Lexus ES 300/ES 330
15354565859105
  • mmccloskeymmccloskey Member Posts: 168
    I've had my ES300 for about 4 days now and had more time to get acquainted with the features and it's super-smooth driving characteristics.
    I have noted that the engine RPM's seem rather high (2,600) for going about 60MPH. My Solara would turn about 2,300 RPM's at the same speed. Maybe it's because the car is so new with only 200 miles on it. Have any of you 2002 ES300 owners noticed this?
    Also I inquired with the salesman about 'break-in' and he said to drive it like I normally do (rather sedate), but to avoid quick starts and abrupt braking. I have adhered to that although I have had the car up to about 70MPH for a brief period. In a successful attempt to move around a slower vehicle, I did press down on the accelerator, the transmission 'kicked down' (very smoothly) and moved out rather smartly easily passing the 'offending' vehicle. I do hope that maneuver didn't cause any harm.
    Michael J. McCloskey -
  • ratdaddyratdaddy Member Posts: 4
    I need instructions on replacing the bulb on the right rear tail light on my Lexus ES300. I have the 1157 bulb, just don't know to get to the burned out bulb.
  • sliangsliang Member Posts: 50
    2600 RPM for 60 mph? That is really high. Did you leave your gear at 4 or D?
    If I used D, the RPM is around 2200 at 70 MPH, but the RPM can exceed 2600 if 4 was used.
    I don't think you need to worry about damaging the transmission by accelerating the ES normally.
    I will keep varying the speed, keep the speed lower than 70 MPH (using D), and do not brake abruptly unless it is really needed for the break-in period, normally it is the first 1K miles. I actually kept the same driving practices until my ES reached 3K miles.
  • hoorayhooray Member Posts: 15
    I now have 1,500 miles on my ES 300 and probably half of those miles are highway miles. With the cruise set on 60 mph, I am consistently at 2,000 RPM when I am in Drive/5th gear. 2,600 sounds more like 4th gear.
    Also, the Owners Manual states a 1,000 mile break-in period where you should stay below 55 MPH. I tried to minimize going over 55, but it is impossible to avoid exceeding 55 on Interstate 95 and I-64 in VA unless you want a tractor trailer going over 75 mph to run over you!
    Shortly after I posted my issue with engine RPM's my salesman called to inquire as to whether I'm happy with my ES300 - I MOST CERTAINLY AM! Anyway I mentioned the high RPM's at 60MPH and he (as well as SLIANG and HOORAY) said to move the lever from the left (4) to the right (D). I did this on my drive home this evening and the RPM's are down around 2000 at 60MPH - problem solved!
    I doubt there was any harm done as I have only 200 miles on the car and have been driving in a very sedate manor.
    The drive home (about 20 miles) was so tranquil and ultra-smooth - this car is going to spoil me!
    Michael J.
    2002 ES300 - Alabaster Metallic
  • kreativkreativ Member Posts: 299
    These new Lexus engines no longer require a formal break-in period (as the Lexus manual mentions). The best thing you can do for your car in the first 1000 miles is the vary your RPMs (no cruise control!), don't push it too hard (not a problem for most ES drivers), and go easy on the brakes.
  • beaver2000beaver2000 Member Posts: 5
    I am waiting for the new 2003 to come out to buy my dream car.
    Are there any info on the 2003 as to when, prices, colors, etc ?
    Thank you for your comments
    Paul
    Will be looking to get color matched mudguards for my new ES300
    Been looking on the net whithout any success
    Can you help ?
    Paul
    Greetings all:
    After my first week of getting acquainted with my Alabaster Metallic ES300, I know I made an excellent choice in choosing this vehicle. I am averaging 26MPG - 90% highway with just over 400 miles on the car. I consider this to be great mileage since the car is still new. The Mark Levinson sound system is very impressive - crystal clear with sufficient bass to make listening to my CD-R's a brand new experience. Very quiet and smooth - I feel no need to hurry since the time I spend in this car is truly a pleasure.
    Regarding the 2003 model - I suspect it will be a carryover with some color changes, probably the 'Starlight Pearl' being dropped.
