Ford F-250 Owners
Enjoying your F-250? Need to find out what F-250 owners think about their truck? Then this is the place!
«13456725
  • cburrusscburruss Member Posts: 3
    I am considering buying my first Ford Diesel And was wondering if this year make and model had any know problems? Like does the automatic Transmission not work well, or is the turbo a head ache? Questions like that. Any info on mileage or anything would help. I dont know enough about this make and model to make an informed decsion.
  • mullins87mullins87 Member Posts: 959
    Well, the key to that truck, just like any other used vehicle with some age on it, is the maintenance. How well maintained was it? I don't know of any particular problems relating to that truck. Of course I don't own one either. I do know of lots of guys that have F-250's and F-350's in the '94 to '97 range, and none of them seem to have any particular problems.
    The engine is pretty much bullet proof. So is the tranny IF it has had regular and frequent fluid changes and has never been allowed to overheat. Overheating and burning the fluid is especially easy to do with a diesel since the engine produces so much torque at very low rpms. Also, since it is a diesel, chances are it has towed some heavy loads. If the fluid has been changed regularly then the tranny should be ok.
    However, you didn't mention the trucks mileage. And as we all know, trannies and most other components have a finite life. What are you going to do with the truck? Give us more details about the truck and we'll try to give you more detailed answers.
  • fordtuffordtuf Member Posts: 101
    I have an 02 with K&N and a set of JBA headers, Flowmaster in the works.
    Anybody done injector changes, chip, airflow changes(throttle bodies/mas air flow ?) or anything else?
    The truck has 60,000 miles on it and was used by a local home builder. So it has probably towed some loads. The dealership where it was traded in is a local Ford dealership that I do buisness for and the owner is very loyal to me as a buisness associate so he said that it was owned by a friend of his and he was actually the one who told me that it was owned by this builder. I know the builder by reputation and he has a very good one. That doesn't necessarily mean that he changed the fluids though. I could ask for some records at the dealership because I am sure thats where it was serviced. Local small town. Does the truck get alot less miles per gallon when you are towing something. Also I was thinking of using the truck for plowing. Is that a really bad idea in relation to how long the truck will last? I mean if its a difference of 40-50,000 miles or should I trade it in in two years if I do buy it?
    60,000 miles ?!?! In 9 years?!?! Most builders I know of will put at least 40,000 a year on their trucks, and most of that is pulling a load.
    Yes, ask for the service records if there are any. If that is the correct mileage, then the two biggies that I see with this truck are regular oil and filter changes and coolant additives. The tranny will go that far without a fluid change as long as it hasn't been allowed to overheat and cook the fluid. But back to the oil changes. These trucks use a second high pressure oil pump to hydraulicly actuate the injectors. So not only will old, dirty oil wear on the engine, it will also wear out the injectors prematurely. The coolant additive is IMO the BIG one you should ask about. Diesel engines require coolant additives. This is due to the high compression ratios. The high compression will actually cause the cylinder wall to bow out during the compression stroke creating an area of high pressure around it. As the piston then retracts after the combustion process, then that cylinder wall will very quickly flex back in to its original position, which creates an area of low pressure around it. The coolant will have a tendancy to form air bubbles, boil if you want to call it that, in this area of low pressure. When the piston begins its next compression stroke, the cylinder wall flexs out again. Only this time those air bubbles formed from the last cycle will implode due to the incredible pressures created by that rapidly expanding cylinder wall. When those air bubbles implode, they can, and will, eat away at the metal of the cylinder wall. Over time holes will form and the engine is shot. This whole scenario is called cavitation. That's where the coolant additive comes into play. It prevents cavitation from happening plus it helps the water to draw heat from the engine metal more efficiently.
    The reason why I have gone into such an discussion of this is because most dealers aren't even aware of this additive. I don't know about the '95 model year owner's manual, but I'd bet it doesn't even mention it either. My '99 model year manual does, otherwise I wouldn't have ever known to ask about it from other diesel owners.
