Oldsmobile Aurora
15152545657112
  • worldii2worldii2 Member Posts: 27
    Well readers...I enjoyed the info provide on this message board regarding the Aurora. My 6 year warranty was about to expire (had 76000 miles on it). It was not an easy decision to let it go, for the vehicle was maintained and provided excellent service. I moved into a Nissan Altima. I had concerns regarding Oldsmobile and there upcoming discontinuance of making vehicles. I will continue to review the Aurora discussions!
  • stormdavystormdavy Member Posts: 80
    Thanks for the comments. Somewhat reassuring, given it is a '99 w/ factory warranty. Tough call. Image is all: Successful businessman=Aurora. Wild [non-permissible content removed] enthusiast=Camaro SS. Clueless=just another FWD midsize pack-blender. Thanks again. Good luck w/ your cars.
  • rjs200240rjs200240 Member Posts: 1,277
    Beachlover and Stormdavy, I'm glad the board was helpful. It's really a great resource and interesting reading. Plus, everyone is real nice. Sorry to hear you're giving up the Aurora Worldii2. Best of luck with your new vehicle, though.
    Hey Henry, I agree with Garnes. A high-performance cat isn't going to hurt the engine. The pipes and mufflers will still provide plenty of restriction. In fact, I would bet the headers and pipe diameters would provide enough on their own without a cat or muffler. Plus, you can probably get a high-performance catalytic converter for less than a direct replacement one. You might also consider Dynomax and Random Technologies for aftermarket cats.
  • beachloverbeachlover Member Posts: 17
    I proposed an unwritten rule for this forum that if anyone is going to be selling their Aurora that they must tell everyone AND give us first crack at buying it. I must continue to own an Aurora because I cannot stand driving, except when I'm behind the wheel of my classic. But I'm always on the lookout for a lower mileage and newer year....
  • larryfllarryfl Member Posts: 214
    I have to comment on some of the posts I've seen recently. As an owner of a '95 classic, I don't have a single worry about Oldsmobile going away and not being able to get parts. In fact, it's very likely that I will buy a later model classic when the time comes, even if it's a few years away.
    Oldsmobile is owned by GM and GM isn't going anywhere. It's not like when Fiat or Sterling pulled out of the US, then you would have had a serious problem w/ parts and service. But GM is not going to quit servicing these cars or making parts available for a long time to come - probably longer than most of these cars will last :-)
    Maybe I'm fooling myself, but at least from a serviceability and parts availability standpoint I see absolutely no reason to shy away from or go out and sell a good Aurora.
    Just my 2cents.
  • garnesgarnes Member Posts: 950
    larryfl - you are right. There will be service and support for a long long time. No worries here either. I'd buy one today as well.
    Rjs - I was wondering the same thing about the headers providing the required initial exit velocities and "restriction".
    Any ideas about why you can't use an aftermarket converter on a 96 or newer car? Maybe you can, but I'm under the impression it's for 95's and older.
    I don't see parts as a problem. My 1987 Celebrity was discontinued back in 1990 but I can still get parts for it with no problems (although I "sold" it about half a year ago to a friend). GM makes the parts, and they aren't going anywhere.
    Garnes, my only guess on the cats for 96 and newer is that it is a legal mandate. I know that you couldn't replace the cat on older cars until it was over 5 years old. You also were supposed to prove a defect. If it was less than 5 years old, manufacturers were legally obligated to fix it. Most emissions control warranties that are separate from the rest of the warranty are to comply with the law. I think the length was eventually changed to 7 years, so perhaps that explains the 1996 and later cars. However, I'm no expert on this. I'm sure you could change to a high-flow cat on your Aurora if you wanted to. I don't think it would cause an OBD-II problem as long as the exhaust was getting cleaned. Perhaps on cold-starts, though, as a freer cat wouldn't warm up as fast...
    Beachlover, I vote for your rule...
