Volvo S80
Welcome to the continuation of the Volvo S80 -
Part Four topic. Those of you joining us from that
topic are welcome to continue your discussion.
If you're new to this topic, you may want to
follow the above link for additional archived
posts.
L8_Apex
Sedans Host
posts.
L8_Apex
Sedans Host
We were driving about the DFW metroplex this evening and again encountered a problem with our Volvo Navigation system.
On more than one occasion - the system seems to get confused and has the car driving 10-15 miles off course, sometimes "cross country" and through lakes. Checking the GPS info- we sometimes show 3-4 satellites, sometimes no satellites being tracked.
We've tried doing a reset on the system via the controls, unloading and reloading the CD's (thinking it would softboot the software). Even turning the system off for 10-15 minutes while driving; thinking the poor thing was overworked after the cross country/water race it had supposedly been through. :-)
Sometimes this seems to help, sometimes not.
At first, we chalked it up to our unfamilarity with the Volvo Nav system (our MB E55 COMAND system, while similar, does not seem to suffer from this problem). But after living with out '00 T6 for 4 months now; I'm beginning to wonder if it's something more serious.
Anyone else experienced this problem with Accuracy on their Nav unit?
I'll have the dealer look at in a few weeks when we roll the T6 into the shop for a few minor adjustments:
- trim bubbling on the passenger window
- the TSB for the "Turbo" hesitation
- checkout out Bushing Thumping
- broken battery clamp in the Engine Compartment
- Nokia handsfree kit keeps losing memory and needs to be reset every 2-3 weeks. That is - when we plug the Nokia phone into the cradle - it no longer shows "Car" mode. The solution is to unplug the power coupling under the seat, wait 2-3 minutes, and then reconnect. The audio who installed the phone after we took delivery advises us that Nokia module is flaking out and should be replaced (under warrenty - whew)!
But otherwise - besides these little sniggles - we ain't got one complaint on our Moondust beast; been doing just fine; averaging 18.3 mpg with our city driving.
Taking the car to Tyler, TX this weekend to check out the Rose Garden there - and will be curious to see what the "true" highway mileage will turn out to be.
Have a great weekend -- Phil
My NAV system cannot give proper guiding commands to my home (entered by street address). Instead, the system guides me to a location about 2 miles away from my house.
Now, since I know where I live, this hasn't been a big problem to me and I 'wrote it off' largely to the fact that my home was inside a gate guarded community. I thought (?) the system might have rules which made it get confused when regarding certain areas regarding restricted access (just a SWAG though).
In any case, I filled out a driver report online to Navtech, the makers of the CD-ROM nav database at:
http://www.navtech.com/database/data_driver.html
but have not heard anything back. I would suggest you do the same so they are at least aware of the problem.
p.s. BTW - I normally get 5 or 6 satellites online here in Southern California. Obviously if you ever come up with 'no satellites' it cannot guide you (you would hope that the system would alert you to that fact and not start giving you incorrect guiding commands). From what I understand, this should NEVER happen unless you are in a parking structure or some other structure / area where you don't have 'line of sight' to the satellites. Do you have metallic tint on the back / rear window?
The DoD recently turned off Selective Availability and this has resulted in many of the aviation GPS units requiring upgrades to handle the "enhanced" signal.
Cheers!
I've been trying to ferret out info on the 2001 S80 for a while now. One thing I've found (I believe) is that it won't be possible to order both the warm weather package and the navigation system.
Living in the deep south, I really want, at least, the power sunshade. Any thoughts/info on if this can be ordered separately or dealer-installed?
I contacted my dealer last October and they replaced the left-rear subframe bushing with P/N 3507924-3 and used J-B Weld to secure it, per Volvo Cars' service bulletin. The noise returned immediately! The dealer again replaced the bushing (same part number), however, used a different (costly) adhesive this time, as recommended by Volvo Cars. The noise is still present. I again contacted the dealer and asked that the vehicle inspected by the Volvo Cars representative. The rep claims he and the service manager road-tested the car and could not recreate the noise! Unfortunately, I was not able to road-test the vehicle with the rep that day, however, I heard the clunking/popping noise TWICE, WHILE STILL ON THE DEALER LOT!!!
