Visitor Agreement.
Really, checking the items on the checklist is easy if you have a large floor jack (lifts one side of the van at once). Here's what I do...
Rotating tires and checking pressure, not a problem... pull the tires, check their pressure w/a guage while rotating.
Checking brakes. Pull the front wheels off (while rotating the tires), and make sure there's as much pad left as backing plate. When the backing plate is as thick or thicker than the pads, time for new brake pads. Inspect the outer and inner cv joint boots while you're at it. They shouldn't have grease on them (or oozing out of them) an should NOT be cracked.
Oil change, diy or pay them for the service. Checking the airfilter is relatively simple. Replace if filthy.
I guess the only tricky part imo is checking belts and hoses. Belts should be clean and not loose, hoses should be clean and not cracking. or showing wear at all.
/javadoc
Maybe it was programmed that way -
Please give me advice!!!
Pjd58
MB
Pjd58
RJ
hskang: We bought our '01 MPV as used last year with 13K miles. Paid $18K. Now, at that time the MSRP on an LX was higher, so we were looking at close to a $6K spread. I thought it was a good deal. I agree with Pete, push harder to get well over $5K off the MSRP, then you're talking a pretty good deal. One thing to consider though - most states' lemon laws only apply to new vehicles, not used. I'm not saying this is something you should worry about with the MPV, but if you want that extra peace of mind, go with new.
tgaines14: Congrats on your new ride! Hope you have many good miles and stick around for a while.
SC
Pjd58(Pete)
I was very excited to read this as my wife and I decide when we want to purchase a mini-van. It looks like it's going to be an MPV for sure. Now, if Mazda would just offer it in that Millenium Red...
Steve
Not only do we have one of the best mini-vans for ride and drive...now we have proof its one of the safest!!
Rich
/java
RBB
Is a self-dimming mirror a safety option? I always put that in the luxury option bin. I guess I can see the safety aspect too. Possibly it wasn't available at time of printing for the report?
I don't think the tire size would materially effect the rollover score, since the 16 and 17" tires are the same overall diameter (almost), and they have the same cross-section width. The entire rollover rating system is complex, and I really don't agree w/alot of the factors involved, as the reason vehicles roll over is chiefly dependent on them striking an object sideways, such as a curb, and more likely, leaving the roadway and overturning due to a higher center of gravity... but I'm not an engineer. Given the MPV's superior handling characteristics, I'd give it an edge on rollover avoidance b/c it would probably avoid a rollover situation due to its nimbleness, and respectable skidpad numbers.
/j
We're about to replace the OEM Dunlops (16") on our 2000 MPV at 36,000 miles. After research, I was leaning towards Michelin X-ones. However, the OEM dunlop's are H speed rated, whereas the X-ones are S rated, and the guys at the local tire shop said that we should stick with H rated tires if that's what's on the van now. Is this really necessary, or can I go to the lower speed rating?
Beachnut, don't you have X-ones?
Imn908: I find that many tire dealers will tell you that you shouldn't do this or do that. In FL, Tire Kingdom is the biggie. In fact, I was just there a little while ago asking about the Dunlop SP's for my Accord. The manager there said they weren't the same speed rating as my Mich MXV4+'s, which is bull - they're both H. When I called him on that, he said they wouldn't work 'cause they would mess up the ride (?). Then I asked him if I could take the X-Ones off my MPV and put them on the Accord - more excuses. Anyway, the bottom line is that the guy just wants to sell me new MXV's for $125 a pop and will try to come up with any justification to do so. Fortunately, I've been following the Tires, Tires, Tires board here on Edmund's (under Aftermarket & Accessories) for a while, so I know better (I think!). Why don't you post your question over there ... there's some knowledgeable folk that I'm sure could help. Good luck!
Thanks in advance.