    The Cadillac SRX is rumored to have a 4.2L version of the Northstar that will make 295hp. That means that a 4.6L should make about 325hp. Pretty impressive... That would be about 280hp from a 4.0L version of it. Of course, my numbers assume the horsepower being proportional to displacement, which of course it isn't. Actually, the Aurora should have more torque than a true 87% Northstar because it retains the same Northstar stroke (it doesn't have 87% of the Northstar's stroke). This would make the Aurora a bit of a stroker which should increase the torque somewhat.
  • matrixfrogmatrixfrog Member Posts: 180
    Hey guys haven't stoppped by here in a while. Glad to see some of you are still around.
    I'm doing the fuel pressure regulator install soon. I went to Autozone and Advanced Auto and neither had it. They told me it was probably a dealer part. I haven't checked the dealership yet but how much have you guys paid for the part? I am pretty sure I can install it on my own but do you guys have any hints or suggestions for me before I do it?
    Last time I was here the Corsa exhaust was just being installed on someones car. Have any other Aftermarket Performance parts been put out? I am really hoping for a cold air intake errr at least an intake. I was thinking about making my own but I didnt know if I would be making a wise choice, I could have ain intake with more flow, bu then I would be getting hot engine air from the engine bay and not from the wheel well.
    Is there any aftermarket parts out there that you guys are hiding from me ;o)
    Oh BTW, I'm getting some new plugs and plug wires. Any suggestions on what kind? Also any problems I may run into while changing them (first time changing them)?
    matrix frog
  • HenryHenry Member Posts: 1,106
    I just thought I would do that. :)
  • fjk57702fjk57702 Member Posts: 539
    I think that installed at the dealer the cost is about $200 or less. Mine was done under warrenty so I don't know.
    Welcome back! You obviously still have her. I had my regulator replaced at the dealer... about $230 + or -.
  • mindseye97mindseye97 Member Posts: 25
    matrixfrog-
    I put Bosch platinum plugs and Bosch wires on my '97 about a month back (along with new coils). Everything is running great. Be prepared for some frustration on the rear plugs and wires in this car! You will need to remove the engine cover and some hardware on the firewall to get the coil pack off to get access. It took me around two-three hours total. If anyone is considering this and has the original coils you may want to just replace them all while you're at it and avoid any future surging issues- they are only about $20/for each of the four.
  • 800wattaurora800wattaurora Member Posts: 187
    Update: Been pretty busy these days, between working 60 hour weeks at work, going to night class 6-8 hours a week, and a full time Girlfriend. I've had no time to post. Lot's of catch-up reading to do.
    Last week I got my official GM service manuals, 2 volumes for 96 Aurora/Riviera for $72 on ebay motors. It was NOS (New Old Stock) In my spare time, I read up on the old Aurora. It's very detailed, has torque specs on every bolt. I'm glad because I didn't want to over tighten bolts into that all aluminum Northstar block. The Throttle body replacement section was the first to be looked up. Didn't know that you have to re-set the throttle position any time you touch the TB. As well as the general re-learn. Also noted: use new TB gasket every time it's removed. Emailed Zsolt over at RSM immediately, kit DOES comes with a new gasket. They said the intake and TB were ready to ship separate if I wanted, but I said I’d wait for it all.
     RSM-Project is still in the mail, ha-ha. Seriously. Talked with them last Thursday and they said that they just finished the Front Strut Tower Brace that day, and would ship everything the next day, Friday. So now it's Tuesday and I'm getting excited when the UPS man comes everyday around 11am, maybe tomorrow will be the day. (sigh)
     I'm also still waiting for my DYNO hookup. My Dad say's it's still in the box, but they taped it out the other day. Hopefully within a 4-6 weeks it will be up and running. I've got 82K miles on my 96, warranted till 90K. Think I'll go in for 100K service now at 82K, be good to the car gods. New plugs should help bring back some lost power before the dyno run. Called about 100K Service, it's $450 for plugs, trans flush and screens, coolant flush, all new filters inc. fuel filter, tire rotate and balance, and oil change. I also need the front air dam. There wasn’t one on the car when I bought it 2 years ago, after reading the service manual, the air dam deflects air towards the radiator, lowering engine temp.