    Again, if that is the correct mileage, that truck has set for long periods of time or has only been driven a few miles a day. Unless something else jumps out at you, the condition of the coolant would be the thing I would be most concerned over.
    Have you test driven this truck yet? If you do, take it on an extended test drive, not 10 or 15 minutes either. I'm talking about a couple of hours. I test drove a '95 dually, crewcab with the 5-speed back a few years ago. Once it was up to full operating temperature, I drove it hard. I'm not talking about redlining every gear, but at least taking it up into the 2,200 to 2,600 rpm range with the throttle to the full. You won't hurt a diesel that way. These engines are designed to work hard and enjoy it, not like a gasser. Anyway, I had made a couple of stops, one being at my house to see if the truck would fit into my garage, and on the way back to the dealer I noticed the truck started smoking lightly under acceleration. Not the typical black sootie smoke, but it had a white color to it. I took it back to that dealer and didn't buy it. Turned out to be a good decision as I later happened to mention it to a reputable diesel mechanic. He told me he was familiar with the truck and that the smoking would have gotten worse the longer I drove it. All in all, he said about $2,000 to fix it. So if you've read this far, take the truck on a good long test drive.
    Your mileage will be considerably different running empty and towing. Remember, my point of view on mileage is based on a '99 F-350 Supercab, long bed, 6-speed, 2wd. I get around 18 mpg when empty and 11.25 mpg when towing my camper. I have a 16' flatbed on which I use to tow my offroad Jeep. I'll get around 16.5 mpg with that trailer behind me.
    I've been told snowplowing is one of the hardest and most abusive things you can do to a truck. I don't know from personal experience as we don't get much snow where I live. I personally wouldn't want one that has been used in that manner. I would imagine the tranny wouldn't last long.
  • connonconnon Member Posts: 52
    Have an 04 f250 with the 6.0 deisel just coming up on 1500 miles.I always changed the oil on a new vehicle at or before 2000 miles.This is my first deisel, should I go the mfr recommended 5000 miles or do it sooner.I do almost exclusively short hops with this truck(5-10 miles).No towing either. thanks.
    I did what you suggested and when I took it home for the weekend I realized that it had some electrical problems and also left a really big oil slick under the truck the next morning. Thanks for the advise.
    You're very welcome. You mentioned electrical problems, could that be the reason for the seemingly low miles? I'm skeptical of that one.
    Diesel engines need several miles of driving before they reach full operating temperature. In your case, I'd change out at 1,000 or 1,500 miles and then every 3,000 after that. Lots of contaminants can build up in the oil when it is not allowed to stay at full operating temp for some length of time. These contaminants will "burn" off when the oil is hot enough. Another piece of advice is to take that truck out on a long run at least once a week. That Navistar engine reallys likes to be worked hard.
    Guess I will do it now. As far as working it hard , I am running it down to Tallahassee from North Jersey for Thanksgiving. Should be a decent shakedown cruise. Getting around 14.6 mpg locally so it will be interesting to see where that goes on a long high speed haul.BTW, 04,King R.,4x4 cc.
    Long runs are good for these engines. Your mileage should go up. Right now it seems that yours is low, however these diesel may take 20k miles or more to break-in. You should get into the upper teens to around 20 mpg when broken in. My truck, an F-350 XLT, DRW, SC, 6-speed, 2wd with 3.73 gears gets around 18 empty(mixed city and highway) and 11 towing a 31' camper.
    Kind of strange, my last Ford, an 01 F150 screw was very specific on what oil to use,5-20 synthetic blend an nothing else. My 04 deisel according to the Power Stroke supplement just refers to a climate chart to determine what weight oil to use and nothing else.So I went with standard 10-w-30 seeing that it rarely goes -10F around these parts. Last thing I need is to void a warranty through inability to read the owners manual correctly.Still I am happy not to have to go synthetic at 15 qt's per change.I will however go with the severe duty change schedule with all the short runs I make. Thank you Mullins87 for the input .I have had this truck since mid August and would like to think the low milage(1350) is because of the weeks it sat back at the dealership correcting problems that should have caught during the so called "dealer prep", however I know I just dont drive it enough.
