Mercedes-Benz C-Class Sedans
But you'll have to get used to the idea of expensive service. MB service is typically more expensive than other cars. The reason your oil change costs so much is probably because they charge you the minimum service which includes a lot of useless stuff like check tires, check windshield wipers, check wiper fluid level. It's a scam to get more than $20 for an oil change and they're all doing it. I'm now wondering if we should lodge a complaint with the state atty general. It's not like we can get the service anywhere else.
Regarding going elsewhere I stick with them. I have the same problem. If I go elsewhere it isn't a guarantee the other place is better and I'm only causing myself more time and trouble. I'd rather chance it that service will improve rather than have to drive miles every time for service. Good luck with your new C.
I would PERSONALLY pay a visit to the manager of your service dept.TELL him of your experince.TELL him to never have that person work on your car again under any circumstances.. and explain to him that the survey will reflect negatively on your experience.. and next time... you will happily fill out a positive survey... ONLY if the service is better!
you will be recieveing a phone call from the regional office of MB when they see your negative reply/.. use that opportunity to AGAIN drive it home..that you were treated poorly and sloppily..and expect more from your dealership
http://www.xpel.com/paint/mercedes.html
re the oil change.. for a 40,000 car... ill pay the 100.. certainly the 1st time.. where theres bound to be some unwanted agents from engine break in in the oil(small metal shavings,"gunk" etc) why second guess?
anyone else care to add??
You might want to ask folks around here for a recommendation. Sounds like your current service dealer is clueless. I wouldn't trust them. :-)
BTW, they probably stuck in 9qts. The 320 engine takes 8.5qts (it's a round number of liters...Americans should just switch to the metric system).
I don't think I'm being ridiculous. I think its reidiculous when an insect hitting the side of my car can chip the paint. And yes, I do have a coat of wax on it. I will put more on to see if it helps.
On another message board I found numerous complaints about a similar problem with the M Class. Someone there said MB was using water based paint due to environmental concerns and that it was not as durable. Could this be a contributing factor?
i have my car since oct.. the chips have pretty much stopped
I dislike the see through adhesive bra because I saw one that had been on for a few months. It was more than the yellowing, it was the fact that every little scratch shows. With the regular paint, you can buff out shallow lines that come from low velocity projectiles and there are a lot more of those than chips, but with the bra it shows everything and you can't buff it out.
Did you call Colgan about a bra (it will be black) for this car? If they don't have one yet, they will take your name and as soon as they do, they will call you.
Anyone know if the tire is covered on the warranty?
Also bought some "Clay Magic" to take off bugs and tar scrapes etc. This stuff is wonderful. Mercedes should give a kit of this with each car. Of course I also think they should give a touch up paint, but thats a joke. Mine cost $20 for glacial white touch up!
The Service person said it was the new oil change machine, it wasn't calibrated correctly. I asked him if it did any damage to the engine, he said no. He said once the oil got hot it expanded and tripped the oil warning system. This is a new service center so I believe him on the calibration error.
That's
$35 labor
$10 filter
$20 check wipers, tires etc.
Now that MB has gone to Mobil1, the oil change is probably going to cost $100 or more.
ZERO chips!
Also everything still works just like it is supposed to. (Except one of the keys) The dealer has been great. I stopped in to get new batteries for the key and they gave me a set. I did not even ask.
thanks in advance.....
Yesterday the service manager conducted a test.
He test drove all C240s and C320s on the lot, about 8 cars. All 8 cars had the same vibration between 30-40mph. The sample of cars had an assortment of different tires... Goodyear, Continentals, Bridgestone.
The service manager contacted the Regional Mercedes Benz factory represenitive. This was the first the represenitive heard of the issue. Since the tires have been ruled out, they think it might be caused by the drive shaft. He commented how the E class had a simular issue and was found to be the drive shaft. So, the dealer ordered a new drive shaft. Should arrive in 7-10 days. Will see if that's the ticket.
greg@thedailydonut.com
If it's the drive shaft, which should be the same in all Cs, then all C owners should be reporting it here.