    Splashguards - these are not currently available and I don't see where they would attach to the lower fender area. My Solara had them and they worked great at keeping road grime and other debri from blemishing the lower panels just aft of the front & rear wheels.
    M. J. McCloskey -
  • bartalk2bartalk2 Member Posts: 326
    If you intend to buy an '03, I'd wait awhile and see whether they fix the transmission. Too many complaints here and elsewhere about transmission problems on the '02s. Aside from that, I can't imagine they're going to make many changes on the '03.
    Further down the line they will have to increase the power of this vehicle, because lower priced cars like the Nissan Altima, Maxima, and soon the '03 Honda Accord will have V-6s with more power than this higher priced Lexus. The Altima has 240, the Max 255, and the '03 Accord, according to advance reports, will have 240. Toyota will also have to increase power in the V-6 Camry, which remains at about 192. ES300 and the Camry are already being called "underpowered." Of course, what those two cars lack in power they make up for in sophistication. Nevertheless, there's no substitute for power.
  • rebelskrebelsk Member Posts: 65
    I have te 6 cd changer in dash in my 2002 ES and a cd jammed. I have to bring it in to Lexus and they said they have to remove the changer and send it out to be rapaired. Has anyone else had this problem? It would seem they should be able to get the jammed cd out without sending the whole unit somewhere to be fixed. Any thoughts.
  • sopecreeksopecreek Member Posts: 203
    Ever since I purchased 2001 ES300, there has been occasional low frequency squeal when I apply brake, and it happens right before the car comes to complete stop. It sounds and feels like the pad is not smooth and grinding. But, once the brakes are applied several times as I stop and go, the squeal seems to disappear. Also, at high speed, there is a slight but definite vibration in the steering wheel as brake is applied. My wife drives the car most of the time and she complained about the high speed braking and vibration issue and I started to notice that recently. I think these two brake issues (high speed steering wheel vibration and low speed squeal) may be related. I read previous post regarding similar experience and wonder if/how the problem was corrected before I take my car to the dealer for inspection.
  • whothemanwhotheman Member Posts: 169
    number of HP in the car for 2003? Does it have to be 10%-20% weaker than everything else in the class? A larger tire size would be appropriate, too. The Camry and ES are short 20HP each.
    I will soon have 1,000 miles on my 2K2 ES300 and I understand it is recommended by the dealer to bring the car in for a 'checkup/service' appointment. Is this just to inquire about the overall satisfaction with the vehicle and any issues I might have? I have noticed that the power recliners are not consistently smooth in their operation in comparison to the rest of the vehicle. I have fiddled with them tilting in both directions at different postions and they sometimes move abruptly, especially if I haven't changed the position in awhile. Maybe they're still too new and need a 'workout' to settle in and smooth out.
    Memory seats - I set postion 1 at the dealership and while driving home yesterday pressed the #1 button and nothing happened. Must the car be stationary for the seat/mirrors to adjust? I know I can check the manual but maybe someone on this forum can comment.
    Oil filters - are the Toyota filters equivilent to the Lexus filters for oil changes? Since they are the same basic engine design and the filter is in the same location as on my Solara, I would assume they would be interchangeable. My point is I reside about 80 miles from the Lexus dealer and only 19 miles from a Toyota dealer and can obtain those 'common' components if they will do the job. I plan on changing the oil at 3,000 miles with Mobil 1 to ensure a long life and good gas mileage.
    One last thing - I have a little over 600 miles on the ODO and was at a stoplight and accelerated rather briskly (not full throttle) and the RPM's did not exceed 4K. I must say the car moved out rather smartly although not with the same urgency as my Solara did. I do hope I caused no harm by this action since the car is still so new.
    Regards -
    M. J. McCloskey
  • michaelf2michaelf2 Member Posts: 12
    My 98 ES 300 has to be in park before you can set the memory seats. Also to move from one setting to another the car must be in park as well. I imagine it is the same in a 2002 model.
  • thomarthomar Member Posts: 2
    Has anyone had the problem of brakes not responding on the first tap. The other day, I pulled into my garage and tapped the brake pedal to stop. There was no response. I hit the brakes again and my car lunged forward in a nosedive and I hit my garage wall and window. I don't know if this is a brake problem, or just another version of the transmission problem.
