I am NOT a mechanic by any means, so please stay with me.
Wife owns a '94 Honda Civic, 1.5L which just turned 30,000 miles. Friday night she told me the car was not acting right and blowing white smoke from tail pipe ... she said it started doing this after it had warmed up a bit. Yesterday, after car sat all night, I started it up and drove it up the road a bit. Noticed within 5 minutes or so that the temp gauge was up near the top red mark ... also at that time the car started hesitating etc. and the bright white smoke then started to come from the tail pipe. Got car right back home and shut it off. No warning lights came on, only the temp gauge showing overheating ... the radiator fan did NOT activate ... when puffing the bright white smoke from tail pipe, it smelled like antifreeze ... noticed also that no heat was being produced thru vents. There IS coolant in the plastic reservoir and radiator showing OK on the marks ... oil and transmission fluids fine also.
Before I take it in for repair, does anyone have
any idea as to what MIGHT be the problem???
Any and all help will be greatly appreciated.
Thanks ... Bob
Thanks ... Bob
Check the level of coolant in the radiator, instead of the overflow reservoir.
Thanks again ...
de Bob
Stuff happens.
We had a 1979 Datsun 310 with a 1.4ltr? 4 cyl.
It lunched the head gasket around 30k miles.
Perhaps the new radiator cap is bad? I can't see how this system is getting overpressured!
Any insights would be appreciated.
Which hose/s are bursting? The radiator or heater hoses. Is it the same hose each time? How long after a new hose is put on, that it bursts?
The radiator cap is working by your description.
Maybe the thermostat is bad?
Maybe something is getting clogged up like a heater core or the radiator?
I would think it would take great pressure to burst a hose. Hope it is not a bad head gasket which is allowing the compression force of the engine into the cooling system.
Good luck
Just got my 2000 Honda Civic LX with AT few days ago. The roaring sound during acceleration makes me crazy. I Just talked to a Honda service and I was told this is probably by a logic system installed for going up/down hill but this happening during normal drive on flat road. I will have a service to take a look but is anyone experiencing the same problem or this is normal.
My suggestion might be a little late but ....
Before I bought my '98 Civic Honda, I owned a 12-yr-old Subaru. As the car was old, things were breaking down. When I started having to replace hose after radiator hose, a mechanic told me I shoulda replaced all of them a while back and all at the same time. As soon as one hose ruptured and was replaced, he said, another would burst. And sure enough, that was what happened. Something to do with pressure and worn-out hoses.
My Subaru also had a radiator that needed replacing because some of the rusted flukes had been bashed in by a clumsy mechanic (who didn't bother to tell me about his gross stupidity) a while back. No doubt that was part of the problem, so was the thermostat that quit.
You might also want to check the thermo resistor, or whatever it's called. It looks like a spark plug and it gauges the engine's temperature (or high heat). If it needs replacing, it could give your engine a false reading as to whether it's reached its optimum heat range (plus 500 deg. F).
The first thing to go will be the head gasket.
Since you continued to drive it in that condition, you are fortunate no real damage occured!
Thanks...
Trunk leak? Get inside the trunk with a bright light and have someone spray water around the trunk seal, rear window, wheel wells, and beneath the trunk area (if necessary) until you see the water. The dealer should have done this but, if he hasn't, you can thus be very specific in your water leak complaint.
Both of these problems are solvable; you certainly should not have to live with either of them. Good luck.
This week, my oil light went on and my car lost all oil! This happpened in an instant. I towed it in to them and they claim it was a faulty oil filter and that no damage was done to the engine. They refused to show me any documentation of them checking the engine, or even let a mechanic test drive it with me. I am totally freaked out and afraid for the long term life of my engine. The service clerk basically stated that "no one had a crystal ball" I took the car and drove it for three hours and it SEEMS to be okay.Any advice on how to approach this issue.
I presume your oil filter ruptured; that would cause very rapid loss of all the oil. If you stopped the engine immediately when the oil-pressure light lit, there is likely to be no damage. A physical check for internal engine damage is not practical but it is suggested, in case you do later need proof of responsibility, you obtain: (1) a record of who provided and installed the filter which ruptured, (2) the ruptured filter if possible, and (3) dealer's written description of the failure mode. In the meantime, monitor the sound and "feel" of the engine, oil consumption rate, fuel economy, engine coolant temperature. If you see significant deterioration in these areas, report it to the dealer ASAP. If you don't get a favorable response, I would next get a reputable independent garage's assessment. Armed with this information, calmly ask your attorney how to proceed.
Hopefully, the above data-gathering is only a form of insurance and your engine is OK. Good luck.
I'm also having clunking noises from the right rear suspension, but since I've lowered the car with aftermarket springs, Honda wouldn't cover it.
