A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
As far as leasing goes I don't see any advantage, I'd just buy the MPV or any car right out. Leasing would be a big problem if you put over 12k on a car a year which I can do in about 7 months.
As far as comparing the Duratech 2.5 to the Honda 3.5, I am not an engineer, but EPA rates both engines at 18 mpg city and 23/25 MPV/Honda freeway, so they are the same in the city, and only marginally better on the freeway. But also keep in mind that the ODY's recommended fuel is 91 octane to MPV's 87, so annualized, you will probably pay more or the same amount of money for gas.
just my 3 cents (inflation!!)
Can Washington step in and begin making significant changes? Of course they can but only if you and I the voters make it a big enough stink. Quite frankly, most of us seem to be too busy for such a protest.
Finally, (please don't take this that I am a big Bush supporter) I fail to understand how a president that has been in office for less than 6 months can be held accountable for MPG on vehicles produced prior to the elections. If you want a figure head to blame you should look to Mr Clinton. After all he had eight years to effect a change and per your own post and Julyar's the only change has been negative.
At least with George drilling new wells the price may drop, but I doubt it.
Tanks
MSGJVH
It doesn't matter how many models of little box cars with hybrid engines are out there if everyone wants great big vehicles with great 0-60 times.
If someone can't afford the gas, than they should worry about MPG. But then they probably should also buy a cheaper vehicle.
If the 3.0L Duratec does indeed make it into the 2002 MPV, it'll probably have the same mileage as the 2.5L because it would allow Mazda to use more efficient gearing ratios.
Duratecs are indeed not state of the art designs by todays standards. But they're not low-tech either. In my book, a chain driven-DOHC/24-valve V6/dual length intake runner induction/ distributor-less semi-direct ignition/ 6500rpm redline/ (7500rpm redline in the Contour SVT?) is by any means not low-tech. Small for a minivan? Absolutely! Low-tech? No way. I even read somewhere that when the Duratecs/Zetecs were in the drawing boards, the engineers even made provisions for a possible addition of variable valve timing in the future. I believe that the upcoming Focus SVT (Zetec 2.0L DOHC I4) has some sort of VVT to help it make 170hp - not quite Honda/Toyota/BMW VVT levels of efficiency yet but it's a start.
Peace...
Of course I'm biased, I have one of those SVT engines :^D
The Zetec has had VCT (Variable cam timing) on the exhaust since 1998 or 1999, but primarily to eliminate the EGR system.
TB
My commute is 18 miles each way with speeds in the 35-50 mph range and maybe 4 red lights. I've been using the a/c about 50% of the time.
WARNING!!! Please do not look at this if you're sensitive! It's gruesome!
<http://www.worldzone.net/sports/300z/crash.html>
Anyway, it really did make me re-evaluate my driving habits (that's good, anyway). I guess I'll maybe save the pics locally for a day when I begin to belive that nothing bad can ever happen to me...
Drew
P.S. I did warn them though ;-)
I said about new two engines, which are 3.0L by Ford and 2.3L with Direct Fuel Injection system by Mazda, would be added on new MPV and the present 2.0L would go out at the next change in my post #1746 on Jun,27th.
Reconfirming this magazine, it also mentions that the new 3.0L will replace the present 2.5L. and Mazda will be able to compete well with competitors.
I guess the new MPV for N/A is only 3.0L.
As for AWD for N/A ,I have been inquiring to Mazda on the Web. and to the near dealership
in Japanese since I visited this forum. But, nobody response me at the present.
I would continue it still more.
I heard from a salesperson of Mazda that Kilometer Per Liter of 3.0L on AWD Tribute is good. It’s about 10 K.P.L. at stop and go traffic in the city.
The K.P.L. of my AWD MPV isn’t so good as Tribute, about from 5.5 to 6.7 in the city and about from 9.0 to 11.5 in the Tomei and Meishinn highway where are between Tokyo and Osaka. But, I’m satisfied and proud of all except fuel consumption.
If someone likes the Japanese home-page and after-market items on MPV and others, please refer to this Japanese website. Excuse me in case you can’t see except for Japanese.
http://www5.cds.ne.jp/%7Eyoshioka/index.html
Thanks, Osaka.
You can write the message in Microsoft Word, as you have been doing, and then copy and paste it into the text box here in Town Hall. However, you have to first turn off Word's smartquotes feature. Those special (and hidden) codes in Word are the reasons why you have those strange codes in place of the apostrophes and such; they're being copied over as well. If you wish to compose a message offline, you can also use an ASCII compatible application such as Notepad.
Hope this helps!
Drew
2001 MPV LX
security pkg
rear air
roof rack
MSRP $25,105
Offered at $23140
before rebate and taxes.
On my trade: 1994 Mercury Villager GS: 79,300 miles,original owner,rear air,abs,cruise,7 seating,roof rack,alloy wheels,cassette,privacy glass,pw,pl,pm,pst,decent condition,no major repairs: he offered $4500. I believe this is low,but looking for opinions. They seemed to think once it hit 80,000 miles,it would be more difficult to trade. Any thoughts would be appreciated as this deal is only through Monday.
