BMW 3-Series 2005 and earlier
1579580582584585
    loebywonloebywon Member Posts: 2
    Thanks, srs49, I'll check into that. I was told(maybe erroneously) that if it was the sensor, I'd get a sensor code. If it's easy to do, I'll change it first. Thanks again.............
    kominskykominsky Member Posts: 850
    My car is almost 8 years old with 150K miles on the clock. I did have to replace one of my tail light bulbs about a year ago. I hope I held onto the receipt!!
    I do recall that 7 series had problems with printed circuitry in the tail lights--causing a warning light to remain on.
    The only lighting issue I've personally witnessed happening on older 3 series, more frequently than I would normally see, is the front directional lenses popping out and dangling off the bumper!
    They are simple push-ins and I guess the little clamps get weak or something.
    kyfdxkyfdx Moderator Posts: 237,383
    I remember some problems with the right tail-light on our '03 model... Seems like the warning light would show it out, even when it wasn't? Rusting contacts or something like that..
    My friend owns the car now... Maybe, there will be a class-action suit, and we'll all get rich!
    I'll have to drop over to his house and see if it is still a problem... He always has a great bottle of wine open... :)
    fedlawmanfedlawman Member Posts: 3,118
    No time for wine.
    Lawyers must be called! Banners must be erected! Oprah must be e-mailed! Victims must be rallied!
    I'm not sure that weeping BMW owners complaining about their tail lights are going to engender huge waves of public sympathy.
    Well I'll be darned. There IS a TSB on rear tail lights:
    SI B 63 03 06
    Lights
    February 2007
    Technical Service
    This Service Information bulletin supersedes S.I. B63 03 06 dated January 2007.
    [NEW] designates changes to this revision
    SUBJECT
    Poor Connection at Rear Lamp Connector
    MODEL
    E46 (3 Series) sedan from 9/01 to 3/05 production
    SITUATION
    Some customers may complain that one of the rear lights is inoperative.
    CAUSE
    Minor corrosion at the 8-pin rear lamp connector creates high resistance causing damage to the connector housing.
    CORRECTION
    Repair the damaged wire(s) and replace damaged connector housing. Install additional ground wires to both left and right rear lamps.
    hgeyerhgeyer Member Posts: 188
    Below is a post that was on the Windy City BMW group last year. I actually had this problem on my 2002 330i. It was easily fixed for about $10 and an hour of my time.
    Does anyone here have tips on how to successfully ask a dealer to
    perform (minor) repairs specified in a TSB on a car is 7000 miles out of
    warranty?
    This is the TSB I need
    http://www.bmwtis.com/tsb/bulletins/bulletin_graphic_temp/B630306g.htm
    It is a fix for incorrect ground wiring used in the tail light of some
    E46 sedans (production dates of 9/01 to 3/05)
    The problem was reported as a dead bulb. After verifying all the bulbs
    were fine, I discovered corrosion on the connector. Heat from the ground
    wire had melted the connector and was causing a short with adjacent
    wires, along with lots of little sparks!
    Some guys have posted a DIY fix here:
    http://forum.e46fanatics.com/showthread.php?t=512469
    I will do that this weekend if I am not able to get it fixed by the
    dealer. I would prefer it if they fixed it though, so what can I do to
    help my cause, other than asking nicely?
    jmb
    roadburnerroadburner Member Posts: 17,366
    The E39s are notorious for indicating that tail lamp bulbs are bad. The cure is simple. Spray the bulb sockets with a good contact cleaner, use ONLY silver base bulbs(OEM or Sylvania/Osram), and coat the bulb terminals with a fine film of dielectric grease. I think it cost me @$300 per side... :P
    Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
    virgilbvirgilb Member Posts: 1
    hi i just inherited a 1984 318i that was stored for about a year. before it passed emissions the icv was adjusted to bring down the rpms (I think). Shortly after that the power steering pump leaked and my husband rebuilt it and replaced the pressure and return hoses. the problem with the P/S was resolved but after he reinstalled it and went to start the car, it wouldnt start. It turned over fine but it was like the fuel wasnt getting to the engine. I suggested to my husband that maybe he didnt connect a hose back or something. That actually turned out to be correct and after he reconnected some hose it started but now it is idling at 3000rpm. it jumps to 4000+ when he presses the accelerator and then drops to 2000rpm when he releases the gas pedal but then right back up to 3000rpm and just idles there. no other real fluctuation. He replaced the ICV and the ICU but no change. Is it possible something didnt get "hooked" back up after the P/S repair? If so, ...what? and if not...what should I do?
