Dodge Dakota Accessories and Modifications
Just a quick "amen" on your perspective of the cat-back tests... MPH is relatively meaningless. Gains (hp AND torque) within specific RPM bands (in whatever gear) hold some water. And a nod of agreement that a COMPLETE install (header-to-tailpipe) is the only way to go for the max... Too bad about that Catastrophic Converter... Takes all the fun out of it!!!
When I do maybe I should keep it to myself...AMEN..
Allen-
FIRST and FOREMOST... I for one THANK you for passing along the Peterson numbers. And while I questioned the test methodology, in NO WAY was that a reflection on you (REMEMBER! I'M the guy who fumbled with the freakin' light bar!!).
The fact is, if all of us participating in this forum were in total agreement on everything, what a boring place it would be!!!
SECOND -- Friendly debates aside, I've gained a LOT from hanging around the QC boards... It's clear that we're all pretty attached to these infernal trucks! Our tastes and priorities may differ... But ultimately, I'm convinced that the board accomplishes what a good one SHOULD: Making the ownership experience more satisfying for all.
FINALLY -- Does anyone have any experiences/opinions relative to auxiliary drivng lights? I'm in a quandary... Stuck between whether I should plunk the $200 down on a set of Ion Crystal Fogs or go with Super-White Driving units. It's that time of the year here in Michigan... Dead deer scattered along the secondary roadsides. Not sure whether the additional peripheral visibility with the fogs would be better than long-range with the driving units, or vice-versa... Any input would be appreciated!
I'd love to see some insightful post from others on this subject.
Want1bad: More tests results, do tell..Maybe You know something that Petersen's and I don't. What do you have?? Have you thrown your rig up on the dyno? I thought not. Until you or someone else does..Well maybe you get the point.
Allen-
RECEIVER TIP -- A quick thought for those out there who are constantly slipping a hitch bar in and out of the receiver, and dislike the looks of the receiver all crudded and rusted... But who are as lazy as I am when it comes to "details"...
Some steel wool, a bottle of rust converter ("Extend" or similar) and a can of rubberized rustproofing can take care of the situation for about 5 years (as it did on my Ram). When the black parts are sufficiently ugly, wash & steel wool them, schlepp some paint thinner or other degreaser in there, dry it, then swab on a coating of converter (I use old, soft toothbrushes).
Let the converter dry, slide a piece of paper in between the receiver and bumper as a mask, then spritz on a light coat of the undercoating. If you want to go "show quality," do the same to the hitch bar. It looks good, you don't have the usual metal-on-metal rust problem, and the treatment can be repeated at least 4-5 times before any serious paint/rust stripping is required.
If you go with long range lights take time to get used to them. It sounds stupid but it is very easy to drive way too fast when you have good long range visibility at night.
Course as I have a brush guard I can have both :-)
Mopar has a Spare tire lock kit which consists of a replacement part for the truck and replacement part for the jack kit. You lower the spare, pull a retaining pin, remove a metal tube, insert new metal tube, replace retaining pin, raise spare tire. The replacment tube has a star shaped key end, much like locking lug nuts, and a corresponding keyed tube that mates up which is part of the jack kit. $37.50 from the dealer.
No extra keys to add to your keyring, just use you jack kit normally with the replacment part.
I installed one on my truck this past weekend in about 10 minutes. Also gave me a chance to find out how the spare tire raise/lower/store system works. The kids enjoyed the opportunity to crawl under the truck.
I'm sure if someone really wanted the spare tire, they could still take it, but this will make it a little more difficult.
I've decided to go with #2... Piaa 910 series 110W Ion Crystal Driving beams, mounted at bumper height to the brush guard/light bar, with remote wireless switch velcro'd to the steering wheel hub for quick shutdown in case of oncoming traffic.
So far, my "bag record" is exceptionally low -- Only hit 2 deer in my 12 years out here... Hoping to hold it at that while I have the QC.
EXHAUST -- The Borla cat-back went on this morning... Very deep and mellow outside the vehicle, but aside from a more aggressive tone during acceleration, virtually the same as stock at all cruising speeds from inside the cabin (thank goodness!)... Exhaust gas temperature at the tailpipe is a good 100+ degrees higher than stock, indicating that not as much heat is being "bottled up" in front of the muffler... Anxious for an impression of any power gain and particularly mileage numbers once the computer's adjusted to the altered flow.
On the other hand, sifting through the information and doing some reckoning of the information that Allen provided did result in some enlightenment. Thank you Allen for the post.
Towcrazy2: If you want to know the truth deer is the real reason I installed the grill/brush guard. Hell thats the only way I'll get one this year. I'm getting too old to sit out in my stand. I hate the cold....Whish me luck??
Allen-
You've got the "big honking" brush guard, so I wouldn't be at all surprised if you could punch one without damage to your bumper or hood... With the light bar, I have to err on the side of caution.
So far, my "hits" have been limited to one in an aging Toyota and one in a '90 S-10 pickup... But it's a problem serious enough to give some serious thought around here.
A friend was out one night last October... Accustomed to the 'burbs, and a rather aggressive driver. I cautioned him about the deer hazard before he left for home... He answered with the usual "no problem man!"
About 10 minutes later, he gave new meaning to the term "fresh venison"... Like the taste of fresh (somewhat hairy) venison flank steak, seasoned with a dash of windshield glass.
I do enjoy fishing, though!!
Fishing, well as long as it's not ice fishing. HEHEHE..
Allen-
Elderly neighbor lady is housebound... Called and asked if we could get here a particular take-out order... I volunteered... Went out to pick up the order.
