btw....i also have never felt any pinging while using 87 octane but use premium for better mileage
Oh, and very short trips for a long period of time may be detrimental to your engine. Best is to have at least one longer (40 mile) trip at least once every 10-15 days.
I've been following your discussion forum for a while and wanted to ask you guys for some help.
I'm getting out of college this Spring and looking for a car. I have shortlisted my choices to 2 cars:
Chevy Malibu 2002 25K miles for 10K
Nissan Max SE 2002 25K miles for about 16K
While, price is certainly a big factor to me as I'm just getting out of college and also I don't really need a maxima type of car right now. But I can get the maxima through financing if the deal is good and if it'll be a better and more economical car in the long run. I wanted to know what you guys thought about it as most of you own maximas. Also, would you know anything about the difference in insurance rates for the 2 cars. I'm thinking that the maxima will have a much higher premium.
Please let me know what you guys think being firsthand owners. I have shortlisted to these 2 cars using help from discussion forums, and i'd really appreciate information. Thanks!
deciding3, hang around here more knowledgeable enthusiasts will fill you in.
Good luck!
Well now that I have praised my "Max". I have one question...is it possible to have the dealer program the keyless entry the lock the doors when the car is in gear and unlock them when the car is in park? It's all Nissan OEM, no aftermarket alarm.
Thanks!!!
before purchasing,i would highly suggest to you if money is an issue, to go for a 1997 to 2000 maxima... it might have more miles than the malibu, but overall, it'll be a better value for your money than the malibu for many aspects - power, size, image (maxima's have a better product image than a malibu)... etc..
The one knock against the Maxima is that it requires premium fuel. However, think of it this way; it is much cheaper to own a car you're truly happy with, than to settle for something you don't want and then ditch cars every two years.
But, since money is an issue for you, the better deal up front is the Malibu. While it is not in the same class as the Maxima, it is one of GM's more reliable midsize products and should give you good service. And, 6K is a lot of cash to save at your stage of life. You have plenty of time to dump big $$$ on cars when you are established.
However, you should be able find a 25K Malibu for less than $10K, unless the '02 Malibu is loaded.
Only you know how much it is worth to you to own a real driver's car (the Max) as opposed to simply having transportation. Good luck with your decision.
However, you should be able find a 25K Malibu for less than $10K , unless the '02 Malibu loaded.
If you are looking at a 5-6 year or older Contour, you might want to consider not even insuring it. The difference between it's market value and your insurance deductable may not be worth the premiums for collision.
http://money.cnn.com/2003/04/22/pf/autos/nissan_maxima/index.htm
Geez, what have they done to this car?
Plus its DEALERS NOT STEALERS KYLE.
i'm driving a 03 grand am GT right now while away from home on business, but for whatever reason, the driver ergonomics is just better.. the steering wheel is beefier.. the radio is slightly pointed towards the driver.. certains things is just better in this car than in my maxima...
i drove my max over easter, and the steering wheel just seem so thin.. i want to replace it, but then i have to do the airbag and etc.. not worth the effort..
I can't wait to see some SUV with 24 inch rims next. Some people really think that the bigger must be better.
Low profile large tires require very careful balancing and that is not easy to get from a regular tire store in the USA. Even balancing my 98 SE 16 inch tires is not easy. 1/4 ounce (7 gram) weight increments commonly used in most tire shops just don't do it. I have to go to places that have weights in 5 gram increments and a well calibrated balancer. And, even then, it takes them several tries to get it right.
I would spend a little more and get the much better more refined Maxima.
BTW-I saw a silver '04 Maxima the other day and it didn't look to bad to me. Maybe the new style is growing on me.
The Sales Manager calls VDC an "expensive toy" and actually advised against the $900 (list price) option. I cannot find any more information on the subject. I will appreciate any opinions as to whether this is a toy or a valuable safety system for a family car. Thank you for your help.
If you ever have to drive in snow, you'll want it. The $900 cost is nothing compared to what one small fender bender (let alone something bigger) would cost you in repairs and insurance rate increases.
That said, I also don't know what the Maxima VDC entails and how well it actually works. BMW's and Mercedes systems are supposedly very sophisticated and work well in panic or unexpected situations. You may want to research this a bit more before taking your salepersons advice.