    Anybody needs something looked up in the Service Manual, just ask. Post or email me at taylorsturf@attbi.com
    Also came accross some good wheel/tire calulator sites:
    http://www.tolan-hoechst.com/cars/tirecalc.htm
    http://www.miatanet.com/garage/tirecalc.html
    Forgot the exhaust up-date: Planning on Corsa Mufflers for $450 http://www.corsaperf.com/flashcadillac.htm haven't decided on tips yet. Maybe Corsa's but for $150 for tips seems high to me. RSM exhaust uses Saber tips for $70 set http://webhome.idirect.com/%7Ersm1/aurexh.jpg both are 2.5in piping. Tough choice, what kind of tips. I need to mesure the tip cut out on a STS, see how it compares to the Classic. Install will be around $300 including new 2.5 piping from cat-back (stock is 2.25). I have to take emmisons before July, probably wait on the exhaust till then. Should I replace the stock cat too? Probably,huh? Hi flow something. Still planning on driving the Aurora in two years for my next emmissions test though.
    800wattAURORA
    matrix - I never did the Corsa exhaust after all, but still consider it. Looks like 800wattaurora will let us know how it all goes. Go to their web site corsaperf.com - it's got sound now.
    As for air induction, you can do the air box mod like I've detailed on caddyinfo.com - it does very well. Or you can get the RSM system and build a heat shield around it as 800wattaurora intends to do. Without the heat shield, its going to pull hot air. Extreme motor sports (x-m-s.com) was supposed to come up with a cold air induction for the caddy northstar, but they don't seem to be coming through. Who knows.
    800wattaurora - good luck with everything. Let us know how it goes. Also, please explain the reset of the throttle body.
    I contacted Granatelli motor sports and they said they will recalibrate the MAF again for me. I said I'll be sending it back and want them to calibrate it back to the stock factory A/F ratios. I've seen the results running richer and leaner and it lost power. My reasoning is that if the darn thing actually lets a little more air through, and the A/F is the same, then it might add at least a little more power. Again - who knows. I'm not holding my breath.
    800wattaurora - let me know if you would be interested in testing this (new and improved) MAF. I can send it to you. If it does finally make an improvement, and you are interested in it, we can talk. Let me know if any of this is of interest to you. The MAF is basically a stock factory unit with the screen deleted and it has been recalibrated for the air flow. I guess it is might now be the same as the factory unit with a simple screen delete. Just let me know here.
  • musclecar97musclecar97 Member Posts: 111
    matrix"neo"frog - funny thing but I was just about ready to do the fuel pressure regulator thang also and thought I'd ask for directions rather than go back and read two thousand seven hundred and fifty seven posts to find the ones on the repair. I suppose their is a search engine to find the posts, I recall at one time even seeing pictures but it may have been on the old discontinued yahoo Aurora board.
    Mine's starting to backfire occasionaly on startups, and Schucks (Parts chain in the Northwest) has the regulator for $63.
    Soooo who remembers or wants to take the time to explain the procedure for old froggy and me?.......please.....
  • ewtewt Member Posts: 127
    I forget all the details, but it's pretty easy. I think you just have to take the plastic cover off the top of the engine, and the FPR is held on by a spring clip. Pop the clip loose, pull the return hose off, take the old FPR off, put the new FPR on, reattach the hose, and pop the clip back on. Assuming your FPR is leaking, let the car sit for awhile to let fuel pressure drop before pulling the old one off so you don't spray fuel everywhere.
    Eric
    I kind of like the slant cut of the Corsa over the RSM's straight cut. However, they look very similar. If you like the price of the RSM's, they look nice. They are thick which looks good. Are the Corsa mufflers 2.5" instead of 2 1/4"? Good idea on measuring the Caddy. I also wondered if the tips would fit. Glad to hear from you. It's good to hear from Matrixfrog too.
