2005 and Earlier Chevrolet Impala
1216217219221222265
  • drivinisfundrivinisfun Member Posts: 372
    Dealer called me just a few minutes ago. The Upper Manifold intake (Plenum?) was totally and completely warped. They said that no coolant made it inside the engine as the leak was mostly external.
    Apparently part is in stock as the car is being worked on as we speak.
    There you go another failed manifold at 18.5K miles on a babied, pampered car. Why GM??
    Upon picking up the car, I will ask the service manager to show me the old Plenum. Also I plan to get a part number cross check. If the part numbers are the same, I will weigh my options about keeping the car in the near future. Pretty dissapointing.
  • atbearatbear Member Posts: 322
    Good Luck
  • b4zb4z Member Posts: 3,372
    Sounds like the identical problem to mine.
    I would guess I had about 18K on it when it happened.
    Just like yours the part was in stock and they fixed it in less than 4 hours. Why do they keep the part in stock if it doesn't happen frequently?
    This is a case of GM engineering cost out of an engine and it coming back to haunt them. Or more correctly the car's owners.
  • johnclineiijohnclineii Member Posts: 2,287
    Well, let's see. I have a 2000 LS, bought new. I didn't buy the extended warranty. It now has 110,000 miles on it. The first repair, for a headlight switch, was at 107,000 miles.
    If I had paid for an extended warranty, every penny I paid for the warranty would have been a loss, loss, loss. And profit, profit, profit for the insurance company.
    But you don't see me on here advocating people not buy one. That's a personal decision. As for me, I would NEVER buy one. Ever. I would rather assume the risk (and pocket the profit). A gamble. One I was willing to take. And one that, this time, I won.
    Out of my last ten cars, there hasn't been a single one where purchasing an extended warranty would have saved me even a dime. In fact, I would say the cost of those ten extended warranties minus the repairs on those ten cars that would have been covered probably equals something like six to seven THOUSAND dollars. I think I will continue being what amounts to self-insured.
  • discgolferdiscgolfer Member Posts: 72
    johnclineii, I totally agree with you. I purchased E.W. on my first 2 cars, and never was able to "Use It". Total loss of my money. And lets not forget the "Deductible" on these things, so you still pay for the first $100, $250, $500 dollars, usually on each "issue"...
    I have purchased 5 new vechiles since then, all without E.W. I would have lost on all of these as well. Granted, on 4 of them I got rid of it at about 65K miles, and the highest only up to 85K...
    2000 LS now has 40K, 2.75 years old, and out of warranty. I guess I'll just have to see how this one plays out...
    I guess I would rather risk maybe, possibly having to pay $800, $1000, or more, instead of definitly paying some $1500 or so...
    JMHO...
  • pluto5pluto5 Member Posts: 618
    This is how Circuit City got so big. They made more profit on selling warranties than products. Now they are doing the same with CarMax, unless they sold it already. What I can't fathom is why so many Honda owners buy extended warranties. I guess Chevrolets are more reliable!
    Yep, Circuit City has sold CarMax, I do believe. Note also that Sears, Roebuck sells a LOT of extended warranties, and now even the office supply houses tout the things.
    I agree with you on principal but if I were to buy a used BMW, Lexus, Mercedes I would definitely go Certified or buy the extended warranty.
    For a Chevrolet I doubt if I would do it. parts are cheap and if they are expensive I would go to a "junk or u pick yard" and save a bundle.
    For probably the first time since the '60s.
    YTD production is 254,843 vs. last year's 218,131.
    Well, got my car back a few hours ago. Everything is back to normal. The car was ready when promised and the Manifold intake was replaced during the afternoon.
    I was greeted by my service manager (Terrific guy, BTW) upon my arrival and he took me to the service bay where my Imp was. He then showed me the original manifold plenum and the area where it had cracked. It had a tiny crack on the right side of the manifold and that is where the coolant was leaking out onto the exterior of the engine. The plenum is a pretty simple part (Well never seen one before)as is hollow inside and made in black thermoplastic. At the base it has the seals that sit at the top of the engine. I can't believe they charge and arm and a leg to repair/replace it when it goes south.
