I was less pleased with their service people. I have only used their service dept. once (I posted before about it) to fix the cold start idle problem. They acted alittle unfriendly when I showed then the TSB and insisted they didn't have to experience the problem first hand to fix it since I experienced the problem each morning!
Overall as dealers go they are fine. They did pay for a rental car when they ran out of loaners. Not sure other dealers would do that. They also gave me a free wash after the service visit.
STEVE
I took the car for its 7,500 mile service to Troncalli Infiniti in Decatur, GA who replaced the TCM and the transmission solenoid valve assembly under TSB Ref. AT00-004A (NTB00-039a). This has transformed the drivability of the car and eliminated the problems listed above. Check with your dealer to see if this fix applies to you car’s VIN – they fixed it on later models.
I called your Infiniti dealer, Ray Catena in Edision, 732-603-9600. the sales, Mike, told me that they do sell I30 with traction control, CD changer, heated seats package, and splash guards for ONLY $28,000.
i am looking for buying I30 in a week.
thanks for your information.
George
Any comments on this?
I liked the tirerack interface, it shows your car and what the rims look like on the car, however, the brand names they had weren't recognizable, and the prices were a bit higher. I then tried tires.com and they had a wider selection, and more recognizable brands. I decided on a set of 17" rims from TSW, with size 225 tires. I hope they look good, and I chose them because they best match my current BBS wheels which came on the "t" I30 models from 96 and 97. The tire selection was quite wide, however, I did not wish to opt for the "Z" rated tires, as I do not drive that fast, and also, I do not require that much performance. I decided to go with a brand of tires called "Nitto" which offered a set of "V" rated tires, for 129.00 each. Unfortunately, there were only these two choices for the size 225 (the Nitto or the Z rated Michelin). The 235 tire size offered many more choices, all for lower prices too, but again, these were all Z rated tires. I did not want to run into any issues with tire width either, and I am quite sure that 225 will be acceptable. I would really appreciate the 2000 "t" model rims on my car, but the dealer said the cost would be thousands more than reasonable. Thanks for the advice on where to get the tires fitted, I will try Dunn Tire...I would also like to ask your opinion of the Goodyear tire shops (especially the one located on Transit Road across from Regal Theaters)? Thanks again!
He also said that the TSB ITB00028 related to the TCM only applies to vehicles with a VIN number of 015xxx and before. My car has a VIN number of 108xxx. I double checked with Infiniti and that is true. To check on your car look at the last 6 digits of the VIN number.
Does anyone own an I30 that has had the TCM/seloniod replaced that has a higher VIN number then 015xxx?
Thanks for your help,
Tony Scuderi
Then I had a conversation with the dealer. The dealer said that they drove it this morning while it was cold and noticed a slight lag. This morning was not a cold morning. I mentioned on colder mornings the lag is very noticeable. He did not care. My word did not mean a thing. He said he could only go by what he sees and he refused to do anything. I could add a few choice words to describe him, but I will hold back.
I have no options to fix this except drive 60+ miles to another dealer which I doubt I will do.
mhammy.... I wouldnt even bother looking elsewhere, You simply cannot beat Dunn Tire around here. They have many locations, in fact, there is one in the Clarence Mall, next to the former Burlington coat factory. To answer your question though, i have not heard anything positive or negative about Goodyear.
You are right, that is why I tried to find out if my car was one of the cars that the TSB affected. I received a few different stories from Infiniti Corporate.
1. First they said NO based on the VIN number
2. Then they said YES, that all 2000 Infiniti I30's fell under the TSB.
3. Then they said that based on the updated TSB xxx28a, that only some VIN's for 2000 fell under the TSB and mine was not one of them.
So since I could not use the TSB it was hard for me to push the dealership. I do not understand how a car can go from being affected to not being affected based on an updated TSB.
redskin: I ended up ordering a set of 17" Voxx rims (conservative looking rims) from www.tires.com, to be mounted and balanced on a set of Dunlop Sport 5000 235/45 ZR17 A/S tires. The rims will arive to my home on Monday, and my appointment with Dorschel Infiniti in Rochester is on Tuesday...they have agreed to install the new tires onto my car for a mere $30 total (and I certainly dont mind paying them for it). I do hope the tires/rims accent the look of the car.
The only noticable things about the other car was rims (pretty sure they were 17s) and that unmistakable sound of that k/n airfilter.
Perhaps it's time for me to opt for forced induction (if stillen offers it) and a good eibach suspension system.