    Ewt and Seegirt, sorry to hear you're quitting the Aurora... Ewt, if you have a big tray (like a cat litter box) then the tranny isn't so bad. I wonder if there is some reason they never use a drain plug. Perhaps it causes some disruption or something.
    someone selling an Aurora doesn't mean we have to lose a forum member...just that there will be a member name change. Except that I would like to own two Auroras.
    ewt...couldn't find any contact info to ask you your price on your Aurora, although I'd have to plan a cross country trip if I ever bought it....
    Those worried about the super depreciation of a new Aurora, don't be. I have confirmation that it will not happen. As you all know I purchased my car back in October 2001. It now has over 7,000 miles on it. However, according to the County of Loudon Department of Taxation my car is still worth an amazing $31,482!! This is only about $3,000 less than I paid for it over 6 months ago. So much for losing 1/2 the value once it leaves the lot, ehh? Looks like the Aurora has what it takes to break some resale value records. I suppose anyone in a pinch could always sell their vehicle to the Commonwealth of Virginia and get a great deal...
    Wow - There's a lot more activity on this board since the last time I was here. Good thing.
    musclecar97 - Does the place with the fuel press reg have a website? I'd like to get out of going to a dealer to get this part.
    I think Im going to buy new plugs an wires tonight. Thanks for the suggestions Mindseye97, I think I'll get the same also and might as well do the coil packs too. Did you get yours from a dealership?
    Ewt - thanks for the run down. Sounds pretty easy. I got a question for ya, Im not totally sure if the fuel press reg is bad. I have the symptoms but should it be dripping gas or anything like that?
    LOL
  • dlcleavdlcleav Member Posts: 40
    Henry...I agree. I was absolutely floored when I discovered the value of my '98 classic nose dived to better than half what I paid last July. I think the combination of 0% financing (alot of good used cars on the market) and Olds going out of business devalued our classics and newer cars beyond belief.
    matrixfrog- The plugs, coils, and wires were all from Autozone. I got lucky- they were all in stock. I'm sure a dealer will charge more unless you get a discount. Good luck.
    Am I missing something? I checked the value of my 98 Aurora here on Edmunds and it's value has held up well compared to the value it said a year ago when I bought it. I entered everything the same except the mileage of course. Is Edmunds not a good guide as to what used cars are going for?
  • blk97aurorablk97aurora Member Posts: 573
    I've had good experience with Crown Cadillac/Olds in Watchung, NJ. Web site is www.crowncadillacolds.com. Their price for the coils (p/n 10472401) is $35.18 ($55.17 list) each; I'd be interested to see how that compares to Autozone, etc. No sales tax if shipped outside NJ. I don't know about shipping prices as I have picked up parts in person (and payed the sales tax). I have no financial interest in this dealership; I'm just a satisfied customer.
    thanks for the info on the fuel reg removal
    frog - I'll check on a website or 800# for Schucks Auto Supply and post it here for ya
    Here's some info about throttle bodies out of GM manual for 96 Aurora:
    THROTTLE BODY ASSEMBLY (TP SENSOR LEARNING PROCEDURE)
    A TP Sensor Learn routine has been implemented in the PCM software to allow the PCM to correct or offset the closed throttle signal value of the TP sensor. This is necessary because of manufacturing tolerances during assembly of the throttle body and TP sensor are not adjustable on the throttle body. If an improper TP sensor offset is maintained by the PCM, a high idle at closed throttle or stall condition may occur. Performing the "TP Sensor Learn" procedure lets the PCM learn the correct TP sensor offset.
    NOTICE: Make sure nothing is touching the accelerator during the TP learn. Also ensure that the cruise cable is not holding the throttle open.
    The TP sesnor learn procedure should be performed when:
    1. TP sensor is replaced (2)
    2. Throttle body is removed/replaced
    3. The PCM is replaced.
    Ok here's how to do it now, TP Sensor learn, it sounds very tough.
    1. Turn the ignition switch to the ON position, with the engine NOT running.
    2. Wait for 30 seconds.
    3. Turn the ignition switch to the LOCK position.
    4. Wait for 30 seconds.
    That's it! The manual makes this sound Very important, but it's so simple?
