Volkswagen Jetta 2005 and earlier
1235236238240241248
  • scapecoatscapecoat Member Posts: 2
    Hey, so the 2005 Jetta is coming out in March, correct? Does that mean that VW dealers will keep selling the current 2004 until that date?
  • fish8fish8 Member Posts: 2,282
    That is correct and probably a little after the new one's arrive.
  • justinjustin Member Posts: 1,918
    all Jetta sedans are built in Mexico. all of them. all Jetta wagons are built in Germany.
    their will be an 05 Jetta IV, and an 05 Jetta V (New Jetta). just like in 99 there were two Jettas. The 99 Jetta (III), and the 99 New Jetta (IV).
  • cgatzkecgatzke Member Posts: 5
    The 05 Jetta will have a body style change, mid year, I have been told.
    As for my 03 Jetta GLS, 1.8t, I love it!!! Sure you are going to have problems from time to time. And being a German car, I will cost you.
    I think VW is trying to make themselves in the same league as BMW or MB. I think they are achieving it. Not yet, but its not the VW of old.
  • ivan_99ivan_99 Member Posts: 1,681
    Not BMW or MB, the new Golf interior (which I assume will be used by the new Jetta 5) comes very close, especially considering the price
  • greamergreamer Member Posts: 8
    I've referred to this in a prior post, but does anyone know if there is much difference in brightness between the DRLs and the regular headlight? I see very little difference between the two on my 2004 GLS. The dealer says there is little difference, but my sister has a 2000 1.8 Turbo, and the difference is substantial.
    George
  • bpeeblesbpeebles Member Posts: 4,085
    I have a 2003 Jetta, there is very little (if any) difference between the DRL and normal headlight brightness.
  • joejettajoejetta Member Posts: 1
    16,000 miles and no problemo.
  • yupoldbullyupoldbull Member Posts: 28
    BPeebles.....You have given out some good information in these Jetta forums. (much better than the information we were getting here several years ago!) Congrat's and thank you! Here is some data on the Jetta from my perspective. Hope this will enlighten you and others. It hasn't been very pleasant experience for me. I suspect a class action lawsuit (due to similiarity of complaints) will follow. I truly got a lemon. Hope your readers made out better than me.
    9/20/99 purchased a 2000 Jetta GLS 5sp 2.0 liter 115 hp 4 cylinder $20,614
    First Month:
    Air conditioner leaked and had to be recharged.
    Check engine light came on.
    Gear shift knob broke. (loose)
    Check engine light on again.....Second time.
    3 Months Later:
    Burning oil at 3k......Dipstick was dry. Burning 1 quart every 1000 miles.
    Glove box hinge broke.....
    Rear defroster had two strands that didn't work.
    Sunroof broke.
    Front floor mats broke.
    Seatbelt recall from VW.
    Front window fell out and crashed inside of the door.
    Engine light came on.....Third time
    6/11/00 Wrote letter to VW Dealership outlining my concern about the oil consumption
    Started oil consumption test at Dealership.
    Talked with 2 Service Managers (one quit) and VWOA Rep. Both said oil consumption was "normal". Told by dealership and VWOA rep. that this was a "break-in" process and it would disappear at 15k. It didn’t.
    Young VWOA Rep. taught me how to read a dry dipstick. (I was rebuilding engines in 60's!)
    Given VW Technical Service Bulletin #92-01 dated 1-31-92....said .85 quarts per 1,000 miles is Ok. I said 1 quart of oil per 1,000 miles is way too much! I was correct.
    It is very…. very easy to run one of these vehicles dry of oil in between oil changes. I can’t imagine purchasing one of these Jetta’s “used” without knowing the history.
    6/22/00 Replace front floor mats.....second time.
    6/25/00 Check engine light (mil) on again.....3rd time
    7/18/00 Contacted lawyer at http://www.lemonlaw.com
    8/3/00 Lemon Law / Breach of Warranty Case filed in court against VWOA.
