Another item of interest a while back when the ABS was put on the TLC. There was a government and insurance push to encourage folks to buy products WITH ABS. They offered insurance discounts for vehicles having ABS. While I did not buy the TLC for the ABS mode, it happen to come new and so... Not even 5 years into ownership the insurance company renegged on the insurance discount for ABS citing amoung other things that there was NO statistical correlation showing ABS equiped vehicles as being statistically safer.
The ABS point is correct. Please don't get me started on insurance companies though. We all know they will do all they can to justify raising rates or denying discounts, independent of anything to do with safety. It could be that abs became so common that like seatbelts, bumpers, padded dashes and safety glass there was nothing to "reward" you for. I have read that some drivers have assumed that because the car has abs they can go faster and still be able to stop short, giving creedence to the insurer's argument that it results in no statistical lowering of accident rates.
What isn't arguable is the actual benefits of the head protection side airbag systems. There is now both crash test and real world data that shows 45% and over reduction in death in side impacts.
http://www.hwysafety.org/news_releases/2003/pr082603.htm
I, like you, think this is a very safe car. That's why I got it. I just wish someone would prove it in this standard manner. I assume it is about cost and bureaucratically unjustifiable based on the low numbers sold.
In regards to the ABS, even with the misconception that you have noted, most folks don't even have a clue that its main reason for existence is to be able to steer with so called full lock up of the brakes. (without abs, obviously) ABS will continue to modulate the brakes so there is NO lock up.
However as you infer, ABS does not counter act the physics involved! While one should keep in practice deliberately functioning the ABS and doing the steering to maintain the "feel"; the real question is how many folks % and/or number actually do this enough or even at all?
Any ideas or suggestions would be most welcome.
If you crawl under your rig and locate the front end of the rear drive shaft then you should see a "cross member" in that area. (this is just ahead of the gas tank) Look on each side, toward the outer portion of the under carriage and you should be able to see a large nut--takes a 32mm socket--this is the adjustment for the TBars. If you're directly under the adjusting nut, the TBar will be a few inches to the left of the nut on the left side and a few inches to the right on the right side. The bars are about an inch in diameter and you can see them quite clearly. Let me know if you locate these nuts. Once you see them, and "study" the layout under there a bit, I think you'll have an idea of the adjustments that you should be able to make.
I've raised my front end via "twisting" up the TBars as I've installed a lift and it's pretty straight forward. I'd be interested in knowing more about the shims etc as this whole issue about adjusting the height of the IFS cruisers is a bit of a hot topic for those that would like a little more ride height in the front.
As stated before, the main problem is probably some comtamination between the brake shoe and the braking surface. Easy to clean out for the do-it-yourselfer.
On the other hand, if you have been using it for braking and not just parking, there may be some premature wear.
There was a TSB on the 98's for excessive parking break noise when backing up: seems that it was not releasing quickly enough. Small chance that that is your problem?
HiC
HTH
I pulled over, ran back only to see the guy climbing out of the ditch asking me if I had gotten the other driver's license plate number. He seemed shaken, but as far as I could tell uninjured.
I checked into Land Cruisers the very next day, but being still in college at the time they were out of reach. Today when going on a road trip, I have no doubt that I'm driving my family around in one of the safest vehicles one can buy.
In this case, too, he was sliding sideways (rotated 90 degrees) for quite a ways on the wet surface (I can still remember thinking how odd that looked) before then flipping at pretty good force. Taking pictures of Explorers after a single roll during the Firestone fiasco as a comparison, I can say the structural rigidity of the Land Cruiser is quite amazing. Remember that he rolled it three full times on road surface, not on some softer ground that would give in and cushion the impact..
Maybe it would be nice to see the "official" 5 stars, but if I had to be in an accident, I would choose an LC (preferably not my own) over most 5 star rated vehicles in a heartbeat. Think about it: Would you rather be in a Ford Windstar? (That's 5 stars for you right there!)
My dealer finally got an allocation for an 05 with the rear DVD and XM radio. Black w/Ivory.
Now my wife is getting cold feet. Arrrggghh!
I made the mistake of telling her that I heard (on this board, of course) that they might be changing the style for 06 or 07 and now she's thinking we should hold out. I am really not sure what to do; naturally, our salesman is down-playing any changes and saying that they would be "minor" because it is such a classic style, etc., etc....