    You might check for a tear/rip in the bottom of the rubber bellows that connects the fuel distributor to the intake air horn, or for some other vacuum leak which can disturb the fuel mixture. Being such an old car, cracks in rubber parts are always suspect.
    Yep, there's a vacuum leak somewhere. Check ALL the rubber lines- especially the boot that connects the air flow sensor to the intake manifold- part #8 on this diagram.
    Yep that the part I was thinking of. Common problem and you can't see it unless you feel around under there!!
    Well, the 1975 '02 has been sitting under its Bavarian Autosport Ultimate Car Cover since early December. Prior to today, the dismal weather and my laziness had kept me from fooling with it, but my son needed it moved as it was blocking his basketball goal, so I stripped off the car cover and prepared to get my jumper cables out of the Jeep. For some reason I decided to go ahead and try to start it and sure enough it turned over. So, I cranked it for @ 5 seconds, pumped the gas pedal a couple of times, twisted the key again and the old sled fired right up. I ended up driving it around town for a half hour and came back home. That car cover was the ticket, despite snow, ice storms, and heavy rain the car was dry as a bone inside and there was no condensation in the interior or the trunk. I'm even debating whether I should try to install the Recaros today. It looks like I might be driving it to the Pittsburgh Vintage GP after all. Woo-Hoo!
    I broke the 150K milestone on my way to work today. It's not the first time I've put that many miles on a car, but it's the first time I've ever done it without the desire to dump it at the side of the road and get a new one.
    With the exception of higher than normal oil consumption, suspension that's getting noticably softer, and a seatbelt that doesn't always want to retract, the car is solid and still a joy to drive.
    If I can find/fix the oil consumption issue at a price that makes sense, I'll follow it up with the shocks and struts and keep it indefinitely... I'll probably just suck it up and deal with the seatbelt. ;)
    Have you had a cylinder leakdown test performed on the car. That should pinpoint the source of the oil issue---if it were just valve stem seals, that might not be too bad a repair.
    I haven't done anything yet... just throwing in a quart every 2-3 weeks. There are no signs that the oil is burning... no blue smoke, no burning oil smell, etc. When the weather warms up a little, I'll crawl underneath, pull off the plastics, and take a good look around. The oil seperator valve seems to be a problem spot on E46's, so hopefully it's that valve or a hose somewhere. If I can't find an external leak, then it's time to take it somewhere. Thanks for the suggestion!
    akv25akv25 Member Posts: 42
    Will the TSB only apply to cars under warranty? I am having the same issue but I have ignored it till now.
    Thanks in advance!
    tnguyen74tnguyen74 Member Posts: 65
    Is this with the 03 and up 3 series with the LED taillamps? My dashboard shows the left taillamp burnt out. However, upon stepping on the brake the right-upper and left-lower light only light up (criss-cross). If anyone has anymore info on this being covered under a TSB please advise.
    pylt1pylt1 Member Posts: 12
    The TSB only provides for the work to be done if under warranty.
    In other words, if you happen to know about the TSB while you're under warranty , then you can get your BMW's design defect fixed for free.
    If you're like us, however, you have problems under warranty and the stealers are clueless, replacing bulb after bulb, carrier after carrier--all of which only defer the problem until you're out of warranty!
    Then the fun begins because the stealers then find out your wiring is melted and want several hundred dollars (per side) to make your tail lights work. Cute BMW!
    Hence, the need for the recall.
    Contact the NHTSA and fill out and MAIL a specific "petition for a formal investigation" (use those words) to this address:
    U.S. Department of Transportation
    National Highway Traffic Safety Administration
    Office of Defects Investigation (NVS-210)
    1200 New Jersey Avenue SE
    Washington, DC 20590
    It's not just he money--it's the principle of BMW knowing about a safety-related design defect, and choosing to not do a damn thing about it.
    More details here:
    http://www-odi.nhtsa.dot.gov/recalls/recallprocess.cfm
    TSB here:
    or:
    Sigh . . . you're missing the point completely.
    The ENTIRE rear cluster(s) INTERMITTENTLY go out on a on some E46 models. This is dangerous. Other symptoms include: turn signals go twice as fast (because the rear one is inop), brake light inop, tail light inop, check system warnings, etc.
    This isn't about bulbs--those are wear items and we all expect them to burn out over time. This is about ground wiring that got so hot that the connector has melted (BMW dealership said it was "fused" together), and BMW's internal safety defect reporting. Here's the scoop: they are legally obligated to report safety defects. Instead, BMW dealers are and were seeing so many of these cars that they would simply change all the bulbs and out the door you went--with no paperwork or other documentation. Not a good idea when you're trying to track a problem . . . .