The rollover rating is pretty much was expected. If you look at the NHTSA ratings all the 2001 and 2002 minivans get 3 or 4 stars for rollover.
see: www.nhtsa.gov/cars/testing/ncap/Cars/2002Vans.html
Only a couple full size Ford vans get 2's.
The rollover rating doesn't tell you much anyway. it's not a test like the crash test. It's just a estimate based on center of gravity and track. The fact that Mazda gets a 3 versus some other vans getting 4's is just a result of the MPV's narrower track.
While these measurements correlate with rollover resistance, any individual vehicle may be more or less resistant than the correlation would predict.
I purchased [Michelin] tires from Costco for my other vehicle and have been quite pleased with their service. In fact, I've had a better experience with Costco than I had with the tire dealership I used previously.
Thanks in advance for prompt advice; the rebate is only good until June 30.
I just had a few questions for you vets...
What kind of deal did you get...I am pushing for invoice price since they are only giving me $1500 on my trade-in ($500 short of the suggested trade-in price). It appears that invoice plus about $300 is ok as well. I got them down to 3.9% interest rate too. Should the deals be better at this time with 2003s coming out? Also, has anyone put a DVD in the MPV? I know it isn't a factory option but some seem to offer it as a DIO? Thanks for any help I think I am pretty much decided on the MPV...test drive went well today.
Are you willing to share the details of your deal here? Since we talked about it earlier, I'm particularly interested in knowing where you ended up purchasing the van. Did you get a chance to visit your old stomping grounds?
-Dave
I'd also recommend a skim through the Tires, tires, tires discussion and visit the Tire Rack linked in the ads on the left for other suggestions.
Steve
Steve
Whoops... did I say that outloud? ;-)
Also, Contrats to the new owners!!!! I envy you w/your shiny new steel! Many happy miles to y'all!
Steve, missed you in the Chat yesterday. Were you waterskiing or something?
And while I'd never [intentionally] reach triple digit speeds, I have occasionally been on highways with a speed limit of 75, and gone with the flow of drivers who were acclimated to the sense of speed. I don't know if the B temp rating should be of concern.
Thanks for sharing your experience with these tires.
basurf--According to the Mazda website
http://www.mazdausa.com/special_financing/default.asp?vehicle=&zip=&did=&state=
Mazda is offering 0.0% financing through 7/8/02. Unless there is something else involved, it sounds like you should not have to settle for 3.9%.
Also, I would recommend contacting several dealers and play them off against each other (i.e., "Hello Dealer A. Dealer B is offering me this deal. If you can beat it by $X, I would be happy to give you my business. Can we work something out?") When we bought ours last fall, I was on the phone with several dealers to see what I could bring them down to and I think it worked well. On the same topic, there was an interesting article in the Wall Street Journal several weeks ago about people dealing with car dealers hundreds of miles from home. Though there may be a little 'grass is always greener' to this, some folks were able to find such great deals that they could not get locally that it more than paid to fly to a distant dealer, buy the car, and drive it home. The internet helps make searching out these deals possible. Though I realize this tactic is not for everyone. Hope this helps, and best of luck. danandkat
Sue
P.S. The 0% rate is only for up to 24 months. I could've done that, but was more comfortable with 36m and the option of early payoff, especially since I was financing only about half. If you plan to take longer terms or higher loan amounts the rate becomes more of an issue.
Java - company came in yesterday for River Fest so I missed the chat. But thanks for noticing I wasn't around ;-)
Steve
The 0% interest has increased to 48 months, with no payment for 6 months.
The low interest option (I think 3.9% but not positive) is available up to 72 months, along with $1,000 rebate (don't know if its factory to dealer or not, but under the s-plan I cxould get it)
With no financing, the rebate has increased to $2,000.
Does anybody know if these incentives are regional or nationwide? If nationwide, I might consider a road trip to the NE to pick one up.
You're probably getting tired of hearing this, but the one thing I really hope Mazda adds to this fantastic van, are a few more exciting colors to the MPV lineup, like Millenium Red! Anyone know anything more?
