As far as I have been able to tell, there is no way to bypass the autoheadlights. The easiest way I have come up with would be to add a small light that shines on the light sensor. This would "trick" the car into thinking that it's bright enough and not turn the headlights on.
You would have to turn off this light to activate your headlights at night vice using the pull out headlight switch. If your car thinks it is bright enough that the headlights are on, it won't turn on all your dash lights even if you pull the headlight switch.
Someone asked this question before and was asked why would you want to defeat the autoheadlight feature. When I start my car in the carport, sometimes the car thinks it's too dark and turns on the headlights. This is not really an issue, but I don't have the dash lights at 100% intensity for night driving. So when I pull out onto the road, the headlights are on (not an issue for me) but the radio display is dark/dim. I end up toying with the dimmer to brighten the display, which messes me up when I drive at night.
But its a small irritation compared with the joy of driving this car.
I saw a auburn nightmist Impala LS a couple of weeks ago. I was shocked!
Watusi--Get a life will ya!!!!!
If I could order my '01 LS I would not hesitate in getting the Bronzemist/neutral cloth interior and spoiler with 1SB package....that's a collector's item for sure!
Right now, I have only been able to locate 3 '01 Impala LS configured exactly the same way as my '00 LS with cloth, spoiler, 1SB package and now the Onstar system installed.
The 3 colors are:
Dark Carmine Red Metallic/Gray Cloth Interior (Like the exterior but I dread 'prison cell' gray interiors)
Sandrift Metallic/Neutral Cloth (I will get this car mainly because of the interior..I am not too crazy about the Sandrift theme for what I think the '00 model year Light Driftwood Metallic was a much better color).
Navy Blue/Gray Cloth (Love the Navy Blue but again I dread getting myself into the gray interior theme).
Does anyone know if the Gray interior was slightly modified from '00 to '01????
So far that's it, I am waiting on my dealer to give an update on the availability and build dates of these cars...
Probably some R&D guys at GM conducted stress/heat/cold tests on the paint and realized certain colors just don't meet up to the GM standards.
The impala is my first GM product ever. From past experience does anyone know how duraable the GM paint is?
The reason why GM mistankenly discontinued the Light Driftwood color was because it wouldn't match with the new pale Neutral interior color...it would look just too weird. My interior was labeled as "Light Oak Sport Cloth interior" and it was a beige but some taught this color was a sort of loud Moustard scheme. Since GM couldn't match the new Neutral interior sucessfully with the Light Driftwood paint, they decided to drop the Light Driftwood in favor of the 'OLD' looking and much pale Sandrift metallic paint. My guess is that the Sandrift will be phased out in 2001 or 2002 in favor of the Light Driftwood or a variant of this color again.
How's the quality of the dark colored cars with metallic paint finishes?
L8_Apex
Sedans Message Board
New shaft
3000 mile oil changes
Taking car in for strut rattle for second time,
first time they added grease to the strut base.
Everything else seems okay
http://calid.gm.com/vci/
After you click on the 'submit' button, you will see a complete list of PCM updates available for your Impala's engine according to the VIN number break points.
These updates are the 'software' that controls your engine's computer and are probably needed to remedy the stalling problems you are currently having. Print out the list and give it to your service manager. Make sure he performs the updates that pertain to your engine's problems according to the symptom description in the list right next to each update.
I bet $100 that your dealer hasn't do any of these updates yet.
Do this ASAP and let us know.
The recorder is still attached to my car in an effort to determine the hesitation/stumbling problem.
The recorder was set to record engine misfiring from Friday through Tuesday. The car was then returned to the dealer and they read the content of the recorder. The recorder was then placed back in the car, this time it is set to record the sensors.
I am really disappointed. The car has not hesitated once in over one week. Of course it showed nothing on engine misfire. This is the third day for the sensor check. The car has been running really well, with no problem.
Normally the car will hesitate within a day or two.
