Visitor Agreement.
i think i posted here, i sold the aurora, bought a 01 alero gls (loaded, for a alero) which i actually really like. looks good inside and out, i did some suspension mods (drop/struts) and it handles really well, and finally looks good...
anyways, ive got a question. im in search of some 17" rims. what im wondering, did the aurora have more than 1 style 17" rim? because i really like the way the 2001+ 3.5 16" looks, but i want to see if i can find that, in a 17". i think it would match my alero...but the 17" aurora rims ive seen i dont think would flow well
thanks!
The Aurora had chrome and aluminum finished wheels in the same style. The Final 500 had a set of STS 17" wheels with a collector's edition center cap. They were like a 7-spoke straight spoke design. They are all 17x7.5", which is an inch wider than the Alero's 16" wheel and 1.5" wider than the 15" wheel.
Anyway, it's a 2001, pristine condition, 40,529 miles, V8 and they were asking 17K and now have them down to 13K.
Are there any recommendations out there? I would appreciate any comments such as: Is this a good price?, is there anything to look out for?, and what do you guys & girls think of this car?.
Tks, Ed
While you wait for some comments here, why don't you hop over to our Real-World Trade-In Values discussion and ask there as well? Take note of the list of details (in red just above the post box) to include in your post.
Good luck!
The V8 was pretty loaded already but there are a few options like heated seats, sunroof, bose stereo, and gold badges. I doubt they affect the price much, but just so you know what there was available, etc.
What is the build date on the car? That's what I would use to determine if it were the car for me. That and the service history, and obviously the condition of the car. Earlier build 2001's had a lot more issues than later build ones, but you can check to see what things have been fixed already.
I think my car might be contracting the ISS issue. The steering has a subtle grinding when turning. It's most noticeable in slow-turning. As the wheel rotates, there are certain spots where it will click/grind, it isn't like a constant thing. As you rotate the wheel through a 90 degree turn, you might feel 2 or 3 spots where it clicks.
Are all of you all still around? It seems like the only posts anymore are in the Problems & Solutions board. I hope our board doesn't go the way the Intrigue one has and just become one about problems. Here's to hoping you all are just out there driving your Auroras and having too much fun to stop and post about it.
I'd have to agree with your assessment on the ISS. I've had it done several times on the '01 with about 35k on it.
Yeah, I agree. This board does get quiet occassionally but it always seems to come back. Looks like some members have migrated to the other board where I see you post frequently.
I took the 500 out last weekend with my son and nailed it for a little bit. My son was shocked at the power and begged for more. For some reason the 500 does not seem as fast as the '01 but it might be due to having so few miles on it.
The wheel vibration between 65 and 80 is common and there is even a tsb on it. GM claimed that on the last of the Final 500s, they altered the front A arms to resolve the problem. My 500, one of the last 100 made, still vibrates at this speed even though it is after the VIN that was identified with the modification. I guess all you can do is have the tires force balanced. You can look at the link below to find a service station near you.
http://209.176.154.132/
John
Ken
#4066 of 4101 Re: GXP Vibration [ravenfive #4063] by desertrat5 Jul 02, 2004 (6:22 pm)
There is a TSB out. Don't know whether it applies to your car or not. I have an '04 SLE and it has the same problem with 17" RSAs and my wife's '00 Ultra has the same problem with Pirellis. Seems to be an inherent feature of the GM full sized 4 door. Here is the TSB.
Bob in Glendale
Document ID# 1455223
2000 Buick LeSabre
Shake/Vibration in Steering Wheel, Floor, Seat at Highway Speeds on
Smooth Roads (Diagnose/Balance Tires/Wheels) #00-03-10-007F - (02/05/2004)
1998-2004 Buick Park Avenue, Park Avenue Ultra
2000-2004 Buick LeSabre
1998-2004 Cadillac Seville (SLS, STS)
2000-2004 Cadillac DeVille (DTS only)
2001-2003 Oldsmobile Aurora
2000-2004 Pontiac Bonneville (17" Tires only)
This bulletin is being revised to add the 2004 model year and delete the
screened tire program information for all tire manufacturers except for
Continental General. Please discard Corporate Bulletin Number
00-03-10-007E (Section 03 - Suspension).