Maybe I can sell her on the safety aspects that have been discussed here lately. I mean, were driving a Yukon XL right now and that thing is a handful!
http://www.pbase.com/drexx/image/35331210
I plan to stay with the stock size 275/70 16
The procomp A/T's are severe weather rated, any experience with them. Any recommendations?
http://sdunion.p2ionline.com/SpecialSections/popup/index.aspx?web- - storyid=7311842&AdgroupID=27894
• LX 470: A global redesign of the Land Cruiser platform is slated for March 2005. But the LX 470 might not migrate to the new platform. The redesign for the United States might be delayed until the 2008 model year, when the LX 470 could become a bells-and-whistles version of the Sequoia.
• Land Cruiser: On paper, the SUV is too pricey for the Toyota line, but the nameplate’s brand equity is too strong to kill it in the U.S. lineup. Given the typical seven-year truck cycle, the global redesign should come next spring, as a 2006 model.
Should be an interesting Spring 2005. I think the picture posted above looks more like a redesign for the Sequoia, but who knows. If that is the LC, I am going to the lot tomorrow to purchase an '05.
I live in northern MA, drive to northern NY and VT often in the winter. Primarily on road and drive an LC 2000. I surfed the web last night and have come up with a couple good looking alternatives. First, as a primarily road car looking at ice, then snow traction which has led me toward a dedicated ice tire.
I think i would be happy with the Bridgestone Winter Dueler DMZ2. Not sure I need to spend the extra ~ $30-40/tire for the Blizzak DMZ3 (a little better at hydro evac, not much). Also, stipping a Revo AT looks like a good way to go, just a $$ issue, but would give a better true off road tire (not worth it for me though).
Anyone running the DMZ2 on their LC?
My second dilemma is whether to replace it with another LC (would be our 4th) since there is so much talk about changes for 2006, or to consider the GX470. Our kids are mostly grown, so we usually just use the 3rd row for short drives. I don't like the swing out back door, but the Lexus warranty and service loaners are a plus. Has anyone taken both for a test drive?
The electrical system was listed as "worse than average."
Does anyone have any feedback on the electrical and brakes on the 97 model?
It is Black/Ivory, all the usual extras plus C7 Convenience pkg. and XM Satellite radio.
We ended up at 57850, which is decent I think. This is only the second LC my dealer has sold this year.
I decided not to trade the Yukon because their offer was very low and our salesman admitted that I could do a lot better on my own.
It was a pretty nice buying experience. Our salesperson actually demonstrated knowledge of Land Cruisers, which is rare in my experience.
The only thing was the business manager's sales pitch for extended warranty. That is always a turn-off for me.
It is a great car; I can't bring myself to put the kids car seats in just yet... I even joked about keeping the Yukon to haul the kids in, but I know that isn't going to fly.
Congrats on your LC - I've always wanted one, but couldn't justify the price.
Cheers
Pat
An extended warranty may be a good deal (Detroit News)
The article is subtitled:
"On the other hand, you could be throwing away your money due to better product reliability."
I always did like subtitles :-)
You got it at a good price. The extended warranty is always a tough decision when you are buying something so reliable.
Here it is:
USA Today
AIG is my car insurance carrier, fwiw.
Below is an example (not auto!) of how insurance companies weedle out of claims!
Dahlin case marks landmark ruling
Dahlin was a regular international for Sweden
Lawyers representing Blackburn Rovers have won a preliminary issue over the case of former striker Martin Dahlin.
Dahlin's Rovers' career was ended by a prolapsed disc in his back in 1997 and Blackburn are looking for a £4m-plus payout from the player's insurers.
Laytons Solicitors have won a ruling from judge Justice Moore-Bick that the injury was not just normal wear and tear but was "abnormal degeneration."
Former Sweden international Dahlin's case will be heard next April.
Daniel Izza, a partner with Laytons, says the degeneration issue is vitally important to clubs and their players.
"For the past 10 years the clubs that thought they had a claim have been warned off as a result of insurers relying on a very wide interpretation of the clause," Izza told BBC Sport.
"It does give clubs the opportunity of considering claiming from the past six years when similar claims in the past might have been rejected by the insurance companies.
The Warranty Gold contract holders with bankruptcy claims would likely agree with that!
