I called Dan Miller at BMWWNA today. He is waiting for a BOW "engineer re" to call him back and then he will call my dealer and instruct them what to do. The dealer told me this morning they were going to replace with the same assembly and I told Dan I rather get it fixed permenitely. He will let me know tomorrow. Also, he will try to get me a more decent loaner car than the Daewoo.
I will keep everyone posted.
Dan
Can anyone help decipher the tire pressure graphic on the door panel? I have a 330i with conti's.
Tinting- Anyone have a recommendation for a quality shop on Long Island. My dealer wants $350.
Alarm- Any comments on the BMW alarm. How's its sensitivity,ie: false alarms.
I can't beleive I've driven 1700 miles in 21 days, actually hit the 1200 mark on day 11. Can't wait to take her on I95 and listen to her growl.
A: Correct. You can order it from any BMW dealer- Part number 51-11-8-195-304 - list price: $16.20
thanks for all your help with my dealer problem they agreed to th6 6.5 and said it was just a mistake.
Josh
I hope this question is not too repetitive, but I've been through 300 plus posts and I don't have time for more. What are the symptoms for the auxiliary fan problem, b/c I think I have it, and I think my bleepin' dealer lied to me about it. Surprise surprise, eh. How do I find more information about it? Thanks so much in advance,
Ladybugnova
What you don't want to do is ignore it - that's how the rare but very discouraging engine fires get started.
Steering: I test drove a 330xi and a 330Ci with the light steering, and I agree with most that it is over-boosted. It's not that big a deal to me though. I noticed that on my car, with the "new, new" steering that there is a huge difference. There is very little power assist at all. While this will make the purists happy, it will probably deter some prospective buyers.
Ride quality: I was concerned that the sport suspension might be a bit too stiff. It's definitely stiffer than most cars, but is still quite comfortable. I think it is a perfect balance between comfort and handling. I can see why BMW made it standard on the 330i. If you want a softer ride you should get a Lexus ES300.
Noise: While there is very little road or wind noise, the engine noise is quite pronounced. The engine makes a healthy growl that I love to hear. I just think it may get tiring after a while.
Power: BMW says the 3.0 liter six has 225 horses. They must be Clydesdales because this engine has a ton of power. I test drove the M3 (both E36 and E46) and an Audi S4. I didn't expect the 330i to be close to those cars. While the E46 M3 is in a different class, the 330i is very close to the E36 M3 and the S4. It has enough low end grunt that I downshift far less frequently than I have in other cars. I haven't played around much at the top end, since I'm still in the break-in period, but I'm betting the top end power is fantastic, too.
shift knob is pretty easy- did it w/ arm rest install. Don't worry about it going back and not being properly aligned b/c there is a female grove on the inside of the knob that fits with a matching male grove on top of the shifter.
Using a clutch since 14 (motorcycle)but after all these posts about how to shift, I frekin grinded second today..ouch- not too bad - rpms were very low. BTW- how badly do you have to grind em b4 you break a tooth .........drcr
Does your 330i has the titanium headlight trim? Some posters who took delivery of their 330i recently have mentioned that the titanium headlight trim is missing.
jnscheong
Say you have a 250-hp car (or 260, since this seems to be a popular number) that is 85% efficient in its power translation to the drive wheels. This yields about 213 horses to the ground. Say a 225-hp 330 is 90% efficient. This yields 203 horses to the ground. This is a difference of only 10hp, not 25.
When you combine this with RWD effects and manual vs. auto (even MORE efficiency gains) effects, you can see how the 330 manual easily beats the CL-S (two similar curb weights) to 60mph. I would expect the same for 240-hp Altimas, 260-hp Maximas, and the like.
BTW, I remember seeing (somewhere here on Edmunds, I think) an actual analysis of this efficiency across several different cars using dynos. The Miata and Mustang Cobra were recently scrutinized for publishing inflated HP ratings for their engines. It was called "Real-world Horsepower" or something similar.
Disclaimer: numbers are fictitious (but hopefully somewhat realistic)and not open to scrutiny.
The one thing everyone seems to say after they have driven a BMW is "this car has more power then ___________"
I guess the IS300 is a good example. I did test drive one before ordering my 325i. With 215 horses and 218 ft-lbs torque, even with auto I expected it to be faster in a straight line.