  • sddlwsddlw Member Posts: 361
    I just finsihed talking to a service rep about a similar problem with my 2000 ES. I have a shake in the steering during high speed braking, but just under certain conditions, and it is an intermittent problem. The rep said he was 99% certain it is a warped rotor and with 27k miles, is recommending to have the pads replaced too. He also said that in his experience, a resurfacing rather than replacement should be doeable. Kinda sounds like this isn't the first time he has seen this. I go in on Tuesday. Unfortunately me, Toyota considers the rotors to be a wear item, even at 27K mile, so it is not covered under warranty. I'm not happy about seeing a warped rotor before my first set of brake pads, but what can you do?
    Maybe you will have better luck.
    1. 1000 mile service is basically a car wash, and to address any concerns you may have about the car. You can take it to any Lexus dealer...it doesn't have to be at the dealer you bought the car from.
    2. For safety reasons, you can't adjust the seat position through the memory seat function when the car is in motion. Imagine being over 6' tall, pushing the wrong memory button, and getting scrunched into the seating position of someone 5'2"...all while driving on the highway.
    3. The oil filters for Toyota and Lexus are exactly the same. Supra, Camry, IS, ES, GS, LS...their oil filters are all interchangeable.
    Here are the Toyota oil filter part #s:
    08922-02011: Domestic-made by Purolator. Spec'd for 6-cylinder engines. Cheapest of the bunch in both quality and price. A lot of times on sale for $3-4 at Toyota dealers.
    90915-20003: Japanese-made by Denso. Also spec'd for 6-cylinder engines. Being that your ES is made in Japan, this is what your car came with.
    90915-20004: Japanese-made by Denso. Spec'd for 8-cylinder engines, but the only difference is that it's a little taller for more filtering capacity. Being that it fits perfectly in 6 cylinder applications, this is the filter of choice for those who really love their Toyotas. Shouldn't pay more than $7-8 for this filter at a Toyota dealer.
    My local Lexus dealers charges a ridiculous $14 for all 3 of these filters. These parts can be ordered online as well, in case you want to stock up and your local Toyota dealer's pricing is high.
    4. Don't worry about it...you didn't even go over 4K RPM.
  • mannymoemannymoe Member Posts: 15
    I have had a '02 since October and have logged about 16k miles. During the winter, the windshield cracked when hit with a rock while driving. Since I replaced that windshield, I have had the two more significant chips/cracks from rocks thrown from other vehicles. I do not follow trucks on purpose and take good care of the car. About 80% of the miles are highway miles and I do not live in a truck infested area. This seems quite odd to me. Coincidence? Has anyone else had any other problems similar to this?
    Other than this problem, I am still in love with this car after 16k miles.
    Many thanks to Kreativ for your detailed contribution to my recent post. I will cetainly obtain several of the 'Denso' filters to ensure my ES300 is pampered in the same way it pampers me.
    I understand why the memory function is employed only when in Park. I tried it and the seat/mirrors started their 'belly dance' routine which would have distracted me if I had been underway. Oh, the trials and tribulations of having all these gizmos!
    Loving every minute I'm at the wheel of my 'dream car' -
    M. J. McCloskey
  • snowdonsnowdon Member Posts: 38
    It is time for a new car and I like the look of the new es300, what is a fully loaded with Navi and Mark going for these days?
    Michael
  • jmdavisjmdavis Member Posts: 1
    I just bought my ES yesterday and to my disappointment I had the same problem. My son told me that it was because I was using a CD that I burned and custom labeled. He put in a CD that he burned without a label on it and it was fine.
    Perhaps that is what your problem is. As for getting the CD out ...tweezers and lots of patience worked for me.
  • rsumasarrsumasar Member Posts: 1
    IM INTERESTED IN BUYING A LEXUS ES 300 AND A JAGAUR X TYPE.WHICH ONE HS A BETTER ENGINE AND RELIABILITY? ALSO WHICH ONE HAS BETTER FINACING?
  • coolguyky7coolguyky7 Member Posts: 932
    Hands down it is the ES 300.
  • i_luv_toyotai_luv_toyota Member Posts: 350
    Lexus=Toyota (ES 300=Camry)
    Jaguar=Ford
    'nuff said.