    Anyway, the dealer keeps these plastic plenums in stock because...you guess it....seems to be a common event with these engines leaking coolant early in their service lifetimes.
    The car is fine now and the coolant tank level is finally where it should be. When i press the gas pedal, I get a reminder of why I like this car so much in the first place....the smooth, quick acceleration.
    Kudos to my dealer for getting this problem sorted out in less than a day. I really do appreciate the service they have given me.
    However, although my car is fixed now, I am still bitter about this manifold thingie. I could not cross check the manifold's part numbers as I will be receiving the repair ticket on the mail sometime this week. I suspect that if the part is the same # as the old one, this plenum is going to warp again in 2 years, at which time the car will be out of warranty (Unless I purchase an extended one).
    I still find this fault unacceptable in my book and a bad cost cutting tactic in GM's part to save a buck or two at the assembly line.
    Everyone should keep an eye on the coolant level of these cars and take it to your dealer should the level goes down or bad antifreeze smells are coming from the engine.
    Merry Xmas everyone.
  • charts2charts2 Member Posts: 618
    My friend has a 1998 Buick with 3800 engine. He wasn't as fortunate. He was on a road trip, and didn't notice his coolant leaking and coolant got into the oil and cooked the engine. $4,500 for an engine/labour costs for a new 3800... I think once a week or so check the coolant levels and any coolant odors investigate right away....Drivinisfun I agree with you that as I type this post new Impalas are going down the assembly line right now with the same plenum part being installed that failed in your car... How much does it cost to revamp a small part like that, to save everyone the $$$$$ and hassle.
  • gasolinegasoline Member Posts: 25
    I am wondering if you gave your car an oil change after the repair? I am going to get my cars oil changed just in case small amounts could have leaked into the oil and contaminated it. I don't know if these leaks result in coolant going into the engine like head gasket leaks. Maybe somebody with more knowledge can explain it to us.
    If you change the oil 3-4 times a year you may spot problems like small coolant leak before they become major problems. I keep extra coolant in the overflow tank and change the Dex-Cool every 2-3 years. My opinion.
    There you have a very good point. I was assured that the coolant leak was external (Right side of the manifold) and that none of the coolant made it inside the engine. I already had my oil/filter changed just a month or so ago, so obviously the oil still looks crystal clear in the dipstick.
    I change my oil filter religiously every 3K miles, so anything of this nature can be discovered in time.
    I guess I was lucky because....a)The manifold warped during warranty and b) the problem was discovered on time and the coolant leak was external.
    I think most people don't realize how serious a manifold coolant leak can be. If left unattended can cause costly widespread damage to the engine.
    It is a good idea to check the coolant level in the recovery tank once or twice a week and be attentive to any antifreeze smells coming from the engine bay. The faster the problem is detected, the less chance for it to damage your engine.
    GM has a real problem in their hands with these plastic manifolds and I am truly surprised that the NHTSA has not forced a general recall upon them. There are thousands of owners that have had the same problems. Most of them have had their manifolds failed outside of the warranty amd coolant, like Charts2 says, have roasted their engines.
    Could it be that the Police/Taxi versions of the 3800 V6 get a better quality manifold? I have no idea. When these manifolds used to be made in Aluminum, people never had these problems with their 3800's.
    I might change my oil and filter again this weeks as a preventive measure....thanks for the tip.
    Seems to be another culprit in the problem. Baseed on my searches, Dexcool appears to break down and due to its acidity, eat away the plastic gaskets, etc. I concur with Pluto's recommendation to change the coolant and do a flush of the coolant system every 2 years.
    My MINI has a factory recommendation to change the BMW antifreeze every 2 years. Yet my Impala, has a recommendation to change the Dexcool not until the 150K Mile mark!.
    Judging from this site:
    http://www.petitiononline.com/mod_perl/signed.cgi?GMcnsmrs&1
    and other complaints it appears that engine gasket and intake manifold problem is less than 1% of the GM V-6 engines--just an estimate--but if that is true your engine's chance of having the defect is not too worrisome. I also have the 3.1 in a 6 yr. old with no problems yet although there are complaints about the manifold, gaskets and piston slap on this engine. Ford has similar engine complaints, too. The manifolds are probably made by a third party supplier and it sometimes takes time to get things right.
