price wise...my hard cost, installed is $350, but
that cost carries the same 2/24 warranty as the car...if you have a problem...we replace it with a new one.
Easy to install, yes. But in order for the system
to operate PERFECTLY it has to be programmed at
the Dealership...Other posts about that here somewhere, problems, etc.
Shop and compare...I think the VW.COM price, and
you can get that at a Dealership, is pretty fair.
Avoid car dealerships like the plague-they rank right behind politicians and lawyers for their propensity to lie, cheat and steal.
It all works perfectly, every feature, and the dealer didn't need to tough it at all.
Thanks for any information.
I heard the Monsoon system is good but it lacks bass and it is hard to find an aftermarket amp to boost the Monsoon system. I am thinking of getting the basic stereo and then replace the speakers and add an amp for the system. Any suggestions ? Thanks.
Anybody has any infor on how to install a new CD/receiver on Passat? (2000 GLS v6)??
However, the Passat's (X3) I looked at all had the Monsoon system....leaving no option. If I wanted the vehicle, I had to buy the system. You may run into the same problem.
Otherwise....the Passat has been a great riding vehicle. Very happy at 5300 miles.
John
booklet that came with your Owner's Manuals...
This System is 200 watts/8 channels, but you have to know how to operate it...For example, you have
to set treble, bass, and mid for each medium...
am, fm, cd, & tape because those sources are so
dramatically different.
If you have problems please contact me...I would be happy to help.
Believe me...this is a great system, but it also
sophisticated and requires a little effort to
optimize...it is not just a matter of hitting the
power button.
r34:
In my humble consumer opinion.....unless you're into a sophisticated sound system that requires reading a manual or book to operate, I'd get the regular sound system and save the bucks. I personally want a car radio I can operate without reading a manual. PLUG N PLAY! There's enough reading on other more important topics.
Bottomline: when I bought the car I did not pay much attention to the sound of the system. The price definitely caught my eye but I figured it was a really nice radio. Plue it was the only wagon on the lot. On the way home (1.5 hour drive) my wife drove and I read the manuals and played with knobs, controls, etc. (the things we do with new cars) and I was kinda disappointed in the price of the sound system compared to what I heard.
Good luck....
John
ever heard regarding this system...and I talk to
every single new car customer that we have.
Regarding price...you might want to check to
compare the cost $287/$325..to other mfg. upgraded systems, or at the cost of a 200 watt,
8 channel, actively crossed system at CircuitCity,
or Best Buy...plus installation.
Once again...if I can be of help...call me
I heard some people complaint the Monsoon bass too and they told me it's quiet difficult to upgrade the monsoon system. They suggested me buy the base stereo and then spend money on aftermarket amp/speakers.
mid for each medium, ie. CD, Tape, am, & fm. Never
heard of the above...
Has anyone noticed (on their Passat) a loud start-up knock from the engine. I noticed when my wife started the engine that it knocked (top end) for about 1 second very loudly. I was wondering if this was normal?
Thanks....John
4X20 to the tweeters (2 at *A* pillars) 2 in rear
Doors)
2X20 to the woofers (front doors)
2X30 to the Sub-woofers (rear doors)
How about things like hoses and battery ?
If a failure of a component will prevent the car to move, that component should be covered under the 10 years warranty, right? Thanks.
trans, diff.,etc. Bumper to Bumper is just that...
Warranty Booklet is 28 pages in length...Talk to
the F & I person re: Masterguard Extended.
Whats the best deals anyone get on a '00 and what dealer. Im on the west coast.
Andrew
your attention to the fact that 4Motion is not an
off-road system, but is all-wheel drive...all the
time. If you go to VWVORTEX.COM and go to *news*,
and then to *archives* at FEB.2000 you will find
a review of the car...you can also go to *PRESS*
at the VW.COM site and scroll to the bottom and
you will find there the press release about 4MO.
I am sorry that VW took off a great animation on
the site that illustrated the benefits of traction, safety, control, and performance. 4Motion/Quattro cars came in 1,2,3 at Le Mans this
year...race cars, of course, but those Audis won
it all.
This is just a heads-up, because if you understand
the benefits; you might get a great deal on the
flagship car...and you guys down there get plenty
of rain...just a thought....