    800wattAURORA
    THROTTLE BODY ASSEMBLY (CLEANING PROCEDURE)
    Notice: Take care not to damage the MAF sensor housing screen. Damage to the screen could restrict airflow possibly resulting in a driveablity concern.
    1. Remove the air intake duct.
    2. Reove the MAF sensor assembly.
    3. Inspect the throttle body bore and throttle valve plate for deposits. It is necessary to open the throttle valve to inspect all surfaces.
    NOTICE: Do not use any solvent that contains Methyl Ethyl Ketone (MEK). This solvent may damage fuel system components.
    4. Clean the throttle body bore and the throttle valve plate using a clean shop towel with GM Top Engine Cleaner, P/N 1052626 or AC-Delco Carburetor Tune-Up Conditioner, P/N X66-P, or equivalent product.
    INSTALLATION PROCEDURE
    Notice: The outlet of th air cleaner assembly and the MAF sensor inlet duct must line up when completely installed. Misalignment may cause incorrect airflow readings resulting in MIL illumination or a driveability concern. Improper installiation of the inlet duct assembly or air cleaner assembly may cause misalignment.
    1. Install the MAF sensor assembly with 3 bolts.
    2. Tighten the MAF housing attaching bolts to 8N.m (71 lb in)
    3. Install the intake air duct.
    4. Perform the DTC P1526 TP Sensor Learn Not Complete. (discribed in previous message)
    Hope this is usefull to my fellow Auroraians.
    Ask me if you need something looked up or need torque specs or something.
    800wattAURORA
    I while back I found some info on home made octane boosters, simular to Octane in a bottle, where the claim to raise octane ratings by whatever, 3/5/7points. They ACTUALLY do incress the ratings. What they don't tell you, I found through research, that if you use premium 93 (the only thing I use and Almost allways from AMOCO/BP) it will raise it to 93.3 or 93.5 etc.
    These home made additives claim to raise points to desired octane rating up to +100. Came with mixing ratio's for desired rating per gallon and overall % of fuel mixture. Think it was from SUNOCO they sell custom blended fuel for race cars. Only find these gas stations near a drag strip.
    It listed to add chemicals that I would never even think about putting in my Aurora. I laughed at the idea of screwing up my Classic and threw the print-out, out. Flipping through the Service Manual, I came accross the Fuel Specifications which SHOCKED ME!
    FUEL SPECIFICATIONS
    Octane Requirements-4.0L (Vin C)
    Min Octane Required: 91
    GASOLINE with ALCOHOL
    Notice: Do not spill fuel containg alcohol on the vechile. Alcohol can cause damage to the paint, finish and the trim.
    METHYL TERTIARY-BUTYL ETHER (MTBE)
    Fuel containing MTBE may be used, providing there is no more than 15% by volume.
    ETHANOL
    Fuel containing ethanol (ethyl) or grain alcohol may be used, providing that there is no more than 10% alcohol by volume.
    METHANOL
    Fuel containing methanol (methyl) or wood alcohol may be used, providing there is no more than 5% by volume.
    NOTICE: Do not use fuel that contains more than 5% methanol. Use of a fuel (gasohol) that contains more than 5% of methanol can corrode metal fuel system components and damage plastic and rubber parts.
    Couldn't belive this when I found this. The above chemicals were everything listed on my home made octane boosters with mixing ratio's. To bad I trashed it. I guess that this Northstar motor can benfit from higher octane gas or they wouldn't list these options. A place by my house carries 101 during the summer for $2.75 per gallon( that price was from two years ago when had my 86 Cutlass 442) probably cost around $3 bucks a gallon now. Ouch. This booster list had break down on cost per gallon too, cheaper and better than Octane in a bottle which DOES use some of the same additives listed above. Going to have to look that info up again. Maybe I'll even Dyno or get a track time for comparison from 93 to 100+. My only experince with 100+ Octane was in my 442 with 307HO. I could definitly tell the difference. I could bury the speedo much faster!!! Stock speedo only went up to 85, why?.