    Before you buy an extended warranty take a look at mechanical breakdown insurance from your auto insurance carrier. Costs about $60/yr for the Imp and you may be able to get it for up to 11 mos. after you purchase the car.
  • night_owl1night_owl1 Member Posts: 760
    The 3400 engine in the Impala comes with an alumnium intake manifold. I don't know about the 3.1 though.
    The manifold cracked? Wonder if they overtorqued the fasteners.
    Interesting, I was looking at the service manual and it doesn't take a lot to remove the intake manifold. It shouldn't cost all that much to replace, labor wise. Drivin, when you get the statement, let us know what they did. I assume you would get a coolant change since they would have to drain the fluid to remove the manifold.
    There also seems to be two different intake manifolds for the 3800 engine. One is alumnium and one is the plastic one. However, these are not interchangeable. The throttle body attaches to the right side of the plastic one and on the left side of the alumnium unit.
    Drivin, did you see any staining on the block? That's something else people can be watching for. If you can give me any details (description, photos, links to websites that also document the problem) I can create another page similar to the engine cradle one.
  • nosirrahgnosirrahg Member Posts: 872
    For those of you having these coolant leaks, did you notice any other symptoms other than the smell of coolant, and a low resevior? Was there any coolant on the ground when you parked, of anything else the rest of us might look for?
    Too bad the aluminum unit won't directly replace the plastic one - I'd hate to replace one with a plastic one, only to have it go out again in a few years. I've never bought an E.W., and didn't even consider it on the Impala, due to the reputation of the drivetrain on this vehicle.
    Question - If people are having this problem now and get it repaired on their own, and GM ultimately issues a recall, do those who already had the problem get reimbursed?
    You've got to understand that this is a very uncommon problem.. If you get one replaced, the chances that you'd have a second one go bad would be almost negligeble. And if you fix it, and then it's recalled you do get reimbursed if documented.
    Hmmmm, don't think so. How come dealers are keeping these plastic manifolds readily available in stock? They are failing prematurely (Between 18K and 60K miles)and most owners believe or not, are probably not even aware that their wonderful thermoplastic plenum is already leaking coolant.
    I have followed these threads for sometime now, and I have seen several posts of mysterious coolant leaks and such. There are at least 4 2001 Impala LS owners here (Including B4z and Gasoline) that have had their plastic manifolds fail before 30K miles.
    I had a very slow leak ( I was losing about a cup or two of coolant every 2 months) and never had any coolant puddles under the car. I took the car last month for a pressure test of the cooling system and everything came back "OK".
    Not until mid November I started to notice the nasty coolant smell coming out of the engine bay, but could not see any puddles or traces of the coolant leaking on the right side of the manifold. The dealer apparently in despite of the strong smell, could not see it either. I am sure this time around they used an ultraviolet light to be able to detect the leaking coolant dye.
    My car was perfectly fixed on Friday. Now my question is, how long the new Manifold is going to last? 15K or 20K miles and then replace again?
    The factory manifold only lasted 20 months (18.5K miles).
    Why is this happening to a religiously maintained car by the Book? Why are these plastic manifolds leaking so early in their useful service lives???
    I am not dissing the Impala or the 3800 V6 engine as I still like 'em both a lot (And still think highly of the quality and durability of the product as a whole), but Manifold leaks are SERIOUS and COSTLY problems and can also cause major mechanical breakdowns such as totally seized engines.
    There are no recalls for these plastic manifolds. People that have been misfortunate to have this happened outside of the warranty, have not been reimbursed by GM for what clearly is THEIR OWN MISTAKE. Unless NHTSA forces a general recall, GM will not do it.
    The only TSB I have found out (But have not been able to see the contents) related to the manifold is:
    TSB 01-06-01-007 "Composite Intake Manifold 3.8L V6"
    I have no idea if this applies to the 2000+ Impalas with the 3800 engine.