    8/22/01 Front window crashed into door.......second time.
    9/25/01 Went to Arbitration Court
    9/25/01 Negotiated Settlement just prior to court appearance.
    9/25/01 Won Settlement (It took 14 months)
    9/25/01 Told to start going to a different VW dealership with a different VWOA Rep.
    10/19/01 Replaced the rear brake pads 40k......front pads were perfect! (?) Rear pads were completely worn out.....front pads still had 3/8"......either defective pads or defective braking proportioning. This is a 5 speed.....the car stalls in first gear with just one click on the emergency brake! (and we don’t ride the brake!)
    Talked to new VWOA rep. He said it was known for the 2.0 liter engine to burn oil because of defective rings. He said the first VWOA rep. should have told me that and offered to fix the problem.
    He said that deglazing the cylinder walls and new rings would fix the problem. It didn't.
    12/22/02 42k……have added 21 quarts of oil since purchase. 1 quart every 2,000 miles.
     1/07/02 43k New rings and deglazed cylinder walls.....part of the settlement to stop oil burning.
    1/07/02 Replaced broken front mats (3rd time) with rubber mats.
    1/07/02 Replaced temperature gauge sensor.
    1/07/02 Replaced Mass Air Flow Sensor.....to fix engine light. This probably broke the oxygen sensors listed below.
    1/07/02 Fix glove box hinge......second time.
    1/07/02 Fix both front windows with new clips......3rd time.
    1/07/02 VWOA Rep. refused to fix rear window defroster. (too costly!)
    12/14/02 Glove box hinge broke.....third time.
     5/13/03 Car wouldn't pass state inspection.....2 Oxygen sensors......$360. (later reimbursed)
    6/22/03 Waiting for official VWOA recall on glove box hinges. Mine has broken 3 times…..and is currently broken. We only use it 20 times per year! (Max.) Come on VWOA……It is “just like” the window regulators and mass air flow warranties!
    7/24/03 Front window crashed down into door.......4th time
    7/26/03 75k Talked with VWOA Rep. Told him the car had 75k and still burned oil at the rate of 1 quart per 1,000 miles and that the new rings and deglazing didn't help. VWOA rep. said he couldn't help with the oil burning. (Said that rings and deglazing cylinder walls usually was a “fix” for oil consuming engines) Also told him the front window fell down into the door for the 4th time and the glove box hinge broke (3rd time) He said that he would pay for the windows....."now" they had stronger plastic clips......but I would have to pay the labor for the glove box.
    7/28/03 Car in shop to fix front windows......4th time.
    7/28/03 Declined offer from VWOA rep. on repair of glove box hinge.....I wasn't going to pay the labor. (Figured these people are stupid!…..why should I pay the labor for a repair…..if they keep putting the same bad parts in….and getting the same failures!) Sure glad they don’t work on the space shuttle.
    10/1/03 VW Window Regulator Litigation notice received. My windows broke 4 times.
    10/12/03 Front rubber replacement mats working well......didn't brake yet!
    11/04/03 Dash lights blink.....sometimes they work.....sometimes they don't.
    11/22/03 Intermittent trunk light.....same way.
    11/28/03 Mass Air Flow Sensor Warranty Extension......noticed received from VW. Looks like they brake every 2 years....mine was replaced at 2 years.... 43k. The extension notice says 7 years or 70k. I am screwed again.....my car has 80k and broke at 43k. Wonderful.
    3/12/04 Front of plastic cup holder brakes off……hardly ever used. I fixed it with a piece of stiff wire.
    6/15/04 90k……I have added 45 quarts of oil since purchase! 1 quart every 2,000 miles.
    7/19/04 91k Replaced plug and plug wires and oil change ($258)......(This should have been done at 50k.....kids!) .....No beef with this as it is normal (missed) maintenance......but $258 is very expensive for 4 plugs, plug wires, and an oil change.
