I'm approaching 2.5K on mine and want to change the engine, tranny & diff oils over to synthetic.
Jim M.
While you would undoubtedly get a superior lubricant, your cost would go up 3-4 times. While I am one of the ones that go the 15,000 with absolutely no problems, in my mind at the 3750 cycle, you are consuming money at a faster rate without "bang for the buck".
API SJ 5W-30 for about $4.49/qt. More than
Mobil 1. Pennzoil spent 250 million to improve
their so called crappy sludge forming oils...They
developed this synthetic oil for NASA for use in
space. Hmmmm, I ve used their oils for many years
without any problems. Pennzoil says on the bottle
to change every 3,000 mi under severe conditions ie stop n go, short trips, high temp conditions...
They also have a reg mineral base oil with PUREBASE that maintains an almost clear oil compared to the others at the 3000 miles.
Just passing along some info I came accross on www
that may be of interest. I may prefer to go to
Mobil 1 for my first oil chg on my '00 Chevy
C2500 5.7L Vortec at the 3,000 mi mark. I intend
to keep this truck for rest of my life. Am
54 year old babyboomer. Still thinking about it.
I use Amsoil but Mobil 1 a great oil.
Also, a little off topic, the owner's manual says that I must use high octane gas, but I wonder if that is really necessary. I have to commute 120 miles round trip to work each day and would love to save a little by using the mid-grade gas. Can I do this without fear of damaging the car?
On your other question, you may want to use the Topic Search feature on the left side of the page for Maxima - you should find some Maxima topics in our Sedans conference where owners are hanging out who may have even already discussed this question.
Pat
I, for one would be curious as to your stats when you find out and care to post. My guess is that is is about as clean as a whistle AND probably 20-40% left on the oil use cycle. (in mileage terms 15-20k) By the way, I use 5w-30 Mobil 1 in all of mine.
Thanks in advance.
I appreciate all comments.
use the weight number your car manufacturer recomends.
In most cases it's 5W30.
In extremely cold climates - 0W30.
10W30 will provide the best oil stability and engine protection.
i use 10w30 in summer and 5w30 during winter ..just what the owners manual says ..inspite of the dealership technician saying that its safe to use 5w30 year round.
i guess i'd rather trust the guy who wrote my manual instead of the technician.
I find it amusing that after years of bashing blended oils, Mobil now makes a synthetic blend.
I also think that Synthetics do not require the high amount of viscosity index improvers to achieve a wide viscosity range. And with synthetics you don't need to be as concerned with high and low temps. Most 5w30 synthetics have Flash Points of 400-450 deg. F. and Pour points of -35 to -65 deg. F.
Dennis
DAVE
Mobil 1 ads say "Nothing outperforms Mobil1". I wonder if Amsoil will try to sue them.
Dave, thanks for the tip and stop shouting ;-).
Dennis
What is one to believe - the advertising budgets of the well-knowns (Mobil 1 and Amsoil) or the testimonialsand documented claimsms of the lesser knowns (Redline and Royal Purple)?
Jim M.
http://www.synlube.com/synthetic.htm
$2.85/qt. for Mobil 1 synthetic?
Sounds too good to be true.
John
In your case, you are probably wise to do that; but consider this.
In two vehicles I am familiar with, (there are many more) the MB E320 and the Chevy Corvette, both recommend intervals of 15k. In the case of the MB E320, the dealer guarantees periodic maint. And of course, the Corvette being a GM product, the buyer is on her own.
For the cycles you are talking about; the conventional oils will work just fine and you will only use up between half and 3/4 of the useable life, as opposed to synthetic which will have between 80% on up left.
You need to do what you feel comfortable with, in my case, pulling the weight I do with my van, I felt the Syn oil offered added protection under that severe load/stress. I also use it in the rear diff (rebuilt 12 bolt w/3:73 and Posi), but I have stuck with regular trans oil since it has 120K on it, and it has performed perfect, and to keep it that way, I have installed 4 transmission coolers...runs around 170 degree's pulling the load.
John
Best price I can find is at Discount Auto Parts for $4.39.
Rbink1 - I'd buy a couple of cases.......
Jim M.
What you guys think. That oil okay?
Should I switch to full syn. oil or stay with Quaker State 4x4?
I'm not real hard on my truck and the temp. here rarely gets to 0 degrees. Usual cold weather temp. is 20 degree (usually coldest).
Thanks for info....in advance.
John
You'll find if you read back a ways in this topic that almost all of us posting here are partial to either Mobil 1 or Amsoil, with some going to the more exotic synthetic racing oils.
Personally, I'm using Mobil 1 in the engine with 7.5K changes until the warranty is out, and Redline 75W90 in the trans & diff.
The synthetics really minimize the normal wear and reduce heat buildup due to friction. These are you're main objectives with any lubricant.
However.....any good oil and filter, changed regularly within the applicable manufacturer's maintenance schedule, will protect the drivetrain. If you've the funds, stick with the best lubricant you can afford.
Jim M.
Plus, Miami is more expensive anyways... even toilet paper probably cost $5 a roll.. kidding.
tks in advance !
i live in canada and mobil does not sell its oil filters here ...just syn oil. bummer !
i tried ordering the filter through their e-store (www.mobil1.com) but they only ship within the U.S.
i had to tell my brother (who lives in california) to buy it and fedex it to me.
sniffy: try http://members.nbci.com/minimopar/oil.html
and http://members.nbci.com/minimopar/oilfilterstudy.html for filters.
Anyone know where to find a Mobil 1 catalog?
Also, I saw the K-Mart ad and purchased 5 qts - 4 for the upcoming change, and one for down the road when I have to change out that Premium Plus filter at 5K due to lack of a good Mobil 1 filter.
Jim M.
goto www.mobil1.com, select the e-store option, click on high efficiency oil filter and enter your make and model ...btw i checked and they dont have a filter listed for the '00 miata, so i checked for the 1999 model.
hope this helps
** nikecar ...tks for the info - although it's useful for comparisons between different oil filter brands, it still falls short in comparing different syn oils - all he says is that castrol and mobil1 are good.
i was looking for a side-by-side comparison of mobil1, castrol, valvoline synpower, pennzoil etc using different characteristics.
tks anyway !