Thanks for the input.
I'll get it documented at 10,000 oil change and have them check it. Not so bad.....with the 100,000 mile warranty I guess.
I wonder if Syn. oil would make a difference....
John
I am a future 2001.5 Passat GLX owner. I cant wait.
I fell in love in 98 when the B5 came out, and now the new B5.5's are super-sweet.
Mine will be:
'01.5 GLX, White, TIP, grey leather, and then I will put some Borbet Type C wheels on it!!
Check out my website:
http://home.pacbell.net/lerxt/passat.html
Im here in So. California (Glendale)
Anyone here from the local area?
Whats the best dealer in the Los Angeles area / The worst?
I helped my sister get her 99 Jetta from the Pasadena VW dealer.
Stephen S
lerxt@pacbell.net
I know for a fact that using a lower then recommended gas octane can cause knowck and pinging under load, but I wouldn't expect that to happen at idle on start up. Keep it documented and you should be covered... that 100k mile powertrain waranty will cover you for a long time.
Is Passat base stereo using FM to receive/send signals from/to the CD changer or it depends on the CD changer ? My friend told me this setting will downgrade the sound quality.
the changer probably without much trouble...
Circuit City has adapter plugs, etc. But don't
change out the head unit. We had a lady go to CC
with her New Beetle, and they screwed up the
wiring harness and some other wiring and she could
not start her car...brought it into us on a hook
with an aftermarket deck...no warranty coverage...
well you get the picture.
One suggestion though...I pointed this out before
in a previous post. A Six Disc changer is $350
installed at my store...pretty reasonable to me,
and as factory equipment, we treat it like a
warranty item. As with most electronic stuff, if
it works out of the box; it will probably work
forever. If a customer has any kind of skipping
problems, etc. we just replace it with a new one.
If you have a problem with an Alpine, or Sony, or
Nak...it will be repaired under warranty, but they
will charge you to take it out, send it to the mfg. and to reinstall...just a thought...
My wife usually uses the mid grade gas, but I put in the 93 oct when I'm in it. But it's not that kind of ping/knock, as you already stated. The knock is when the engine is first started, usally on colder mornings. I've noticed it doesn't do it every time.
I'm not very worried at this point because of the great warranty VW offers. I'll have them check it at 10k service (in writing) just in case.
Thanks for response.....
John
fit...
1. About what is the discount I should expect from a dealer for a new 2000 wagon vs. a similarly equipped 2001 car? (If it matters, I'm in the Wash. DC area).
2. Is the only difference between the '00 and '01 models that the '01 has "side curtain protection"? What exactly is it, anyway? How does it differ from airbags? I noted that though the Passat has "airbag" marked where the front airbags are located, there's no such marking for the side curtains (at least, not based on what the salesman showed me).
The difference between a 5-year-old vs. 6-year-old Passat wagon is $1750. This is one way to ESTIMATE the cost to you if you buy a 2000 vs. a 2001 and trade it in after 5 years. On the one hand, a 2000 (with little or no miles) is a brand new car; on the other hand, you are purchasing something less valuable than a 2001 and should see a reduction in its cost.
The dealer wants you starry-eyed with exhileration after a test drive--but you are making a huge purchase and need to look beyond the thrill of the moment. Even if a "new 2000" has that "new car smell," don't forget that it isn't quite as new as a 2001.
Side curtains are thinner airbags that basically cover the front and rear window in the case of a side collision, protecting heads from getting whacked and keeping the flying glass to a minimum. Side airbags usually only extend up to the shoulder and don't do much to protect your noggin.
I think that the 2001's also have the addition of steering wheel controls (cruise and radio) with the leather package and GLX trim.
John
2000 Passats, as part of a 2001 *Build Out Incentive* program. Your best price would be $1000
back of invoice plus $2-300. Isn't a Dealer out there that won't take that deal on a 2000...But
this incentive DID NOT apply to 4MO...be advised of that.
*Full Curtain Side AirBag Protection* is STANDARD
on all 2001 Passats with an August or later Build Date...Steering Wheel Controls Standard on ALL
Passats.
Side Curtain Protection Labels at the *A* & *B*
pillars...
