In most other ways, I like the car. Just wanted to put in my two cents and let mdriver know that there are mileage-conscious people out there today. Also, I do realize that the ULEV rating means a lot more for the environment than the mpg rating (no?). Also -- my fuel guage is incredibly whacky, too: the other day it seemed to come on way too early, then went off and hasn't come back on. I'll see how many gallons are in there when I get gas tomorrow/next day.
Some people immediately start checking mileage and don't like the results. It seems to take about 5000 miles before they peak.
Why? I don't know.
Bye-the-way, anyone planning to get the HX should be aware that what you gain in mpg, you lose in throttle response. At steady speeds, the car hesitates and balks when more speed is desired. This is not a defect, but a characteristic of the so-called lean-burn. This is an annoyance that is not worth the few $ saved at the pump.
I'm at 3600 miles now. The lowest MPG to date (30% highway/70% city) is 29. The highest, though, is only 32. If I don't get on the highway at all and don't go flying through town, I'll get 30. Once, I had to run to a small town 40 miles away. Traffic moved at 75-90 mph. The entire 80 mph trip guzzled a bunch of gas, let me tell you. If you have to go above 70, set the cruise. If you don't, you'll pay later. As for city driving- try as hard as you can to stay under about 3500 rpm. Above that, you inch closer and closer to where the VTEC timing switches over, which throws your gas mileage out the window badly (instead of 30, 20). DX & LX owners should adhere to that also, even though they are VTEC-less. For you 5-sp owners, don't tool around town at 35 mph in 3rd gear. Upshift.
My stereo still codes, but the dealer says that a fix is on the way. They're supposedly doing it by VIN number, so...hopefully mine is on the way.
A buzz has developed at the base of the driver's side A-pillar. This in addition to the creaking above the passenger airbag. My seatback release only works on one side, but the sunroof sqeak fixed itself. All this will be fixed at 5000 miles, when the car will get its first oil change. One other thing- everyone check under their front bumper after you read this. There's supposed to be a flimsy black rubber something attached with flimsy plastic clips under there. No rubber- you ripped it off. I did it within about 1200 miles. Oh well.
Likes: good gas mileage, good pickup, good handling, classy interior, good looks (love blue), and user-friendly controls. Really roomy inside, and a large trunk. Defroster is quick.
Dislikes: No remote trunk release. Not much interior storage. Too-shallow cupholders. Marginal ride, especially on highway. Noisy above 65mph. Sensitive to crosswinds at highway speeds.
Despite all of this, this car is far nicer than just about anything out there. The Protege is a better sport sedan, and the Sentra is really close (the Focus is poorly assembled). The Civic is better overall than both. The Jetta outclasses the Civic, but is more cramped and more expensive.
Anyway, right now I use a portable CD player going through the radio on one of those kinda cheap cassette-style FM modulators and it sounds LIKE CRAP IN THE NEW HONDA. On my old car, a Subaru, the exact setup sounded fine, but on the brand-new Honda, I have to turn it up almost all the way to hear fairly muffled music. And I even checked this out -- the Alpine aftermarket CD changer that goes with the Honda would cost almost as much as getting the Honda changer (I'm told it's actually the same changer), after you add the price for the required interface.
So... if I want a changer and I don't want to pay for the direct changer, would a fairly decent aftermarket FM modulator CD changer sound as bad as my cassette FM modulator setup I have now? I don't want to go to the trouble of having this thing installed and having it sound just as bad. I'm NOT that picky about sound -- I just want a sound improvement over what I have now, with the added convenience of the changer.
Any suggestions? Thanks in advance.
You could check the following web site to find out which model fits in your car. But the price is not very cheap and you have to install yourself.
http://www.crutchfield.com/
steve
Anyway, check out http://www.autotoys.com. They should have what you're looking for. If they don't, go to http://www.hondaprelude.com
I know, it's not a Civic page, but their links section is extremely thorough. Between the two, you should be able to find what you need.
I also thought the civic speakers were fine until I installed the new head. Actually, the stock speakers match the oem head - which is the typical low power setup. Remember too, an FM-mod changer will sound no more than what your tuner can pull, defeating the purpose of why we buy CDs.
