This was an extremely well kept car, a hoot to drive, and I'm interested. Dealer is annoying. I made an appointment for a PPI (you'd be nuts not to do a PPI on a Mazda RX-8) but dealer refused to hold the car for me until such time. Wouldn't even take a deposit, and kept repeating how the price is "firm".
Great. He can peddle it elsewhere. Did he think he was sitting on some kind of gold mine?
If the car is still there when the PPI comes up, I'll still take it to the shop.
I found the car to be very comfortable and handling and braking are first class for this class of car. It made my Mini feel old and worn out. (which, in fact, it is). Nice, smooth short-shifting 6 speed, and if you watch the rev counter, it moves along smartly. If you don't watch the rev counter, the car feels dead below 4000 rpm.
Nice new set of Michelins, nice paint, clean topside and under, and good service records.
Soooo, we'll see.
Not a car to buy in haste or in the heat of the moment. Someone else can roll the dice if they want it that badly.
Spoke with two Mazda rotary specialists of some renown, and they were both nice enough to assure me that I WILL have trouble with this car. I should count on it.
Well, yeah, okay. I can handle this.
https://www.thetruthaboutcars.com/2018/10/junkyard-find-1993-honda-civic-with-325k-miles/
"As the owner of a very battered fifth-generation Honda Civic, I’m always aware of examples of Honda’s 1992-1995 subcompact when I spot them during my junkyard travels. I see plenty of these cars with odometers showing better than 300,000 miles...."
I test drove one when they first came out. Quite fun.
Did the specialists specify the expected problems?
First, if the seller won’t let you have it checked out, he’s hiding something. Can you at least run the vin#?
Things to know....
-they use oil....low mileage, high mileage, doesn’t matter. They use oil.....about a qt every 2,500-3,000 miles is normal
-the early ones, ‘04/‘05, tended to flood. Best way to keep that from happening is to never start and shut it down immediately when cold. Plus, a quick rev before shutting it down after driving it usually clears the excess fuel out of the rotary chamber so it won’t flood when you start it, again
-they are meant to rev......to redline (9K).....a lot. Don’t be afraid to do that....as often as you can
-The A/C is weak. Nothing wrong with it. Not sure why, but Mazda just put a weak compressor in it
-make sure the battery is relatively new. Mazda OEM batteries were weak (again, not sure why). So, if the battery was replaced with a Mazda OEM battery, swap it out immediately to put the most powerful battery in it that will fit. Personally, I think this was part of the issue with the car flooding. The starter turned so slowly because of the drain with a weak battery, unburnt fuel would settle in the chamber without clearing
The rest.....you know the drill. If it shifts good (and RX8s should shift as good as anything on the market), if it brakes well (it should of the brakes are in good order), and it looks good (no drips, runs or errors), you’ll have a fun car on your hands.
Let us know how it goes. There are only 9 moving parts in the engine, and it’s small. So, you could become relatively profficient in doing your own mechanical work.
When I first noticed the trend I was taken aback (the OEM battery on my Volvo went 9 years/147K miles) but I found plenty of threads on Subaru boards about weak OEM batteries in the Outbacks. And Acura has fairly generous warranties on any replacement battery, but not on the original!
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
The fintail, which has a generator, got 7 years out of its last battery, and it probably went prematurely due to a fuel delivery issue which forced replacement. The current one is 4 years old and doing fine.
Price is...well....debatable @ $6995---but most of these you find are rats, so when you see one nearly pristine, in the perfect color, and if it flies through PPI, I don't see a lot of wiggle room. I think the fair price is $5500 but man, the dealer is digging in his heels here. I might just walk at $6995--but I have seen really nice ones sell for more.
It's faster than my Mini--about Porsche Boxster speed (but not Boxster "S")---so nothing spectacular there--probably in good tune 0-60 in 5.9 or some such.
No sunroof but I can live without it. Most important, I am totally comfortable in it. I love those little back doors.
As others have noted, this is a very risky purchase, but then, what 10 year old car isn't? I could pay 3X as much for a Cayman and end up with a worse disaster (although the Cayman is, historically, a more reliable car).
Hey, that's kind of interesting, now that I think of it. A blown engine on an RX-8 just about totals it at $6,000, and a blown engine on a Cayman just about totals it at $18,000.
PS Back in 2003 C & D measured 0-60 in 6.3. But since that's a few years newer Mazda probably improved it by then. So you're probably right on in terms of the speed. Sounds good to me.
https://www.caranddriver.com/reviews/mazda-rx-8-first-drive-review
https://www.acuraturnersville.com/inventory/used-2018-acura-tlx-3-5l-v6-wtechnology-package-front-wheel-drive-sedan-19uub2f56ja001533
If it's nice....I mean really nice, I'd throw $6K at it. Wave 60 Benjamins at him and see what he does.
0-60 isn't the RX8s forte. Thinking high 5s to low 6s, 0-60. Same vintage 350Z will take it off the line. But, it's fun to zing around in, and as you say, it's a fun drive.
Rotor seals are the things that will fail in the RX8. Won't know about those unless you start tearing it apart. But, if they seals are leaking, you'll know it, as it will belch smoke out the back, just like a piston engine. But, if it's as clean as you say. And the paperwork proves that it's well cared for, I don't think it will be any worse than any other 10 year old car.
Have you driven it, yet? If so, how'd it feel? Torque comes way high into the rev range, so you have to rev it to find it. Power steering should feel firm and direct. Shifter shouldn't have any sign of "hanging" on to any gear. Should shift easily. Brakes should fee firm and linear.
Wait.....you know more than me. I'm not saying anything you don't already know.
I also found a 2011 (one of the last ones) with 59,000 miles (so about half of the other one) but again with a whopper price on it of $12,999. This is from a BWM dealer. I mean....get real, dealer!
Sure, a low miles 2011 is worth more than a higher miles 2006, but double? I don't think so.
The 2011 is fresh meat, so I'll let it sit for a while until the dealer gets tired of hearing crickets.
I found a nice 2008 Boxster for my friend--blue w/ tan, and automatic (which he wanted). The tan interior really helps to dress up the early Boxster's dreary and old-fashioned interior. Not sure I could ever live with a gray Boxster interior from that vintage. It just looks....well....cheap. The tan color warms it up, I have to say.
Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
Impressive for a car that is not really small, in is very comfortable and reasonable power.
Please let me know trade in price. He is retired Chrysler foundry employee so has employee slip for new Ram.
he didnt know trim - he’s 74+ yrs old - what are his choices?
https://www.cars.com/vehicledetail/detail/753165030/overview/
The one you find looks very nice. It's too far away for me (Riverside in L.A.) but I do have friends down there. But still, it has to go to a rotary specialist for a PPI. Low miles doesn't give any assurance on these cars.
One thing I like about "mine" is that it has no spoiler and spankin' brand new Michelins.
another problem is that that Riverside dealer has baddddd reviews on Yelp.
http://www.fantasyjunction.com/cars/2165-BMW-M6-3.5 Liter DOHC Inline-6?utm_source=M6,+964+Carrera,+Giulietta+Sprint,+Giulia+Super+1600&utm_campaign=E24+M5,+964+C4,+Giulietta+Sprint,+Giulia+Super&utm_medium=email
Very pricey indeed, but most of the ones you find are either rust-buckets, or flogged to death, or modified.
Rough calculation--he put about $7000 in the car at least in the last few years.