    Assuming the oil recommendations are the same for your 6.0L as those for my 7.3L, 10w-30 is OK for cold weather use only. When the temps get over 40 degrees F, or some temp close to that, you'll need to switch over to 15w-40. However, the most important issue here is to make sure you use high quality oil rated for diesel engines. Diesels place much greater stress on the oil than gassers. You can use oil rated for diesel engines in a gasser, but not the other way around.
    What brand of oil did you put in it? I have only used Rotella-T in my truck. Walmart sells it around here for about $6.50 a gallon. I got familiar with Rotella-T when working for a trucking company. That's what they used, and still do today. Several of their trucks had 1 million miles on the odometers when they were sold. They were never rebuilt either. The company choses to buy a new truck at that point rather than chance a truck on the road that might break down. I have 140k miles on my truck now and can tell you the inside of the valve covers are clean and sludge free.
    Obviously I'm a Rotella-T fan. Others really like Chevron Delo, and there's another major brand but I can't think of it now. Ask around at the truck stop when you fuel up. You'll get lots of good information from the guys that know what they're talking about and far more opinion than you want.
    Welcome to the Ford diesel club. If you're like most of us, you'll find out it's a love affair.
    I had the shop put Valvoline 10w30 in even though they tried to get me to go with 15w40.I even tried Ford Cust. svc for a clarification but the operator in Dearborn did not know what the Hell was up. After 20 min. on hold he comes back and tells me to go with 5w20. I told him that that wasn't even listed in the Diesel power stroke supplement. So much for going to the top.I will go back tomorrow and compare the ASI specs from the manual to the specs on the Valvoline drum(bulk oil) and if it does not agree I'll dump it and go 15w40.Rather waste the money then ruin the engine.
    Good grief!!! That should prove to you that you need to read that manual thoroughly AND talk to both highly respected diesel mechanics and diesel truck operators in your area. The machinery they deal with may be larger, but the same knowledge and products usually apply.
    Since I may run afoul of the Edmunds membership agreement, I'll send you an email with some information on another website that you'll find very helpful.
  • tightlinetightline Member Posts: 1
    Man what a truck!! This is my first diesel. I've been reading the owners manual and talking to some friends that have diesels. In particular, I have a friend that has the 7.3L and has added a K&N system and a 4" tailpipe plus the 'program'. My question is "Is all of this necessary?". This truck has great get-ee-up and towing ability as is. I use mine to travel w/ the family and towing my 4000lb boat to the lake and sometimes out of state. And like I said - MAN WHAT A TRUCK! right now planning on keeping this one til the wheels go square.....
    I posted this exact message on another post and was directed to put it here - ANYWAY - my truck is awesome - I went from a ranger to a f150 4.6 v8 to this 6.0L diesel - WOW!
  • rrichfrrichf Member Posts: 211
    connon,
    Generally speaking, the diesel class of oils are intended to keep the carbon particles suspended. The carbon particles are the result of burned diesel fuel and blown by the piston rings. This is much more prevalent in a diesel due to the higher compression of the engine. Usually the commonly available oils in 15-40 are diesel and have the API ratings to support use in a diesel engine. Using a 10-30 weight oil may not harm the engine from a lubrication perspective, however the lack of the ability of the 10-30 oil to keep the contaminates suspended could be disastrous and very quickly.
    that 10w-30 oil is rated for diesel engine use.
    Changed the 10w30 out and went with the 15w40. I should have let the techie put it in the first time. all better now.Drove the monster from No. NJ to Tallahassee three fillups. The third was really just a topoff because fuel in Ga. is cheaper than Fla. avg on last tank was almost 20mpg! Gotta love it.almost all the way doing 75-85 mph in cruise.beautiful ride with almost no traffic.almost as smoothe as my 01 f150 screw.too bad the trip computer really doesn't reflect mpg accurately. it's still reading 16.5mpg. 525 miles to empty on the last fill! this truck is fantastic. 04,cc,4x4,King Ranch.6.0. I think the Pace Edwards roll top helps with the mileage as well.