    Remebering the good old days: At top speed in the old 442 at a speed of 1??, it once took 11 seconds for the speedo to un-bury itself. The car would de-ecclerated around 4 MPH per second at 84MPH. After the math thats around 130MPH, thats 20MPH faster than my damn limited 112. Wish I could re-move that speed limiter for special occasions.
    Man I typed a lot tonight, time for bed. (sigh)
    800wattAURORA
    "Ewt - thanks for the run down. Sounds pretty easy. I got a question for ya, Im not totally sure if the fuel press reg is bad. I have the symptoms but should it be dripping gas or anything like that?"
    Mine was leaking into the vacuum hose that connects the FPR to the intake manifold, so that gas would pool in the manifold, which resulted in long cranking times, followed by black smoke at startup from the excess fuel. It only happened on hot starts when the car had been shut down for a relatively short time. The extra gas would evaporate overnight, so it started right up in the morning. I'm not sure if that is the normal failure mode or not. I thought it was probably a leaking injector at first. After pulling all the injectors and finding no leaks, I noticed fuel in the vacuum hose and realized what the problem was.
    Eric
    garnes - you probably got a better deal than I did on my autobahn. Last July, I paid $21k for my '98 White Diamond with 18k miles in perfect, mint condition. Including sunroof & cd changer. I was surfing last week and decided to check the value of the car. I looked at Kelly & Edmunds. In either case, the average trade-in value was around $11k with additional miles (48k) and the rest of the car still in excellent condition. I'm disappointed the value dropped so significantly but that has no bearing on my decision to keep the car. Heck, this is my 2nd autobahn...I may even purchase another down the road.
    800watt, that relearn is pretty cool. On my Corvette I had to hook a voltmeter up to it and ever so carefully turn the TP sensor. Then you have to carefully tighten it so as not to mess it up. Sort of like adjusting the distributor timing except on a smaller part.
    Garnes, I was just trying to be funny about the difference in assessed value when it's for tax reasons as opposed to purchase reasons. However, I have seen some 2001 4.0s with reasonable miles (around 20k) in the low $20s. I doubt I could sell my car for $31,000, though (although it's nicer than when I took delivery). The NADA for a 2001 with my options and mileage (they don't have 2002 numbers yet) is $26,625 retail and $23,450 trade-in. Actually, I hope it depreciates fast as I have no intention of selling it. The tax on the value over $20,000 is 4.2% every year. It used to be 4.2% on the whole value... Can you imagine? That's like paying sales tax on your car every dang year. Now, they "relieve" me of 70% of the tax on the value under $20,000 (so it's like a 1.25% tax on that). I like Virginia, but the car tax and the annual car inspection are the pits. Both the inspection and the tax require you to have a decal in the window which I hate the most. If some bone-head mechanic scrapes it off with a razor (which they undoubtedly will if I don't remove it before going in for re-inspection) it will certainly ruin the Solar-Ray coating on the windshield. Plus, it interferes with the headlight sensor as it is often in the shadow of the decals.
    I still Lexol the leather about every two weeks. I think I have become addicted. I had the bottle for almost 4 years with the Corvette and used about 1/4 of it. Now it's almost empty and I've only had the Aurora for like 6 months... Granted, there are twice as many seats to apply it to in the Aurora.
    rjs - I got the joke. Pretty good really. I was referring to dlcleav. I still don't get it. I'm not referring to the price I paid - just the edmunds listed values for trade in - private party and dealer for now and for what I remember from one year ago. I have about 30k on it now, bought it with only 13k. The car is like new. According to Edmunds, the price has not gone down too bad.
    Rjs - I love that Lexol too. Long term, nothing compares. I too have used it a lot. I'm amazed at how long the seats retain a soft texture that kind of grips your jeans. Nothing else retains that. I hate it when the leather gets that slick dried out feeling. You just slide on it like it was vinyl.
    800wattaurora - thank you for the info.
