If you take a look at the complaints database, the 2001 Impala only has one entry related to the engine cradle. This entry talks about vibrations felt specially when making turns and the dealer has replaced the cradle several times with no results.
When you dig deep down in these databases once can find a wide array of responses and problems. Often, inept and plain bad dealerships are unable to properly troubleshoot problems, replace numerous unrelated parts galore and typically make the problem worse or help generate other issues.
Interesting to point out that NHTSA currently has an open investigation into possible engine fires involving new Toyota Sienna minivans....not even the mighty Asians can escape serious safety issues.
There is also only one investigation involving the 2000 Impala in regards to sudden engine shutdowns. The investigation was closed back in February of 2000.
The cradle is more an annoyance than a safety problem. But regardless, who wants to put up with a creaky and noisy "New" car??
The frequency of engine cradle related complaints has minimized considerably for the 2001 model year based on the NHTSA data. This soesn't mean the problem has been erradicated, but rather that cradle related issues are less frequent and far in between.
On another note. I was bored today so I checked out the local library and found "Roger and ME". Just got done watching it. I found it to be pretty interesting. I was in high school in northern Indiana at the time, but I sure don't remember that plant closing and all the hoopla that circled around it. I was probably to busy chasing skirts.
I mean, if the lubrication dries or leaks out over time, which appears to be the reason for the ISS clunk, then continued use of the defective part could lead to steering failure.
Now, obviously, most dealers are installing replacements. However, they eventually fail too. Considering that GM has come up with a temporary fix involving drilling and re-lubricating the existing shafts, you'd think they would at least release an official TSB. I have a feeling they don't want to admit to any problem with the ISS, officially, as they would be admitting liability for possible future lawsuits and recalls involving the ISS or any steering problem, probably.
A while ago, I had a slight vibration at high speed shortly after having rotated the tires but NOT having rotated in the prescribed fashion. The Chevy mechanic found that the front wheels were slightly out of balance and one of the nuts on the top of one of the front WHEEL struts was not tightened to the proper torque. Said he had seen the same thing on several other cars.
This may be of interest to others if they feel high speed vibration or hear clunks at low speed when going over "speed bumps" on parking lots. They were my symptoms of the wheel strut problem which was simply and quickly resolved by a very competent mechanic.
well- call this 1-800 # if you have anything else blah blah blah. It's encouraging that I at the least got a letter in response to the survey. To be fair they say they tried to call but I don't answer the phone on "Caller Unknown" in the caller ID
http://service.gm.com/gmtechlink/Nov2001/articles/steeringshaft.html
When I talked to the service manager, he said it was cracked cradle bushings. So in a few days I should find out if this is it. I'm even more encouraged to find Teo's sister's car had the same diagnosis, and appears to be fixed.
Anyway, I was given a slip of paper with the part numbers. There are two each of 10402881 and 10402883.
And to bdime, I had Chevy call me about my answers to an earlier survey reply. I don't pick up "unknown" calls either, but they started talking to the answering machine. They seem very interested in making sure these things are taken care of, and that's great.
http://www.cbc.ca/cgi-bin/templates/view.cgi?/news/2001/12/12/Consumers/paintjob_011212
I don't think that any Impala owners have reported paint delamination, but this ruling sets a precedent for other vehicle owners with crummy paint.
Another thing that can damage these mirrors is when during cleaning, excessive pressure is applied on the mirror itself, thus damaging the photocell inside of it.
Have the dealer check it and replace it if necessary...not a big deal.
Also missing from that list are the N-body cars, the Pontiac Grand AM, Oldsmobile Alero and Chevy Malibu, all of which use either the same 3.1L V6 or 3.4L OHV V6 in the Alero/Grand AM (And Impala Base sedan).
According to the bulleting virtually every other GM midsize and full size sedan (Also the J-body cars)may experience ISS related clunks. It seems that some ex-Impala owners that escaped to cars such as the Buick Regal and Pontiac Bonneville after all, likely will have to deal with the same ISS issues they had with their Impalas!
After reading this tecnical bulleting heads up, I have the following questions:
1) Will every single car on that list ever experience the problem?
2)Is the ISS' lack of sufficient lubrication caused by a inherit design defect or simply the part supplier did not put the required amount of lubricant/grease on each new ISS??
3)Does the ISS lubricant "Dries out" with use, does it get burn or it simply leaks thru an opening in the yoke assembly?
4) Will this be a permanent fix or simply a "band-aid" until GM can come up with a new redesigned ISS part?
I remember reading in the Olds Intrigue forum that GM had issued a "revised" ISS part some time ago, but going by this TSB heads up it looks like the Intrigue's ISS revision did not solve anything.
Night_owl, what's your technical perspective in regards to this ISS "Fix"?
Ken
p.s. I covered the info that is in the other links you posted on my site also.
Plastic bottom body in lock cylinder of ignition switch having plastic flashing falling down and preventing key from going all the way into the housing. Instal key, Impact key and lube cylinder 10 times. Verify repair. ok.
The service manager said it is a common problem on one of the Cadillac models (de ville I think). This seems to fix it for now (I hope). they took car of it all under warrenty from first fix.
Basically severe hesitation that only happens intermitenly
http://home.hawaii.rr.com/impala/
The ISS is a telescopic shaft and there is a hole in the end already. The syringe is only used to get the grease in there. You could use a grease gun or get a tube of grease that comes in a toothpaste-like tube. So you inject the grease into the opening of the yoke on the right side of the ISS (I am referring to the drawing on my page). Then you use the rubber stopper that comes with the kit (or something similar) and collapse and extend the shaft a couple of times. This will distribute the grease.
I looked at my manual. There is no way you can access the ISS without removing it from the car. So installing a zerk fitting really won't help. If you guys wanted to see what it looks like on the car, I can post some photos of it later.
I've put 23K on my car since buying it in Jan when it had 18K on it already. Sure was quick getting to 40k - and now 60k is only a year away.
Ken
Paint it Marina Blue, Black interior, Digital Dash, Silver Ground Effects, Camaro 17' Wheels, Replace the power train with the Cadillac Northstar system, 3' duals out of 50 Flowmasters. Killer Audio and Video systems.
One can dream.
However, it takes unusually high skills and substantial experience to do it properly. With American labor costs it would not pay. The cost of parts probably also would be prohibitive.
I can just imagine that car in a dealer service dept. "We plugged in the computer and couldn't find any codes. It's running per specification" Even better, "All the Impala rear ends look like that."
I think the seller is not being totally upfront.
WOOO HOOO Post # 7000!!!!