    7/19/04 Mentioned that the car still burned oil to the dealership ....They asked if I was the original owner......told to start an oil consumption test (again!) at 91k. Told to drive it 1,000 miles and come back.
    8/24/04 92k....Drove it 1,000 miles.....Technician agreed that it burned oil at the rate of 1 quart per 1,000 miles and that the new rings were not helping. I was told it needed a new engine and that they would order one.
    Minimum of at least 20 repair visits to the dealership so far…… I have only had it 48 months!
    9/01/04 Source for legal opinion on VW oil consumption
    http://www.lemonlawclaims.com/Volkswagenoilconsumpt
    I truly feel for you. VWOA should have replaced the car and "made things right".
    Instead, they have lost a customer for life (yourself) and perhaps others that hear your story of woe.
    It is sad when big corperatons do not realize that EVERY customer is important.
  • sandbarsandbar Member Posts: 3
    The wagons are made in Germany; the sedans are made in Mexico.
    The Wagons are made in Germany; the sedans are made in Mexico.
  • kyleknickskyleknicks Member Posts: 433
    wow... looks like you had one really defective car.... my gf's glove box has the same issue you do..the dealership didnt want to acknowledge there's a problem.... we're just gonna leave it for now..
    what did you mean your floor mats broke??
    The front carpeted floor mats had a hole in two corners. On the floor, near the seats, there were two immovable clasps mounted to the floor....(similiar to the front clasp that you will find on a pair of bluejeans) The idea is for the holes in the floor mat to hook over the clasps on the floor and be held in place.
    The problem was that when you get in and out of the car....you push down slightly with your feet and put pressure on the mats. This caused them to slide forward and tear free from the clasps. (ripping the holes)
    Then you would get in the car and find the mat "folded up" under the brake pedal from your last exit. The holes in the mats were too close to the edges and were not "reinforced". As so often in other cases with VW....they kept putting the same defective replacement part back in.....and getting the same failure. These carpeted mats wouldn't last more that 6 months before ripping out.
    After 3 or 4 rounds of failures....The rep. "gave in" at 43k, and replaced the carpet mats with a set of really heavy duty "deep" rubber mats, which are very, very nice! ($120 prox.)
    This is a classic VW response to a small problem....we know the problem exists, we will replace with another "new" part, with the same inherent defect....you will get the same failure, in about the same amount of time.
    They have done the same thing with window regulators and glove box hinges. Not sure about
    oxygen sensors, mass air flow sensor, front cup holders, sunroof repairs, rear brakes, and oil burning engines.
    Anyway this is an old (3-4 year) issue. If VW hasn't fixed this one yet.....they won't ever correct anything!
  • rdeerdee Member Posts: 1
    Hi, I'm almost 16 and my parents and I are looking to buy a car for me withen then next month. I personally have fallen in love with the Jetta, but after reading some of these posts are unsure. The specific car I have in mind is a 2000 Volkswagen Jetta GLS. It is going for 9,500, has 49k miles on it, and a 6 cylinder engine. The classified ad says it's in excellent decision.
    I'm looking to make a smart investment since more than half of the price I will be paying.
    Would I be making a mistake by buying this used car?
    Yes, it would be a BIG mistake to buy this car. Especially since this is a '00 Jetta. I would pass this car up and go for something more reliable. Look into an Accord / Civic type car. VW's will be expensive to maintaine and fix. I, personally, don't think this car would be a smart decision.
    Good Luck!!
    I would consider the Civic/Corolla in its stead. Keep in mind I say this, owning a 2003 Jetta TDI which I plan to keep a minimum of 500,000 miles and hopefully at least 1,000,000 miles.
    I just feel like the history of VW is not on your side.
    What is the proper octane rating for 2004 GLS? The owners manual says regular gasoline is sufficient, but the promotional literature says that premium is recommended for all Jetta models.
