Visitor Agreement.
Second, don't believe Java about his bad manners. Among his other traits, he's an inveterate liar [his point #2 proves it]. He's actually a very civilized man--for an Alaskan.
Happy Miles!
RJ
Scott
The Tribute, Protege 5, MP3, 200hp MPV and the 01 Protege fresher look.....Way to go Mazda.
/Javadoc
After driving pre-owned MPV, Sienna, and Caravan over the weekend we bought a used 2001 MPV LX (Rainforest Green) for $20,500 (sticker $22,995). Had dealer pay for Carfax (after he bad mouthed former rental vehicles) and found out he was trying to sell us a rental also! Has 13K w/ security pkg, rear air, touring pkg.
As this was not a Mazda dealer, they new little/cared little about specifics AFTER the sale. They only gave my wife one key, and knew nothing about the keyless entry. Needless to say I was irate, as I know the keys are expensive and hard to make. Our salesman basically told me "tough luck" regarding above problems. I called the General Manager and he told me he would split the cost of new key ($120.00).
My questions:
1. I believe I need to bring vehicle/one key to dealer and they will make another. Is this correct?
2. Keyless entry does not work. Obviously the batteries may be dead, but the car is only 6 months old. Does the keyless entry also need to be programmed?
You can program a key with immobilizer as well but you need TWO working keys to do this. If you have only one, then you have to go to Mazda dealer who can program another one.
I hope this helps.
Thanks again!
Chuck
Also, I'm being offered Mazda's 4.9% financing. Can a better rate be negotiated?
I'm not sure that the time of the year is a factor. The new 02's won't even be manufactured until November and won't be available in the U.S. until January or February, so it's not like they have to clear ou the 01's in a hurry to make room for the new ones.
It might be worth your effort to try and gnaw him down another couple hundred, [and you might check to see if the $1500 rebate is still in effect--Edmunds should be able to tell you that],but if you can't, it's still not all that bad of a deal. And even at that price, it's thousands less than a similar Ody or Sienna.
Good luck with your negotiations.
RJ
I know the Honda is bigger and has a bigger engine, but I don't think that alone is worth quite $4000. Anyone have any thoughts about whether the Honda is worth the extra $4000? I am especially interested in repair time/cost.
Certainly, resale value, and residual will probably be higher on the Ody (it's a Honda afterall), but figure out if that's ultimately most important in your buying decision.
I've noticed that Odys aren't up to the std that you'd think of a Honda. A good friend of mine has one and remarks that it is "less reliable than" his "1995 Windstar was." That's not good to hear after remembering those troubles. The MPV has a few issues, but not to the magnitude that I've read of regarding the Ody. I've read their problem boards and seen troublesome transmissions, sketchy engine performance and mileage, wide-spread problems with automatic doors opening of their own accord (pun not intended), and my friend's has a ton of rattles after 20,000 miles while my 2000 MPV has no rattles (except the stroller in the back) after 20,000 miles and is just now going in for its first "problems," a loose vanity mirror door and squeeking rear brakes. I'm working hard to convince you. :-)
/java
The only thing was it was faster.
I didn't need faster. I needed smaller than the DC van we had.
We could have waited to order a new Odyssey since our Grand Voyager only had 25K on it and was still under warranty for another 6 months when we began our shopping.
We didn't feel it was worth the premium price for an average equipped van.
TB
First the more minor issue,power. The Ody clearly has more of it and the 5% of the time you want it,it will be there.This is a personal decision. Also,this indirectly has an effect on the next point.
The single biggest advantage to the Ody is Resale value. It will be MUCH HIGHER on the ODY,that is a fact. Check the used values on Carpoint or Edmunds or even with other auto dealers including Mazda, which will prove this.I do not believe it is fair,but it is very real.
That being said,the $4000 difference is hefty. It will also depend on how long you expect to keep the MPV,if you keep it for 6+ years and 90k mile,then the difference will not be too much;however if you trade it in 2-3 yrs from now, the advantage of the MPV is less. Also,the monthly payments need to be considered. Isn't this car buying stuff fun?
I personally have enjoyed our 01 MPV the first 6k miles with no problems.My wife loves it. Consider what you like best,and also if you want to deal with those greedy Honda dealers and wait 5 months. Good luck.
$ wise, I think both will cost about the same for the period (~6 yr) I will own the van. Sure, the Ody folks will tell you how great Ody's resale value is, but many of them forgot Ody's price tag is much higher, 70$ worth of Java beans more each month to be exact.:)
Power wise, yes, there are 5% of time I want more. But I bet no matter what van you choose, those 5% of time will alway be there, because they are just "vans", not sport cars.
The deciding point for me is its size. We only got one girl and not planning for more. Ody is clearly too big for us. Also, it is easier to park anywhere, especially in my garage. The extra space it left make it easier to get in and out of the van.
Go try out both vans for yourself and make sure it's most suitable for you not some critics from some auto magazines:)
Templeton:
When we shopped for our van, it was sorta easy to do back-to-back comparos, since the same dealership sells both the MPV and the Ody. However, in the case of the Ody, they had only one on hand, and it was "pre-sold" so we weren't even allowed to unlock it, just peer thru the windows, and could put a deposit down on one. The major factors that sent us across the street to test drive the MPV (many times) was cost, we thought the Ody was bland inside and it actually is too big to fit in our garage). Also, reliability was an issue with us as well as my low opinion of Honda's paint quality in past years.
We really liked the layout of the MPV and it was just the right size and we thought the styling was much more interesting than the Ody, as well as reading how the MPV handled much better than other minivans. It does handle very well. I didn't care that it can't do 14sec 1/4s or 0-60 in under 11secs. However, these were opinions, so you'll have to decide for yourself there.
Good luck!