  • montanaf250montanaf250 Member Posts: 3
    Have a 02 F350 CC 4x4 with 14000 mi. The Problem is when comming to a stop the engine will stall. It will start right back up but when you put it in gear it stall again. I'll let truck sit for a few min. it starts up and runs fine for a week or so then happens agin. Have had truck to dealer four times and can't find problem. I sure could use some help on this one.
  • wpalkowskiwpalkowski Member Posts: 493
    V8, V10, or PowerStroke Diesel?
  • hobbes13hobbes13 Member Posts: 2
    I'm looking to buy a diesel '99 or '00 Ford SD crew cab and most of the ones up for resale seem to have 60 - 100+ miles on them. I've never owned a diesel before. Assuming the engine has had it's routine maintenance - how long should the truck last? I plan to use it for everyday life with some towing of a jeep sprinkled in here and there adding up to between 20 - 30k miles a year. Thanks!
    I haven't seen Jim Mulliins comment yet, so I'll take a stab. At 60K the PowerStroke is finally broken in. With care the engine can easily go 300K without a rebuild. Other parts of truck will probably start falling apart long before the diesel gets tired. If possible try to find a truck with maintenance records.
       From what I understand one of the few things that can compromise the longevity of a diesel engine is coolant cavitation. Cavitation occurs when microscopic bubbles momentarily appear in coolant - when the bubbles pop (implode) near the outside of the cylinder wall they cause microscopic erosion of the metal. Over years, it can cause $$ problems. If previous owner used anti-cavitation coolant additive then great. Unfortunately a lot of diesel owners don't know about this phenomenon or the additive. I don't know how fast cavitation will cause damaged, my guess is at 60K, it's probably not worrisome. Maybe Jim can add his knowledge here.
         Some '99 and '00 Powerstrokes exhibited a noise called "the Cackle". Supposedly a funny noise akin to pinging in a gasoline engine. Had something to do with a shortcoming with an injector on cylinder 5 or 6 (?). Supposedly, the noise doesn't damage the engine, but a lot of folks with the cackle complained of sluggish engines, or mediocre mileage.
        Diesels require a bit more maintenance than gassers - bigger oil capacity, more expensive filter. Bit finicky on quality of fuel too - watch out for fuel with water in it; buy your fuel where the big rigs go to ensure it's fresh. Need to be religious about changing fuel filter, and learn how drain any water out fuel line separator. Also, have to be mindful of cold weather - starting is a bit more complicated than a gasser. Need to wait a minute while glow plugs warm up the cylinders before trying to start. Depending on how cold it gets in your area, you may have to use the engine block heater too.
        By and large Super Duties are pretty solid trucks. They have a tendency to warp brake rotors, and can be rough on ball joints, etc. But you can beat the snot out of them on a daily basis and they'll keep going. Though, personally I'd stay away from one that had been used to plow snow, or one that had towed a really heavy trailer for a living.
      Disclaimer: I own a V10 F350 4x4, and have two very good friends with '99 and '02 Powerstrokes. However, I'm the one who has a heated 30x30 garage with 8 ft doors. So guess where everybody's winter maintenance gets done? All my diesel knowledge rubbed off from them.
    has hit the nail on the head again!! :) The cavitation is something I wouldn't worry about on a 60k mile engine. However I would make sure that I put that coolant additive in it. It's called "FW-16" and is available at your friendly Ford dealer for about $15 a pint. I order mine online for half that. That online place will even send you the test strips so you can test the coolant in order to add the appropriate amount of additive. Email me if you want that address.