Condition
Some customers may comment on shaking/vibration in the steering wheel,
floor or seat while driving at highway speeds (typically between 60-72
mph (96-115 km/h)) on smooth roads.
Cause
These specific vehicles may be sensitive to various rotating mass
assemblies, especially if they are considered to be out-of-balance.
Correction
1. Visually inspect the tires and the wheels. Inspect for evidence
of the following conditions and correct as necessary.
* Missing balance weights
* Bent rim flange
* Irregular tire wear
* Incomplete bead seating
* Tire irregularities
* Mud/ice build-up in wheel
* Stones in the tire tread
2. Set the tire pressure to 30 psi (205 kPa) COLD.
3. Road test the vehicle with the Electronic Vibration Analyzer
(EVA) essential tool for a sufficient distance on a known, smooth road
surface to duplicate the condition. Record the Hertz (Hz) reading as
displayed by the EVA onto the tire data worksheet found at the end of
this bulletin. This should be done after a tire break-in period of at
least 10 miles (16 km) at 45 mph (72 km/h) or greater, in order to
eliminate any possible tire flat-spotting.
4. If the road test indicates a shake/vibration still exists, check
the imbalance of each tire/wheel assembly on a known, calibrated,
off-car dynamic balancer. If any assembly calls for more than ¼ ounce on
either rim flange, remove all balance weights and rebalance to as close
to zero as possible.
Important
Some GM dealers may have a Hunter GSP9700 Road Force Balancer.
This will simplify Step 5 by not requiring dial indicators. If a Hunter
GSP9700 machine is available, it may also be used to measure the radial
force of the tire/wheel assembly. A guideline here is 18 lbs or less.
5. While on the balancer, measure wheel runout. If radial or lateral
runout exceeds .020 in (0.50 mm) for aluminum wheels (.030 in (0.76 mm)
for steel wheels), replace the wheel.
6. After confirming wheel balance and wheel runout, if any changes
were made, road test the vehicle again.
7. If the smooth road shake/vibration still exists:
Important
The completed worksheet must be attached to the hard copy
of the repair order.
Record Radial Force Variation readings if you have access
to Hunter GSP9700 Wheel Balance equipment. Use the worksheet found at
the end of this bulletin to record the readings.
* If one or more of the tires have RFV readings in excess of
18 lbs, match mount the tires to get below 18 lbs. Readings of 12 lbs.
or less are preferable for critical customer concerns.
* If the RFV can not be reduced to an acceptable level,
replace the affected tire with one obtained locally.
* The screened tire program is no longer in effect for
Bridgestone/Firestone, Goodyear and Michelin. Low speed screened tires
are available from Continental General only, and only for the Buick LeSabre.
* Road test the vehicle to ensure the shake/vibration has
been resolved.
8. Replace both lower control arms on vehicles built prior to the
following VIN breakpoints. On Aurora, Bonneville, DeVille, Park Avenue,
Park Avenue Ultra and Seville models, a newly developed hydro-bushing
lower control arm with improved damping characteristics has been
released. This control arm is not used on the LeSabre. The new lower
control arms may provide an incremental improvement to the vehicle ride.
Customers who have become "tuned in" to the shake condition may still
feel some shake in the vehicle after the new lower control arms are
installed. Refer to Lower Control Arm Replacement in SI (refer to the
Parts Information table below for SI document ID numbers).
Important
THE CONTROL ARMS SHOULD ONLY BE INSTALLED ON VEHICLES IF, AFTER
THE TIRE AND WHEEL DIAGNOSIS AND REPAIRS HAVE BEEN PERFORMED, THE
VIBRATION CONDITION STILL EXISTS.