  • neuroguyneuroguy Member Posts: 34
    Ron - well, you've asked the right guy here! I bought a 2002 X-Type and had it for 5 1/2 months, including 28 days in the shop, before dumping it and getting a ES300. I had so many problems with my X-Type and my dealer that I just couldn't take it anymore. Got my ES300 in May and have had virtually no problems with it - not even the transmission problem that has been discussed here. And the Lexus dealer here has been fantastic - a 180 degree turn from the Jag dealer. To see my new ES300, and for a link to what happend with my X-Type, go here:
    http://home.carolina.rr.com/jonkennedy/lexus1.htm
    See my messages on this board - #2716 for the very minor issues I've had with my ES300, and #2698 for my shopping/decision making process in getting the X-Type over the BMW 325xi last year.
    For more on X-type issues, in addition to the board here, see http://www.jagtalk.com and http://forums1.roadfly.org/jaguar/forums/xtype/
    Go for the ES300 and you won't be disappointed, if it's anything like mine and my dealership! You'll also note that the ES300 has more luxury touches that the X-Type lacks, like memory seats, an in-dash 6 CD changer (it's in the trunk for the X-Type), two cup holders up front, etc. All that, better reliability, and it costs less, too!
    The only things I miss about the X-Type are the audio controls on the steering wheel and the back-up warning sensors.
  • mz1234mz1234 Member Posts: 8
    Hi All,
    I've got a quote of $32,598 for a new ES300 with
    following option:
    - Premium Package (PM)
    - Wood and Leather Steering Wheel (WU)
    - Vehicle Skid Control (RF)
    - Heated Front Seats (HH)
    - All-season Tires (FT, no charge on this)
    - High Intensity Headlamps (HL)
    - Cargo Net, Wheel Locks, and Trunk Mat.
    Guys, what do you think of this price? Please let
    me know. I sense that i can knock down a few
    hundred bucks more.
    As for with Nav and Mark, the quote is $37,883.
    Again, one should be able to slash a few hundred
    bucks more of this quote.
    Comment welcome! 'cause I need to make a decision
    before the end of this month. Otherwise price will
    be a little higher.
    -mz
    Just got an updated quote ($31,957) for the 1st
    combination I just listed in previous message.
    I beleive $31,957 is the exactly invoice price
    for this combo.
    Question: how much a dealer will make out of
    selling a Lexus ES300 @ an invoice price? $1k?
    Thanx.
    -mz
    Not sure about the quote for the premium package, but for the NAV/ML, does it also include the AVS option? If so, you should try to knock down another 1K, at least that is where my purchasing price was.
    For your reference, the MSRP for my ES is $39,963.
  • lexiowner1lexiowner1 Member Posts: 3
    I still have my first es300 93' w/150k and no problems. So I decided to buy a second 02' for my wife. I S/O starlight pearl/ivory, with everything except avs. 38k out the door. It took 4 months and I wasn't sure I'd like the color, but... The color is awesome, I've had the car two days and have gotten two unsolicited compliments already. Everything else about the car is great as well. The Nav/ML is definately worth it. I'm waiting for the Motorola bluetooth car kit to complete the dream car. Again I can't rave enough about the color though. I'm glad I didn't wait til 03' as the color might become unavailable.
    The invoice on the package you mentioned is $32,319. Being able to purchase it for $31,957 is an excellent deal. Are you in southern California?
    This makes me wonder what's happening with the ES. I don't think it customary for a nrewly redesigned car to be selling below invoice in its first year.
    kreativ, I think I was right on this one *$31,957*, not $32,319. Let me break it down:
    Following is the invoive price:
    Base price=27935; PM=1688; WU=264; RF=520; HH=352; FT=0; HL=512; Dest_Charge=575.
    This addes up to $31,846. I could not find invoice price for Cargo Net, Wheel Locks, or Trunk Mat). The MSRP for these 3 small items are (28+41+64)=133. If I assume invoice of $111 out of MSRP $133, I came up with exact $31,957.
    So Lexus dealer is not selling below invoice price but @ invoice price. BTW I am in MA.
