Speaking of Intrigues, the dealer I traded mine at appears to have it listed in their ad that was in today's newspaper. They are asking $13.9K for it. If someone is willing to take a crapshot on the fact the car might not have anymore problems and can talk them down $1500 or so, they will have a heck of a deal on a very nice Intrigue.
While I'm sure everyone knows that I'm really loving the Lincoln's V8 power, excellent ride and handling, and much quieter interior as well as many other things, there are a few things I miss from the Intrigue. One is the Intrigue's separate control stalk for the wipers on the right side of the steering wheel. The Lincoln has it's wipers on the turn signal stalk. Also, on the Intrigue(as well as many other cars these days) to put the high beams on, you push the turn signal stalk forward. To go back to low beams, you pull it toward you. And to simply flash the high beams(optical horn) you pull it toward you and release it. On the Lincoln, you pull the lever toward you until it "clicks" to turn the high beams on and then do the same thing to go back to the low beams. IMO, this is old school as my old 89 Olds Touring Sedan was this way. Two other small things on the LS are the doors do not automatically unlock when you shift into park(no Ford product does this) and there is no "delayed locking" feature when you press the lock switch. I had really gotten used to that little feature. Oh and the Lincoln doesn't turn the interior lights on when you remove the key from the ignition. Okay, so I've nitpciked enough! So while the LS is clearly a higher calibur car than the Intrigue was, the Olds did have some very neat little touches that one quickly starts to take for granted.
Interesting sidebar: as I mentioned before, it didn't come with carpet mats for some reason. So I ordered a set. I got them this week and they are the "final 500" mats! My car isn't a final 500 car but I'm keeping these anyway since they have the old-style script "Oldsmobile" logo embroidered on them. Very cool.
Anybody out there have any other ideas on how to fix an extremely in accurate temp display?
TIA
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
Needless to say I told the service rep. I didn't buy it and it's obvious there's a design problem with the car, he said he wasn't allowed to say that.
I had mine changed this winter and the flickering light issue is gone. Your dealer is not being honest IMO.
b4z : Not helpful.
I've gotten quite fond of the phrase the GM fellow at the Lemon Law department used. This is merely a "design characteristic"! Apparently they forgot to include this bonus in the brochures.
All else I still am quite satisfied with at 33,000 miles on our 2001 GL. Great ride, gas mileage and body style. We just have to restrict our driving to daylight hours!!
Was in the process of formulating a pithy comment about the alternative.
Appointment arrived a few minutes early so I didn't finish typing and hit the post button.
Anyhow, my advice would be to go ahead and get another replacement alternator. Possibly an aftermarket one.
My car is ok now so clearly there must be a replacement that works. If it doesn't I suspect there must be another issue.
Once again the air pump is a cop out by the masters of spin as mine, after many moons of nothing, turned into strobe light a while back Every 3 to 5 seconds for a 40 minute drive home. Awfully stupid design to hav ethe airpump come on every 5 seconds.
Headlight flashes from two oncoming cars and one poor soul in front, pumping his brake lights at me. Plugged my DVM into the lighter and watched the voltage go between 14.5 and 12.5 volts. After two days and fretting about the dealers excuses, now going on three alts., I cleaned the rusty nut connection on the ground wire that runs from the negative bat. terminal to the frame rail just behind the battery and the problem has not reoccured. Good management or good luck, time will tell. I'm leaning on the latter.
This crap from Gm is why i shredded my Gm loyalty certificate. So dissappointed. Never again, unless they discount it 40 percent to compensate for the massive depreciation and incompetance of engineers. Besides, i couldn't afford the divorce lawyer the wife would want if i put more hard earned money into another one of their .......
V8 lincoln guy : I read with baited breath for your new car purchase with every post as you battled a war between products. I said nothing but am glad you didn't go back to gm after the very unfortunate garbage and losses you incurred.
Dindak: the luckiest Gm owner in N. A., not once but twice with the alero. Not only are you not afflicted by most probs that every one else has but when you are, they get magically fixed the first time with a wave of a wand. I for one am envious.
Get an aftermarket headlight harness from somewhere like suvlights.com. Another bonus is improved headlight performance in general which is mediocre at best on the Intrigue.
I don't think I'm lucky, I think I am not unfortunate like you and some others. Most Intrigue owners are generally happy, you just tend to hear all the bad here. It's too bad the quality wasn't more consistent in the car because I love our car. Ok maybe I'm a little lucky.
As for the Alero, not much luck there. The car ranks near the top in initial quality and I have an 02 with an Ecotec power plant which is more reliable than the V6 or the 2.3L it replaced. Solid car. I worry about the Intrigue a little, don't worry about the Alero at all, it's been trouble free for the year and a half.
To date
first set of skins gone at 40,000 kms
several check engine lights with one under warranty and the others at $200 to $400 evry 6 months for sensors/modules/ harness, not sure as i was not involved.
Air condintioner toast after 65000kms, hasn't got it fixed or looked at.
Three sets of brakes with rotor turnings, only the first covered.
Wheel bearings shot at 75,000 replaced under warranty when i told him to go back cause '01 have powertrain to 100,000. Originally i think they told him about $500 a side. My motto, be informed, if you don't ask , you don't get.
Of coarse most of the above are typical of gm, shame really cause i don't think they will be very popular in ten years or less. People today won't put up with the north american poor quality crap that our parents did. They will move on to offshore models and take their chances.
Loyality doesn't ring anymore as a lot of people see the lack of loyality from the manufacturers and say "i'am not going to buy N.A. again just cause its N.A."