Let's hope it's not as serious as a defective driveshaft. Thanks for the update. Please keep us advised.
The vibration does go away or is less noticeable after driving continuously for 20-40 minutes. If it's not the tires nor the road, what could it be?
On vibrations that go away after driving some distance: 99.9% of the time, this means the tires are flat-spotting, and are then returning to round after they warm up. This is all too common these days as suspension systems get more sensitive, and more makes specify H, V, and even Z-rated tires as standard. The W202 C was especially sensitive - any tire more than 1.0-1.5 mm out of round could easily cause vibrations. No tire maker is immune from the syndrome, though it is my rather extensive experience than H-rated Michelins [MXV4s especially] seem the least susceptible to the problem. Over the years, Pirellis have been the most likely to exhibit this syndrome...general rule of thumb: the more nylon in the casing or belts [as distinct from Aramid, rayon, or some of the other alternatives], the more likely this will be a problem.
Look, when every car on the lot exhibits the syndrome [and they all will if they have been sitting any length of time], that should tell you something. Yes, some Es had lumpy driveshafts, but here's my prediction: they will go to all the time, trouble, and expense to replace the driveshaft, and then discover the car still vibrates for the first 10-20 miles after sitting. Same with balancing - often, when an owner complains of this symptom, the first thing they do is go off and have the wheels rebalanced, often making it worse in the process. The factory balancing machines don't make mistakes - if your car has less than 10k miles, and the tires/wheels/suspension have not been abused, balance is not going to be your problem.
I am very sensitive to these kinds of vibrations, and have used various tricks over the years to reduce the problem. My solutions are not going to be used by 99% of drivers, so no reason to detail them here, except to say I have not hesitated to throw away the OEM tires on at least 6 of my cars [including 3 MBs] and replace them with whatever was the top-line touring Michelin of the time. Without exception, this always solved the problem. There are other things I do that most of you would be unwilling to do.
Ironically, Hondas used to be the world's worst for the shakes. All of my recent Honda products ['96 RL, '98 Accord 4, '01 Accord V6] have been smooth as butter right out of the box, and can stand being in place for at least a couple of days or more without showing symptoms. They all are equipped with Michelin MXV4s, either H or V-rated, tires that get no respect from the enthusiast driver because they are not the ultimate handlers, and can be noisy on certain surfaces, but I would have nothing but them or XGT Pilots on any of my cars.
Oh, and I took the Accord V6 in for its first oil change this week, and watched how ridiculously easy it was to pull the filter and get to the plug on this car...began thinking about doing it myself, until I got the bill: I furnished the 5 qts of synthetic, and the total bill from Elk Grove Honda was $14.89 for the labor, filter, and tax/disposal fee. Needless to say, at that price, I don't intend to get my hands dirty.
since it has to be factory installed, I was thinking about installing the alpine navigation system.
Is the alpine as good as the command system offered in Mercedes??
will it void the warranty?
thx
Regarding the clear bra from X-Pel, it does have a warranty against yellowing, etc...
Regarding Tele-aid, how about this for a fantasy: "Since GM's On-Star system and other similar systems are now so common, we at MB have decided to reduce the price of the subscription to the entirely more reasonable price of $100 a year. We thank our customers for their continued loyalty. Love, MBUSA" Yeah, right!
1) A lemon.
2) Someone traded up. Reading these boards I've come across a lot of people who've traded good cars for even better cars after a few months.
OK, I can think some other reasons,
3) Works for Safeco, Kosmo.com, lost job.
4) Got divorced.
5) Works for Boeing, transferred to Chicago.
6) Transferred out of country.
7) Wanted stick shift.
See if you can get the service records for that car.
If the tire is out of round, which I can believe it is... why would you only feel the vibrations between 30-40mph. You would think a very noticeable thump would occur as speed increases from a dead stop. However, I'm not noticing any thumping or vibrations from 0-30mph. It's silky smooth.
I'll use the example of a shopping cart. Did you ever get a shopping cart where one of it's wheels were flattened? It makes a horrible thump right away, but the faster you push the more it becomes a vibration.