    They initially thought it was bad bulbs, by the thousands. They were mislead because just moving the wires was enough to "fix" the problem for a few weeks or months and the wires were always moved when they replaced the bulbs.
    Many of us we had these problems off an on every few months until we were out of warranty. Now BMW dealers are sticking their customers with bills upwards of $500 to accomplish the BMW Service Bulletin which came out over two years ago: replace the melted connectors, add the second ground wires, replaced the sockets and clusters, etc.
    Here's the third version of this defect bulletin:
    If it doesn't work, just try to Google "SI B 63 03 06 pdf"
    BMW's actions so far have been wrong, unsafe, illegal and unethical. BMW HQ in Germany has been advised of what's going on here in the states and we're hoping once the higher ups see the details they'll step up to their legal and ethical responsibilities.
    There are many thousands of these cars out there. A very small fraction of the owners are reading these blogs; the others are probably just living with the problem thinking they have rear lights--when they actually don't. Heaven help BMW's execs if/when there's an accident for a safety defect they've been aware of for over two years now, and that they failed to fix via a recall. :lemon:
    Only the later E46's coupes had LED tail lights.
    You may have someone's modified car if you have an E46 sedan?
    Don't know about problems with LED tail lights on the coupe so you may want to search other boards to see if there's another TSB for that.
    alibajalajaulaalibajalajaula Member Posts: 89
    After a painful sale of my beloved '06 ZCP M3 due to unexpected events :cry: I ended up buying a 2000 E46 323i sedan with 83K on the clock for a little more than eight grand. :D I test drove the car and it was very good, with the only brakes a tad long. So even though the worn brake pad indicator is not on I am planning doing front & back replacing rotors, pads, and sensors. I have also heard in this forum that water pumps need to be checked, maybe replaced around the 80K mark. Other than that, the engine sounds pretty good plus its a 5 speed manual (so I don't anticipated the "reverse gear syndrome" that plagued some automatic E46 slushboxes around 100K).
    So the question to you friends out there is, should I sign for a 4 year 1800$ extended warranty or should I get myself a good indie shop and do the brake & water pump deal and come ahead while at it? Can I just wait for the water pump to fail without risking major engine damage? I don't know I feel at times that if it ain't broken don't fix it. :confuse: I am all ears.
    nyccarguynyccarguy Member Posts: 16,439
    Besides replacing pads, rotors, & sensors, I'd also advise (as I've learned from my friend roadburner) to flush out & replace the brake fluid, manual transmission fluid, and coolant using only BMW fluids and definitely replace the water pump ;) . I think E46 cars have problems with front control arms if I'm not mistaken.
    Good luck!
    2001 Prelude Type SH, 2022 Highlander XLE AWD, 2022 Wrangler Sahara 4Xe, 2023 Toyota Tacoma SR 4WD
    What nyccarguy said. Stick the remaining cash is a money market account and self-insure. And replace the water pump.
    Now.
    jjdanieljjdaniel Member Posts: 3
    I have a 2004 325 with automatic transmission. When I start the car and put it in drive, the transmission will not engage for 5 to 10 seconds. If I apply the accelerator, the engine races but nothing happens. If I shift to first in the manual mode, the transmission will engage a little more quickly. If I put it in reverse, it engages immediately. It's almost like when I put it in drive, there is a lag like when a computer is booting up. Th problem is most severe when the car has been sitting overnight. Is this a common problem? Any ideas on what needs to be done?
    Take it to a good BMW dealer or independent tech and have the AT fluid level and condition checked.
    If you're really lucky, the transmission is just low on fluid.
    If you're not, you need a new, and very expensive, transmission.
    :lemon:
    lucky1manlucky1man Member Posts: 20
    I have exactly same problem. 04 330I Steptronic. (34K)
    Warranty has expired , of course
    Ditto to being worse overnight. I also have EML (elec malfuntion icon) .
    Hope to get some info befo taking to Stealership.
    do u hve EML lite?
    Once in gear shifts smoothly. Wonder if is some computer that controls gear selection , independent of transmission body.
    How check ATF fluid. Let me know what u find out and I will post any ifno I have.
    Have to wonder if this is a probl common to the 04 3 series??
    Thanks for your response. My EML light is not on, but like you I think this may be some electronic/computer issue for engaging the transmission. No problems after the first 5 seconds or so. Just have to wait for forward to engage after the car has been sitting overnight or for extended period. Then evertything shifts smoothly. If problem was related to shifting between gears, fluid might be the issue, but that doesn't seem likely here.
    You should take the car to a dealer or specialist and have them check the transmission fluid level PROPERLY -- fluid has to flow out of the overfill hole, you don't stick your finger in there.