You are right though, if I had a car like that, I'd be looking to another manufacturer. Statistically however, GM isn't very far behind the best Japanese makers these days and I'll take statistics over a one off case anyday. My neighbor had a his Accord transmission blow up a year but I certainly don't believe that Honda's are crap.
As for N.A. quality, I haven't become a Ford convert yet, but I am impressed with the Lincoln's build quality. Then again, the CTS(and Cadillacs in general) have impressed me as well so it may just be that being higher dollar cars, they are better built. While I think the Taurus is a dog compared to the Intrigue(as well as many other midsize sedans) I would be curiuous to see how it compares in reliability to the Intrigue. I still think GM has an edge in engineering and design, but from some recent Ford products I've tested(the LS and Explorer) they seem to be pretty serious about putting the cars together well. And whats really going to be interesting to see are the next generation Chrysler products as we are going to finally start seeing some fruits of the Diamler-Chrysler merger.
There are other Gm forum sites on the web(not as good as edmunds) and although i am not aloud to list them here(rules) they are out there and their participants generally have a beef with GM and the issuses i have noted. Call up your local dealer and ask them the quanity of their stock for pads, rotors, wheel bearings and blower motor resistors.
The rental place that was giving me rentals when the trig was in the hospital told me when i returned a impala with a bad driver bearing that they have a lot of gm bearing probs before their 35,000 klic limit. Albeit, their rentals, however, with further questioning he said it was mainly gm with the bad bearings.
To have not had these problems, as well your family, i still consider you lucky. Any chance of adopting me..
I guess we will agree to disagree. LOL
Hey, GM cars aren't perfect or the best but they certainly aren't as bad as you make them out to be either.
Shim kit and ISS have helped but not completley.
Wish i had known aout the shim kit when i had the intrigue.
We have the 5 year, 100,000 mile warranty so don't worry about GM picking up the tab on repairs until they get it done right.
Hey, GM cars aren't perfect or the best but they certainly aren't as bad as you make them out to be either. "
Dindak by that same reasoning:
I don't think using my immediate family and making an observation is a scientific way to prove GM cars all don't have issues but if I was in your shoes I might think the same thing.
Hey, GM cars aren't perfect or the worst but they certainly aren't as good as you make them out to be either. "
I base my view on statistics which don't lie (though they may not be exact). You can believe what you like (and maybe if I was in your shoes I would also), but if the cars were as bad as you claim they are no one would buy them, me included.
TIA
Drove 'Vette,Hummer,CTS, BMW3er. Malibu'04
Along with MDX,Maxima,Altima,Saab 9-5 9-3. Escalade,Rainier,GP-GT, L300.Pilot HL, Vue.
Passed on E Class, C Class, Lexus LX 470.(length of queue, and chances of my actually buying them)
Corvette experience was very very impressive. May be now I will begin to get it. The course for the vette started with a straight run for may be 200 yds. I am not good with these kind of distances. but you could mash it as hard as you wanted, then a sharp left turn followed by a nice meandering slalom part, then you repeat the whole process once more, then you gett off with a wide grin on yur face. I couldn't tell what my max speed would have been, but one of the friendly 'help' said 'oh You can get up to 70 on the vette course'. May be 50- 55 for me I do not know.
The Hummer was also fun. It was an 'off road' course, where first you go up a hill with your nose pointed straight up. Since you can go no higher, you figure it is time to come down. You are pointed straight at the ground. I guess this illustrates approach and departure angles for the great unwashed. Then you go through a right hand bank at a very steep angle where you feel you will topple over sideways, then you are done.
MDX, Pilot are two products where GM does not have a credible entry. SRX probably more expensive and RDV not quite as competent. (though a good value). The Nox couldn't come sooner, as atleast it will help saturate the market with 3-4 entries(nox,vue,Rdv,Srx,vibe).
The 04 Malibu, looked a lot better than pictures, again should help the fight with multiple entries, even if not a super hit, with Bu and Imp. like Altima and Maxima. The LT V6 had good fit and finish,interior and solid feel. Compared to Alero, rear seating looked a lot more spacious. The course was just enough for you to get a feel for the car, not an actual test drive.At least enoght to get you to the dealer for a real test drive of a 24 hr one. Did not see a Max.
CTS of course, does n't need my endorsement. Considering you get a more lux and performance for 3er price. With 2 other potential halo cars in SRX and XLR, CTS should go for volume now IMHO. I am sure every visitor drove the CTS,(they had 4-5 of these vs. 1 each of the competition C E , 3& 5) so we should see a bump in sales now? I guess we will run into how many like it vs how many can afford it.
My only complaint, (do they allow complaints in heaven) No Lincoln LS and no veggie food.
Now that I am trying to install it, I cannot locate where it goes. I recall someone posting that it is on the right side of the engine, is this from the perspective of standing in front or from the driver's seat? In any case, I looked around throughout the engine compartment and could not find the old one. Any help would be appreciated, I have the 3.8 engine.
searched for DRL topics in this forum looking for the bulb # and couldn't find the specific post I wanted. Right turn signal flashed at like 6X normal speed this morning and a visual showed the right turn directional/DRL was not flashing.
What's the bulb#? Want to go to Pep Boys at lunch and get a pair so I can have some "fun" replacing them tonight.
Thanks, and I'll remember to keep my ears open, Sister!
Deke
You can just punch the # in the "go to Message box" at the bottom, or the top. Of coarse you probably already know that.
Happy hunting
