Dodge Ram Accessories and Modifications
Anyone out there with an '02 Quad have information on the best looking / best price on nerf bars / running boards and tonneau covers?
If you remember back, I mentioned a Mopar magazine in which a new Quad owner had tricked out his truck, adding hp (up to 350hp on a 4.7), handling goodies, and I think a nice bed cover. Check it out.
Now looking for some step bars. Something durable and yet good looking.
Kenwood changer and an adapter to connect it to the factory radio. I went with
their suggestion, and the total cost with shipping came to about $280.00. The
installation was very simple. I put the changer under the drivers seat. The center
section of the dash (02 QC) comes off by just removing one screw and then
pulling the whole piece out. This exposes the 4 screws holding the radio in
place. Remove those screws, slide out the radio, plug the adapter cable into
a plug in the back of the radio, plug the cd changer cable into the adapter, and
reverse the disassembly process. Crutchfield actually included some very detailed
instructions, complete with pictures of the dash disassembly specific to the Ram,
so that made it very easy.
what kind, and where did you mount them? Thanks...
for the heat and a/c) has a single screw on the right hand side, towards
the bottom of the panel. There is a hook right by the screw that looks like
it is probably designed to hold a trash bag. After removing that screw,
you just pull the panel straight out. It takes a little bit of force to pull it
out, to release the snaps that hold it in place - a little scary the first time
you do it. I lowered the cup holders, lowered the ash tray, and gripped
it by the recessed storage area under the a/c controls, and pulled firmly.
Hope this helps...
USA Spec changer. Crutchfield was about $95.00 more than that with shipping.
I'm sure you will enjoy it... I know I really like having everything still looking
and working like it came from the factory. It seems to me that no matter
how expensive an aftermarket stereo is, it always looks a little cheesy
in the dash, plus it is a thief magnet.
Much appreciated.
I'm considering some mods to improved gas mileage, e.g. air intake sytem, performance exhaust, and maybe high performance computer.
Anyone have any luck with any of these mods? Will they affect my warranty?
Sure would like to get some!
Please let me know
I thought it sounded pretty decent stock but added FlowMaster exhaust with dual pipes, now it sounds AWESOME! But now it needs more power! Where can I get a bolt-on supercharger (I would expect additional exhaust mod)?
Also, since I wanted 20" wheels I couldn't get the Off Road pkg - I don't like the lean/roll on corners - any recommendations to mod the suspension, without sacrificing the fine ride I get now?
Jay
My question is: anyone do this yet? I see only the kits with the add-on switch on Ebay. And I would like to find a used dash switch to save $.
I don't believe there's a "Sport" equivalent in the RAM series, but I've seen one with front and rear sway bars so Dodge at least does offer them.
You could simply buy the sway bar(s) and necessary mounting hardware and install them yourself. That would make a noticeable difference, I would think. In fact, I know someone who did just that on their Chevy and it really made a cornering difference. I don't know if I'd elect to replace the rear and front spring with heavier versions, but you could do that, too.
The last thing I'd do is install load leveling shocks. My son did that to one of his Blazers and his '91 Dakota. It made both of them ride like bricks.
Best of luck,
Dusty
Anyone know who makes this accessory?
Dusty