    The cackle can be a bit worrisome. Ford says there's no damage to the engine, but the ones I have talked to that have cacklers feel differently. I think the problem lies in part in injector #8. At some point Ford started putting in an injector stamped "LL8" (long lead?). This supposedly fixed the problem according to them. But the Ford abandoned the LL8. I don't know why unless new computer programming fixed it. I have an early '99 that has the regular #8 injector, code "AB" I think. To my knowledge I do not nor ever had a cackler.
    Rotor warpage, IMO, seems to be related to drivers rather than the truck itself. That SD CC is a very heavy truck. But with that said, I have 142k miles on mine and they are just now beginning to exhibit very slight signs of warpage.
    Even if you do your own oil changes, look to spend about $35 to $40 for oil and filter. Fuel filters are available at the dealer for just under $50, or online for $15. Same filter too. :) Maintenance is VERY important. You are going to pay extra for that engine, so you'll want to make sure it lasts a LONG TIME.
    Starting in cold weather has only been a problem on those occasions, like last week when the temps suddenly went to near zero, when I got caught with my pants down by not having my usual winter time fuel additive in the tank. I use Stanadyne, in case you're wondering.
    Fresh, water-free fuel is of great importance. About this time last year I got some water-laden fuel that ended up costing me $900 for two new injectors. These injectors don't cost $450 each, that $900 included labor, testing 4 injectors and replacing 2 with rebuilt ones.
    With proper maintenance, that truck should go 300k with no real problems. Give us a few more details about the truck you buy, we'd love to hear about it!
    Thanks for the information on the engine...I would not have had a clue what to look, listen and ask for/about when I go to buy one. When I get one, I'll be sure to let you know the details.
    Thanks again!!
    Andy
  • rscott6rscott6 Member Posts: 20
    Anyone out there with a 6.0..When going 70 MPH what does the Tach read?
  • socsmm6socsmm6 Member Posts: 2
    i own 2 7.3 diesels and considering buying a new truck with the 6.0 diesel but don't know if it is as good and strong as the 6.0. does anyone have the 6.0 with over 150000 miles on it and still like it.
  • jatwaterjatwater Member Posts: 3
    I own a 2004 6.0 and at 70 mph mine shows about 2100-2200 rpms. Also to give a heads up to anyone who should have the following problem: Going do steep inclines my cruise control will shut itself off. On 2 occasions, the engine has cut off too. The dealership has diagnosed the problem as a switch in the telescoping brake and throttle pedals. Part ordered and problem solved!
  • hdriderhdrider Member Posts: 49
    Jim (Mullins87) (or anyone with knowledge on this),
    What online sites do you use to get your parts, filters, additives and such? Wife just got a new 04 F350.
    Dave
    Well, I gave Jim more than 24 hours. He must be on vacation. I think this is one of the sites that Jim would recommend anyway
    http://www.dieselsitetoo.com/store.asp
    Good luck with the new truck.
  • horseshoerhorseshoer Member Posts: 1
    Just found out my 03 F250 has 3.73 gear in front and 4.10 gear in rear. Plan on trading it in tomorrow. Worried about further damage. Any recommendations
    This can't be a factory job, is it??? If it were, I'd make them fix it!!!! As far as any damage to the drivetrain, there shouldn't be any unless you have engaged 4-wheel drive on dry pavement or any other non-slick surface. Even in mud or some other slick surface, do damage should have been done.
    Walt: I sent the guy an email. I didn't know if Edmunds would allow me to post a website address. I got my hand slapped by the host over in the Jeep forums for doing that. Didn't want to take a chance a do it again. Bob's place there really is a very good one also.
  • groupergrabbergroupergrabber Member Posts: 1
    I am in the process of ordering an 04 F250. I plan to get the King Ranch package, Diesel, auto, 4x4. I plan to tow my boat several time per year and may pull it up to 1K miles. My wife and I have talked about getting a 5th wheel some day but who knows. The majority of the time this truck will get me back and forth to work in the winter.