    -mz
    Sounds like a great price, Min! My car, purchased in May, is similarly equipped, save for the skid control, and I paid significantly more.
    Looks like you are getting a great end-of-model-year deal. I'd jump on it! Just make sure they don't try to jack the price with a bunch of add-ons at closing and you're good-to-go!
    Looks like we have a discrepancy in what the base invoice price is. It's an excellent deal either way! Where are you at?
    To "kreativ"
    I am in greater Boston area. Bought a Toyota Camry from IRA Toyota back in 1999. The quote is from them as well this time. There're totally 3 Lexus dealers in greater Boston area. The other two quote me MSRP price when I called in. Ask dumb questions like "have you droven one before?", "how much do you know about this car", "do you really know what you want?".
    Come on, give me an honest price and I'll write you a check in 3 days. It's pretty simple, cut and dry. Don't want to waste time with those other guys.
    That's good news that this pricing isn't from southern California. That means more people across the country should be able to get pricing close to invoice.
    I do find it interesting how salesman will try to take advantage of unknowing customers. I played dumb at one dealership and the guy reeled off a series of lies and tried to sell the car at MSRP as well.
    With the new Honda Accord coming on in Sept. with a 240hp V6 and a 5-speed automatic, Lexus should be ready to deal on the '03s. It will soon become obvious to anyone who shops around that the ES300 is underpowered for its price (or overpriced for its power).
    Isn't it great when car manufacturers keep one-upping each other? The specs on the V6 Accord sound very nice, and the interior looks great as well, especially for how much the car costs. Based on specs and interior, I'd choose it over the new Camry. Not sure about the exterior design yet...
    As far as how it relates to the ES, the '02 ES was what you said it is ever since it was released. The TL-S has 260hp, the I35 has 255. And both are less expensive than the ES. Yet the ES trounced both of them in sales. The ES has far more luxury than either of these sportier competitors. Granted, a redesigned model will have more interest than aging designs. But why have one awesome year when you can split it into two? The ES330 should also be quite a hit when it's released.
    Anyways, I find it funny that people still say things like "will soon become obvious" when it's been obvious since the car's specs were released.
    Yes, the ES300 has trounced the I35 in sales, but when you add Maxima sales to the I35, a Nissan clone, then it's not so clear who's ahead. True, Lexus can offer a smaller engine and still sell cars galore beause of the Lexus name and reputation, its plush interior, its renowned reliability, its proverbial silence on the road, etc. Yet, at some point, others narrow and even close the gap. Plus there have been a lot of complaints about this ES300, beginning with the transmission. Consumer Reports says the 4-speed Camry transmission is better than the Lexus 5-speed, and in fact, they preferred the V6 Camry to the ES300 altogether.
    By "it will soon become obvious," I meant that it often takes time for info of any kind to trickle down and become well known and understood.
  • lenscaplenscap Member Posts: 854
    I don't think extra power means much to most buyers looking at the ES 300. Yes, it will sway some people. But not everybody. It didn't matter to me.
    The same reasoning goes for cars like the all-new, redesigned 2003 Mercedes CLK and E320. Both cars will keep their 221 HP engines. And both are slower than the 2002 versions since they are heavier. As a matter of fact, they're just about as quick as the ES 300 with a 0-60 time around eight seconds. And these cars cost well over $50,000.
    If you can, check out the latest issue of Car magazine (a publication in Europe). They test the all-new CLK against the BMW 330Ci, Volvo and Renault. The Mercedes is one of the slowest of the group, yet they place it in first. They say that everything combined makes it the best car, even if it is not the fastest. That's exactly how I feel about the ES 300.
    Lexus should not increase HP just because the Accord now has 140. The Altima has had that much for a year and it hasn't hurt Lexus sales. Similarly, Mercedes and BMW will not be rushing to increase their HP either beacuse of what the Accord has.
    Lexus knows what's its doing. Right now the ES 300 is hot and the extra HP won't do much for sales. But as interest decreases over the next year or two, as happens with cars, you'll see the ES 330 or ES 350 come out.
    I bought my car for the exterior look, beuatiful interior, hushed ride and superior dealer service. In my mind, no car in the $35,000 range comes close.