I just bought a 93 civic DX,It is a really good car (only 67k miles on it). but i run into a trouble after stupid forget turn off the light last week. the battery run out. A freind help me to recover the power without any difficult. The problem now is that the radio system stop work now!! the manual says that it need a code to reset the radio system. But i do know where can i find the code. Please help me out!!
it is really surker to drive a good car without music.
You will have to bring the car to the dealer and let them pull the radio system out to look for the serial number. From there, they will be able to look up the security code, at the same time you might as well as them for the plastic card that contains the code.
This car has been unbelievable. The interior and body have been thoroughly trashed by a flood, and a far to close encounter with an uprooted freeway sign in a real bad storm (separate incidents)in the last couple of years, and I've been severely neglecting maintenance, but at 233,000 miles it's still running great.
I'm planning on replacing it with another Civic soon, and am interested in those reporting problems with the new models. For those reporting problems, please keep us updated.
Also, I'd like to re-iterate aklapa01's comment. Whenever I've gotten into one of those hassles about warranty repairs, I've never gotten any satisfaction in bitching at the dealer, but have done very well complaining to corporate. If you have a problem with your Honda, stop arguing with the dealer and contact American Honda.
Is it possible that a bad PCV valve could cause this much oil consumption? Many thanks for any help.
Thanks for you help and input!
day it will be hard to impossible to start. the dealer says to give it some throttle and that this
is not uncommon. I'm no mechanic and from the sound of the answer I got, neither is the service manager at the dealership. Anyone else out there with the same problem?
What model is it? I can try and research it better knowing.
I read in the Accord forum that you are located in NY, where exactly??
BTW, I had found out the problem with my Civic... I have a leaking front passenger strut. Also would you mind if I ask you to confirm this two part numbers:
51605-SR3-013 Right Strut Unit
51606-SR3-013 Left Strut Unit
Capri
I have a 94 Civic EX and the price is about right. By the way, is there any differences between the struts used in the 94 Civics against those is the later years especially in the EX trim??
I had talked to a third party shop that had mentioned something that the engine mounts from the 94 model is different than that after 96, in terms of better mounts. I am hoping you can shed some light on this.
As far as the struts go I doubt it because they did make a bracket change on the struts and I think that I have been down that wrong road before thinking that I could and couldnt...I will try and check..see ya
#0 of 0: Honda Civic Power Door Lock Problem (denisme) Wed 12 Apr '00 (12:43 PM)
Asking for help on a 93'Civic Lx sedan which the
power door locks stopped operating a few months
ago. Started out with intermittant failures on the
PDL,sometimes they worked,sometimes they did
not.Now nothing works.None of the doors lock or
unlock,either with the drivers door switch or the
respective door switch.Looking at the Haynes
manual,I tried to measure voltage at the back of
the drivers door switch,0v on either wire.Ground
wire is good(tested with multimeter).The fuse is
good also. Anybody have any suggestions?
Anyone have any thoughts on denisme's problem?
Pat
Assuming the above are OK, but your symptoms are unchanged, the most likely problem is a faulty switch in the driver's door. To check this, reconnect the control unit wiring and disconnect the door-lock switch. On the 3-pin switch harness connector, (A) jumper the black terminal to the Green/White terminal momentarily; the doors should lock. Now (B) jumper the black terminal to the Green/Red terminal momentarily; the doors should unlock.
If both (A) and (B) produced the desired result, replace the switch. If either (or both) of these checks failed, it's a near certainty that the control unit needs to be replaced. Good luck.
As for VTEC, I haven't driven a VTEC civic, but from what I hear the VTECs actually give you a burst of power at higher RPMs, and the non-VTECs just revs loudly but not much power develops.
perfect idle speed - - - then "bam" jump'in
off the line. On the freeway, very intermittent
but can feel it. No help from mechanics both from
honda and outside. One suggestion is a fuel line
"bubble"??? C'mon...been going on for 18 months
now.
background: 1988 civic DX 1.5 ltr. 4 spd A/T.
109,000 miles.
any help or suggestion...tranny is fine..works
(when it wants to) like a champ. Just don't
want to get raped on the cost to fix.
reply: bishopk99@yahoo.com
P.S. owner of a new 00 Accord V6 EX (Vtec)
and my poltergeist car, really loved this
site!! great info.
thanks,
Kev
Bishopk99, Is there anything more you can tell us about the problem...like is it possible the ac could be on and set too high.Is the car in gear, not in gear,and how high do you think it is going(rpm wise)? There is the possibility of a bad ground by the thermostat housing and also I remebber something about the wire going to the air control valve? I will have to check on that one and what the causes were it has been a while since I have seen those. I will check on tuesday when I return to work..Sorry it cant be sooner but hey I have off a few days and I try to not think to hard about cars:)....see ya
a brief history.
Never had a problem....10 yrs worth, simple stuff
like alternator and tires, brakes..what you would
expect from a 10 yr old car.
However, while deployed to the persian gulf, my wife (by my recommendation) took the car accross the street for a blown radiator hose. OK, fine..