    If the fluid was low, then you top it up, drive the car to determine that that solved the shifting issue and THEN find out where the fluid went.
    if the fluid level is okay, then they have to run a diagnostic scan and see what, if any, trouble codes are present, and then proceed from there.
    If the trouble codes demand disassembly of the transmission, you might be having a very bad day--but there could be access to used units or perhaps the fault code might indicate a problem that does not require complete overhaul.
    Yes, we do not have shifting issue, but rather initial engagement issue.
    Let us share diagnostic info with each other. Make sure our stealerships or Indies are on the same page.
    Will, however check fluid level per our Host suggestion, first.
    Forgot to mention have same issue of engagement after overnite ; have been warming car up in am to about 3/4 and then have less probl when engaging.
    We still need to get diagnostic , of course.
    jtuellerjtueller Member Posts: 3
    Hey, about to lovingly dive into the world of BMW ownership, totally committed to doing research, keeping up on maintenance, and getting the most out of the car, but could use a little advise on the two cars I think I've narrowed it down to:
    Option A: 2000 328i, in the last year he's replaced the water pump, power steering pump, serpentine & acc. belt, intake elbow hose, fuel filter, gas cap, outside temp sensor, final stage resistor, brake rotors and pads, and oil change (about four months ago). Also comes with two sets of wheels: 16" BMW OEM wheels with Winterforce studded snow tires. And 18x8.5" Ronal wheels (made in Germany) with Potenza S03 Pole position summer tires. It's automatic (have to get an auto so the wifey can drive it) 98k miles and asking $7000
    Option B: 2001 330xi, 126k miles, talked to him on the phone so can't be to detailed on the specidifics but he also has replaced both pumps, radiator, and a few other minor repairs. Planning on calling him back to get specifics but much like Option A seems to have kept the car maintained. Also an auto and wants $8850, can probably get him down to $8300.
    Also have seen some 2002 325xi in the similar price range. So my questions to someone out there willing to be helpful for a newbie like me:
    #1 I live in Salt Lake hence my looking at the AWD. But that said it I've been driving rear wheel my whole life in Utah and don't necessarily want to pass up a potential good deal (option A) as I think I'd be fine. (Plus on super snow/ice days, I have a land rover that would get me to work just fine) In my limited couple of weeks of research my gut tells me that first car has really been taken care of (seeing it today) and that the lower price tag is of course appealing letting me sock some away for maintenance that might/will occur.
    #2 I could spend more like $11k on a car and get something a bit more recent (03-04) with perhaps around 75k miles, but then from what I can gather I'd be facing a lot of these repairs that the above cars have already taken care of. I'm not sure there's a lot of value for me to spend $3-$4k more and have to face things these have taken care of. Would love some input keeping in mind I don't put a lot of miles on cars (mighty 6 mile commute - usually only put on 6-7k a year) and just looking for a fun car to drive for the next few years, with the understanding coming into it that I need to be very proactive on the maintenance (have already been recommended a great indie mechanic by other BMW owners in the area).
    Thank you so much in advance for taking a moment to post you comments. I really appreciate it!
    My 325 is a convertible and I noticed that the automatic top has the same delay effect. If I try to put the top down right after starting the car (particularly after it has been sitting overnight), there is about a 5 or 10 second delay before the mechanism for lowering the top kicks in. Seems likely that there is a common cause for these delays.
    I'd be tempted to go with the 2000 328i assuming that you can have a pre-purchase inspection performed by a good BMW tech-and it sounds like you already have one. The only problem is the automatic; it may go 200K with no problems and it might go tomorrow. The only decent repair is with a BMW remanufactured unit, and they aren't cheap. I wouldn't pay extra for AWD- just get a set of winter tires and wheels from Tire Rack and you'll get around just fine. That's what I do, and like you I have a serious 4X4 when things get really treacherous.
    Appreciate the feedback, I'm thinking the same. Guess I'm just rolling the dice on the automatic, but at the price I'm getting it even a $3000 repair is putting me in the same range of most similar year models I'm looking at. Perhaps I'll start socking away a few hundred a month just in case! The current owner was saying something about some of the transmissions on this year being built by one manufacturer, and the rest by an other. Does this ring a bell for anyone. And if so does one tend to fail more than the other. Figure I could dig into it and find out which I had by the VIN. Always better to see a major repair coming at you when possible!
    The transmission should be the GM A5S 360R, and a BMW Remanufactured unit will run @$3600-$4000 plus installation. I changed the fluid in my wife's 528i at 100K and the tranny is still going strong with its third owner. Some techs say leave the ATF alone if the ATF has over @65K on it, but I guess I dodged the bullet. In any event, I change the ATF every 50K in my wife's X3, and I'd suggest that you follow that regimen if you do wind up having to replace your autobox.
