Visitor Agreement.
Here's what you posted http://www.americanracing.com/wheels/details.asp?wheelid=29&n- ame=Torq-Thrust%20II&style=505&desc=2-piece%20alloy,%20po- lished§ion=A
It would have turned into a link by itself if you had included a space between the ... and the http
I thought I was in for some good reading when I saw there were a dozen new posts.
Thought I was having a flashback to 2000 or something.
That brake kit also fits on Regals, though they aren't mentioned either. One thing you could check is if the caliper part numbers are the same for the Intrigue as they are for the Grand Prix or Regal. I think the Impala/Monte actually have that kit already installed as standard equipment.
Were there any brake options on the Intrigue? I read a thing on a Grand Prix brake upgrade using F-body parts that made it sound like the Intrigue had larger brakes than the GP does. Though, I though they were the same.
A quirk of the software here is that if you hit refresh/reload after making a post and before following a link somewhere else, your message will repost. It is very possible that you will not notice that - you just think that your message remains the last one posted.
The way to avoid that is to use the "Recent Msgs" link on the page bar to reload a page in a discussion in which you have posted.
Dekester, I've seen a few Intrigues with the mast antenna. It may have been an early 98 thing as I know some of the 97 GPs had a mast antenna(even the optioned out GTPs) due to a problem getting a part related to the rear window antenna.
Thanks Pat for the fix and cleanup. I did have a second browser opened doing some research and came back once in a while, i guess 8, and just hit refresh. Something i will be aware of in the future.
Sorry again for the mess up.
Deke
Tire Rack has a lot of choices from affordable to outrageous. I've always looked to upgrade brakes ever since I did my first drum to disc swap on a 70 Road Runner many years ago.
If you've ever spent time driving in New York City, you know you need good brakes! People pulling out whenever they feel like it, changing lanes without looking or signaling, cutting red lights because they don't feel like waiting... I know it's not exclusive to NYC, but nowhere else on such a large scale!
To add to my dream upgrades if I ever move out of New York , a true dual exhaust system... Illegal to do here since you cannot alter the factory exhaust system (i.e. duals, no cats, etc).
Deke
Possibly. Here in canada, i was told that the basic bumper to bumper waranty includes all bulbs. Never had the opportunity to try it out and of coarse they told to me about other things that turned out to be lies.
The fog lght is probably a #893 and should be available anywhere bulbs are sold
Anyone ever found where these are and how to get to them- thanks, ketch
I have often thought a brake upgrade would be cool on the Aurora. I've thought about the 11.5" rears from the STS, or the bigger brakes on the new Bonnie GXP. I thought about them right up until a few weeks ago. I locked up the tires braking from 85 mph down to about 40. I figure if I can kick the ABS in at 85 mph, then what the heck will bigger brakes do? Maybe if I got more/stickier rubber then I'd need more brake, but for now the stock setup is more than adequate.
All oil changes until the end of the warranty were done by the dealer with rotation every second change, so if there was any overtorquing of the lugs, it was by them.... Rears scored because the clips on the pads had loosened/bent and cut their own groove. Not pretty to look at.
I ate $200+ for brakes that should have been covered.
GM actually said that I was causing my car more harm by driving it as little as I did. And they wonder why they don't get too much repeat business? They lost me.
I was looking to upgrade the entire suspension, too, since I might try autocrossing the Trig.....Rode with a friend on a course in his M3 and it was a blast!
Anyway, I've been looking at pics of the 2005 Mustang and I like! Might go back to try Ford again with that one.
Deke
Like the cues from the past a lot!
The GT will have 300+ HP - before the SVT and Saleen get hold of it!
Deke
Also, when I go over a speed bump I get a nice big creaking sound from the rear end. Sounds like the suspension, is this normal? When do most people change out their struts?
dindak: where did you see those numbers for GM? I like looking over the sales numbers for various manufacturers. Tomorrow is the big day for my Olds purchase.
dekester: larger rotors won't help in the stopping distance but thicker aftermarket rotors will definitely last longer. Good luck.
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnum- - - ber=pk12456148
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnum- ber=12498354
The heat thing is a good point I hadn't though of. 12" rotors would handle heat better, even if they didn't improve your stopping distances due to grip limitations. They should be less prone to warping.
Hey Dindak, what was the 2003 Aurora production? Thanks!
dtownfb, I believe all Intrigues were built in Fairfax, Kansas.
Itching Type Noise From Rear of Vehicle (Replace Rear Compartment Lid Adjustment Bolt) #01-08-66-010
"Itching" Type Noise From Rear Of Vehicle (Replace Rear Compartment Lid Adjustment Bolt)
1997-2001 Buick Century, Regal
1997-2001 Cadillac Catera
1998-2001 Oldsmobile Intrigue
1997-2001 Pontiac Grand Prix
Condition
Some customers may comment on an "itching," "chirp" or "squeak" type noise coming from the rear of the vehicle while driving.
Cause
This condition may be caused by metal-to-metal contact between the rear compartment lid height adjustment bolt and the rear compartment lid hinge.
Correction
For ANY "chirp" or "squeak" sound that appears to be coming from the rear compartment, rear seat or rear underbody areas of the vehicle, place a piece of ordinary masking tape, or the equivalent, over the head of both deck lid hinge height adjuster bolts and re-test. If the noise is eliminated, follow the bolt replacement procedure listed below. Note that the deck lid hinge height adjuster bolt "chirp" is often experienced during normal static rear door slam.
redline - In addition to moonshadow's or evandro's posts, I'd also have the rear strut mounts checked/replaced. These are known to fail on the midsize GMs.
http://www.media.gm.com
8878 Auroras sold in 03
I had it installed in my IMpala and wish I had known about it in the Intrigue.
30 new posts.
I think i am having some deja' vu.
Oldsmobile would have seen the same fate (of no new product) though I think it may not have lost quite so many sales as the cars were more modern. We will never know for sure though.
Also, looks like the 8,878 was for 2002. There were 3,161 Aurora's sold in 2003. I wish they broke it up by model year too...
Got the ISS replaced about a year into ownership, no problems since.
Had the Reveal Molding replaced on the front doors.
Fog lamp had to be replaced about a month out of original warranty but dealer replaced N/C as goodwill. (I have all my maintenance done at the dealer).
Upper leaking plenum was replaced, out of warranty ($600) but had extended warranty and paid nothing.
Outside Temp Sensor replaced and trunk struts also replaced under extended warranty.
I still have the original pads and rotors (40% left at 45,000 miles).
Just replaced the tires with Michelin Hydroedge which give a great ride.
No regrets about the Intrigue so far. With another 2 years left on the extended warranty I will keep the car at least that much longer.
Hope everyone's Intrigue is as good to them as mine has been to me.
http://news.yahoo.com/news?tmpl=story&u=/nm/20040112/bs_nm/au- tos_gm_recall_dc_3
Having a steering shaft that needs lubrication as periodic maintenance is something i have never had to do on any car,... ever.
Another, thats normal. Well it doesn't make it right. Crappy design is normal for GM.
Oh well, another reason why Gm will never be on my short list again.
Now, should I spend the extra and have it refilled with DexCool (which I'll probably have to bring with me) or use the Prestone/whatever like all my other cars ever needed?
Inspection is $35, oil change is $34, God knows what the flush will run me.
Have about 5000 miles on the Avids, so next change I'll have them rotated.
Deke