    The dealer has recommended that I go with the standard suspension w/o heavy front springs or stabilizer bar. He thinks I'll prefer the better ride on a daily basis over the slight improvement in towing behavior.
    Any advice who be appreciated.
    Get the heavier front suspension. The diesel engine is very heavy, at least my 7.3 is. I've added airbags to my front as I have noticed a slight drop in the front. And I can point you to several PSD owners on another website that has upgraded their front springs as they are also sagging from the weight of the engine. Also, get the camper certification package. That probably will give you the heavy front springs, but it will also give you larger sway bars front and rear. I have them on mine and body roll in a corner is almost non-existant. When you get that 5'er, you'll appreciate that extra stability. However, if you off-road your truck very much, then you might not want the stabilizer bars as they do limit the amount of articulation in the suspension.
  • bpetbpet Member Posts: 16
    Does anyone know where to find Technical Service Bulletins for a 2000 F-250 SD 4x4?
  • jf067jf067 Member Posts: 17
    I bought a ‘04 F250 SD SC with the 6.0L 6spd auto. My truck came with a 3.73 limited slip rear axle. About a week ago I was parked with my pass side rear tires in a small snow bank on the side of the road. When I went to leave, the pass rear tire started spinning. I could see my driver's side tire in the mirror, it wasn't moving at all. I was not hammering on it at all, just gently accelerating. I had no load, and no trailer, just the empty pickup. I thought a limited slip was supposed to push from both tires? I asked my dealer about it, they claim that the factory has told them the rear end is supposed to break free at 53 ft. pounds of torque, so this is normal. What the H_ll good is that when you have 504 at around 2k RPM?? I figure I could have saved the 300.00 and had a standard rear-end for that matter. Anyone have/had a similar experience, or input on this?
    There's a little trick with a limited slip rear end to get going when you're in situation where one wheel is spinning.
    Push the parking brake in part way. Not a lot, but just enough to put some drag on the wheel that has no traction. This will shift some of the torque over to the side that's not spinning and allow it to start going.
       It's a "limited slip" rear end, so it only will divide the torque between the two sides up to a certain point. (Like the spec the dealer mentioned.) If you want power equally distributed to both wheels, you'd have to get a "locking" differential. Lockers are great for mud bogging, and can get you out of really deep snow, but they're impractical and possibly dangerous for normal driving. A great compromise is an "air locker" - a pneumatic control on the dash allows you to momentarily lock the differential when needed, then release it. Unfortunately, they're $$$.
       Lot of folks complain about the Ford LS rear end. I think it's fine - applying the brake has always worked on my F350. It takes a while to get a feel for it, but then it's second nature.
    Thanks for your reply. I have heard of that trick before, but It didn't occur to me at the time I guess. I think I was too upset over what I was observing. I have had limited slip rear-ends on several cars I've owned in the past, they never acted this way. I read your explanation, but what I don't understand is why we should have to be "tricking" the rear-end to do something that it should do normally? Their explanation of a 53 ft. lb. breaking point seems awful low to me. You could almost go past that just putting the truck into Drive! I mean, my old Camaro would do better than that - I guess I may be stuck with it, but I'm not going down quietly as far as the dealer's concerned.
    Have you, or anyone else had trouble with door-alignment on the Super Cab? Mine knock and shift when on a bumpy road (normal speed). If I'm at a complete stop, turn the wheel hard in either direction, then accelerate, it (driver's side)shifts so loud it scares you. (First time in happened, I thought I ran something over pulling out of a parking space) Luckily nothing/no one was there!
    Thanks again for your help.
    Jim
    Sorry to be hitting you guys up for info again. I'm being told be another 04 6.0 diesel owner that the Hyper-chip is the way to go. I realize my warranty would most likely be voided to do something like that. This guy is telling me that the computer can be rolled-back to factory default settings before you have it serviced, and the performance boost is well worth it. Now mine has already been re-programmed once by the dealer a week after I bought it, due to an emissions recall. Has anyone tried this Hper-Chip? Is any of the talk true?
