He claims that 90% of the recent trend by manufacturers to increase wheel size (and reduce aspect ratio) is being done purely for aesthetic reasons. And 95% of the result is not better handling, but higher profitability for replacement tire companies and alloy wheel manufacturers.
About the only manufacturer he gives any credit to for making adequate suspension modifications to handle large diameter, low aspect ratio tires is, in fact, BMW. (excluding pure sport manufacturers like Porsche, Ferrari, etc.) But, even then, he said only BMW's "M" cars are really built to warrant "40" aspect ratio tires. (He also rated Mercedes "AMG" cars and Audi "S" as "good").
My friend, Dave, noted that the most eggregious recent violation of the principal that the suspension and tires must be complimentary was the Lexus GS400. We have a mutual friend who bought one when they first came out (1998?) with the 17" wheel option. Dave describes it as a 300 horsepower Buick. And, in fact, our friend goes through his $700 a set tires almost as frequently as he changes his Mobil 1. As Dave said, there is a high cost to get .85 g performance out of a .75 g suspension using the tires to make up the difference.
So going back to your point about the fact that the standard 330i has 205/50HR17 wheels and tires and the non-sport version 530i and 540i have 225/55HR16 wheels and tires. Does that mean the standard 330i is set up to perform better than the 5-series, or look better? My guess is the latter, since the sport suspension is still an option.
What do you think?
P.S. I understand that the new 350Z may have 19/20" wheels. Where does this "mine are bigger than yours" stop?
It keeps getting better - more 18"s coming...open your wallets wider...
Its only when I moved to Toronto a couple of years ago that people recommended snows.
I will definitely be getting them for my car as it is my sole means of transportation to/from work. (Unless I car-pool with my brother).
Someone whose judgement I trust put it like this: It's better to spend $400 now to avoid $4000 of damage later.
I'm sure it's done partially for looks, but I believe all 330s come with sport suspension standard starting MY2001 or 2001.5 (someone correct me if I'm wrong)
2) guess i'm a member of the "better safe than sorry school". we do have wimpy winters in nj (vs. maine/nh where i learned to drive). that being said, we (in south jersey, anyway) get these neat little "surprise" storms.
3) yea, the snows don't exactly hold the road. i agree there. i'm willing to sacrifice 4 months of "bad" to get the 8 months of "good" rather than have 12 months of "mediocre".
oh well. i can understand where you guys are coming from though.
-Chris
ps. shipo, if you turn into vtech, we'll force you to sell the bimmer...
I have heard mentioned that because of the car/paint coming from Germany that it needs some special consideration?
Other questions:
Can I wax it right away?
Should I polish it first, then wax it?
What products should I use?... I do not have a lot of spare time so would need something that would not take days to do.
How about the wheels?
Any thoughts?
CNorthrup
As far as wheel size goes, if you want larger brakes, you must have larger wheel sizes. To fit said larger wheels into a given fender opening, you must then decrease the width of the sidewall of the tires that fit between said wheel and said fender. Suspension calibration not withstanding, IF a manufacturer takes advantage of the larger interior diameter within the wheel (by mounting larger brakes), you still have a benefit even if the suspension cannot quite keep up with the tires.
Of course, there is the flip side to this, and we see examples of this almost every day. Look at almost any fully “Riced” vehicle and you will see enormous 18” through 20” wheels and tiny little 9” brakes inside surrounded by a whole lot of air. I just bet those things stop real well, NOT!
On the subject of snow tires, I actually think that for winter driving (at least here in northern NJ), that snow tires would be too much of a compromise. Given how few REAL snow days we have here and how bad REAL snow tires handle on dry pavement, I suspect that the best rubber for my car for winter driving is all season rubber. So, now I guess that means that I need to buy a new set of wheels and tires for SUMMER driving and then remount my all-seasons for next winter.
Derprofi,
You are correct, all 330i sedans currently come equipped the sport suspension, like you, I am not sure of the exact date when that took effect.
Ccotenj,
“ps. shipo, if you turn into vtech, we'll force you to sell the bimmer... ”
Ouch! ;-)
Genie1,
“can we make him replace the Bimmer with an Aztec?”
Double OUCH! In fact, a fate worse than death. I think I will hang on to my Bimmer and just make this a long post instead. ;-)
Best Regards,
Shipo
Shipo made an interesting point -- I'd also like to see any data on how a SP-equipped 330i with ALL-SEASONS (225mm width fronts, 245mm width rears) stacks up versus one with the performance rubber. It's too bad tire selections are not a factory option -- same wheels, suspension, and seats, just a few different "rubber" options to choose from.
Quantifying performance tires vs. all-seasons - the 325i SP is good for .86 g at the skidpad. The non-SP stock setup and rubber are good for .82, so that's a pretty significant difference. The questions, though, is how much of that .04 g difference is attributed to the tires alone and how much to the stiffer suspension. My guess would be at the skidpad, the tires play a bigger role than the suspension.
Would you prefer the Avalanche or the Escalade EXT?
ps: Can I have your Bimmer?
Welcome to the former Bimmer/new Aztek owners club. ;-)
If the 325i SP with 225/45R-17 performance tires can turn @ .86 and the stock 325i non-SP with 205/55R-16 all-season tires can turn @ .82, what do you suppose that a 325i SP with 225/45R-17 all-season tires can do? Maybe .84 or .85?
Habitat1,
If you look back a few (hundred) posts or so, I seem to remember somebody posting that the folks at TireRack.com have had a special 16" alloy wheel made that will just barely fit the 330i. Other than that single wheel, it is my understanding that the 330i MUST have 17" wheels mounted on all 330i cars.
Best Regards,
Shipo
My rear armrest doesn't seem to have these even though they are specified in the manual
Got my steering retro-fit scheduled for next Thursday. It only took 4 months.
This is another reason for lower-proifile tires: to keep the same tire circumference while increasing the wheel size, the profile must decrease. That's why you see 19" 35 aspect ratios tires, not 65 aspect ratio (and conversely, why you don't see 14" 35 aspect ratio tires, except maybe for "riced" cars).
I have said this before (like 8,000 posts ago), but I think it is worth repeating. Over the years, I have read and contributed on many message boards, and I have always been very impressed with the level of thoughtful discussion here as well as the level of consideration that we seem to have for others who share dissimilar views (v_tech not withstanding). It is for these reasons that we are able to discuss wide-ranging topics where everybody learns and benefits from the discourse. Keep it up folks.
Brave1heart, I think it is time for you to re-institute your “Friday afternoon group hug”. ;-)
Best Regards,
Shipo
dunno where you live, but if i drive at "sustained speeds" of more than 99 mph, i ain't gonna have a license very long...
-Chris
-Chris
Michelin Pilot Sport A/S 225/45YR17 $212.00
Pirelli P7000 Supersport 225/45ZR17 $143.00
Michelin Pilot HX MXM4 225/45HR17 $168.00
Michelin Pilot XGT H4 225/45HR17 $146.00
From what I was told by a friend over at MBUSA, the Michelin Pilot Sport A/S are actually great tires that happen to have All Season capabilities, however, he thinks that either they are not being made any more or they are made in limited production runs so their availability is limited.
Best Regards,
Shipo
I wonder who's going to get 10k post?
On Monday I asked a guy if I could get a ride in his DB7 Vantage. Can't wait...
If I make 9 more post I can get 10k. :-)
8 more to go. ;-)
Also, house in SF area are ~500k. Can't think of a single car that expensive.
500k huh? That would buy a nice 4-5BR/3car garage mini-mansion in some parts of TO. In others thats just a cottage.
Best Regards,
Shipo