BIG MISTAKE!!!!!!!!!!!!
I now have a real nice set of swirl marks on the the hood! I am in the process of trying to get them out with #5 Zaino. Film at 11.
Took my White C320 to Toronto from NJ cruising at about 85-90 MPH. Once in Canada 407 ETR, I went as high as 110 MPH sustained for 10 min. Wow, it was such a rush. I know the car could still go a lot faster because I was hardly pressing on the gas. The ride was so nice and smooth my wife did not even notice my speed until 10 min after I hit that speed (that's when I slowed down) and she was awake!
Can somebody who has the Timeport Phone option tell me if I can get a non-MB Timeport and hook it up? Is it a cable or a cradle? Where is the hookup located?
Some cars, chassis, and drivers are much more sensitive to this phenomenon than others, and yes, depending on the car and tires, it can manifest itself in a narrow speed range. On our '94 C220, only from 50-65 mph, depending on ambient temps. It was delivered with Michelin MXV3s, a German-made Michelin with a different tread design, and 2 of the 5 tires were far enough out of round that they could only be used on the rear [proving that Michelin is not immune to mistakes, either]. All you had to do was jack it up, and spin the wheels, and the flat or high spots [we had one of each] were obvious.
Anyone who has a car that sits for 3 months, and drives it without flat-spotting symptoms, has either a very unusual car [I would have preferred to hear the make, model, and tires involved], or simply is not tuned to the kind of vibrations the rest of us are talking about...which is OK, because most people are not [I did say that up front].
Look, drive shafts don't fix themselves; if the vibration goes away during a given drive, this is not the problem.
Finally, some history: When the previous generation S-Class was introduced [1992 models] to the US market, very quickly cars started coming back to dealers with complaints of severe, unambiguous shaking through the steering wheel. After the usual humbug about people being too sensitive, service advisors around the country decided it was a real problem. Unfortunately, the first thing most of them did was run the wheels through their balancers...since half the electronic balancers in the nation's service depts haven't been calibrated since they were installed, much less the once-a-month schedule they are designed for, this of course resulted in making the problem worse on about half the cars. Big Mystery. Guess what? MB had decided to equip these cars with the same tires used in the EU, Z-rated Pirellis, because of course these 5000 lb. tanks [remember the prev gen S-Class...double-paned windows...] were expected to run all day on the autobahns at 140 mph. Problem was, in the US market, sustained speeds never exceeded 85 mph in most cases, and the tires turned to rocks when sitting overnight. They got flat-spotted, and stayed that way, because they never got hot enough to get un-lumped. Some enterprising service type finally figured this out, replaced the Pirellis with H-rated Michelins, and voila, problem solved. The factory finally responded, and began equipping the cars bound for the US with MXV4s [though I think they went with V-rated tires], a speed-limit on the EMC of 130 mph for the US, and eventually, a new material for the front suspension bushings for ALL cars worldwide.
That last point plays in, as well: suspension design and details can make a HUGE difference in how sensitive or resistant a particular car is to this kind of problem. It is, after all, impossible to make every tire/wheel package on every car absolutely perfectly round and straight. Thus, patterns build up: Lexus LS and SC cars are absolutely like trains, but GS cars have a bad rep for the shakes. The Camry is more susceptible to the problem than the current Accord. BMWs have been historically some of the worst about this, especially the pre E-36 3-series cars. I could go on....
Who knows, until someone takes the initiative to try a tire-based solution, just exactly what is bugging the cars whose owners are noting this problem on this board? I'm just suggesting that there is history [and in my case, experience] to suggest a place to start.
Incidentally, this site can be a goldmine of information, or a dry hole, depending solely on the manufacturer's willingness to be forthcoming and air its dirty laundry in a semi-public setting. Honda is religious about posting ALL problems from the field, sometimes laughably trivial ones. Mercedes likes to pretend that everything is hunky and shares this info very closely within the dealer body [ sometimes too closely...the dealers can often remain clueless about problem patterns that the folks in NJ already know about ], and sometimes after a lot of time has passed. Still, I'll keep an eye on it and report back if anything interesting shows up.