    We have a Super K-Mart closing near us and they had 40% off auto supplies. I went out there to see what kind of deals I could get and I ended up buying a set of Splitfire plugs and a bunch of car cleaning supplies for the aurora. With the 40% off they were ~$18. Then I noticed on Splitfires site they will give $1.50 off for each plug as a mail in rebate. So it turns out I actually paid ~$6 for a set of 8 plugs. Anybody use these before? Just wondering how they run. BTW Splitfire is also offering $15 off of their plug wires.
    garnes - I understand what you're saying. I don't think I looked at the value of my autobahn prior to buying it therefore, I can't comment how Edmunds is portraying values. My only point was I suspect 0% financing and Olds going out of business put me in a huge upside down position with regard to my payoff. I still think the cars are an excellent value today no matter what market indicator you use.
    I bought my 98 in the summer of 98 as a program car. I figure that I paid about $30,000 for it. It had 12,000 miles on it then and now has 46,xxx. The April NADA blue book says that it is worth about $12,000 trade in (here) and just under $15,000 retail. I have now owned it about 4 years, so this is not too bad. But, a local dealer was advertising one (a 98) for $11,000. Not good. But this was a used car dealer, so I guess he got a good buy on one at an auction? The ad has disappeared, so I guess it sold.
  • lobstermanlobsterman Member Posts: 31
    have not posted for quite awhile. my 97 teal has been running really good. changed plugs in Jan. just had my front brakes done at dealer, $180. now have 83640 miles. have been reading all your posts. still plan to keep car forever. see ya.
    btw, have been changing oil myself using valvoline maxlife. seems ok. will need tires soon.
  • hammen2hammen2 Member Posts: 1,284
    Hi folks,
    More downtime for my Classic - just picked her up tonight - been in the shop since Sunday night. While on a cruise to the gas station to get a gallon of milk, the "Service Engine Soon" light came on. After verifying that all gauges/DIC were fine, and topping off the gas tank (made sure the gas cap was tight), I gave up and drove the car the half mile to the dealership, and had my wife pick me up.
    The error code in the ECM was "low idle speed". They reset the code, and they tried to duplicate the problem. The tech ended up driving my car home Monday night, and it finally errored out again. Diagnosis? A weak Idle Air Control Motor. Took 'em a couple of days to get the part, but I've finally got my car back (just before I fly out of town for a week :-(. Thank god for my extended warranty, which has now more than paid for itself ($250 for this repair - on the heels of the $1250 AC compressor repair of two weeks ago). No Classic owner should be without one. I've owned mine for 13 months, and put 18k miles on it. She's been good up to this point (water pump failure and some trim issues under the GM warranty, and tires and brakes), but the back-to-back problems are a little disconcerting...
    --Robert
    P.S. More info on idle problems at
    http://www.salemboysauto.com/faqs/faq-27.htm
    if the map pockets on the back of the front seats (of a 2001+) are actually leather? They don't feel like it, and definitely don't look like it from the inside. On the inside of the pocket, where you can see the back of the material, it looks machined and has a cloth fiber backing. I assume that means it can't be leather? Same question on the rear seat armrest. The part that is visible when the armrest is closed (like if a third person were to sit there) doesn't really feel like leather. Is it safe to assume it's not? The reason I ask is that I don't want to use leather conditioner on a product it won't help. I'll use vinyl conditioner instead.
    As an aside, anyone use Vinylex by Lexol? What do most of you use on weatherstripping? Silicone grease is really slow to apply. Plus, it's hard to get it into the sides and creases of the stripping. I have been using Armor All monthly and silicone grease every 6 months. The Armor All gets in the creases better, applies much quicker, and it helps me keep the stripping clean (especially the lower door seal). Should I try Meguiar's interior protectant or Vinylex or something instead? I know Armor All isn't the best, but it says it helps rubber. I don't think the Meguiars mentions rubber. Plus, Armor All would be better than nothing, and I do use silicone too. Any and all thoughts would be appreciated. Also, any way to treat the stripping in the sunroof?