The "problem" for me is when listening to different sources (like in our home or minivan systems), then the dead-end Honda unit had to go.
Civics are now easier to go aftermarket, using standard DIN (E-size). Aftermarket also gives you the benefit of a "base" starting point, where you can grow/upgrade your listening preferences. With a little planning and preparation you can vastly improve the stereo, with equal or less the factory option costs.
http://www.jcwhitney.com/
As far as california is concern....depend where you at. If the headlight are for off-road used and aim improperly sure...they will pull you over. Where I live is a small town the the police there doesn't seem to have anything else to do....so they love to pull over people for anything they done.
There seem to be a few companies out there that made bright blue bulb. I bought some phillips cool blue for my honda accord. Works fine.
It now has 7,000 miles on it.
The worst gas mileage I have had is 33 MPG
The best I have had is 39 MPG
The overall average is 36 MPG with driving split
70% hwy/30% city.
Had the PCM replaced pretty painlessly about a month ago.
Zero problems, zero complaints so far....OK, one complaint. I wanted a blue LX model, but they don't make LX in blue.
Just thought I would let you know miles per gallon figures are normally low for all cars when first purchased. It takes at least about 2000 miles for the engine to break in and Loosen up. After that your mileage should go up... So don't worry.. Just expect low mileage when new and the numbers will get a little better after 2K+ or maybe even 5K miles.
You guys are lucky. getting 32MPG at least. When I first got my car I was getting 14 MPG and it is rated at 17 City 23 Highway. Now I get about 18 MPG. I do rev that V8 every now and then.
Remember the MPG figures on the Sticker are just refrence results for your particular vehicle. Traffic, Terrain and most importantly your driving style will actually dictate you MPG. Just as you might never hit those numbers you might do better.
Glad to hear Civic is a reliable car. My ex also drove a Civic and I owned an 85 Honda back in the day so as far as I am concerned you can't go wrong with HONDA. Now if I could only muster up about $88,000 and buy and Acura NSX!
Airwolf1000
http://groups.yahoo.com/group/AcuraEL
There are links to various reviews and information in the bookmark section. Just reading the archives will give you an idea of what's going.
Good luck!
1) No, the glove box isn't lockable. They did at least move the handle to the driver's side of the compartment door.
2) They're more useful, but still not the best. They're deper, and they've got a better mug cut out. But unless it's a can or a mug, whatever it is is prone to wobbling. On top of that, the cupholders are in front of the shifter, a slight problem for 5-sp drivers when in 3rd. One last gripe: if you use the 12V power outlet, the passenger cupholder is basically blocked.
3) No, but they fog at just about everything else. :~) Anti-fog works well, I've found.
4) Nope, because they stay attached now.
5) No, the driver only can lock the doors.
6) An '01 LX should at least keep up with, if not outaccelerate your '99 once broken in. Until then, you'll be eating dirt. My new EX could barely keep up with my friend's 95 DX at 1500 miles. DXs & LXs got a pretty significant boost in horsepower and torque for '01, with no real weight gain.
If you need anything else, feel free to ask. I've probably already answered it- I've got a big mouth and like to blab.
http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy.cfm
Service Bulletin Number: 161100
Bulletin Sequence Number: 157
Date of Bulletin: 0011
NHTSA Item Number: SB615796
Make: HONDA
Model: CIVIC
Year: 2001
Component: FUEL:FUEL TANK ASSEMBLY
Summary: SUBJECT REGARDING FUEL TANK CAPACITY CORRECTION. *TT
and then:
Service Bulletin Number: 161200
Date of Bulletin: 0012
NHTSA Item Number: SB615808
Make: HONDA
Model: CIVIC
Year: 2001
Component: INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR:GAS
Summary: INFORMATION ON ERRATIC FUEL GAUGE READING. *TT
I called my dealer's service tech and told him about the above info. I have been having erratic fuel gauge readings for a while, and my gas mileage seems really low (like 20's). He is ordering the Fuel Tank sensor (not sure if that is the actual name of the part) for my car, a 2001 LX, and will replace it next week. It supposedly takes about an hour.
There is also stuff at the NHTSA site about air conditioning problems. I don't know about that yet, but the way things are going with my car, I imagine I will have to deal with that, too. I thought Hondas were supposed to be well made?