    Well then, let's just add Camry's sales to the ES 300's and see who's ahead.
  • atoewsatoews Member Posts: 637
    And I couldn't have said it any better.
    I had previously written that I had a problem with my 6 Disc Changer as CD's got jammed in it and I could not remove them. I brought it in last thursday to the dealership and they removed the changer and ordered me a new one. The new one was installed today and works perfectly. They sent the old one out and will remove my cd's and mail them back to me. I was treated very nicely and it was all covered as warranty work. So far, my 2002 ES has 18500 miles and I am quite pleased with it.By the way, wht are they changing with the 2003 ES? I would imagine the only change would be the addition or deletion of a few colors? Does anyone know more than that?
    Fellas, my final post on 2002 ES300 price (should make your guys feel better)
    I made a mistake. The car does NOT have Vehicle Skid Control (RF) and the price is $31,957. RF is
    $520 in terms of Invoice goes which means this price is about $520 over invoice price.
    Bought a black/ivory one today @ this price, though I *might* be able to knock down another couple of hundred bucks, who knows? Just thought those sales people need to make a living as well... Favorite ext. color actually is blue, they don't have that, have to settle with a black. Comparing specs on paper, Camry and ES300 is about the same size, somehow i feel ES300 is smaller than Camry when i am in it and also don't feel 02 ES300 is bigger than previous generation. Maybe I did not feel it right or deceived by its ext. contour.
    Would I have liked an '02 ES with more power? Sure...I'm not going to argue with more power for the money. Would I have purchased another car because there was no power increase in the '02 ES? Obviously not, since I have the car now. And Lexus knows this. Let's face it. They're in this business to make money. They're going to sell more cars by splitting up the redesign and the engine upgrade. If they packed it all into the '02 ES, they wouldn't have much left to garner interest a couple years down the road when their competitors are releasing new cars.
    So they'll top sales this year based on the redesign, the luxury edge, etc. etc. etc. Then they'll up the power a couple years from now, give things a marketing spin with the name change to ES330, and sell even more cars based on a "brand new" ES.
    My general point was that luxury features gradually trickle down to mass market vehicles. Compare the '03 Accord, for example, with the first generation Accord of 20 years or so ago. As mass market vehicles acquire luxury features (at lower than luxury prices), there's constant pressure on the luxury & near-luxury cars to maintain the distance, move ahead, push the envelope, acquire new luxury features that mass market cars don't yet have, etc. It was in that sense that I argued that there is now pressure on Lexus, with the ES300 and the GS300 to make engine upgrades and at least approximate if not equal the power offered by lower-priced cars. No one is arguing that people will stop buying the ES300 because it has slightly less power than lower priced cars. But it's one factor, easily quantifiable and easy to compare at that (240, 230, 220, etc.)and it drives the market.
    Blue would have been my first choice, too, but there weren't any on the lot or in the pipeline to my dealer - would have had to order one. I got the silver with gray interior. Don't know why the blue is on the scarce side. You still did extremely well on the price, btw. Congratulations on your new ride! Enjoy!
    mz1234 -
    Congrats on your purchase! Let us know how you like it after some time behind the wheel.
    When can we expect the ES300 to make its final curtain call, and the ES330 to make its debut?
    If its possible, this is what I would *like* to see.
    For the 2004 redesigns due out in early Spring 03, the Lexus RX will get the 3.3L. At the same time, the GS300 will hopefully move to a more powerful version (or new design) of its straight six, allowing the ES to gain more power (I'm sure Toyota is scared of cannibalization).
    In the fall of 2003, for the 2004 MY, the ES can go to the 3.3L V6, while the Camry will finally get VVTi for the 3.0 V6, and be retuned to make the 220hp of the Highlander/current RX (same retuning for the Avalon). In fall of 2004, for the 2005 MY, the Avalon (for its redesign) and Highlander (for its 4th model year freshening) go to the 3.3L V6.
    **This just represents my ideas, and in no way do I claim it to be economically efficient, or productively viable- just changes I would like to see happen****
    What does anyone think?
    ~alpha
    I think that there will be a 3.5L V6 to go into the Camry. Although this doesn't seem right because it would cannibalize Avalon sales.
