testing while hooked to the TCM. The test proved the transmission was fine.
But if you opt for testing the transmission I would recommend rechecking for engine codes first. Something might be there. Long shot, but might be worth to look before spending to have trans tested. Sometimes the check engine light will not be on but a code may still have been stored. You can buy a scan tool or go to an auto parts store that offers free scanning of trouble codes.
About the warranty: I was told by Ford (in my case) that if my Manufacturer’s Warranty had expired and if the transmission was found to be broken or 'defective' or it 'failed prematurely', Ford might still replace it.
Quote from website:
"As a starting point, if a transmission repair is needed, the first thing your mechanic should do is hook up a scan tool and test the ECM, TCM and every input, sensor, module, controller, etc. on the car. So many times it turns out that the problem does not require you to replace the engine or transmission, or if replacement is needed, the ECM or TCM transmission control module may be the culprit. So, in essence, you can put a replacement transmission in your car and still have a problem."
"...Ask the technician at the repair shop checking out your car if the electrical system has been scanned or is going to be. If the answer is anything less than “right now”, take your business to another shop."
Source: http://www.gottransmissions.com/blog/transmission-control-modules-tcm/transmissi- on-repairs-check-engine-control-moduleecm
I have read some info on this forum and in other forums. The problem could be a worn lockup clutch or solenoid issues. I don't think there are other issues, because I have figured out how to defeat engagement of the lockup clutch. When I do that, the car runs smoothly under all conditions. There are no scan codes being set by this problem.
How did I defeat engagement of the lockup clutch? I added a resistor in series with the thermistor that measures the ATX fluid temperature. With a 70 K ohm resistor in series, the engine control unit thinks the fluid is cool, and doesn't let the lockup clutch engage. The line pressure seems higher as well, so the shifts are firmer.
However, I don't want to permanently defeat the lockup clutch and give up good gas mileage. So I am wondering if anyone has advice on how I could further analyze this problem. I have read on the forum that solenoid B controls the lockup clutch, but that solenoid C also plays a role. I thought that solenoid B would be either on or off and could not therefore cause the jerky feel. But it is hard to know. I have not been able to find a good technical explanation of how the engine control unit controls these solenoids for lockup clutch control. I have a DVD of the "factory" manual, but even it is not clear. Throttle position, MAF, temperature, etc. all seem to play a role.
If I thought that changing some solenoids would fix the problem, I would do that. I am not so sure about getting a new torque converter or re-built transmission installed. That would be expensive, probably more than the car is worth.
DuncanFocus
The check engine light has not lit up. I replaced the "A" solenoid tonight & that did not solve the problem. Does the car have to driven more than about 10 miles for the new solenoid to make a difference?
The car has 145,000 & also has a couple of other other issues (bad rear bearing & it needs front brakes & needs new tires). I'm thinking that it may be time to get rid of the car, but other than these problems it's really in great shape. I had the A/C, the timing belt & the rear brakes\cylinders\drums\lines replaced this summer. That wasn't cheap, but I was planning to keep the car for awhile longer. Now, heading into winter, I'm not so sure I wantr to keep it given the issue w\the transmission.
Does anyone have any insight inot the transmission issue I'm having? Can I fix it myself (cheaply), will if get worse if I don't fix it? How long will it last with this problem?
Thank you for reading & I look forward any replies!
They found that one of my engine cylinders was only firing about 73% of the time. They suggested replacing the spark plug wires & the coil (for about $470), which I had them do. The car no longer bucks! And it has a lot more pep!
I hope this helps anyone else having this issue.
I didn't see too many follow-ups indicating how the fix worked and how long it has lasted. Hoping this fix works!!!
By the way, other car is '05 Scion xB with 138,000 miles and NO major problems whatsoever... FYI.
Other issues yes, but not trans related.
Dean
GL
D