In case that anyone wants to have the recorder attached to his or her car, it is really simple to do. The recorder plugs into a receptacle just under the dash to the right of the steering wheel. The recorder is small and can sit inside the open area in front of the ashtray. A cord with a push button switch is attached to the recorder. When you start the car you must push the button to turn it on. If you have a hesitation, you must again, push the button as it is happening. The recorder also records on its own every few seconds, which causes the parking brake, ABS, and battery light to activate for a short time.
If the recorder is preventing the car from hesitating, maybe GM should install one permanently.
I dont mean to make light of your situation, but I had to laugh, because I DID highjack a technician. Once we were in my car, I grabbed his arm and said "how much time do you have, because you're not getting out of this car until you feel what I've felt for 14,000 miles.". Its frustrating.
I'm afraid of my car too. I've been afraid. The steering is worse than ever. The parts were ordered last Thursday. Still no parts.
Now that the snow has finally melted, I noticed a spot on the right hand side mirror that has a paint flaw on it. It started to bubble and then the pain peeled off. The exposed part is now black. But when it first peeled off it was a grayish color. I just hope the rust doesn't start from there.
Do you think that touching up that spot would be sufficient? Or should I demand the dealer to repaint that whole surface?? I am just afraid that there might be slight color mismatches between the rest of the and the mirror.
The size of this bubbling is about the size of a quarter..but it hasn't increased any.
Your thoughts would be much appreciated!
You can live with the chip and enjoy your car, or you can get the dealer to take care of it and live without your baby for a few days. Truth be told, I'm not sure which way I would go.
Get the dealer to paint the scratch themselves. They should be able to match it exactly. I ordered touch up paint for my medium regal blue and the "ordered" color seems too dark. I did get a couple of bottles from a collision repair shop and they were the right color. Seemed weird to me that the "ordered" color was too dark. Anyway, I also scraped my passenger side mirror (against an SUV's side mirror) and knocked a dime size piece of paint off. I used the touch up from the collision repair shop and it seems fine.
Ken
Get on the dealer's case.
Several days ago I did what you suggested regarding checking the PCM updates on the GM site. The read out showed a new calibration to address false settings for stalling in park, neutral, and drive.
My eyes lit up thinking maybe this would correct the problem of hesitation. I took the printed page to the dealer and was told that the first thing they did (several weeks ago) was to check for computer program updates and that my car had the latest one. Since the GM site does not show the date of the new calibration I have no way of telling when the update was released. I am unable to question this, and must take their word.
Last summer I took my 00 impala to be checked for the ticking sound when turning the wheels at low speed. The dealer said the cradle would need to be welded. I did not want the dealer to learn how to do this on my car so I did nothing. Today, at 13k miles, I told the dealer that I still get the sound. After checking with GM he said that a new cradle would be ordered and installed under the warranty and that this can be done without lifting the engine.
I am in southeast Ohio. Our LS was built either 5/99 or 6/99 and we don't have the problems you are talking about. The only thing that has bothered us is the brakes. Front rotors turned then replaced and the rear ones turned also. Then we had a clunking in the tranny that we can't reproduce when test driving with a mechanic.
Later
LRCobra
"Silver Bullet"
* Engine cradle noises
* Intermediate steering shaft problems
* Sporadic A/C problems
* Sporadic brake related problems
* Engine shutdowns and sttuters (This is very frequent among early Impala build date samples such as yours).
If I were you I would start persuing GM to either buyback or replace your Impala with a new 2001, which is exactly what I am doing now. My trade-buyback repurchase was approved 2 weeks ago and in another couple of weeks I should be behind the wheel of a new 2001 Impala LS.
Your problems deserve special attention. Engine problems are serious safety problems. If your dealer hasn't been able to troubleshoot the problems (This also goes to you Scotsman) you should persue GM to take the car back. You paid TOP DOLLAR for the product and the product failed to deliver in the quality and reliability dept. Don't put up with that non-sense anymore. Enforce your consumer rights and get GM to stand behind their faulty product and to take it back or replace it.