Model
VIN
Park Avenue
34175493
Seville (SLS, STS)
3U247643
DeVille (DTS only)
3U247644
Aurora
34175503
Bonneville
34175497
Parts Information
P/N
Description
SI Document
25746324
Lower Control Arm, Left (Aurora, Bonneville, DeVille, Park Avenue, Park
Avenue Ultra, Seville)
Aurora -- 639351
Bonneville -- 657809
DeVille w/FE1, FE3 -- 724856
DeVille w/FE7 -- 724858
Park Avenue, Park Avenue Ultra -- 657760
Seville -- 539332
25746325
The force variation of 12 pounds is a maximum if you're a perfectionist about the slight shake.
I have one that was 12, the others were all single digits. I can tell when the 12 is rotated to the front. If you want perfection, get a tire - wheel combo with less than 12. It may mean new tires for two of the rims, assuming new ones will have less uneveness than the ones you already have. That may not be true...
The dealer was putting new tires on a Gran Prix for shake problems. They measured in the high teens and were a name brand same as the original tires (the company used blimps).
Does anyone who why the new A-arms aren't available for LeSabres? Are LeSabre's different in build quality than Park Avenues (they look the same underneath) or the other related cars? Aurora, STS, Deville.
John
John
I started using Mobil 1 in my V6 Fiero at about 80,000 miles, somewhat concerned about the common advice that oil leaks would develop. None did and the oil-smoke-on-startup problem disappeared (almost all Chevy 2.8L V6s suffer from leaky valve stem oil seals at high miles). With that experience I started using M1 right away when I purchased my '97 Classis at 37,000.
Les
I'm curious how the cost compares to regular oils and whether there's any advantage.
The Seville was new, the Aurora, four year before, had been a program (used) car. The warranty had run out a year before. I am quite happy with the Seville, the interior space seems much bigger, like my 1995 Riviera's. The Seville handles nearly as well as the Aurora and has more power. Fuel consumption seems about the same.
On the Aurora, I just replaced the front struts and the rear air shocks at Sears with Monroe equipment, I like it. ($409.00)
Rides a bit firmer, but no nose dive when I slam on the brakes. Also had all new rotors and ceramic pads( Wagner) installed. Stops great. I did not want to mess around with turning the rotors. ($570)Got a force 4 wheel alignment. Rides nice
I have had KUMHO ECSTA KHll 235/60, all weather tires on for about a year, Tirerack.com, great traction in the rain and the snow, rides quiet. handles well but when I push it on the entrance ramps get some tire squeal at about 65mph. I have only 10k on them but show no signs of wear. Great Tires. Buy these tires.
I had the dealer replace the tranmission fluid at 90k,($99), no problems
I like the Aurora. Steady and fast,it consistantly pushes 100mph after I hit the straight away on the entrance ramps. As it is my wife's car, and when I am driving, she is reading in the passenger seat and does not even realize we are at the century mark. She has remarked that it sounds louder when we accelarate!
My only problem is the rumble when I turn the wheel slowly, dealer said power steering problem, DUH.
Enjoy reading the small problems and comments.
Hope your Aurora's do not develop all of the little problems.
Keep them shiny!
My wife and I just took a trip to see our daughter and son in law, it was 1900 miles round trip. Very comfortable ride and lots of fun...when you mash the pedal you leave the world behind.
Tires still look good, slight shake on brakes.
Wife's CTS is sure a blast and a lot faster than the Aurora (and not nearly as heavy).
Steve
I have visions of CTS-V's sometimes (or maybe GTO's) but I think I want a car that's light and nimble. That's what I find myself wishing for most when driving in the Aurora. Maybe in a few years I'll check out the Z06 market or something.
Oh, and welcome to the board tshot!
Bob
Also, are all of the Classics now over the 100,000 mile mark??
Steve
--Robert
John
I get my yard mowed and don't wash my cars. IT'S GOING TO RAIN.
The last time the odometer gave me "weird" numbers the numbers came out in the New jersey pick three lottery.
It also the usual suspension stuff along with, get this, Corvette cross drilled rotors and calipers!! The other cool thing is it will feature 18x8 tires in the front and 18x7 in the back. Said to help handling. Autoweek called that decision "un-GM" like and hopefully the GP GXP will pay off.
Can U imagine what a generation 3 aROARa would have been like??????