    GM has been getting away with these crappy plastic manifolds for far too long. They are making owners of these vehicles outside of warranty pay for their own cheap part and mistake. Not fair in my book.
    It seems to me the leaking manifold in the 3800 happens slowly and overtime. My advise to fellow 3800 Impala owners: Keep close tabs on the coolant level in the recovery tank, check for coolant presence in oil, flush the coolant system every 2 years (Dexcool is known to eat away the gaskets if left there for a long time) check for stains in the engine block or puddles under the car and treat any Coolant smells coming from the engine bay as a red flag that something is going on with the plastic manifold.
    No, I don't think this is an uncommon problem, unfortunately.
    Dexcool is not the problem. And I'd say that less than 1% of the population is pretty uncommon. I'm sorry it happened to you, and I'm glad you caught it and got it fixed, but this is still not a common problem. Thanks for warning us none the less. And good luck with your second manifold.
    To learn more about the cause of this problem got to google.com. Search: 3800 engine manifold problems.....The first heading surfing down "LEARN HOW TO BE A SURVIVOR WHEN PROBLEMS ARISE BY DOUG ANDERSON..surf down halfway again to "Buick 3800 vin K Hydrolock"...It explains the problems with the plastic intake manifold.
    After reading that article on the cause of the problem, I might have something that will help us. I will be getting this soon (I decided to get it way before I heard of this problem), but now it might be good for preventative maintainance, as well as performance gain! Here is the product:
    http://www.zzperformance.com/zzp/products/l36_coolantplug_info.htm
    That is something formed by Jim Wierzbicki who owns a Grand Prix with the L36. He makes lots of neat mods for our motor, and this one was meant to help performance. But, after reading this article, it might help with the manifold problem. Check it out
  • jeffbogjeffbog Member Posts: 63
    Just had to ask.....
    Teo doesn't post here anymore. I have an email address for him that comes back as undeliverable.
    He is registered with mountaintopclub.com but doesn't post there anymore either.
    I think his last post there was May '02. I guess he is officially AWOL.
    That coolant plug looks like a good workaround for the problem. Has anyone here installed it? How Much? How easy it is to put in there?
    I am not very mechanically inclined.
  • etcarrolletcarroll Member Posts: 87
    Just made an appointment for loss of coolant. The service manager told me he had just read a GM bulletin addressing this issue. He thinks from the tone of it a recall/update is coming for this, though it didn't say precisely that in what he read.
    Anyway, I'm bringing my car in, '01 LS with 40,882, this Thursday. I'll post how I make out.
  • larryfllarryfl Member Posts: 214
    I'm on the fence with this. I bought a 1984 Maxima new and got the 60K mile extended warranty - about the longest available back then. It definitely paid for itself in a string of repairs from 45K to 65K miles. Of course, I had to pay for the ones over the 60K mark. I kept the car to 120K miles and never had any other problems.
    The next warranty I bought was for a used '92 Infiniti Q45 with 89k miles. I bought a 24/24K warranty for that and THANK THE LORD! That car had over 20K in repair work done under that warranty. Towards the end, I actually had to sue the warranty company to get the last $4500 paid. Needless to say, the car was traded immediately after it ran out.
    BUT, I traded on a used '95 Olds Aurora w/ 50K miles that I still own. Because I was gun-shy after the Q45 experience, I bought a 24/24K GM Bumper-to-Bumper warranty for $1500. When it ran out, I had made only 1 $125 claim. Of course in the 8 months since, I've spent about $1500 in new radiator, AC compressor, Water pump, etc. Oh, Well.
    Extended warranties are another form of insurance. Is there for when you need it. The same argument can be made about car insurance. Since it is mandated by law, you have no choice but to pay for yearly coverage. If you never file a claim, oh well, you made the insurance company richer. If you do use it, is there for you.
    The same can be said about EW's. Depending on the car's warranty repair history and overall reliability stats for the make/model, one needs to make a decision if it is worth to "prepay" for any unexpected breakdowns down the road or to take the gamble and hope for the best.