My current '00 Impala LS was built during 1/2000. The car has NEVER ever had any sort of engine trouble...the engine has always worked like a Swiss watch..no hesitations, stutters, shutdowns, zero, zilch, nada. No brake problems, no electrical problems or no transmission related problems. However, I had serious problems with the intermediate steering shaft, a blown A/C compressor at 7K miles and some minor quality problems in the interior. However, I made a big stink about these problems to my service manager and clarly stated my dissatisfaction with the car..two MAJOR repairs in less than 11 months of ownership..unacceptable in my book. In the end the GM factory representative accepted without hesitation to replace my '00 with a new '01 Impala LS Trade buy back from sticker MSRP to sticker MSRP minus mileage use offset on the '00 at $.20 per mile. Short, sweet and simple. My service manager was on my side and it took only 10 minutes to convince the GM factory rep to buy back and replace my car...I say this is a great effort at keeping me a satisfied and happy GM customer. NEVER PUT UP WITH A PROBLEMATIC CAR! get your money's worth and stick to your guns!!! Demand a buyback or replacement buy DON"T DELAY!.
* How to reset the Oil Change monitor on the RDS radio.
* How to reset the Tire Pressure Monitor on the RDS radio.
* How to program or re-program the remote key fobs on the RDS radio.
* How to access and set all personalized features (Theatre lighting dimming, alarm horn, etc) on the RDS radio.
* How to program and use the Integrated overhead Home Link remote transmitter unit.
* A brief overview of all function included in the overhead DIC trip computer and an explanation in how to re-calibrate it should the compass and exterior temp readings are incorrect.
* Care tips for the interior, including the upholstery.
* How to adjust the striker plate for the glove box latch should it start to rattle.
* How to access the engine's compartment power steering reservoir on the 3800 V6.
* How to change the headlight bulbs and the tail light bulb assemblies.
* How to change the trunk lid's third brake light bulbs.
* a brief explanation or animation as to how the interior self dimming rearview mirror works...
There you have it...some good ideas to add to your website overtime...most Impala owners will find this info incredibly valuable!.
The Montecarlo guys over at Yahoo Clubs (Y2K Monte Carlo club) had their first chat meeting about 2 weeks ago and it was a sucess! They have scheduled the second chat meeting for tomorrow night...I'll be there.
Does this sound like a good idea to you??
http://clubs.yahoo.com/clubs/y2kmontecarloclub
is$852. Is this worth it?
I paid about $2100 Canadian for this plan.
I personally feel that extended warranties are always worth it. Especially when I have all the toys (sunroof, heated seats, cd player etc etc) in my '00 LS.
Fixing all these gadgets down the line can be quite expensive without the warranty.
On another note, I took my car in to let the service guys look at the paint chips/bubbling. I am quite surprised how these guys can pick up stone chips I didn't even notice before. He told me that he could do the touch up for me no problem at all.
I'm just kinda shocked at how many little tiny chips I have on the car. I wonder if it is due to subpar anti chip coat in the pain process?
Does anyone else have problems with paintchips on their cars??
Boy! every timw I remove the car bra to wash the car and I see that front end clean perfect and free from paint chips, I give myself a pat in the back!! Those $84 that I paid for that car bra a year ago were the BEST investment I made to protect the car's paint finish...good thing it will also fit the new '01 LS! ;-)
If I ever win the lottery, I am going to get a collection of brand new '01 Impalas. Drain the oil..mothball them. And they will be worth lots of money down the line!
http://www.warrantydirect.com/index.html
http://www.allpar.com/reviews/2000/impala.html
I gotta say, for being Dodge fans, they sure aren't biased towards the Intrepid...
I'll look into the chat idea. Never thought about it so I'm not sure how feasable it is. Being the lazy sort, I would say go on over to the MC site on Yahoo because Kissfan is correct in saying that the MC and Impala are pretty close in nature. The gas strut that holds the trunk open says it is for the MC or Impala. The downside of sharing a chat like that is people who are only concerned with MC issues or Impala issues have to wade through all the other's stuff. Let me look into that one.