And just to bring everyone up to date about my transmission problems.....after a very agressive standoff with the service guys....they have agreed to fix my tranny and if they cannot..... they're gonna replace it.
mhammy... $30 is a nice price! To update you on my "service" visit: I woke up at 8:00 am to take the car over there. i drove as slowly as i could, so that the car would be semi-cold when it was there. I pulled in, the service manager and i went for a ride and the car did what was wrong(thank God). the guy told me he would have to order the parts and to bring it back on Tuesday and they'll give us a loaner. Total time at dealership: approx. 20 min. On monday, my father got a call from Autoplace stating that the parts werent in(they were "backordered") and they will call us to set up an appointment when they do. It is now Saturday and still no word from the dealership. This is somewhat of a problem because we also wanted an interior detail, oil change and inspection. ill keep you posted.
I took your advice about Dunn Tire and just had the folks there install it since I received the rims package on Friday instead of Monday. They charged me only 17, as opposed to Infiniti's offer of 30 (just to bolt the tires on). The Z tires are slightly noisier at lower speeds, but they are very good tires.
When you were at Autoplace, you must have met with Tom Wall, the service manager (thin, tall older fellow). Looks like you had an OK experience with them so far...hope the rest follows through for you. Did you tell him that you found a TSB for the issue, or did he take your word for what was wrong with the car (and offer any new input)? Will you get your detail from Autoplace or from Delta Sonic?
...went to the Autoshow also, not what I expected. Mostly passenger vehicles there...nothing really of the "concept" status. I did like, however, the NEW Q45 and the LS430 parked next to it. The Q45 had height adjustable HID lamps with 7 projectors on each side...very nice. Driving it must be a whole other story...340hp V8!
mmcbride1: When not having a major service (30K miles, etc..), where do you take your car for service?
Auto show was ok, it was more fun last year when my dad was in the market and we got to be nitpicky. this year was just for fun. Wasnt it odd that all the Lexus' gear shifts were removed?
I would suggest you change the brand of gas, drive it for 2 weeks, and if you still hear ping during daily driving take it to the dealer.
(Often its the gas causing the problem so changing brands is worth a try and always use 93.)
Good luck
STEVE
When I took my I30 in to have the wind noise problem corrected, another service writer said he had never heard of wind noise problems in the I30. When I got the car back, the invoice said "repaired and replaced both rear window run rubbers and installed foam shims." It reduced the wind noise by about 75%!
I drove back to central Illinois the next day to visit relatives and left my car outside in my sister's driveway (she wasn't having anything to do with garaging mine and letting her car sit in the cold). It was about -10F I with wind chill overnight and the next morning, I noticed the wind noise had increased from the rear windows. This happened the next morning as well. When I got home last night, I garaged the car, as usual. My garage isn't heated, just well insulated. This morning I didn't notice the increase in wind noise. It seems the rubber window seals do shrink somewhat in cold weather. Maybe Infiniti should find a new supplier for their window seals!
If you haven't gotten your problem solved as of yet, then I hope this helps. Good luck.
I have the 2000 I30 with the heated seats/traction control option both of which are great. (live in NJ) At the time, could only get the dealer to go down to 4.5% over invoice (29,000). But it was early in 2000 so they were less flexible.
Have fun.
STEVE
ps the silver and black leather is a nice combo and the silver never looks dirty!
However, the first service writer said their experience with the wind noise came from the same area you described. In my I30, it was happening on both side rear windows, near the small window by the "C" pillar.
If it helps, let me know and I'll send you a copy of my invoice where the complaint and solution are clearly listed, with no TSB reference. Maybe if your progressive, service oriented dealer sees that, he'll try the same repair, or at least call Infiniti of Cincinnati, who didn't hesitate to fix it.
I would like to know why these particular seals shrink with the cold (I know it's basic science), when our experience with Acura and the seals on their Legends and Integras was (or still is) completely different.
I would appreciate your sending me a copy of your invoice with the complaint/solution to the wind noise. Although mine is the Maxima, the problem is the same.
-umpopa
doc@zunga[dot]net
I am sorry to hear about what you are going thru trying to get the "delayed shift" resolved. I went thru the same experience. The dealer refused to fix the problem with my car saying that the delayed shift fell within the "normal guidelines", whatever the hell that means. Just like your car the delayed shift is very noticeable when the car is cold, although my engine light has not come on.
I called Infiniti Consumer Affairs to find out what VIN numbers are affected. They told me that
according to TSB ITB00028a, which replaces TSB ITB00028, only cars with VIN of 015xxx and before are affected. My car has a VIN number of 108xxx so according to Infiniti my car was ok. To check on your car look at the last 6 digits of the VIN number. The earlier TSB said that all 2000 I30's had this problem, but the new TSB changes that.
To me this sounds like a load of crap. How can one TSB say ALL cars are affected and then a later TSB changes that.
Good luck with your car, and do not give up!
I've searched through this thread - I'm wondering if others have had problems with I30s with stick shifts???