    Interesting, so since it's at 90k don't mess with the ATF fluid, but if I have to change it out then make sure every 50 I change. Got it! Here's hoping the transmission isn't a problem (crossing fingers, knocking on wood, and many other cliches)
    Like I said, I changed it at 100K in my wife's car with no ill effects. I forgot to mention that BMW also recommends a 100K change. Confused yet? Anyway, I strongly advise joining the BMW Car Club of America. Among other things, you get a great monthly magazine and many dealers and shops offer significant discounts on parts and/or labor.
    ladymagicianladymagician Member Posts: 1
    I recommend you stay away from Option A, the 2000 328i sedan. Consumer Reports says it is one of the worst cars to own, and I have to agree, having had one for six years. I replaced all kinds of major parts and didn't see an end. I finally traded it in for a 2005 330i.
    Some times Consumer Reports actually does get it right. I am not convinced they know their new cars, being a major fan of the Ultimate Driving Machine, but they like my 2005, and I love it.
    Happy twisties. And don't forget about your local chapter of the BMW CCA.
    fezginfezgin Member Posts: 17
    I would try to find out whats the transmission manufacturer/model is . Make sure transmission is NOT 5HP19 by ZF. This transmission has a design flaw; the drum breaks as early as 35k miles with no sign of failure in advance. Hundreds of people have complains about it (including myself), there is a suit going on against bmw. There is even a website (noreverse.org) dedicated for it...! Hope its not too late for you.
    Thanks: Good Info; I will research see if I can find out what tranny I have.
    (anyone have suggestions how to do this?)
    My car is at the dealer now and will have info on what they diagnose Wed nite.
    Will post my info Wed nite:
    Thanks again for your helpful input..
    Dealer should be able to tell you from the VIN. Also look at the website I mentioned above...
    sebring95sebring95 Member Posts: 3,241
    Hi all, been thinking about picking up a used 3-series for my commute. I'm driving 60 miles of twisty/hilly state routes in my Tundra, and while it has advantages (avoiding large road kill, visability, possibly surviving a head-on with a semi.....) it's not the most fun vehicle for this commute. I'd like to run go with an AWD (gets nasty in winter and will run snow tires too) and a six-speed manual unless there's a major reason to avoid those models. I'm looking at '04-'05 models as I prefer that bodystyle to the newer ones. I want something reliable since it's over an hour to the nearest dealer and there's no BMW mechanics around either. So what's the safer choice for this generation? I'm not as concerned about performance, so if the 2.5L is more reliable (an efficient) I can go that route. And suggestions would be appreciated.
    As promised , am posting reply as had similar prob with addtion of whistling/whining noise when moving selector when cold.
    Not do when warm
    Bmw dealership states is Cyclone Separator otherwise known as Crankcase ventillator.Gave me estimate $1285.
    Local Indy Edge MOtorworks in Dublin Ca, Gives me $567.
    So not tranny afterall. Did u get diagnosis??
    Folks:
    I am thinking of getting the short shift kit sold by BMW Performance Parts. The shifter travel is supposed to be decreased by 25% or so using the kit. Anyone have any experience using a short throw shifter, please share them. How does this compare with the UUC shifter?
    I've used short shifters and they are great but they do increase shifter effort (it's a trade-off) so if you do a lot of traffic driving you may not care for this mod.
    Does anyone have a roof-rack and kayak carrier on their car? It seems like Thule and Yakima are the two big players. Any feedback on either of those two brands? Any other manufacturers I should check out?
    thanks!
    takafoomi1takafoomi1 Member Posts: 8
    I have Thule bars and racks on my minivan, and previously had them on other cars for years. They are always superb in terms of quality and fit. I have a 2004 330cic which I'm likely going to get a trunk mount Thule because of my previous experience. If you go Thule or Yakima, you have to stay in that 'family' forever as they dont mix and match .. Yakima has round bars, Thule has squares..
    I have a 323i, MY2000, with 85K on the clock. The DSC light come on while driving, no noticeable effect on the drive, then stays on, ignores the turn-off button , and then goes off, a day later. So does the check engine soon light: it comes on and then a day or two later it goes off. I took it once to a parts store and they read a code "cam sensor" but then it went off. Bottomline, these light come on and off at random, but there is no sympthom on the car drive at all. I have not taken the car to an indie shop among other things because of a hectic work schedule (in-out of town) but I wonder if this is sign of a more serious issue. Any thoughts? Could these be related?