Drove SLOWLY (15 mph) down the private backroad to her house, then slowly back... On the way out, a doe popped out of nowhere... I was within a foot of being totally stopped when she ran into the edge of the front bumper, deflected off the light bar, and disappeared into the woods.
No damage whatesoever to the truck, though I'm sure she must be a bit sore this morning.
Self-fulfilling prophecy???
Bookitty
Glad your ok..
Allen-
The 77 degree spread give me the peripheral vision that I need. I don't drive that fast to need "flamethrowers". All I'm looking for is that retina "bounce back" to know where they are.
Understand that the dealer-applied sealant is one of several so-called "services" that dealership insiders refer to as "Rust & Dust" add-ons that do little more than beef up the gross margin on a new vehicle (thereby beefing up the salesperson's commission).
Because of the relatively skinny gross profit on vehicles these days, some dealerships really push the sealants, scotchguard, undercoating, etc. to punch up margins. But the fact is, the real VALUE of these products is marginal at best. For example, in the case of undercoating, I believe it was Consumer Reports that indicated improperly applied undercoats could actually promote rather than prevent rust by allowing salt-laden moisture to become trapped between the coating and steel underneath.
I could go on about these margin-boosting "services"... Credit Life Insurance (called "Choke & Croak" on the inside) is another good one... Suffice to say, you're better off buying good-quality polishes and waxes, and taking care of that beautiful black paint job yourself.
A final note -- DON'T use ANYTHING on that paint for the first couple of months... Just hand-wash it and chamois it until the paint's had chance to fully cure.
Please take this simply as one man's opinion... Good luck!
I'll be using a superfine polish (not wax), buffing it, then rinsing the truck onece more before applying the wax... Just an added step to assure that all surface dirt/impurities have been removed prior to waxing.
EXHAUST -- I've had the Borla on for about 150 miles now, and love the system! One interesting note... Immediately after the install, my idle speed jumped nearly 200 RPM... After 100 miles, that condition corrected itself, and idle is back to normal. I suspect that the computer is beginning to "understand" that something's different down there underneath.
As for the paint sealer, I'm with Towcrazy, stay away from it. I used to work at a Dodge shop and those extras, if even they are actully performed, just line the dealers pockets. You are much better off using that $250 of a GOOD right angle polisher ( not the cheap polishers found at Sears,Western Auto, ect.) Milwaukee,or Porter-Cable, or Bosch would be my choice. Practice with it, and with a good quality ( Meguires pro line) wax, spend some quality time with your Dak.
My 01, QC is Black/Silver. There is nothing prettier than a CLEAN black truck. There is nothing uglier than a bunch of swirls.
So do you use a straight line when applying & removing the wax/polish, or what?
I suspect that the reference is to a system such as K&N's Filtercharger Injection Performance Kit, which eliminates the stock airbox and feeds directly to the MAF ("Typhoon" is a "pretty" version of the same).
Unfortunately, last check by phone with K&N revealed that they don't have a Filtercharger kit part number for the 4.7 or 5.9 QC yet... Something about relocation of underhood components on '00-'01 Dakotas. They said it was coming, but not WHEN.
RELATED SIDENOTE -- K&N and Borla are either properties of the same company or have a joint venture agreement for intkae/exhaust coordination & kits. They carry the same "million-mile" warranties, use the same owner registration & feedback marketing mechanisms, and Borla includes repackaged Filtercharger kits as a part of its expanding "Powerset" exhaust/intake line. Unfortunately, the Powerset is currently unavailable for the Dakota (though it IS listed for the '98 Durango).
Chrysler, Ford and others have used Harley-Davidson as a "benchmark" for its outstanding P&A sales and marketing. They've spent a LOT of time in the H-D stores and in Milwaukee observing and picking brains.
It so happens that H-D offers a low-restriction intake kit utilizing a trick air filter backing plate and 50-state emissions plumbing COMBINED with a K&N rechargeable air filter. I've installed one on each of my bikes, and they work GREAT with proper carb jetting and exhaust system.
With that in mind, COULD IT BE that Mopar is actually getting into something like that! I'd still be surprised, but would like to think that's the case!!!
Also where is the best place to install it. Behind the driver's seat?
Enjoy this site. Lots of great info.
"http://shop.store.yahoo.com/wyckoff-chrysler-parts/index.html"
http://www.hitchhand.com/features.html
Here are a couple of sites for racks and stuff.
There was a fella who was looking into various racks to carry his 17' canoe. Scroll back and I am sure you will find his solutions.
Ron
Springfield, VA
Did look at Yakima racks the other weekend. Would be about $300, rides on the paint, caries only 150#. Still looking.
Intake system is by K&N, I assume as a K&N cleaning and recharging kit came in pkg.
Cat-back makes a 5.2 sound like a RT 5.9.
Probably the same system as the pipe angles and exit angles are the same.
Be advised that the intake system does create a little more noise under the hood ..even at idle.
1. I am planning on removing the decals from the tailgate using the hairdryer/plastic spatula technique mentioned elsewhere in the forum. Will this work for the plastic badges on the truck as well? I intend to remove all of the badges with the exception of the one on the hood. This would include the "DAKOTA" lettering and "SLT" badges on the doors, the "Quad Cab" badges on the rear cab, as well as the "V8" badges on the front fenders.
2. In looking at the various options for bed caps/covers I am considering the LS II tonneau cover from ARE. Can anyone comment on the ease of removal/replacement of the cover when you need to haul something without the cover? I am also interested in any opinions from those who have the new power lock feature of the LS II.
Thanks...