    George
    The 1.8T and VR6 engines require higher octane fuel than the 2.0L. Failing to use the higher octane can lead to pre-ignition and possibly damaged engine. (Holes in the pistons)
    My daughter reciently bought a 2000 Golf. She LOVES it. Her 1981 Golf had over 120K miles and was running great when she sold it.
    Yes, the early MK4 VWs had some "teething pains" but there is more to a car than just reliability. Besides, with 49K miles, the wrinkles should all be worked out of it. We all KNOW what the problem-areas were for those vehicles and it would be easy to verify that the issues have been addressed. (Updated Window clips, coolant migration, soft rear brakepads...etc)
     I owned a Cvic once and it was 12 years of BOORING driving. (except for needing a new exhaust every 2 years) All of my VWs (over 5 of them) went over 120K miles....and they were a JOY to drive. That is why I was GLAD to get rid of that Cvic for a Jetta.
    If you REALLY LIKE the Jetta and have verified that is is truly in good shape... go for it. ($9500 is quite reasonable. Thousands less than my daughter paid for the Golf of the same year.)
    I forgot to mention that the Jetta is by far the safest small car on the planet. There are air bags in the steering wheel, it the door pillars and in the seats. (That is why seat-covers are DANGEROUS in a VW)
    Also the Jetta has 4-wheel disk brakes and ABS. (Just TRY to find that in the same price-range!!)
    For a 16-year old, I would bet that parents might choose SAFETY over reliability any day of the week.
    good points!!
    This is not to take any of the winds out of your sails, but I.E.,the "lowly" Honda Civic, not pejoratively, but literally thousands cheaper; has a 5 star frontal rating with a four star side rating!
    I have also read that the Jetta 60-0 is a 135 ft mark with the Civic at 132 ft mark, the kicker being the Civic has rear DRUM's and DX and LX models do not have ABS!!??
  • 600kgolfgt600kgolfgt Member Posts: 690
    Since the Civic weighs less than the Jetta, the braking requirements are different (simple physics)...
    A lighter car will have shorter braking distances, all things being equal due to the lower mass that's in motion...
    Yes app 500#'s, but in a real sense we are going by objective measures, such as I cited. But even with the greater weight of the Jetta 2950#'s vs 2500#'s, the 5 star and 4 star rating apply to the Honda Civic. So the Honda Civic can do MORE with LESS. (500#'s less weight think of it as structurally driving around with 3.33 more passengers @ 150 #'s per passenger):)
    So to me, this creates a performance opportunity. If the Jetta could get the strength correct with a decrease in app 500#'s, I think my TDI performance (which is pretty stellar now) would be even MORE stellar !!
    Some performance parameters for example, would be: 1. even shorter stopping distances, 2. better handling, 3. 5 mpg better fuel mileage(for every 100#'s of weight is app 1-2 mpg) 4. quicker handling 5. longer (WEAR)component life, such as: tires, brakes, shocks, etc 5b. While it is conceivable that such things as engine and clutch wear, etc. would be decreased due to motivating 500#'s less, it is hard to quantifiy.
    What is confusing me is that in the technical section of the manual, it says that the car will run on both regular and premium, but it has a footnote which says that premium is recommended. In the tips and advice section of the manual, it says that regular is recommended. All this is for the 115hp engine. In that I drive this car in extreme city driving (my small village has over 7000 stop signs) and I rarely drive highway, I guess I will use the premium to get better performance.
    George
  • venus537venus537 Member Posts: 1,443
    here we go again... it seems that everytime this questioned is asked mis-information abounds.
    George-
    just read the sticker inside the gas cap door of your car for the octance that should be used.
  • mrjettemrjette Member Posts: 122
    Did anyone recently get the $1000.00 customer loyalty rebate on a new VW? The build a VW website lists it when building a passat, but my dealer has all sorts of limitations on it's use.