    Let's face it, Impalas are great cars and probably one of the best qualitywise products put out under the bowtie brand by GM in many years. But these cars still do not match the reliability reputation of the Japanese competitors and things will surely break after the factory warranty.
    The ISS and the plastic intake manifold are 2 prime examples of costly to repair items that at some point will fail again. Thanks to the GM beancounters, Steering shafts and Intake Manifolds are part of the wear and tear dept.
    I think the Imp is a terrific car in many ways and I don't have a problem keeping it for the long run, but not without an EW contract. I do not trust these cheesy plastic manifolds at all, not specially after one that "melted" under normal use at 18K miles.
    EW are a personal choice, and I don't think you can't go wrong getting a good service contract to cover for unexpected repair expenses. Chevy parts perhaps are cheaper than many other makes and models, but labor rates is what makes auto work in these cars so damn expensive.
  • garywgaryw Member Posts: 116
    Not sure about GM's policy but some auto manufacturers will not charge to repair the same the thing twice. My Volvo was covered under this little known policy.
    I doubt GM would have a policy like that. Would be nice though, but doubtful.
    That coolant plug just came out about 3 weeks ago. I only know of a few people who have it on their cars. It's very easy to install, there's only 3 screws to unscrew on the throttle body (you can easily do this install if you choose it). It's main purpose is to keep scalding hot coolant out of the throttle body to keep it cool (a cool throttle body creates more power), but by keeping the coolant out of the throttle body (according to that article charts2 posted) it might help solve our potential problem with the manifold. They can be purchased here: http://www.zzperformance.com/zzp/products/l36_coolantplug.htm
    I was wondering if the Coolant Plug can void our powertrain warranty....toughts?
    You cannot have your warranty voided simply by having something installed. To have your warranty voided, the aftermarket product must actually cause the problem, and the dealer must prove that it was the aftermarket part that caused the problem. I wouldn't worry about it at all, but it is still your desision.
  • dieselonedieselone Member Posts: 5,729
    My wife's 01 Impala 3.4 w/ 39k miles just got out of the shop because of the infamous ISS problem. They lubed it up and it seemed to do the trick. I don't know what the bill was since it's a company car and all repairs go directly to a service company that manages their fleet. Another problem that has developed is the low coolant warning light. It comes on immediately after start up and will go out after about 15 min. of driving time. I've checked the coolant level and it is topped off. Overall it has been a good car, not exciting by any means but a good car. It will be going away at 50K for a replacement. Word has it the wife's company is switching over to Ford so it looks like an 03 Taurtus will be in the driveway this summer. I'm sure it will come with the despicable 3.0 vulcan, YUK!
    I'm a little confused. How is the throttle body coolant plug supposed to solve the issue of a warping intake manifold? I thought the warping was between the upper intake manifold (plastic) and the lower intake manifold (metal). Is the warping actually between the throttle body and upper intake manifold?
    Have someone check the coolant level sensor in the expansion tank. It could be that the sensor is sticky.
    Did you read the article about the 3800 manifold problem? From what that said, it sound like the coolant coming from the throttle body might be the cause of the warping.
    Be aware that the 3.4L V6 in the base Impala is infamous for manifold intake problems and in a much greater margin than the 3800 V6.
    The 3400 V6 is used primarily in GM's current crop of Minivans, the Alero, Grand AM, Aztek and Buick Rendezvous.
    The ISS problem is a fact of life in these cars, but I'll take that any day over an engine/manifold leaking coolant.
    It seems that the ISS relube has had some degree of success as I see that complaints about this item have minimized since it was introduced in a new TSB.
    Would like to know how much your company has paid for the ISS relube out of warranty.
    Here is the article I a refering to:
    http://www.babcox.com/editorial/ar/eb110112.htm
    And, here is the exact part I am refering to:
    "This passage is partially protected by a metal sleeve that sticks up from the lower manifold, but that doesn’t keep the heat from the hot exhaust gas from damaging the upper manifold over the long term. When the plastic deteriorates, it exposes the coolant passages used to preheat the throttle body that are located on both sides of the EGR passage. Then, when the engine is shut off, the pressurized coolant runs down through the manifold, past an open intake valve and ends up hydrolocking one of the cylinders."