Ladychaos... I drive a 2k-Sedan-LX and it's bare bones compared to our 01-minivan. Why is that - simply price (you can only get what you pay for). Why do you think Honda sells the DX trim/level? Besides, if needs to be secured, then it goes to lockable trunk (you have to exit the car anyway). The LX package fits my needs/use more than the EX (for one, since I knew from the start to upgrade the stereo system), and not bad for a $14.5k Honda A/T.
Jimsxn... "a few more bucks" is relative (and a whole different topic). Or, in the same sense, a BMW is nicer.
Enjoy.
"moving away from the thing that gave it success"... why, isn't the Corolla and Civic the standard everybody (Focus, Sentra, Protégé, etc.) is trying to beat. Nevertheless, this competition among the manufacturers can only be good for us.
The finish on the Elantra doesnt seem as bright or "dense"..and the upholstery a little "cheezy"...but the Warranty is amazing.
The Civic is handsome, inside and out...but virtually no warranty...(no matter the generally-known reliability...there is no real warranty in terms of years, drivetrain, etc...)
Wehave had several Toyotas, which lived a years and years...but feel like we need a change...
Please send advice...or warnings about particular problems you all may have encountered with these cars..
Thank you so much.
The Civic is the best value 90% of the time. It gets great gas mileage, isn't too expensive to start, and is roomer than everything except the Focus and maybe the Protege. It's a great all-around car.
The Elantra is a decent value. It doesn't get great gas mileage, though, some things about it seem cheap, and the interior space isn't as good.
The Corolla is probably the worst choice in my book. It's got a great powertrain, and not much else. The dash isn't as modern, the interior is cramped, and the thing moves down the road like a rental car.
Look at the Civic first, the Elantra second, the Corolla if you must. Also check out the Mazda Protege, in 2.0LX form. The Nissan Sentra GXE is a good car, too, albeit a rather snug one.
What do you think about that measly 3 year , 36000mile warranty pkg. of the Civic...
We keep our cars for years and years.
Hyundai was forced into going with the long warranty because of their dismal past.
It was pure marketing, and probably the thing they had to do in order to survive.
VW had to do the same thing.
If you are still concerned, a hondacare extended warranty is available for modest cost.
Buy that one.
Also, my driver's side upper part of seat rocks a little bit. I wonder if this is a defect in the seat or can it be adjusted.
As for gas mileage, I'm averaging nearly 35 mpg with a 70/30 hwy/city.
Someone mentioned earlier about a black thing under the engine coming off. I had my engine cover catch on a low curb the I parked up to and it came undone. Dealer, put new clips back on it but I was disappointed that something like that would happen on a curb that was low.
Please stop by and introduce yourself in Meet the Members and let me know how I can help build your club.
I have linked this discussion into that folder, but it will always reside here in Sedans.
Looking forward to meeting everyone!
KarenS
Owner's Clubs
Quite affordable. And must be very reliable.
Any thoughts?
NewCiv
Any thoughts?
NewCiv
Overall: Pleasant and honestly sporty, but at the price, so are others with better reputations for quality and resale value.
James R. Healey's Test Drive column appears Fridays. Healey has covered the auto industry for USA TODAY since 1988. E-mail him at testdrive@usatoday.com.
Personally, I think that is a mistake.
FOR THOSE PEOPLE, paying a bit extra for the peace of mind of an extended warranty may be a smart idea. It is your opinion that these are overpriced. I guess for the person who had to use it, it was a pretty good life perserver.
The length of a warranty does not equate to the quality of the product.
Sears has long offered a "lifetime" warranty on their Craftsman tools.
There are professional quality tools out there that cost more and work better. They also don't break nearly as often.
What do you suppose the professionals use?
Once again...the BEST warranty is the one you don't have to use.
First of all, how often will a new car under warranty need this service?
For many years, I keep renewing our AAA membership. It's not expensive and gives my wife a bit of security.
I think I've called them three times in the last twenty years.
But, to others, I guess this might be a big thing.
http://www.edmunds.com/chat/freewaychat.html
Drew
Vans, SUVs, and Aftermarket and Accessories message boards