    Basically, an '05 Passat GLS TDI for $26,000. They will give me $13,800 on an '02 Jetta GLS TDI with 29K miles. The rebate is the stumbler as of today.
    Any thoughts? Thank you.
  • ncjettaguyncjettaguy Member Posts: 2
    My 01 Jetta Turbo just turned 80K miles. The only thing I've had to replace are rear brakes (went to ceramic pads this time) and Mass Airflow Sensor. I've used a variety of gasolines and with various octane ratings. 90% of the time, premium...however, thank goodness for the computer management....when I use regular I get lower performance b/c the computer is "protecting" the engine from the vapor lock (pinging) that could render the turbo useless. I've had 2 Camrys and they were considerably more expensive to maintain. Nonetheless, reliable.
    I got the $1000.00 rebate on my 2004 GLS. It was a lease, and they told me it would only be applied to a lease -- not a direct sale. The loyalty was because my sister had bought a 1.8T GLS 2 years earlier. She lives at my address.
    George
    It seems that they play fast and loose with the details! This is my reply from the TDi discussion:
    My question is really about VWoA. Why do they list a rebate on the "build a VW" section of their website, but not list all of the sticky details? The web shows a $1000 loyalty rebate for trading in a VW on a VW. It does not say it is only for financing through VWCI (at a higher rate than my local credit union) nor does it specify model years (2004 vs. 2005). It just shows that the customer is entitled to a $1000 rebate. Period.
    If you visit the incentives and rebates section of Edmunds website, there are no stipulations or limitations listed there either. That tells me that the information released from VWoA is not specific enough. Look at any other rebate listed and the manufacturer is very clear about limits and stipulations. Why would VW put information out there, and get people thinking they have some money coming to them, only to lead to disappointment in the salesroom?
    I think this is deceptive and an aweful business practice. Hardly a good idea when the product is fairly good.
  • irnmdnirnmdn Member Posts: 245
    Try Scion TC
    Why compromise when you can have both for less?
  • kallykally Member Posts: 9
    I am planning on selling my 2001 Jetta GLS. What is my best bet? Should I sell it to a VW dealer, any dealer in general, ebay, private sale, etc? I don't know if I am comfortable with a private sale, since I never had to do one before. Thanks for any advice.
    I am almost willing to bet the private sale might yield you the best price. The best is to research all those venues you are considering. Keep in mind used car sales have the potential to yield dealers even more profit than new car sales.
  • larryglarryg Member Posts: 1
    I have a 2001 Jetta,4 cyl. engine that was not included in the most ignition coil recall. The car has 23,000 miles. The ignition coils have just failed, new plugs and wires are also needed. VW service of course denies any connection. Does anyone have any experience or knowledge of similar failures? Please help. Regards, Larryg
    If it 'needs' ignition wires, then it is NOT 1.8T Audi engine. If it is NOT a 1.8T Audi engine, then it has never been a part of ANY ignition-coil replacement programs.
    In other words, If you are TRULY having issues with the ignition coil on a NON 1.8T Audi engine, then you are a rare case. Can you please explain why you think your problem is the ignition coil?
    VW service is 100% correct in that the ignitor issues with the 1.8T AUDI engine have absolutely no connection to the VW engine which you seem to have.
    A 2001 with only 23000 miles has hardly been driven. You are also in a small group of folks that dont drive very much. my daughters 2001 has over 45Kmiles and runs great.
    (Just dont forget to keep your intake snowscreen cleaned out!)
  • bdassjettabdassjetta Member Posts: 1
    this is totaly off your discusion but i have resently bought a 2001 jetta 1.8t and i was wondering what is some of the less expensive parts that i could put on to increse my horsepower and gain an advantige at racing.
  • cpurickcpurick Member Posts: 28
    I just took delivery of a new '04 GLI VR6. I noticed that there was no spare tire, and the dealer promptly put one in the trunk -- presumably after robbing it from another new car.