I contacted the dealer and requested to meet with the Volvo Cars rep, to personally demonstrate the problem I am having. The service manager refused to schedule an appointment with the rep. I then contacted Volvo Cars Customer Relations and requested an appointment with the Volvo Cars representative. I was told that this request can only be made by the dealer. I informed Volvo Cars that the dealer is refusing to honor my request. Volvo Cars Customer Relations suggested contacting another dealer in my area (northeastern New Jersey).
It seems that I am getting the run-around from the dealer and Volvo Cars. I've read the numerous posts about the subframe bushing problem. I recently read that Volvo Cars has a 4th generation bushing (P/N 3507924-4) and an o-ring available, which supposedly solves the problem. Has anyone had the latest bushing installed?
It seems that Volvo Cars doesn't have a solution to my problem. I am very disappointed that Volvo Cars has failed to even acknowledge the existence of the clunking/popping noise in my vehicle, probably out of fear of having to repurchase/replace the vehicle. In the past, I have even offered to make the vehicle available to Volvo Cars of North America for inspection, since I live near their Rockleigh headquarters. They refused and referred me back to the dealer.
The last time I was at the dealership, I was given an identically-equipped 2000 model-year S80 2.9 loaner car, with 5,000 miles showing on the odometer. This vehilce made NO CLUNKING NOISES WHATSOEVER!
I would appreciate hearing from other S80 owners who have also had similar noise problems and what if anything can be done to correct it. Can anyone recommend a Volvo dealer in northeastern New Jersey who has been successful in resolving this problem?
The vehicle currently has only 1,600 mile on it and is my second Volvo, my first being an S90. Aside from this ongoing problem, I really like the car. However, I feel that this subframe bushing problem poses a serious safety concern.
Any advise on how to proceed in resolving this matter is greatly appreciated!
Some time ago, someone here posted that they had ordered the navigation system and WWP, and they insisted that the Volvo dealer assured them there was no conflict. I don't recall anyone posting absolutely that they in fact have both options, working perfectly together. So, you may want to research this further.
Broeux
I hate to parrot VCNA on this one but your best bet is to find a better dealership. It shouldn't have to be this way but it is sometimes (and this can happen with any marque). If your current dealer won't even make the appointment to speak to the Volvo regional rep. I would leave them in a heartbeat if it is an option. Take your hard earned money elsewhere. Explain to the other dealer your problem and the work to date and tell them you want to give them a chance to earn your future service spending. The sub-frame bushing problem is an annoyance that has taken Volvo too long to finally find a solution for but it is not a major safety issue by any means. If you can't use another dealer send a letter to Wolfgang Rietzle (sp.) who is the head of Ford's PAG. He is in the process of implementing new customer service programs and is tying executive bonuses to customer satisfaction (isn't it about time!)
-rdo
rdollie@mediaone.net
Good luck!
Have a '00 S80 T6
Your comments are appreciated
pix e, under the circumstances you described the AC should be on but you shouldn't be able to really feel that the air is colder than ambient temperature. Unless you are running the heater, you should always keep the AC on in Volvos (and Mercedes) in order to keep the windows from fogging up (the AC removes the moisture from the cabin air). Odd but true...
-rdo
broeux
jhamley, this problem sounds like the lubrication issue with the splines in the steering column. It has been referred to by multiple owners on the BrickBoard (www.brickboard.com) so their may be an actual TSB (Technical Service Bulletin) out on it. If you check the BrickBoard you should be able to find an S80 owner more familiar with the remedy.
-rdo
The reason I bought the S80 from Ramsey is because, strangely enough, my salesman at Englewood was not interested in selling/leasing me a Volvo. At the time I wanted to buy either the V70 or S80. He suggested I buy a Honda!
Still, the service department at Englewood is great. The sales staff at Ramsey has been exceptional; hopefully the service department is as good.
I only purchase premium high octane gas but still hear the knocking.
Does anyone else experience this same problem?
trip7, yours is the first I've heard of with a pinging problem. I would call the dealership and ask them if there is any reason you shouldn't try a can of dry gas in case you somehow ended up with excess moisture in your tank. This would be the easiest solution. If it doesn't work then you would need to waste some real time with the dealership to let them diagnose the problem.
-rdo
It's been awhile since I've been to this site. Has anyone had problems with their air conditioning fan? Mine will only work on low speed. I took it by a dealership that I happened to pass and they didn't get any messages when they put it on computer. They will need it for at least a full day to try to track down the problem. Any clues? I could sure use high fan with 100+ heat!