  • tukul1tukul1 Member Posts: 1
    I heard from a person who installs the boxes and changes exhaust that the 6.0 is really awsome, but i also heard from a guy who worked at the ford manufacturer that you should not install anything, don't change exhaust or add a box, it will decrease the life of your pickup and increase problems later on, those trucks are built to last like they are from the factory. For the other person wondering about the tacs on the new 6.0 mine reads 2 at 70 mph.
    Your friend is correct, but not completely. Those engines are built by Navistar(International). They are extremely tough engines from the factory. Adding a mild chip and changing the exhaust most likely will not in and of itself shorten the engine's life or cause problems down the road. Lack of proper maintenance will, especially when coupled with performance mods.
    The only word of caution that I have when adding a performance chip is this: Get a pyrometer, a gauge that reads the exhaust gas temperature. A chip can raise the EGT's to a point where turbo failure could occur. However, lot's of people run mild chips with no pyrometer and never seem to have any problems either.
    You mentioned also adding an aftermarket exhaust system. A larger diameter system with a less restrictive muffler, or none at all, will most likely reduce the EGT's. However, there is a downside to doing this. Unless you're going to go with a hot chip, you may notice a loss of low-end torque. I don't know the physics behind this, I just know of others that have noticed it. I'm sure if I wanted to, I could find dyno data to prove it also.
    Gentlemen,
    Thank you for the sites! I have bookmarked them! They will come in handy soon.
    Right now, we're looking for nerf bars that are frame-mounted, and not body-mounted. Any recommendations!
    Dave
  • lleggllegg Member Posts: 5
    I'm looking for a truck to tow a gooseneck horse trailer with a GVWR of 6080. I think I want an F-250 Super Duty, extended cab, 4X4, manual transmission, gas engine. The truck won't be used more than about 1,000 miles per year for short trips (less than 50 miles each) so I don't think I want a deisel.Any arguements there? What I'd like your "expert" advice on, guys, is what other details I need to know-I'm not knowledgeable on gear ratios, types of engines, etc. Can you give me a hand? Thanks, Lynn
    Lynn,
      Considering you're only doing short trips, and only a 1000 miles per year towing, the diesel would not be a good option for you. It'll pull anything, and gets significantly better mileage when towing than a gas engine, but it costs ~$3K more and you'd be hard pressed to make up that money difference on fuel savings alone. Maintenance is more involved as well, and the low miles you say you'd be doing may cause you a few more hassles with a diesel. Stick with a gasser.
     Does the 6080 lbs trailer weight include the weight of the horses? A gooseneck puts a fair portion of its weight over the rear axle of truck and this affects the payload capacity of the truck. Payload of F250 Supercab is around 2200 lbs. (Payload includes passengers and their gear, along with the weight of the gooseneck.) That trailer puts at least 20% of its weight on the truck - that's 1200 lbs right off the top of your payload, before the passengers, the cooler, luggage etc. - doesn't leave too much payload capacity for the tack, feed, etc. (If you've got a couple of 1200 lb horses to add to the weight, the remaining payload's even lower.) Don't want to spend your money, but for ~$750 more you might be better off with next step up in trucks. The same configuration in an F350 - has a payload of about 3300 lbs. You can "legally" carry half a ton more.
       Also where do you travel? Any big hills that you're gonna have to go over? There are two gas engine choices in the Superduties- 5.4L V8, and 6.8L V10. The 5.4L can have either 3.73:1, or 4.10:1 rear ends. The 6.8L comes with either the 3.73 or a 4.30:1 rear ratio. The higher number means that the engine turns over more times for each revolution of the rear wheels. So the higher number ratio puts out more torque and allows you to pull a heavier load easier than the lower number axle ratio. Of course since the engine spins more, there is once again a small mileage penalty.