    I don't know if the coolant plug will actually help, but I was just bringing it to light to see if it might be a fix. I have contacted Jim Wierzbicki about it to see if he believes his product could serve this function. Stay tuned
    Thanks for the article. I would be interested in hearing what Mr. Wierzbicki says but I think this is two different issues. Hydrolock describes a condition where one or more of the pison cylinders fill with water. Water does not compress so when the valves close, the piston cannot move up. I don't know if the ERG system passes through the intake manifold in the Impala. I thought it was bolted on somewhere else, but right now, I couldn't tell you where.
    From the photos of the plug and of the K intake, it looks like the hole developed in the intake and the plug seals the throttle body. To fix the issue described in the article, one would have to remove the intake and fill the passages with epoxy or something.
    I wonder why the plastic manifold makes more power? Maybe they can form the air path better in plastic?
    I wish they had said how old that manifold was.
    You're probably right.. Since I don't have a tangible model of the problem, it's hard to visuablize all of the components from that article. The coolant plug would still be a good mod, even if it would have minimal effects on this particular problem... Thanks, night_owl
    Hey check this out. I tried to post the link, but Edmunds won't let me post a word with greater than 115 characters.
    11/15/01:
    "My 98 Bonneville SE 3800 V6 automatic, had a small coolant leak between the throttle body and the plastic intake/plennum. When the local service tech took it apart he said there was a pin hole in the plastic intake/plennum. The car only has 48k miles on it and he said this was a pre-mature failure and the second one he has seen on this model. He suggested after he makes the repair, I take the failed part and invoices to the local Pontiac dealer and attempt to get reimbursement, even though it is out of warranty, because it should have lasted much longer. Do I have any chance of recouping $$ from Pontiac and is this a common problem?"
    11/21/01
    "Here is an update.
    The local dealer contacted the D.S.M. and he said because I did not take the car to the dealer they would only reimburse me for 50% of what the warranty "cost" would have been, which came to $162.64. My bill at the ASE certified repair facility was $637.41. The intake manifold itself was $295.66. I took it up with Pontiac customer relations and they say what the D.S.M says is final and I have no other recourse with them because I am out of warranty.
    The problem appears to be an incompatibility of the new Dexcool antifreeze and the plastic material the intake manifold is made of. The coolant is eating though the manifold.
    I would be interested to know if anyone else has seen or heard of this problem."
    My theory is that the fasteners on these plastic parts are being overtightened, overstressing them and leading to cracks/failure. Easy to do with an impact wrench in the hands of a robot! Just my opinion. New Year's resolution: spend more time checking the Dex-Cool in my cars than posting on this board.
    I would agree with you. Overtorquing would also warp the mounting flange.
    I did find a TSB that covers the leaking ERG area of the intake manifold. However it does not say it applies to the Impala. Various 1995-1998 GM vehicles with the 3.8 L engine (VIN K - RPO L36). It was issued in July 2001 so if it applied to the Impala (and Monte Carlo) it should have been incorporated. It has not been revised since then. I'll post the full text on the ImpalaHQ site later this evening.
    The TSB I found was the one you cited earlier. Actually, the one I have is the updated copy. It doesn't cover the Impala, but it sounds similar to the problem you encountered.
    The TSB is posted on the ImpalaHQ site and I'll work up a How-To article on this later.
    drivinisfun,
    If you have the info on what the ISS relube costs, let me know. If the ISS creak comes back and they charge an "arm and a leg" we may just wait for the new car to come and not waste the $$$
  • tommy42tommy42 Member Posts: 70
    MERRY CHRISTMAS TO ALL
    Thank you. I'll be checking out your site later on tonight.
    Possible over torquing of the manifold bolts could cause premature cracks in the plastic intake. I think I read this somewhere a long time ago, but can't remember the source.
    Are there any aftermarket companies that make manifolds for the 3800 V6?
    Which manifold are we talking about? ZZP makes performance intake and exhaust manifolds.