    It suddenly occurs to me that the GLI has different wheels and tires than other Jettas. Should my spare be an exact match? What size it the spare tire in other GLIs?
    Mine were but it is/was a 03 Jetta TDI GL. If you have researched this, this is old news, but while the oem recommends 4 tire front to rear rear to front rotation, indications are the 5 tire cross rotation is really the way to go! So to me if you get any resistance I would definitely use this arrow in your quiver! :) The first thing I would do is to say the delivery checklist was not followed in delivering the correct full sized SPARE tire!
    Perhaps you would be looking for a boost-control valve. It is a simple-inexpensive airvalve that "tricks" the turbocharger into supplying more boost. (this may gain up to 10-20 more HP)
    http://www.dawesdevices.com/
    http://www.boostvalve.com/
    Of course, a CHIP might be the next-step above that. This reprogamms the fuel as well as controls the boost. (Expect 40-50 more HP)
    http://www.upsolute.com/
    http://www.speedtuningusa.com/
    Do not forget that any of the above voids any warantee and can damage the engine if not applied with some wisdom, consideration and thought.
    I have buddies putting nearly 400HP to the front wheels and doing the 1/4 mile in around 12 seconds. Serious power like this costs $$.
    Well, there's another GLI on the showroom floor, and it has the same spare as the one they gave me. Maybe "full size" doesn't mean it's exactly the same. The Edmunds specs call for a "full size non-matching spare."
    My guess is that this is a GL steel wheel and the std. GL tire, and that a GL owner might be able to do 5-tire rotations as you are doing.
    After 44,000 miles with a 5 tire GY LS-H's and 10,000 mile rotation intervals there is one tire (6.5/32's in) that is 1/64 to less than 1/32 more worn than the other 4 tires (all more or less 7-7.5/32's in)!! So again, another set of data (point) that indicates the VW Jetta wears faster (in order of fastest to slowest) on the 1. right front side 2. left front 3. right rear 4. left rear and of course 5. no wear when its a spare!
  • lvboy1980lvboy1980 Member Posts: 11
    I have an 02' GLX VR6 with 17 inch "Long Beach" alloys. My car came standard with Michelin Pilot Sport but the spare is a 16 inch Goodyear tire!
  • mdcruiser1mdcruiser1 Member Posts: 9
    That's the way they all are actually. I have friends with the 17s and their spares are all the 16" tire. At least it's not a temporary one!
  • hotmailhotmail Member Posts: 3
    I bought 05 Jetta GLS 2 weeks ago. I noticed that the engine rotation does not engage in to transmission when I shift the stick to the reverse position from parking while pushing the brake. It only engages almost I completely release the brake, which create jolty motion to the car. I have never had a car like that. Usually, when we pull the lever to reverse from parking, the engine sounds a little lower and we feel the car is pushed back and lower. There is no such feeleng since there is no engagement between the the drive shaft and engine. I went back to the dealer and tested with other Jetta and noticed the same thing. Is it normal to ther other Jetta? Or is designe problem or unit problem? I need your help.
    I thought I posted a message but I can't find it in this forum. where has my message been gone?
  • patpat Member Posts: 10,421
    You have posted a total of two messages here in the Edmunds.com forums since you joined about 10 hours ago. They are #12243 and #12244 immediately above this one I am now posting. If you click on the "Recent Msgs" link, you will see the last 20 messages in this discussion, including those two.
    My sister is looking to lease a Jetta. She has a Passat on lease that expires this month.
    I have about $3,000 on a GM credit card that I am willing to give her, but would need advice on a comparable GM product AND a way to give my credits to her. We live in different states, and the card is restricted to household use only (unless someone knows a loophole...)
    Thanks. Mike
    can you use your GM product card on saabs (which is owned by GM)? The saab 9-3 would have a driving feel closer to the passat than any GM car.
    i guess you could buy the car in your name and then re-sell it to your sister. she's lucky to have such a generous brother.