Years ago I had 1982 Audi Quattro (similar body to the 1982 Audi GT Coupe), this car was semi hand built with lots of special goodies, as a result, the Q/C was different from a production car. My car apparently had a soft or otherwise defective second gear syncro, and when the tranny was warmed up, it was very difficult for me to shift into second without a horrendous sounding clash of gears. The car only had 3000 miles at the time so Audi agreed to fix it under warranty, however, getting a new transmission here in the states would have taken months, so I was given the option of waiting or having my unit rebuilt. I opted for the rebuild, and when they pulled the unit apart, the second gear assembly showed few signs of damage; the syncro on the other hand, was totally trashed.
This is not to say that if you accidentally grind your gears you will damage your syncros, in my case, the syncro was bad from the factory which is why it failed so soon.
Best Regards,
Shipo
1) Loosen the headliner plate (it just pries off) just to the rear of the mirror (the one with the sunroof control) and disconnect any wires.
2) There is a pre-scored rectangle (about 2" by 2.5") in the plate that you need to cut out. I used very sharp window scraper (ie. new razor blade) to cut mine out, total time about 15 minutes.
3) Insert the Homelink unit into the headliner plate from the outside and snap in into place.
4) Locate the power connector for the unit (mine was tucked into the headliner just to the right of the opening).
5) Reconnect the sunroof wires (if so equipped) and the transmitter and snap the headliner plate back into the roof.
Total time should be less than 25 minutes including the cutting.
Best Regards,
Shipo
My 330i is missing the titanium headlight surround, too. I think I actually like it better without it, but that's just a matter of taste.
By the way, my car arrived at the VPC on 7/2 and I picked it up at my dealer in Massachusetts on 7/10. That may give you an idea on when you will get yours. Hang in there.
PS Went from North Austin to Lockhart for lunch today at an average speed os 85mph. Man I love this car (and my Valentine).
Well, today I had another freaky experience. I'm going about 30 mph, and my DSC light comes on, as well as the parking brake light. The weird part is that I was driving slowly in a straight line on dry pavement, PLUS my parking brake was in the down position, AND the parking light was orange, not the usual red when the parking brake is activated. The car seemed to drive fine, but these lights stayed on for about five minutes. I even tried to shut the DSC off, but the light stayed on regardless. So I call my dealership and they said to bring it in Monday when they'll have a loaner. After I get off the phone, I stop to take a left turn and suddely my power shuts off AGAIN! Thank God I wasn't turning into traffic! Can anybody explain what the #$@#($* is going on here? Help me! Lena's hurtin' bad!
break-in - aaron, you'll be fine. Don't worry about a couple of blips above 4,500. The break-in rules are more of a guidance, not religion.
The optimum level to drop the clutch for fastest off-the-line acceleration is from the peak torque level (3,500 for the E46 engines). I've read that this is how C&D was able to achieve their best time in repeated tries.
guru - the clears on your ride are OK. I still would not pay to put them on my car but I am close to being indifferent between those and the ambers, so my position has shifted after seeing the clears on your car.
False alarms: none so far. BTW, the alarm switches the sound off in 30 sec leaving just the lights flashing for a couple of minutes, so there's nothing to worry about.
Tire pressure - well, look at your tire specs and then find out which box you fall in on the tire pressure table
Bi-xenons - the low beam is all you need with the xenons. I've never even had to use the high beam.
radar detector - K40 is better because it's built in. It is too expensive, though, and the V1 is probably just as good as far as detection. I would not like driving around with an exposed radar detector, though.
One of my colleagues drove me today in his rented Mazda Millenia. The rear seat space is no bigger than the E46's and headroom is substantially less. Not to mention it's a much bigger car. The tires are very noisy, I realize how quite my performance Contis are.