/Java
My MPV is 16 months old, has about 12k miles, far too early to draw definitive conclusions. While I'm sure Honda and Toyota are fine vehicles, they cost alot more up front. For this reason, I'm not sure it's a valid comparison. These vehicles are priced with sufficient differences that they may not really serve the same market segments.
With all the awful reviews I read of the GM vans in 2000 when I was shopping, I cannot believe they are now listed in the top 6. Even more unbelievable is who on earth would pay 34k for a Pontiac?! That's worth repeating, what kind of moron would pay 34k for a Pontiac??!!
The reviews for the Chrysler vans in 2000 were only slightly less horrible than those for the GMs. Consumer Reports went so far as to say don't buy one. That was good enough for me.
Ford was also significantly more expensive than Mazda in my search. So I compromised, I bought a van with a Ford engine and transmission for less money than a Ford.
This entire review process puts too much emphasis on engine power and not enough emphasis on utility. My 2.5L MPV drives nicely at 65-70 mph and I have had zero problems merging from on-ramps. After 10k miles the transmission smoothed considerably and seems to find the appropriate gear at the appropriate time, as it should. The seating configurations, interior storage, roll-down windows, numerous cup-holders etc. are more important to me than power.
Having driven a 92 Caravan 3.0L 6 cyl. for over 9 years, (118,000) miles, with few problems, I can attest the MPV doesn't have as much power and gets no better gas mileage (the only truly valid criticism) but it is bigger than the Caravan and certainly not too small as the reviewers claim. This is supposed to be about "mini" vans isn't it?
The only other issue I have with the MPV besides gas mileage (22 hwy, 16 city), is oil use. My old Caravan needs only about 1/2 pint at 1000 miles before the oil change at 2000 miles. The MPV consumes about 3/4 quart during the 2000 mile interval. That's not a good sign. I'm also going to stick with my plan to service the transmission every 18k, twice as often as the manual recommends.
Overall, I'm satisfied with the MPV LX. I got what I paid for, about 23k with sales tax (invoice price with no destination charge). I plan on driving it for another 15 years barring accident. I hope it's the last minivan I ever feel compelled to own. I think it will be.
Would it be more fun for me with a larger engine? Of course it would. I'm an American: you could put a Saturn V rocket engine in it, and I'd wonder if it would do better with two. But is it "underpowered?" Not in my eyes.
Call it power "Lite."
RJ
RJ
I'm sure you won't regret your decision! Our LX has 9K and not a single issue!
Pete
RJ
Now would be a great time to purchase an MPV, 0% financing with Mazda American Credit. 9k miles on our 01 LX and not a single issue. BTW, I believe our transmission is smoother with age.
Pjd58
Gonna find a problem one of these days....!
As for your other problem--that you can't find a real one to complain about--I 'm afraid you're on your own. Hey, how about this? On a bright sunny day it's very hard to read what gear you're in.
I'm trying. Really I am.
RJ
You're right about the sun/glare thing - I always note the RPM gauge to indicate what gear I'm in - especially after I have taken it out of overdrive after stop & go on the freeway (freeway??) and noted I'm turning 4500 RPM when I'm up to speed again - oops.
-Engine noise a bit high,expecially on acceleration,not too bad on crusing. Even though I cruised easily at 70 mph and at times found I was going 80,did notice that the rpm's were fairly high,about 3000 at 70mph. This compares to 2500rpm for my 99 4 cyl. Camry. Certainly nothing new here,the engine has to work hard to pull all that weight. BTW, don't you love it when a car mfg. corrects a 'problem' with engine power by putting a larger engine in the next years model. What about all those people who have the 2000 and 2001's,is Mazda going to give us the new engines too? They should have known this 2 years ago.
Now about the rear heat,which I don't have. How is it that the A/C and Heater use different mechanisms to distribute the air? I have never seen this on any other vehicle. It may not pose much of a problem,but how and why did they do this. Also, would like to have some darker tint on the front side windows,and more knee room on front passenger side(must be the world's largest dashboard).
RJ
Heat and A/C are two totally different systems in all systems with the exception of the heat pump. They generally just share the vents and fan. Now I do not know why Mazda decided to separate the two. I think they should have both been standard on the ES with an automatic control system. Was your remark just because you did not have it? Or did you notice a problem keeping the rear of the van warm. I don't have the rear heat either, and the kids are thankful I would have sweated them out just from the front.
MSGJVH
"My point was that I have never seen any vehicle use different vents or systems to deliver the Heat then the one used for A/C. This amazes me. The only reason has to be the chance to make more money.Shame on you Mazda."
Up front, they use common ducting. To have rear heat, you need to run water lines from the engine to the back. They are saving the customer money by making it an option.
Where I live, I have no need for rear heat and I don't want it. I'll never use it and it's just something else to fail down the road.
So in light of your post, I say thank you Mazda for not making me pay for something I don't want.
And I have nothing to whine about today.
I would think that there are a/c lines going back there to some a/c hardware, as well as water lines going back to a heater core or something, then the rear fan blows whichever climate I select, be it frigid or toasty.
To the needing/not needing of the rear heat, rutger3, we've just started using the rear heat last week in Mochavan, when the temps dipped into the teens (F, not C). It is useful when it gets really cold out and has kept up with the coldest of days that I've seen, in the negative 30s.
/Java
white reel well
right wheel yell
might sweel as well
quite real squirrel
...I give up...
/J
The beige interior of our MPV is highly conducive to java-consumtion.
/Java
Looks like I'll have to trade in my 2000 for a 2002 w/ 3.0 and rear heat... bummer. ;-)
/java
Steve
Pjd58
I want to thank the little people that I stepped on to get where I am today! ALso, my employer will be happy to know I did something constructive for a change instead of surf edmunds all day long.
/Java