P.S. I am still considering the Toyota Highlander, 4cyl,2wd,MSRP $25,450. Probably get no more than $1000 off sticker. Payments would be 40-60 more per month depending on financing. I like the price,financing,and most about the MPV,my only concerns are resale value,and the 'small' V6. The Highlander although more,would be better on gas by about 4 miles per gallon,and I believe the engine may be more advanced. But,is it worth $50 more per month???
The Invoice of your MPV is right about $23,000. I would offer $23,400 less $1500 incentive( to dealer)= $21,900+ tax. There is $400 dollar profit, plus a 2% holdback to the dealer and the money they will make off your trade. Check the Bluebook wholesale value of your Villager, should be closer to $5,500+. Early models of Villager/Quest haven't held their value well.
I would be very leary of any dealer that says this deal is only good to a certain day. Although, Mazda's incentives change this Monday, July 2.
As far as the Toyota Highlander. IMO, it's a very nice car. I've only seen a few Highlanders and it's a sharp SUV. Comparing it to the MPV is like comparing apples to oranges. If you want to compare the Sienna and MPV it would be alot easier. The Highlander is in the first year of production and has had a few issues, just like the MPV last year. Alot of people have complained that the Highlander has had a TON of road noise. But overall, the quality has been very good, another Japan built product. Our 01 LX has been perfect( 3 months-3500 miles) I've been following this forum and other van forums for over 6 months and without a doubt, the MPV is the most reliable new minivan on the road. Drivetrain is fine for us, other's are waiting for the 3.0.
Rurger3, I'm no expert and my opinion's can be taken with a grain of salt. I love cars and research them to death, especially new models.
I wish you all the best, let us know what you decide.
Pete
Now I see. Thank you for your suitable and kindly advice.
It was not until you said me in #1772 that I learned the its cause.
Osaka
Do you think Mazda will sweeten their current rebates or financing when this one runs out?
A few other points, Do you like the dealership and trust them? Are you going to bring the MPV back to them for service?
The MPV has side airbags( security pkg) and alloy wheels and lot more features than the 4cy HL and is alot easier on your wallet. No crash data available on the HL, although I suspect the HL will do well. The MPV has 4 front and 5 on the side. Just a notch below the Sienna and Ody.
The Toyota dealerships in my area are kind of sleezy. Not to say, all Toyo dealers are sleezeballs.
Our Mazda dealer is terrific and the service is exceptional. I would have had no problem paying a few more $$s for our van since I trust our dealer and service dept, I also own a Protege.
Btw, my sister lives in Bergen County, she owns a Windstar.....AGGGh!
Any more questions, give me a shout.
http://www.hwysafety.org/vehicle_ratings/ce/html/00011.htm
Osaka, you're very welcome! :-)
Drew
I have thought of one more advantage for the Highlander,gas mileage. 23/27 vs. 17/23. This would calculate to about $200 more per year in gas for the MPV, or about $16 per month, or about $1000 savings over 5 years. I do HATE to overpay for gas,plus I am somewhat of an Environmentalist; so although there are many things the MPV has that the HL doesn't, the gas thing would bother me. But then I think about how hard it is to get an HL and how some of the Toyota dealers are,then think otherwise. It is a shame that Mazda/Ford didn't make the engine more efficient,but I realize nothing can be done about it now.
2001 lx
with rear ac
alloywheels, sideairbags and maybe a few other things that are in that package
21700 which for me includes the 1500.00 rebate
need to add tax tag title and maybe a hidden 400 fee im not sure yet on that fee
This isn't a bad deal at all. One of the dealers here has about 60 base lx or dx on the lot, and for some unknown reason expects to have 100 on the lot. I have no idea why. I haven't even bargained with them yet.
Also I'm going let this 1500 rebate go till I have all my cash in 2 weeks. If i miss 500 of it I'll rethink my purchase.
I'm still going to dealerships and looking at other things besided the mpv, hl or sienna. I must say every dealer I have gone to the salesmen looked bored to death. Sales have to be slow. One dealer had over 40 salesmen on saturday doing nothing. This was in a Toyota dealership.
This saturday the toyota dealer I went to had a supposedly huge sale.
They sold 7 cars for the day when I left at 5pm. Mostlly corollas camarys or trucks. No high end autos. Their average is usually 14 a day. Sales are killing these people I'm not kidding. The more we wait the better I think we can do.
I drove a explorer for 7 years until I back out of my driveway and someone hit me and flip the car over.
Enjoy your van, you made a great choice.
Thanks to all the posts here,which were instrumental in our decision. We got an LX in the sand mica color, will give more details later. By the way,I still 'miss' our 94 villager because of its great engine and no payments,I love no payments,but I think the MPV will prove to be a good choice.
I see TONS of Odys and US minis on the road...?
Jodie
I wouldn't be that much concerned about this fact. Actually it even helps to keep the price low which is much more beneficial, right?
Anyway, I stumble across this Japanese site that apparently deals with the same issue: http://www5.plala.or.jp/MPVGALLERY/asimawari.html
You can try using AltaVista translation service to at least try to render some information from it.
I hope it helps.
You shouldn't be buying a MPV for resale value, you should be driving it till it drops.
Sorry if I got too far off topic. I had to "vent" too. : )