Which to buy? Dollars VS Safety, I guess...kids,
driving profile, ie. Miles you or your wife drive,
and where...highway vs in town. I was a Paramedic
for years and T-Bone Accidents come out of no where, believe me. Kids in a car can be a distraction, if they are little...Don't know enough about your situation to give much advice
beyond take all of these things into your decision...
Now here's my story: I ordered an Indigo Blue GLX wagon back in September. Last week my salesman called and told me there is a Blue anthracite 4MO GLX wagon available. By that point, patience has pretty much evaporated and we decided to take the car. The color is actually quite nice and I've read a lot of good things about 4MO so we didn't mind paying extra for it. Not that we need it that much in San Diego.
Now the (not so) sad story, we paid full MSRP for it (>32K with destination). Well, almost. We got window tinting for free. Knowing this is a hot item, I didn't expect to get much discount anyway so I didn't bargain very hard.
Here's some other items they offered to me:
in dash CD player: $495
CD changer: $595
Teflon coating protection: $395 (later reduced to $295)
Extended warranty (6 yrs/72K miles): $1250
LoJack: $595, later quoted again at $495.
All numbers seem way too high for me so I didn't take any of them. However, I AM interested in extended warranty but couldn't find out more on vw.com. vwguild, you mentioned MasterGuard. Is it the official VW plan? How much is it and can I purchase it from a different dealer (such as you)? The one offered by my dealer is run by Fidelity Warranty Services, and they claim all VW dealers will honer the warranty. I'm also interested in getting a CD player/changer from a different dealer since this place doesn't have one in stock anyway.
Thanks for the help. vwguild, thanks for being here and offering lots of valuable information.
Richard
or give me a call...all numbers posted at
westerVW.com
I really do not want to engage in any commerce
here. Will be at work by 10:00AM
Glad you got the car...what color leather? BTW...
Anthracite has been the more popular color up here, do not know why, but nonetheless true. And,
you will learn to love the 4MO...If you were to
go back and drive one w/o now you would feel the
difference right away. The fact that it is so
transparent is it's beauty...Talk to ya later...PS
How did this happen? Why wouldn't he budge? Especially since 4-motions are not selling well in So-Cal!! (See post #73)
The fact that the dealer did not give you a good deal, should be sending up all kinds of red flags if you are considering any of the other items he is trying to package into the deal. This dealer is trying to take you to the cleaners big time!
I wouldn't even use his prices as a way to comparison shop--they are that high. For instance:
*Your dealer's "$595 cd changer" can be installed for $350 at many VW dealers. (He would have made another $245!)
*Compare your dealer's $1250 "6yr/75K extended warranty" to prices mentioned on this bb and others for the same warranty--$1195 for 10yr/100K!
*Teflon coating is generally recognized as a scam--a relatively worthless add-on. First, you don't park your car in the Death Valley sun, and Second, VW paint is excellent-it doesn't require this kind of additional protection.
etc......
But hey, after you outfit your new car as you please (hopefully for a good price), I am sure that you will love scooting around town! Congrats on you new car!
For everyone, is it worth to buy an extended warranty ? Which long did you extend ? I received a quote from autobytel, I can't remember whether it is $399 or $499 for 5 years vs my local dealer's $999 for 5 years.
For anyone who is interested in the 4motion's, my friend got a 1999 Audi A4 2.8 quattro auto, leather seats, sport package, sunroof package, Bose packages, heated seats at the end of 1999 for just several hundreds above invoice. If you don't care the additional year warranty and scheduled maintaince, compare the 2000 Audi A4 2.8 with the 4montion Passat. You can usually get more discount for a 2.8 than a 1.8t.
However, if you've already bought the car, you might not want to know (unless you want to raise H#@& with the dealer).
I remember the Hondo Odyssey selling for full retail about 9 months ago. I didn't believe it until I checked with four different dealers and also compared on edmunds TMV. The vehicle you purchased may have been in that category. If not, we all live and learn......my advice: enjoy your car.
John
System, ie. regular is 4X20.
In Dash CD Player is $350 in your car. VW Master-
Guard is what I would recommend if you want an
Extended, but that is up to you...many opinions
on that subject...but if you do it that is the
way to go...$50 deductible and honored at all
VW Dealers US/Canada.
Andrew
-R