      You said you wanted a manual transmission. This will give you a lot of control over the engine's power, so you could probably be fine with the 5.4L with the 4.10 gears. (Might still be a little slow towing over a mountain.) A V10 with 3.73 is only about $600 more, but you'll have a lot more power at your disposal, and surprisingly, the gas mileage is not much different than the V8 with 4.10 - the V8 has to work harder to pull the same load and ends up burning just as much gas.
       I am biased. I have a V10, 3.73 automatic, 4x4 Crew Cab. I tow more than you, but still not enough to warrant the diesel. I've towed 10K lbs and am quite happy. (Well except for maybe the towing mileage.)
    I agree with everything Walt said, with one exception. The diesel will set you back ~$4,500, not $3,000. Sorry Walt, your advice is so dead-on, I felt that I had to pick it apart somehow.
    Walt,
         thanks for the advice! I took a test drive today in a truck that had most of what I was looking for-F250 SD, 4 X 4, extended cab. It was a little sluggish on hills, and I was wondering if this is typical of this truck, and if it is a truck I should consider for what I want to haul.The trailer I will be hauling is a gooseneck that weighs 2100 lbs. empty and has a gross loaded weight of just over 6000 lbs. The truck I drove today was a Triton V8, 5.4 L. gas engine. Of the three engine sizes available in this truck, what do you think of each considering what I will be hauling (3 horse gooseneck trailer). Thanks so much for your advice! Lynn
    Walt,
        forogt to mention the truck I test drove was a 2001 model (any particular problems with that year?) and it has 63,000 miles on it, one owner. Looks clean and rides nice.
    Lynn
    One more correction....the trailer weighs 4100 lbs. empty, not 2100. It has an automatic transmission.
    The 5.4 Triton is a fine engine, and with proper maintanance should go well beyond 100k miles. But, that sluggishness that you noticed, while driving around empty, will only be compounded when you have that trailer behind you. For what I think you are wanting, I'd suggest holding out for a V-10.
    Jim is right. 5.4L is good engine, but the Superduty with 4x4 and an automatic is a big load to move, so it's gonna feel sluggish. Worse when towing. If you can find one with a manual transmission, and a 4:10 rear axle, it won't be sluggish as compared to the automatic.
       The diesel is the superior platform for towing. With it, you would barely even know that you're pulling the horse trailer. If you can find a good used one it would serve you well, though it would cost more $$. But be advised, it'll take extra care and attention to deal with the foibles of a diesel. 15 quart Oil changes. Issues with fresh diesel fuel, water in the fuel, then summer vs. winter diesel and cold starting issues. (My wife dislikes diesel fuel odor, and positively loathes the exhaust smell.) Loads of folks deal with these matters all the time and love diesels; it would be a matter of your personal choice and pocketbook.
      My (biased) choice is still the V10. The extra two cylinders make a big difference in the way the truck moves out. (I have a 3.73 rear.) No special driveability, or maintenance issues compared to the diesel. Similar power output, just not as good mileage as the diesel. I surprise other cars with how fast my 7500 lb 4x4, crew cab behemoth can move when I need it to. It's just a bit disconcerting to watch the gas gauge visibly move as a result.
      My truck is an '01, with 26K on it,(not my daily driver,) just out of warranty a couple weeks ago. No major problems with it. One stupid one: lock on tailgate is possessed and locks itself going over bumpy roads. Only problems I've heard other folks consistently complain about is a tendency to go through ball joints quickly, and warped brake rotors resulting in pulsing brakes. V10s can sometime have a problem with blowing out a spark plug - I guess cylinder head is only 5 or 6 threads thick (and can be stripped?) Plugs are supposed to last 100K miles, but you still need to pull and inspect them every so often. I put anti-seize compound on mine, and take special care to put them in at the specified torque setting. So far no problem.
    Older model (pre '01) Superduties were a bit shy on transmission cooling - could factor in towing on hills. People add tranmission temperature gauges and supplemntal cooling to prevent costly problems from overheating the transmission.
     I love the truck, and would have no pause in selecting the same setup should I need to buy another.