    The weatherstripping on my Corvette was neglected when I bought it. It cost me about $1200 to replace, and that was doing it myself. It would have been over $2000 to have done. The car was a targa top, so keep that in mind. Plus, I did it right and replaced all the weatherstrip retaining brackets and hardware. I don't want to have to do that ever again. It's a real pain in the butt. I can also say, steer clear of aftermarket makers of weatherstrip. I spent about $600 on aftermarket stuff in order to save a few hundred on GM parts. I spent a whole day installing it only to have the material be too fat. The doors barely closed, the windows wouldn't go up, and the roof wouldn't attach. It wasn't an adjustment problem. The stripping was much thicker than stock. So I had to pull it all off, return it (with much difficulty as it couldn't be used again), and do the whole thing again with GM parts.
    It's finally starting to get nice out and I can feel the gas flowing through the veins. It's time for some mods.
    Will the same mufflers that the caddy guys are using fit on the aurora? I read most of them are using Dynomax Super Turbos. If they will Im gonna buy 2 of them and upgrade the Y pipe with my next pay check. I'm gonna have to hold off installation until I get my FPR fixed. Right now Im trying to price them and get an idea for labor cost. I hate working on exhuast...
    I think Im gonna get the stock replacement K&N. Until somone has made a CAI I dont think I will want a cone. I've heard some bad things about the cones on the caddys. Well not really bad, just that the heat from the engine reduces the horsepower even though it has more flow.
    Anyone have there windows tinted on their aurora? How much did you pay? I want the rear side windows and the rear window done. I have a friend that cant tint but I want this done really nice w/ no blemishes.
  • patpat Member Posts: 10,421
    Folks, I need to point out that your Membership Agreement forbids using the Town Hall to sell or buy anything. Most of our membership is in favor of that policy because that's how we can keep salesfolks from assaulting our discussions with advertisements of all sorts.
    So I need to ask you to not use this board for the purpose of selling a vehicle (or anything else).
    Why don't you check out Edmunds.com's Used Power Shopper either to list a used vehicle or to look for one available in your area.
    Thanks for your understanding.
    Pat
    Sedans Host
  • aurora5000aurora5000 Member Posts: 168
    http://www.autopia-carcare.com/producttests.html
                     and
    http://autopia-carport.com/
    Click on Detailing articles
    The Lexol works great and have not heard nothing bad about it. Will look at my car and write you direct about the inserts.
  • gisomgisom Member Posts: 144
    I also want to thank you for that throttle body info.
    #56-32-02A...Steering column clicking noise
    #63-33-01...Popping noise when turning steering wheel.
    #43-83-13...traction control system
    #47-60-7...Fuel throttle linkage control (clicking noise under dash)
    #53-12-08 Air conditioner condenser
    I recommend if any Aurora owner has the above problems, refer to TSB number and ask for a good faith warranty repair if you do not have warranty coverage.
    matrixfrog - yes, i had a professional tint job done on my '95 autobahn. I was able to get limousine black done on the back glass but had state regs limit the sides to 30% filter. Still looked awesome against the black paint. Cost was around $250 for everything about 3 yrs ago. I'm planning to have the same company tint my '98 White Diamond as well.
    I bought a bulb for one of my foglights that were out and Im trying to figure out how to take out the old one and get the new one in. I can reach it from the top if I cramp my arm down in there but I can only touch it with my fingers and not my thumb. Do I have to take something off inorder to reach it?
    Thanks for the links. The blind impressions of the Vinylex were interesting. However, I couldn't find any discussions on the carport dealing with weatherstripping... What do you use on yours?
    I recieved my 2002 service manuals for my car the other day. I noticed a few things that were interesting. The first is that the badging on the back is shown differently in the service manual. It shows the "Aurora" badge being centered on the trunk with the "4.0" badge sitting off on the right side of the trunk. On the car they are right in a row and the sentence "Aurora 4.0" is centered. This is the only way I've seen it on actual cars. I wonder why this is wrong in the service manual, and why it didn't get caught if it was wrong in the 2001 also. Secondly, I've noticed that the RPO list, while more complete than any other I've seen, still isn't complete. There are about 5-6 RPOs listed on my car that aren't in the manual. Plus, there are about 8-10 RPOs listed on my car that start with a number (like 1SA). There aren't any RPOs listed in the manual that start with a number. I thought this was interesting...
