Yes you have to take the transmission out to get to flywheel, but I never herd of a case where flywheel teeth were damaged by the starter. You see, flywheel is made of regular steel and it looks like a rarge flat and really havy disk on manual transmissions, and on automatics, which yours is, its called a flex plate, its thin and light but it has a heavy and bulky torqe converter bolted to it. Anyways in both cases there is a high carbor ring gear attached on the outside of the disk, it is very hard metal. Usually the gear on the started is much softer and it wears out much faster. Now if your flywheel ring gear has chipped or broken teeth on it in one spot, then it will have good teth on the other side. so picture this: starter gear is about one to two inches in deameter and has about 10 teeth or so, and ring gear is about 15 to 18 inches in diameter and has over 100 teeth. Its impossible to damage all teeth on the flywheel ring gear. So try this: if the starter does not turn the engine over then follow theese steps:
1) apply e-brake put a brick or something on both sides of the tire so the car won't roll.
2) Open the hood and as you are facing the engine on your left side find the belt and underdrive pulley: its the largest pulley on the engine, it would be on the bottow, and right above oil pan in the center of the engine. It will have a big bolt righ in the senter, most likely 21mm socket.
3) turn ignition on, stap on brakes and shift into neutral gear without trying to start it. Make sure you turn ignition off and leave it in neutral every time you repeat step 4.
4) take a big wrench and turn the engine over by hand about 1/8 to 1/4 of a turn, then take the wrench and socket out and try to start the car.
5) if the starter doesn't turn engine over then keep repeating step 4 untill you would be able to start the car. If you tried step 4 more then four to six times and starter did not engage and did not turn the engine over on its own then its not your flywheel, and its probably your starter. In this case I would go to a different mechanic.
Ok if the starter does enagage and the engine turns over after you tried step 4 then its still 50/50 chance that your car did not get new starter or your flywheel is bad. I would take it to a different mechanic and do not tell them that you just got new starter and see what they say.
Please let me know if I this was helpful to you?
Just a litle advice: iIf you will need any mazda parts, don't buy them from mazda dealer, but instead go to www.mazda-parts.com or www.onlinemazdaparts.com then click on parts catalog and order it directly from the same place your mazda dealer is geting same parts from, but ist gonna be cheaper this way. And if you can't find something then there is a phone number on their site and you can call them, ask them for part number for what you are looking for and then go back to parts catalog and search for that part number.
1: Is this just an adjustment problem and what needs to be adjusted.
2: If I have to replace the trans is there a big difference between the S and L model trans. How much difference does the VIN make in the trans.
Basically what trans options I have to install in the car. Thanks in advance for any help given.
danny
thanks.
p0303 is misfire on #3 cyl. most likely the coil is bad. the rt bank(rear) coils get way more heat than the fronts. and #3 is the middle one back there. also, because of the intense labor to get to the plugs, lotsa places you take the car to will charge you for the plug change, but never do it, because it takes a couple hours to get to them suckers. when i do it, i make sure i got new plugs, and i take a known good set of coils and replace them. you can switch the coils from the back to the front, because the front ones will outlast the rears. and if someone says to switch #3 coil with another and see if the miss follows, has NEVER done this job on a 2.3.
p0431 is your post cat 02 sensor telling you the cat is dying. that, along with 1173(heated o2 sensor, same bank) tells me somehow you fubar'd the cat. you need to take care of the fuel problem, because if fuel fubar'd the sensor and the cat, if you just put another one on, it will kill them, too
Had starter, flywheel, another starter, installed by my local mechanics. Finally,
I talked with a Mazda mechanic and he said that he would recommend an OE Mazda starter. I did, and the problem seems to be fixed.
I also get only OE Mazda brake pads since they do not shed an excessive amount of brake dust.
I had mine replaced (there were several teeth broken off) at a local, reputable,
transmission shop.(Not AAMCO) Cost: $600. A dealer will charge in the range of $1700.
I have a 2002 P and the dealer and oil change shop have both told me that I have a leaking valve cover gasket. I guess this is the reason that I smell a burning smell after I drive for awhile. Is this a serious problem that needs immediate attention? Also, is this a difficult and expensive repair? Please note that I also need to replace my EGR valve(??) and would like to know if this is costly.
2015 Subaru Outback Limited 2.5
P1743
P0750
P0755
The Engine runs fine expect the
Pls any do-it-yourself approach will be appreciated....Thanks!
Prompt responses will be highly appreciated as i need to check its present state ASAP.
1 is when I accelerate, there is a high squeal of a noise....at first I thought it would be the transmission but it shifts find. Would this be the super charger needed to be cleaned out and the filters changed???
2 The car nudges when its in idle....I'm thinking that would be caused from the needing new spark plugs and coil kit. Am I right about this?
3. The engine light has been blinking...don't know for how long but its there.....does this happen....should I be concerned about this for any major damage?
4. Is he asking way to much for this car? I don't know to much about them but I do like the look and feel of it. I know the basics of the car like replacing all the filters, spark plugs and changing the oil but nothing on supercharge cold are intakes.
Can anyone suggest their expertise on this please before I make my decision. Oh and the owner has had done a safety on it and its good for another year. And its a right off from Auto Pac, but my friend has put in about 3k worth of repairs.....the car looks great though
Since the trunk isn't too big and I couldn't fit in my trunk and do the work, I had to perform the fuel filter swap by going through the access area in the middle of the rear seat. With the arm rest folded down, I then reached in with my smaller socket set and set forth with the task. I had some new hose clamps because I hate the OEM style and reusing them isn't the best idea. When all was said and done, it took me about 3 hours. Seriously. Just a few days before, I got a quote from a tire shop that does my wheel alignments for $140 to do the work. They wanted $60 for the filter and the rest was labor. In my case, this is clearly one task on the Millenia that I'd pay to have someone else do the work on.
Thanks in advance for your help!!!
BENTMAN
po105
po170
po173
po303
po400
we changed the coil on cylinder 3 and replaced all 6 spark plugs, still no power and still have to loud noise, just ordered the front Y pipe with the flex joint, any ideas if this will solve this? I love my milly and would hate to part with it
BENTMAN
Hope you get a fix that doesn't cost you too much! Good luck!!
