Any thoughts out there?
My take is that even if it needed a new steering rack and a new AC compressor/evaporator, that would almost be the cost of the warranty, after maybe tossing in a window motor. So I would only break even IF those problems arose (and GM dealer admitted that a problem existed). The tranny shifts very smoothly. As a matter of fact, under the same conditions, (my wife following in my GLS) going 74 mph on flat interstate, this 2001 GX runs at 1950 rpm while my GLS runs at 2150 rpm. So the GX is running at 10% better efficiency.
It is more possible the efficiency is due to the gls having PCS where the final drive ratio is 3.29 versus 3.05 without PCS. Almost a 8% increase in RPM.
It's a good car overall and delivers good mileage. Reliability-wise, it's been fair, weren't for a couple of power-windows falling inside the doors...
I would think that the remote receivers could at last be sync'd to same signal. I'll call dealer tomorrow and find out.
I would offer the dealer $2500 and see if they bite. The car is not in high demand.
good luck.
the one thing you need to be careful is the car can move onthe highway. You can do 80 with no problem. Not sure how old your daughter is....
Thanks for your info dtownfb.
Your daughter will enjoy the vehicle. I would get the transmission fluid changed and watch the oil. The 3.5L burns oil. I've been adding a quart every 1k-1.5k miles for the past 40k miles. No big deal.
How do you do that? I'm tired of the poor job done in lube shops and I want to start changing the oil and filter myself, but there's barely any room under the car...
Thanks for any advice.
Best place to get decent priced filter: Autozone as the STP brand (8765) for 4.19. The FRAMs will cost upwards of $10, even $8 at walmart. Buy the STP filter at Autozone, and the oil at Walmart ($2 a quart for Quaker State). Hope this helps, and that you have the reach. Maybe from under the passenger front door is a shorter distance for the filter.
"Performed my first oil change on my 2000 Intrigue (3.5). Pretty uneventful with all the information the board (minus the full oil filter canister falling out of my hand).
Drain Plug - Fram Sure Drain system (SD-4). I'll let you know how that works. If it weren't for the black plastic shield along the front, you could probably drain the oil without lifting the vehicle.
Filter wrench - Rite Fit A258 - 74 mm/15 flutes (purchased at Pep Boys). Perfect fit for the canister. Almost too perfect as I needed a screwdriver to pry it off the canister. AmPro 74/76 mm/15 flutes or Oil wrench "A" (forget the brand name but sold at AutoZone) will work as well as long as the canister was not overtightened like mine was.
Oil filter - Purolator 8765. Fram sells this filter for $9 while everyone else is $5 or less (purolator, AC Delco).
Engine Oil - I used Walmart oil for High Mileage vehicle hoping the thicker oil will help with the "burning". Also did the engine flush prior to changing. Figured no harm and it only cost $3.50 for the bottle.
Get a big drain pan. Lots of oil."
For an 02 grand am se with 76,000 miles they want 7,000 (1000 more than this olds), yet the olds has more features and feels like more car.
It's a hard decision. My son doesn't love either, but they are the best choices we've seen. In fact he was saying "whats an Oldsmobile?" who ever heard of that? He is looking for a "cool" car.
Does the side safety rating mean the insurance will be higher? What kind of "issues" should I have a mechanic check? Does GM still service them and do they make parts?
Thanks for the input. This search is making me CRAZY!
On another note, driving home tonite the Service eng Soon light came on :mad: . I just hope it's not another issue with that darn secondary air pump.
Because I got such a sweet deal on the Intrigue, I put up with a number of annoyances that I would not if I had purchased new. I currently have 138k miles on the vehicle and it still runs well and should top 150k with regular maintenance and one or two minor repairs.
Read the Intrigue forum carefully. There are a number of common repairs for the Intrigue. Some hit or miss, some just a matter of time. If you are looking at an Intrigue with 97k miles, get the tranny fluid, coolant and oil changed. Don't be surprised or alarmed if it burning oil. It is a "characteristic" of the 3.5L engine. Check the wheel hub assembly. Most check engine light codes have been posted on the forum and regular posters can help you solve the problems.
I would take the Intrigue over the Grand Am any day.
The auto parts store had a $5 gas cap, but without a tether, so I got one from the dealer. Yes, for much more money ($25), but not enough to bankrupt me.
I own a 99 Olds Intrigue. I'm having a problem that it seems no one can diagnose. This only happens once or twice a month at any rate of speed. A whining noise starts, sounds something like a fan belt and then the car starts to bog down an almost quit. Anybody have any suggestions?
I stumbled upon this message board two weeks ago and it sounds very helpful. I bought a 2000 Intrigue a few months ago and it is having a similar problem of overheating, but only at certain RPMs. Below 2000 or 1800 RPMs, depending on the load, it heats up. If I give it some gas and have it shift into passing gear or a lower gear, or shift it mysef into a lower gear, and have the engine rev above that threshold- it cools back down. (It's a good thing the temperature gauge and the tachometer are close together in this car. But I do find myself disregarding the speedometer at times.)
I have a thermostat on standing order at a local repair shop. Since I took it in a few weeks ago, they haven't been able to get the correct thermostat. Is this one stamped into the block like they say?
I still have my '79 Buick as my fall-back steed, thankfully. I also love the Intrigue and I just want it to melow out.
I had to have the belt tensioner replaced a few weeks ago. It locked up, threw bearings on the road, taught me how to thread a newer belt in jest, and I had the water pump tested while pros bailed me out. The belt-tensioner was a gonner but the water pump tested out fine. (I had hoped while I was waiting for the car to be fixed that this failing tensioner was placing undue burdons on the engine at lower RPMs, and thus it's overheating. Not true.)
I've read here about this models overheating problems, either by bad thermostat, bad water pump, or bad coolant burping- but are any of these causes only symptomatic over 1800-2000 RPM?
Thanks for anyones help. I like this car and I want to get it running right. Thanks again, Joe
my GLS & the car would shimmy & shake at speeds higher than 50 MPH plus my car died from an electrical problem. I had it towed to the local GM dealership whereas they came up with a list of $3000(e.g. bad wheels hubs, brakes, engine $ transmission servicing, etc.) of items that needed attention. Too make a long story short, I let them replace the alternator & battery then I took it to Tire Kingdom whereas they replaced the tire rods/front tires & they did a front end alignment. The car runs great but occasionally the engine will sputter right after starting up then the right hand SES light will come on then go out after a few days.
Any ideas on what may cause this?
I have $10 that the code will be P0101.
Otherwise, this year I replaced the rear brakes for the first time and the temperature sensor for the climate control. Since the warranty I have put almost nothing into the car other than brakes, oil and a battery. It's been a very good car and as tempted as I am by a new one, I can't even justify it yet for any other reason than because of age.
I am still looking at an Aura, the 08 Malibu, Impala and Fusion as replacements. Maybe a 08 CTS if they don't bump the prices too much. Not many cars that catch my eye.
Anyway, that's it for now.
This is my second Intrigue the first I gave to my son with 200,000 plus miles. I wish I could still buy a new one.
http://www.gm.com/gmcomjsp/contactus/ContactUs_Faq_AnswerVC2.html
Did you get this radio from a different car? The code in the radio is not matching the data in the car's computer. A dealer is required. This is Theftlock. :mad:
1. Turn igntion key to the "On" position
2. depress the accelerator 3 times within 5 seconds
3. Wait a few seconds for the "Change Oil" light to begin flashing.
4. After it finishes flashing, turn key off.
It should reset the light.
