2016 Subaru Legacy Lease Questions
MichaellMichaell Moderator Posts: 267,596
edited August 2015 in Subaru
Ask your 2016 Subaru Legacy lease questions here!
«134
  • toyoman8toyoman8 Member Posts: 114
    ok I start with the obvious: what is MF and RV for 2016 Legacy 36 X 10k miles
  • MichaellMichaell Moderator Posts: 267,596
    Which trim level and engine type?
    I thought numbers are not available yet
    I've got numbers now.
  • blacksiblacksi Member Posts: 6
    Legacy premium MF and RV for 36 month/12k please. Thank you.
    2016 Legacy Premium 36/12 - 63% and .00100
  • brianmislebrianmisle Member Posts: 21
    Looking at leasing a 2016 Legacy 2.5i Limited w/Moonroof Pkg. + Keyless Access and Push-Button Start + Navigation System + EyeSight®
    Term: 36 months/12k miles
    60% and .00060
    thnaks
  • carenthusia85carenthusia85 Member Posts: 48
    Hello Moderator, can you provide me with residual and MF for 3.6R for 12k and 15k miles for 36, 39 or 42. Not sure if Subaru does 39 or 42. Thank you.
    15K numbers:
    36 - 59% and .00090
    39 - 56% and .00100
    42 - 54% and .00100
    Add 2% for 12K
    Thanks moderator can I get the same numbers for the 2.5r limited  please.
  • alexfrnchalexfrnch Member Posts: 82
    May I please have the RV & MF & any incentives for WA STATE on the 2.5i Base model
    36 month/ 12k miles
    36/15 - 58% and .00060
    39/15 - 56% and .00065
    42/15 - 53% and .00060
    Add 2% for 12K
    36 month/ 12k miles
    65% and .00165
  • carpersocarperso Member Posts: 148
    60% and .00060
    Do these numbers vary from state to state. Would the above numbers for CT?
    60% and .00060
    Subaru numbers are national.
  • jim53jim53 Member Posts: 118
    Can I get the residual and money factor for the Legacy 2.5i Premium for 36 months at both 10k and 12k miles per year?
    .00100 and 63% / 64%
    Thanks.  Is 2% under invoice a good deal for one these days?
    We don't track pricing; use the "make / model / year" pull downs at the top of the page.
    thanks again. Did the numbers change for September? I am being quoted a mf of .0005 and residuals of 61% and 60% for 10K and 12K miles
    also, can you confirm the bank fee charged and is that ever waived?
  • kyfdxkyfdx Moderator Posts: 270,965
    .00050 MF and 61%/60% residual
    Acquisition fee is $595. You can't negotiate that away.
  • lovelove1lovelove1 Member Posts: 2
    Hello
    could I get september numbers for legacy 2.5i limited? 10k/12k 36 months thank you!
    lovelove1 said:
    Hello
    .00025 and 58% / 59%
    Hello
  • odat888odat888 Member Posts: 1
    I was looking to lease a Legacy 2.5i Premium for 36 months and for high mileage, 20k-25k a year, they informed me that they do not do that, is that true or did I find a dealer who did not want to play?
    ODAT
    ODAT
    36/15 numbers are 58% and .00050.
    .10/mile charge if you want more. No indication of what the limit might be.
    Try other Subaru dealers - only takes one to make a deal.
  • comradsuhovcomradsuhov Member Posts: 12
    Hi Michaell,
    thank you for all the help and information you provide on this forum!
    We already placed an order for 2016 3.6R Legacy Limited, but not sure if the car will get to the dealer by the end of the month or it will be in October, so I might inquire about MF and residual numbers again next month :)
    Could I please get the lease info (MF and residual) for a 2016 3.6R Legacy Limited with the Pkg#23(Eyesight) and PP#5 - 36/12k and 36/15k miles in Colorado?
    Hi Michaell,
    .00055 MF and 59%/57% residual
    Thank you KYFDX for providing September rates! Unfortunately the car didn't arrive yet and I'm now looking at mid-October for this.
    Could you please provide me with the October lease info (MF and residual) for a 2016 3.6R Legacy Limited with the Pkg#23(Eyesight) and PP#5 - 36/12k and 36/15k miles in Colorado?
    .00080 MF and 60%/58% residual
    Thank you KYFDX.
    So, the money factor got worse on 0.6% but residuals slightly improved.. Interesting... I wish Subaru would keep rate at 1.32% with the new residuals :)
    Thanks again!
  • nyrangers2015nyrangers2015 Member Posts: 16
    Hi Moderator,
    May I please have the MF and Residual values for
    2016 Legacy 2.5i PREMIUM and LIMITED also
    3.6R LIMITED with AUTO and Eyesight pkg for 36/15K in NJ? And if there are any incentives this month.
    Hi Moderator,
    2.5i Premium - 58% and .00050
    2.5i Limited - 56% and .00025
    3.6R Limited - 57% and .00055
  • michael_hartmichael_hart Member Posts: 1
    edited October 2015
    Hello Moderator,
    Would you be able to provide me with MF and Residual for 2016 Subaru Legacy 3.6r Limited w/ Moonroof/Nav/Keyless Access & Eyesight w PP #5.
    12,000/36 & 15,000/36. in Pennsylvania Thank you very much.
    Hello Moderator,
    36/15 numbers are 57% and .00055. Add 2% for 12K
    Hi Moderator,
    could you please confirm the October lease info (MF and residual) for a 2016 3.6R Legacy Limited with the Moonroof/Nav/Keyless Access & Eyesight (Pkg#23) and PP#5 - 36/12k and 36/15k miles in Colorado? Because as you could see below, on October 1st KYFDX gave me different rates then what was given to people here couple days ago for seems like the same configuration (see below). Thank you!
    kyfdx Posts: 37,608
    October 1
    Hi Moderator,
    kyfdx Posts: 37,608
    October 1
    .00055 MF and 59%/57% is correct.
    Must have read off the Outback line, the first time.
  • j2timesj2times Member Posts: 44
    Can I have the residual and MF for a 10 & 12K lease for 2016 Legacy 2.5i Premium 36 month lease.
    36/12 - 60% and .00050
    Add 1% for 10K
    Working on a deal but it's no longer October. What are the November money factor and residual values for a Legacy 2.5i premium (with popular package 11 if it matters) lease for 36 months and 12000 miles a year?
    Also, do the dealers have discretion to charge even more on the interest factors? I've never encountered that before, but this one says you have to add 0.5....which is just a ridiculous number that I don't think he fully understands or means. Aren't the numbers set by Chase/Subaru Finance?
    Thank you so much for your help!
    .00040 MF and 59% residual.
    Dealers are permitted to mark up the money factor by .00050, for extra profit. They aren't required to, naturally.
    Hi Moderator,
    Do these numbers apply for CT in november. Looking specifically for the 2.5i Limited
    carperso said:
    Hi Moderator,
    .00020 MF and 55% residual for 36/15, if your dealer uses Subaru Motors Finance (SMF)
    Some dealers in New England do not use SMF.
    carperso said:
    Hi Moderator,
    Thank you. And is it add 2% for 36/12 ie 57%. And incentives this month. and a particular term subaru is pushing for like 33/39 month leases that mazda is pushing
    carperso said:
    carperso said:
    Hi Moderator,
    Yes, add 2% to go from 15K to 12K.
    No incentives or special lease terms from Subaru. 36 months is generally the sweet spot for them.
