Lexus ES 300/ES 330
I highly suggest interacting with the units prior to making a purchase.
My father purchased a 1998 LS400 through an auction for me. The key we recieved for the car is slightly damaged. I spoke with someone at the Lexus dealer and I was told that there is no way to tell if the key actually works, so if I purchase a new key ($250) the new key might not work, an that I would need a "engine program" to reprogram a new key at a cost of $1100. What?? So I asked, if the two master keys, that is given when a Lexus is purchased is lost and/or damaged, some one will have to pay $1100 for a key? I got no answer. This seems crazy. Please tell me this guy was wrong. What is the replacement procedurce if someone loses both keys or the key(s) becomes damaged?
Try taking the key to a locksmith to see if it can be repaired. Just buying a new key will not enable you to start the engine. It has to be "programmed". You need a working master key to be able to put the car in programming mode so you can program another key to the car. When a working master key is placed into the ignition of the car and rotated to the start position, the on board computer in the car sends a signal to the key via an antenna near the lock cylinder. The key then sends back the transponder code programmed into that key. If the car has been programmed for that transponder code then the computer will permit the car to start.
It will be quite expensive for you if you can not get the damaged key repaired.
One way is that Lexus will give registered owners a "free" Engine Control Module (ECM), so that new keys can be programmed into the vehicle. But they will charge you for two new master keys, and the labor cost to remove and replace the ECM, and to program the new keys. Total cost, at least $600.
Or, you can go to certain locksmiths that have the computer program that allows them to "flash", "re-flash", or "reprogram" (different names for the same thing) the ECM so that it will then be ready to accept and program new transponder keys.
I went to www.locksmithcharley.com to have my ECM re-flashed. I brought two new master keys I had ordered from www.lexus-parts.com But most locksmiths can make generic keys that will work for your car. I removed the ECM from the car, he re-flashed it, I reinstalled it, and he programmed the keys I had brought. Two non-remote (no buttons on the key) master keys cost me $110, and the re-flashing and programming cost $150. There are other locksmiths who do this. Do a search using re-flash and ECM as key words. But locksmiths don't locate and remove and reinstall the ECM. Know anybody?
Any way you go, it is an expense and a hassle. Lexus went overboard with the key and security complexity.
There is no such thing as a "master key" for 2002+. There is also not a key named "transponder" key for the 2002+. I don't believe you have to remove and replace an ECM for the 2002+ either.
New keys WILL cost you $250 apiece however. If they break under warranty, Lexus will replace without it costing you anything.
I own a '99 ES300 with about 86K miles and love the car; I'd buy another one in a minute. But I have noticed that once in a great while - as recently as a few hours ago - that I get a puff (or more) of white smoke when starting cold. I have no clue why this is.
Someone mentioned the possibility of sludge and the fact that their mechanic might have said that they were aware of no such problem. Consumer Reports recently ran a quick feature of engines that are known to develop sludge problems, and the Toyota 3.0 liter manufactured in around 1997-2000+ was mentioned prominently as just such a powerplant. I regret that I don't recall the exact issue of CR, but it was published between 4/05 and now - a recent issue, in any case. The article went on to say that dealers/mfrs. can be difficult to deal with on the matter but that Toyota/Lexus are apparently agreeing to pay for repairs, provided the consumer can produce some evidence that they have changed their oil on at least an annual basis - I believe that is what I read. This motivated me to check my own records.
I've always put regular 10W30 in my car. This past weekend, it was recommended that I switch to Mobil1 Synthetic 5-10W30, which I did. 5 minutes later the mechanic called me out to the car after he'd taken off the filler cap, stuck his finger just below where the cap sits, held his finger out to me and said: " Here's your sludge..." Great....
I'm not exactly sure what to do next, but encourage you to obtain a copy of the CR article. Camry/ES 3.0 liter was mentioned as susceptible to sludge, as were several Volvo and VW powerplants, as I recall.
Sorry so lengthy...
I suppose the idea is to keep the master key in a safe place. Like Fort Knox, maybe. :-)
Here is the link to the Consumer Reports article you referenced.
http://www.consumerreports.org/main/content/display_report.jsp?FOLDER%3C%3Efolder_id=66584- 5&ASSORTMENT%3C%3East_id=389451&bmUID=1120745101755
Lexus and Toyota have a special policy that allows for free fix of the sludge problem for 8 years from the original date of purchase. It is my understanding that you should still be covered, even if you are not the original owner. Toyota requires that you provide proof of reasonable maintenance, but I am not sure how that can be done if you bought used. I would be very wary of buying any of these models without the previous owner(s) also turning over all maintenance documentation.
Please advise
P.S. recently had the computer updated (see TSB 3/05), and car drives much better. Even my wife noticed more get up and go
thanks....
Ron
FYI: I have had 3 Lexus'
Now have ES330, 2005, and I agree with your assessment of turn signal.
My '94, and '01 had loud signals, too loud.
My new '05 is too "silent", and its very easy not to hear it.
I suspect that company had complaints about the noisy ones, and decided to
go the other way...I, too, wish it was adjustable.
However the ES is a great car, and gets good milage.
My ES330 now has about 7000 miles on it and the turn signals still drive me crazy!
Everything else works just like Toyota/Lexus says it is supposed to, so I have been happy with it otherwise.
It is good to hear another voice of reason!!
Ron
was 5,000 miles. I drive 800-900 highway miles monthly. Is every 5,000
about right to maintain this car properly ? Any thoughts on the topic ?
Thanks !
Overall, I would say that I bought a fancy Camry. (But my wife's 2004 4 cyl. Camry has a smoother transmission.)
Sometimes will come on for a few seconds but most of the time it will stay on.
Has anyone had this problem and if so, what did you to take care of the problem?
An interesting story is that prior to 2002, Lexus windshields had "Toyota" printed on them until Lexus owners complained. Lexus owners apparently want the status showing on the windshield.
The same is true, I believe of all of the windows. They have "Lexus" printed on them.
I need to get the new lexus ES330 tomorrow and I am still to decide the exterior color.
I know is more of a personal choice but still appreciate your comments.
1. Overall which color is good? More appleaing ? which is more famous ?
2. All the colors have same kind of durability?
3. My wife likes light green, but some one said that this color was mainly for older people..Is it a general perception ?
4. Is it a too much hassel to maintain Black exterior?
5. What about white?
Really Appreciate your comments and feedback.