Who's Lady Bugnova? Sounds mysterious. Could it be a spy from the Beetle board )
HP: BMW does not understate the HP in their cars. Just keep in mind that the HP rating is a measure for the engine's power. In reality, what matters is how these ponies get to the wheels and that's one more thing the BMW engineers shine at. When they say 225 ponies, you know you'll find most of them at the wheels. My 184-HP 325i can do battle with cars that have much higher-rated HP. Also, it's important to keep in mind that the peak HP is just a point in the chart. What really matters is having a high and flat torque curve for continuously fast acceleration and both E46 engines have very flat torque curves.
drcr - I've also grinded in second a couple of times for a brief second - you'll be fine. The tranny is built really tough and I would not worry about it.
I'm in Texas, and 75% of the people drive large cars (pick-ups or SUVs). I've already had two near-death experiences, and think that the ML320, would provide more protection.
BUT, the BMW is sooooooo nice to drive. Do I risk death for pleasure?
Mine's been produced, still waiting. Expect it in 2nd or 3rd week of August. Ah the agonizing wait.
A pretty cool, although greatly exaggerated, display of this phenomenon is to watch motorcycle road-racing on Speedvision some time. These guys (some of them anyway) brake so hard entering a corner that the rear-wheel leaves the ground. Because the back end is so light and they start applying heavy throttle before the weight transfers back, they 'paint' a thick black stripe of rubber on the asphalt. Some of the more ham-fisted riders will even start smoking the rear tire. I say 'greatly exaggerated' since I seriously doubt you could lift the rear of any car by braking. Otherwise, the concept is the same.
Is it because that web site shows how to break down VINs for 2000 models??
What do you think.
jnscheong
P.S. also noticed digits 4-6 do not have decoding for 325's.
Was going to clay bar but found nothing to clay bar
Dried
Applied Z1
Applied Z2
Going to bed.
Lastly, the dealer loaner was a 330 - i purposely didn't test drive this because I thought I would be sucked into the power and of course I was. I usually keep my cars for a while but now I can see myself upgrading in a few years...
I am able to use my opener from 30 to 50 feet, I have not figured out what makes the difference but some days it just seems to work better than others. Based upon the instructions and the homelink.com web site, there are few if any remote controlled units that cannot be programmed into the Homelink unit for the BMW.
From the "Sometimes a Sleeper is the best" department,
This evening I was driving into the City (NYC) with the kids in our van. I was sitting first in line at the light on 56th Street at 9th Avenue when some "Rice Boy" in his IS300/Altezza squeezed around several cars in the left side parking lane and pulled up next to me with his nose pointed in such a fashion to make it obvious that he intended on being first across the intersection.
Well, maybe he was just asleep at the wheel, but when the light turned green, the first car across was our ubiquitous Green Dodge Grand Caravan with this little &^%@)* following me about 2" back and sawing back and forth trying to find room to pass me in the parking lane. At 8th Avenue, there was one of NYC's finest who was directing traffic and who must have been watching us coming up the street, because when we stopped at the light, Mr. Officer went back to have a chat with Mr. Rice and motioned for him to pull over. Green light, SEE YA!
Best Regards,
Shipo
I just don't know what to think anymore. First I was told it'd be June production/July
delivery (I ordered the car on 05/11). A couple of weeks ago we were talking August delivery. Today we don't know when the heck the car will be delivered.
Please, Gurumike, could you find out what's going on with my car? Thank you!
325xi (Tulley, Nashua, NH)
T_Silver
AWD
Step
Fold down rear
CD in dash
HK
Wood trim
daswolf - I absolutely love the Orient Blue exterior - great choice. Black 'ette is sportier, beige is more luxurious. Which one is better would only depend on personal taste but one thing is indisputable: as much as I like the black 'ette, it does get pretty hot in the car when you leave it in the sun.
Komisnsky - thanks, I got it. I'd fight the guy (not too hard, though) who said that engineers don't know how to explain in layman terms. So can you smoke the 330's tires while accelerating in a straight line on a dry road without heavy braking?
Shipo - you're a riot! Beat the sucker with a dark green van and your kids in it. Brings sweet memories of platypus' fun story about the RS4 family that puts on helmets at the intersection before they blow off all the other cars at the green and then they take the helmets off and high-five each other.
"So can you smoke 330's tires while accelerating in a straight line on a dry road without heavy braking?" Although I've never attempted it, I would have to say the answer is "no way". I think I'll give it shot tonight on one of the worn down tar and chip roads near home. The traction on those roads is terrible. I'll let you know.