(now the car has no A/C (light on, but does not engage)) idle speed at start and "poltergiest" times, flies off the line, intermittently...this
was in '98. RPMs up to around 5 grand guestamate as there is no TAC.
I came back and found she took it to honda and
they could not diagnose the problem..sure..
it is intermiittent...I received 280.00 worth of
motor mounts due to excessive motor vibrations..
(not too bad, probably needed them sooner or later), but problem not fixed. Came back...
I did a 90,000 mile service, and they told me
I needed a new muffler...replaced everything
from the manifolds to the rear. Worked good
for a time with the new muffler and pipes,
but the polergeist is back.
Honestly, I have been driving it only. I put the
car in neutral at lights and baby it. I will get into a little bit of extra cash in June and want to get her fixxed up right but don't want to get
raped on cost (yes sir, you need a 3,000 tranny).
To me, it sounds simple...fuel line?? computer idle chip?? the O2 senor and exhaust has already
been checked out fine.
Hope this helps....
Reply to here or to bishopk99@yahoo.com
Any help appreciated.
Kevin.
P.S. My 10 day old EX VTEC Accord V6 is a
dream, take it on a mountain road to feel the
wishbone! (like I did on Saturday).
Kev
As far as the idle if the ac switch is coming on but no load from the compressor then this could be a problem for the idle. However if no ac on at time of problem it sounds as if the idle control valve and or its wiring is defective. It is about the only thing that can cause an idle surge like that. Unless a coolant temp sensor is sensing cold motor while warm. I forgot to check on the year of the wiring problem to the Idle control valve so I will try and remeber tomorrow.Just as a verification this is a duel port injection model correct. Thats the one that looks like a GM throttle body style with two injectors in the front of it. I will check back tomorrow...
Lost a post during the save to favorites page...
anyways...auburn63, thank you so much for your
quick reply.
Yes, my CIVIC is a dual port fuel injection system. And as well since the maintenance from
a non-cert'd honda tech...from my wife's first
occourance is the genisis of my problem this
wiring problem is probably on the money. As
all of this happened at the same time. Living so
close to a "cheaper labor evironment has its
disadvantages"
Please let me know the last info and I can
assist the tech's at my honda dealership with
the diagnosis.
BTW, for all the honda voyers...I have driven in
young guys cars doing "wheeleeeeees" off the line
in the fastest cars in Southern California...
Absolutely amazing web site with such technical
support that I am lost for words.....
92 octane keeps it tame...at least for know...
(always put 92 in the 88 civic.....) and
Can wait till the extra money comes in.....to
make my CIVIC right.
Thanks and waiting for your reply..........
Great site...Recommended it to 3 honda owners
today at work.
Kev
Bishopk99@yahoo.com
1hged3...ml011574(sedan)
2hged6...mh512869(hatchback)
Jhmed3...ms031565(sedan)
and some others but yours should be within that vin range being that it is an 88.
It refers to a bad ground for the throttle angle sensor.To repair it you remove the existing wire and install a new one that goes to ground at the hold down bracket for the wire harness.Part number for the wire is 32105-PM5-315 ask for the bulletin for installation instructions. This should be cheap enpugh to try so start there. If it doesnt fix well we will have to try something else..Also you want to make sure your coolant is full and bled of air.Should see a bleeder valve up fromt by hose..Good luck
keep it until student loans paid off, and Acura CL
goes below MSRP. I noticed that in the past
month, my speedometer has been acting erratically. It occasionally jumps all over the map. This happens at various times, speeds, and length of driving. I notice nothing different with the way the car responds, except that it seems to be jumpy when in cruise control when this happens--which makes me immediately turn off the cruise control. The only major problem in this car's history is that I had to replace the distributor a year and a half ago. Otherwise, I've been pleased with the performance and reliability. Any thoughts on what the problem could be would be greatly appreciated.
Nothing worse than walking into a mechanic's shop
and saying "my car's broken" -- cha-ching!
What is the machine that all Honda dealers use to check balancing of the tires? I know it is a Hunter but not the ones you typically find at NTB but more like a high speed balancer??
BTW, my vibration still exists. I have tried to get NTB to allow me to swap the tire but to no avail. According to the Honda dealer, my balance is fine and according to the folks at NTB, the rims are out of round (purchased January 00). I am at a lost since I hate the vibration but I am also broke that I can't afford to pay for all 4 Michelin's Energy MXV4 Plus tires while tossing out the old Yokohama's (only 10,000 miles plus since I bought it).
So what do you think my options are at this point?? The car drives straight and vibrate like crazy. Dealer/s (two of them) say it is the tire and not the rim and I have seen NTB put the rim without the tire on the balancer and it does wobble and is out of round. (Sigh)
Anyhow, thanks for all your input and patience with me.
There are several other dealers in the Denver area who do not use high pressure sales tactics. We purchased our CRV from Fisher Honda in Boulder. Ask for Suzi Smith or Craig Sweeney.