Kathy
I got a full load of fuel from a particular station and noticed after I got the car back out on the road that acceleration was very poor. The car didn't knock or ping but the RPMs wobbled a bit at idle.
I didn't like the look of it so I siphoned out some of the fuel and let a chemist friend check it out. He said it looked like someone mixed 89 and 87 octane fuel together, with about 3 parts 87 to 1 part 89.
Needless to say I haven't gone back there since.
- Jim
broeux
Is the center speaker in the dash only for the pro-logic stereo? Is this the 9th speaker and the center channel for surround?
If so, will there be nothing under the mesh speaker cover in my T6? Maybe I can make another cupholder out of the empty space!
neil2212, if I were a betting man (and I'm not), I would put big money on the possibility of a low capacitance battery. It seems the initial Volvo batteries that come from the factory seem to loose their deep charge capabilities prematurely from time to time. I remember this started with the 850 series several years ago as I recall (I learned the hard way by playing the radio for about a half-hour while I washed the car once.) If you get a chance you may want to have your battery checked and or charged. Again, I can't be sure but I think the battery is a likely culprit given your symptoms.
-rdo
Now another question, which Orange County area Volvo dealership goes above and beyond the call of duty to keep service customers happy? I will need to lease or buy another car in the next week or so and want to buy from a top notch dealership comparable to my current dealership of choice (Boston Volvo Village). If I can't find an exceptional dealer I may be forced to buy a [gulp] BMW or Audi to park alongside the T6!
-rdo
I checked my battery voltage last night. Resting voltage (with car off, and not having been started for > a day) was 12.45 volts. Voltage measured while cranking the engine dropped as low as 11.0 volts (for an instant), and rose as high as 15.0 volts (for an instant). From these measurements, I'm suspecting that my battery is not to blame for my rough engine performance on start-up. Thanks for the thought though. Neil
Please inform me on how this ugraded system to the Dolby Pro Logic System works. Do you lose the cassette tape playing capability?
Camps
If anyone has recently purchased the S80, 2.9 or the T6, would you be so kind as to let us know what a reasonable price would be to expect from either model. We were just looking to pick up a decent price from dealer inventory. we are in Cincinnati,ohio, but any price suggestions are greatly appreciated !
thanks in advance
I bought my T-6 through Volvo- Irvine and I live in Detroit. Long story, but look up Alex Doegle (pronounced doogle) , we did the whole transaction via fedex and phone, he found my car in transit, had it delivered to dealership in Ann Arbor, that he felt would provide the best "service" after speaking with them ( he had 3 to choose from in the Metro Detorit area). I have had no service issues to date, but feel that if I do encounter a problem I can call Alex to get help, even though he is 3000 miles away.
Are you sure that the 2001 are coming in Oct/Nov? I am purchasing the 2001 through the overseas delivery (OSD) program and I leave for Sweden July 1 and pick up the car July 4. As far as pricing goes (at least for the OSD program) the 2001 is cheaper than the 2000 if you are getting the leather seat/sunroof package. For the 2001 model the leather seat/sunroof package is included and the OSD base price of $37,850. The 2000 OSD base price is $37,000 and $1,200 for the leather seat/sunroof package.
Thanks for your response. The 2001 S80's do not come out in the US until Oct/Nov according to Volvo N. America. Obviously going to Sweden is another story. I have no intention of dealing with Europe in the summer, it is a crowded mess. It looks like I will look at recent build 2000's because I can't wait that long.
Has anyone got any recent 2000 purchase stories, please?
Aaron
Eric
Also, on price (I'm off topic some) I see Volvo is currently offering yr 2000 buydown of $1000 cash plus $500 for loyal Volvo owners. With these discounts I've been quote a selling price of $40,220 + Tax & Lic fees. This cost includes the following 4 options:
1. Sunroof & leather package
2. Homelink Security System
3. Cold weather package
4. 4 CD In-Dash w/surround sound
According to my research this $40,220 is slightly below the dealer invoice price. Should I be negotiating a lower price given that Volvo is throwing in at least $1500 on this deal?
Thanks in advance for any advice and/or replies.
Regards... Barry Sharp
